ZCAT3618-2630DT
ZCAT3618-2630DT
    TDK(东电化)
    特性:使用TDK独特的结构,铁氧体磁芯安装并集成在塑料外壳中,无需切断电缆,即可一键安装到接口电缆和电源电缆上。 利用铁氧体磁芯的高频吸收特性,对高频噪声具有出色的吸收能力。 对共模噪声有效,可在不影...
ZCAT3618-2630DT 数据手册
E M C C o m p o n e n t s Clamp filters For cable RoHS REACH SVHC-Free Cl Br Pb Halogen Free Lead Free ZCAT series FEATURES Using TDK's unique structure where the ferrite core is mounted and integrated in a plastic case, it is possible to attach them to interface cables and power cables with one touch without having to cut the cables. Have excellent absorption of high-frequency noise using the high-frequency absorption characteristics of the ferrite core. Effective for common mode noise, so can be implemented as a noise countermeasure without influencing signal quality. Series are according to the outer diameter of the cable in order to be compatible with various cable sizes. APPLICATION PCs, monitors, HDDs, digital telephones, audio equipment, electronic musical instruments, video games, copiers, and facsimiles PART NUMBER CONSTRUCTION ZCAT 2436-13 30 A -BK Series name Shape dimensions (mm) Product internal code Fixing type code Outer color code A B D DT Non code Fixed cable type (cable is affixed to the main body) Chassis fixed type Flat cable type Flat cable type (double-sided tape fixed type) Band fixed type (cable is affixed to the body by a cable tie) -BK Black Non code Gray PRODUCT LINEUP ZCAT1518-0730(-BK) ZCAT2017-0930(-BK) ZCAT2032-0930(-BK) ZCAT2132-1130(-BK) ZCAT3035-1330(-BK) ZCAT1325-0530A(-BK) ZCAT1730-0730A(-BK) ZCAT2035-0930A(-BK) ZCAT2235-1030A(-BK) ZCAT2436-1330A(-BK) Impedance( )min. [10 to 100MHz] 25 20 50 40 80 50 40 50 50 30 [100 to 500MHz] 50 50 100 80 150 100 80 100 100 80 [50 to 500MHz] — — — — — — — — — — ZCAT2017-0930B(-BK) 20 50 — ZCAT3618-2630D(-BK) — — 30 ZCAT4625-3430D(-BK) — — 35 ZCAT6819-5230D(-BK) — — 35 ZCAT3618-2630DT(-BK) — — 30 ZCAT4625-3430DT(-BK) — — 35 ZCAT6819-5230DT(-BK) — — 35 ZCAT10D(-BK) 25 70 — ZCAT13D(-BK) 40 100 — ZCAT20D(-BK) 60 150 — Type Part No. ZCAT ZCAT-A ZCAT-B ZCAT-D ZCAT-DT ZCAT**D Background yellow: The products which are planning to stop production. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (1/9) 20220609 clamp-filter_commercial_zcat_en.fm E M C C o m p o n e n t s ZCAT type CHARACTERISTICS SPECIFICATION TABLE Impedance( )min. Part No. [10 to 100MHz] [100 to 500MHz] [50 to 500MHz] 25 50 — ZCAT1518-0730(-BK) ZCAT2017-0930(-BK) 20 50 — ZCAT2032-0930(-BK) 50 100 — 40 80 — ZCAT2132-1130(-BK) ZCAT3035-1330(-BK) 80 150 —  A cable tie is included when shipped. • Test conditions: When passing through an impedance meter (unloaded) ø1mm copper cable Operating temperature range (°C) –40 to 85 Individual weight (g) 6 11 21 22 62 IMPEDANCE VS. FREQUENCY CHARACTERISTICS 1000 ZCAT3035-1330 ZCAT2132-1130 100 Impedance (Ω) ZCAT2032-0930 ZCAT2017-0930 ZCAT1518-0730 10 1 1 10 100 1000 Frequency(MHz) SHAPE & DIMENSIONS A D B C Part No. ZCAT1518-0730(-BK) ZCAT2017-0930(-BK) ZCAT2032-0930(-BK) ZCAT2132-1130(-BK) ZCAT3035-1330(-BK) INTERNAL CONSTRUCTION Dimensions (mm) A B 22±1 18±1 21±1 17±1 36±1 32±1 36±1 32±1 39±1 34±1 C 7±1 9±1 9±1 11±1 13±1 D 15±1 20±1 19.5±1 20.5±1 30±1 Applicable cable outer diameter 7max. 9max. 9max. 11max. 13max. STRUCTURE OF THE CABLE TIE Ferrite core 2.5mm typ. 104mm typ. Plastic case Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (2/9) 20220609 clamp-filter_commercial_zcat_en.fm E M C C o m p o n e n t s ZCAT-A type CHARACTERISTICS SPECIFICATION TABLE Impedance( )min. Part No. [10 to 100MHz] [100 to 500MHz] [50 to 500MHz] ZCAT1325-0530A(-BK) 50 100 — ZCAT1730-0730A(-BK) 40 80 — ZCAT2035-0930A(-BK) 50 100 — ZCAT2235-1030A(-BK) 50 100 — ZCAT2436-1330A(-BK) 30 80 — • Test conditions: When passing through