ZCYS51R5-M8PT-01
ZCYS51R5-M8PT-01
    TDK(东电化)
    SMD
    ZCYS51R5-M8PT-01
ZCYS51R5-M8PT-01 数据手册
Common Mode Filters For high-speed differential signal line/general signal line ZCYS series Type: ZCYS51R5 Issue date: September 2011 • All specifications are subject to change without notice. • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. (1/2) Conformity to RoHS Directive Common Mode Filters For High-speed Differential Signal Line / General Signal Line ZCYS Series ZCYS51R5 FEATURES • The ZCYS series common mode filters provide highly effective noise rejection characteristics without distorting the transmission signal. Especially, most available for USB interface circuit. • Well suited as a countermeasure against high-frequency radiation noise in small signal interface lines, this product is a spaceefficient solution for multiple-line cable applications. • A high level of miniaturization has been achieved with a maximum height of 2.5mm. PACKAGING STYLE AND QUANTITIES Packaging style Part No. ZCYS51R5-M4PAT-01 ZCYS51R5-M6PT-01 ZCYS51R5-M8PT-01 Taping Quantity 3000 pieces/reel 2000 pieces/reel 2000 pieces/reel APPLICATIONS Personal computers, telephones, LANs, ISDNs, digital PBXs, word processors, electronic games, palm-sized computing devices, CTVs, CD-ROM drives, 8mm video cameras. SHAPES AND DIMENSIONS/RECOMMENDED PC BOARD PATTERNS ZCYS51R5-M4PAT-01 ZCYS51R5-M6PT-01 A E 7.4 10.3 C B 1.45 1.45 1.27×5 pitches 1 2 3 4 5 6 7 8 D 0.2 (0.1) D G Marking 7.4 10.3 C B 1.27×3pitches 1 2 3 4 5 6 D 0.6 Marking 4.2 7.9 1.85 C B 1 2 3 4 Marking E A 16 15 14 1312 11 10 9 121110 9 8 7 E F F Weight: 0.28g 8.89±0.2 Weight: 0.25g F 1.27×8 pitches G 0.6 8 7 6 5 ZCYS51R5-M8PT-01 0.6 (0.1) A Weight: 0.1g Dimensions in mm Part No. A max. B C±0.5 D max. 5.7 6.0 7 2.5 ZCYS51R5-M4PAT∗1-01∗2 ZCYS51R5-M6PT-01 8.5 8.5 9.4 2.5 ZCYS51R5-M8PT-01 11 8.5 9.4 2.5 ∗1 T means the taping product. ∗2 The "-01" designation at the end of the product code indicates Lead-free compatible product. CIRCUIT DIAGRAMS ZCYS51R5-M4PAT-01 ZCYS51R5-M6PT-01 E 0.4 0.4 0.4 F±0.15 1.27 1.27 1.27 G 0.2 0.2 0.2 ZCYS51R5-M8PT-01 L1 L2 L3 L4 8 7 6 5 L1 L 2 L3 L 4 L 5 L6 12 11 10 9 8 7 L1 L 2 L3 L 4 L 5 L 6 L 7 L8 16 15 14 13 12 11 10 9 1 2 3 4 1 1 2 3 4 5 6 2 3 4 5 6 7 8 • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. 001-03 / 20110928 / e971_zcys.fm (2/2) ELECTRICAL CHARACTERISTICS Part No. Rated voltage Edc(V) Rated current (A) Test voltage Edc(V) [Between terminals for 5s] Insulation resistance (MΩ ) [Between terminals at DC.50V for 1min] DC resistance (Ω ) [each line] Operating temperature range(°C) Impedance (Ω ) [+5 to +35°C] ZCYS51R5-M4PAT-01 50 0.5 ZCYS51R5-M6PT-01 50 0.5 ZCYS51R5-M8PT-01 50 0.5 125 125 125 100min. 100min. 100min. 0.2max. –25 to +85 200min. [50 to 500MHz] 0.25max. –25 to +85 200min. [50 to 300MHz] 0.3max. –25 to +85 100min. [100 to 300MHz] TYPICAL ELECTRICAL CHARACTERISTICS IMPEDANCE vs. FREQUENCY CHARACTERISTICS (for 1 element) ZCYS51R5-M4PAT-01 ZCYS51R5-M6PT-01 ZCYS51R5-M8PT-01 3000 3000 3000 1000 1000 1000 Common mode 300 100 Common mode 300 100 30 3 10 30 100 Frequency (MHz) 300 Common mode 100 Differential mode 30 30 1 300 Differential mode Differential mode 10 Impedance (Ω) 10000 Impedance (Ω) 10000 Impedance (Ω) 10000 1000 10 1 3 10 30 100 Frequency (MHz) 300 1000 10 1 3 10 30 100 Frequency (MHz) 300 1000 • All specifications are subject to change without notice. 001-03 / 20110928 / e971_zcys.fm
ZCYS51R5-M8PT-01 价格&库存
很抱歉,暂时无法提供与“ZCYS51R5-M8PT-01”相匹配的价格&库存,您可以联系我们找货