an impedance meter (unloaded) ø1mm copper cable Operating temperature range (°C) –40 to 85 Individual weight (g) 6 12 21 26 29 IMPEDANCE VS. FREQUENCY CHARACTERISTICS 1000 ZCAT2235-1030A 100 Impedance (Ω) ZCAT2035-0930A ZCAT2436-1330A ZCAT1325-0530A ZCAT1730-0730A 10 1 1 10 100 1000 Frequency(MHz) SHAPE & DIMENSIONS A E B C Part No. D ZCAT1325-0530A(-BK) ZCAT1730-0730A(-BK) ZCAT2035-0930A(-BK) ZCAT2235-1030A(-BK) ZCAT2436-1330A(-BK) Dimensions (mm) A B C 25±1 20±1 5±1 30±1 23±1 7±1 35±1 28±1 9±1 35±1 28±1 10±1 36±1 29±1 13±1 D 12.8±1 16.5±1 19.5±1 21.5±1 23.5±1 E 11.2±1 15±1 17.4±1 20±1 22±1 Applicable cable outer diameter 3 to 5(USB) 4 to 7(USB/IEEE1394) 6 to 9 8 to 10 10 to 13 INTERNAL CONSTRUCTION Ferrite core Plastic case Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (3/9) 20220609 clamp-filter_commercial_zcat_en.fm E M C C o m p o n e n t s ZCAT-B type CHARACTERISTICS SPECIFICATION TABLE Impedance( )min. Part No. [10 to 100MHz] [100 to 500MHz] [50 to 500MHz] ZCAT2017-0930B(-BK) 20 50 — • Chassis fixed type attachment hole: ø4.8 to 4.9mm, Plate thickness: 0.5 to 2mm Operating temperature range (°C) –40 to 85 Individual weight (g) 12 IMPEDANCE VS. FREQUENCY CHARACTERISTICS 1000 Impedance (Ω) 100 10 1 1 10 100 1000 Frequency(MHz) SHAPE & DIMENSIONS A E Part No. C D B ZCAT2017-0930B(-BK) Dimensions (mm) A B C 21±1 17±1 9±1 D 20±1 E (29) Applicable cable outer diameter 9max. INTERNAL CONSTRUCTION Ferrite core Plastic case Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (4/9) 20220609 clamp-filter_commercial_zcat_en.fm E M C C o m p o n e n t s ZCAT-D type CHARACTERISTICS SPECIFICATION TABLE Impedance( )min. Part No. [10 to 100MHz] [100 to 500MHz] [50 to 500MHz] ZCAT3618-2630D(-BK) — — 30 ZCAT4625-3430D(-BK) — — 35 ZCAT6819-5230D(-BK) — — 35 • Test conditions: When passing through an impedance meter (unloaded) ø1mm copper cable Operating temperature range (°C) Individual weight (g) 16 34 60 –40 to 85 IMPEDANCE VS. FREQUENCY CHARACTERISTICS 1000 Impedance (Ω) 100 ZCAT4625-3430D ZCAT6819-5230D ZCAT3618-2630D 10 1 1 10 100 1000 Frequency(MHz) SHAPE & DIMENSIONS A B Part No. ZCAT3618-2630D(-BK) ZCAT4625-3430D(-BK) ZCAT6819-5230D(-BK) D C Applicable cable thickness: 1.3mm max. Dimensions (mm) A B 35.5±1 17.5±1 45.5±1 24.5±1 67.5±1 18.5±1 C 26±1 34±1 52±1 D 11.5±1 12±1 16±1 Applicable cable outer diameter For 20 wires flat cable For 26 wires flat cable For 40 wires flat cable INTERNAL CONSTRUCTION Ferrite core Plastic case Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (5/9) 20220609 clamp-filter_commercial_zcat_en.fm The products in this catalog will be stopped production E M C C o m p o n e n t s ZCAT-DT type CHARACTERISTICS SPECIFICATION TABLE Impedance( )min. Part No. [10 to 100MHz] [100 to 500MHz] [50 to 500MHz] — — 30 ZCAT3618-2630DT(-BK) ZCAT4625-3430DT(-BK) — — 35 ZCAT6819-5230DT(-BK) — — 35  Double-sided tape fixed type (tape included when shipped). • Test conditions: When passing through an impedance meter (unloaded) ø1mm copper cable Operating temperature range (°C) Individual weight (g) 16 34 60 –40 to 85 IMPEDANCE VS. FREQUENCY CHARACTERISTICS 1000 Impedance (Ω) 100 ZCAT4625-3430DT ZCAT6819-5230DT ZCAT3618-2630DT 10 1 1 10 100 1000 Frequency(MHz) SHAPE & DIMENSIONS B A Part No. D C ZCAT3618-2630DT(-BK) ZCAT4625-3430DT(-BK) ZCAT6819-5230DT(-BK) Applicable cable thickness: 1.3mm max. Dimensions (mm) A B 35.5±1 17.5±1 45.5±1 24.5±1 67.5±1 18.5±1 C 26±1 34±1 52±1 D 12.5±1 13±1 17±1 Applicable cable outer diameter For 20 wires flat cable For 26 wires flat cable For 40 wires flat cable INTERNAL CONSTRUCTION Ferrite core Plastic case Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (6/9) 20220609 clamp-filter_commercial_zcat_en.fm E M C C o m p o n e n t s ZCAT**D type CHARACTERISTICS SPECIFICATION TABLE Impedance( )min. Part No. [10 to 100MHz] [100 to 500MHz] [50 to 500MHz] ZCAT10D(-BK) 25 70 — ZCAT13D(-BK) 40 100 — ZCAT20D(-BK) 60 150 — • Test conditions: When passing through an impedance meter (unloaded) ø1mm copper cable Operating temperature range (°C) –40 to 85 Individual weight (g) 6 15 45 IMPEDANCE VS. FREQUENCY CHARACTERISTICS 1000 Impedance (Ω) 100 ZCAT20D ZCAT13D 10 ZCAT10D 1 1 10 100 1000 Frequency(MHz) SHAPE & DIMENSIONS C A D ZCAT10D(-BK) ZCAT13D(-BK) ZCAT20D(-BK) E B Part No. Dimensions (mm) A B C 27±1 14.5±1 10±1 34±1 20±1 13±1 35±1 30±1 20±1 D 4±1 5±1 5±1 E 7±1 8.5±1 15±1 Applicable cable outer diameter 4max. 5max. 5max. INTERNAL CONSTRUCTION Ferrite core Plastic case Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (7/9) 20220609 clamp-filter_commercial_zcat_en.fm E M C C o m p o n e n t s ZCAT series OUTER BOX SIZE, PACKAGE QUANTITY ZCAT1518-0730(-BK) ZCAT2017-0930(-BK) ZCAT2032-0930(-BK) ZCAT2132-1130(-BK) ZCAT3035-1330(-BK) ZCAT1325-0530A(-BK) ZCAT1730-0730A(-BK) ZCAT2035-0930A(-BK) ZCAT2235-1030A(-BK) ZCAT2436-1330A(-BK) Number of products (pieces/trays) 112 80 60 60 40 112 84 60 50 50 Number of interior trays (trays/box) 8 8 7 8 5 12 10 8 8 8 Package quantity (pieces/box) 896 640 420 480 200 1,344 840 480 400 400 ZCAT2017-0930B(-BK) 70 5 350 385x331x216 ZCAT3618-2630D(-BK) 80 6 480 395×250×225 ZCAT4625-3430D(-BK) 40 6 240 395×250×225 ZCAT6819-5230D(-BK) 20 8 160 395×250×225 ZCAT3618-2630DT(-BK) 80 6 480 395×250×225 ZCAT4625-3430DT(-BK) 40 6 240 395×250×225 ZCAT6819-5230DT(-BK) 20 8 160 395×250×225 ZCAT10D(-BK) 77 10 770 490×350×220 ZCAT13D(-BK) 50 9 450 490×350×220 ZCAT20D(-BK) 40 7 280 490×350×220 Type Part No. ZCAT ZCAT-A Outer box size 490×350×220 490×350×220 490×350×220 490×350×220 490×350×220 490×350×220 490×350×220 490×350×220 490×350×220 490×350×220 ZCAT-B ZCAT-D ZCAT-DT ZCAT**D Background yellow: The products which are planning to stop production. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (8/9) 20220609 clamp-filter_commercial_zcat_en.fm E M C C o m p o n e n t s REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using this products. REMINDERS The storage period is within 6 months. Be sure to follow the storage conditions (temperature: 5 to 40°C, humidity: 20 to 75% RH or less). Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.). The case may crack when it is handled below freezing point or when it experiences a fall or other mechanical shock, as it is made of plastic; please exercise caution when handling the case. In a case where the product is attached to a cable larger than the product's internal diameter, the ferrite core may be damaged. Please confirm compatibility with the cable before use. Dropping or forcible engagement may cause damage to the product. Please handle the product with care when engaging. Do not detach and reuse a product that has been engaged. Do not expose the products to magnets or magnetic fields. Do not use for a purpose outside of the contents regulated in the delivery specifications. The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions set forth in the each catalog, please contact us. (1) Aerospace/aviation equipment (2) Transportation equipment (cars, electric trains, ships, etc.) (3) Medical equipment (4) Power-generation control equipment (5) Atomic energy-related equipment   (6) Seabed equipment (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing protection circuit/device or providing backup circuits in your equipment. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (9/9) 20220609 clamp-filter_commercial_zcat_en.fm
ZCAT3618-2630DT 价格&库存
很抱歉,暂时无法提供与“ZCAT3618-2630DT”相匹配的价格&库存,您可以联系我们找货
