Common Mode Filters
For general signal line/power line
ZJY series
Type:
ZJY51R5
Issue date:
September 2011
• All specifications are subject to change without notice.
• Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific
bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications.
(1/2)
Common Mode Filters
For General Signal Line / Power Line
ZJY Series ZJY51R5
FEATURES
• A common mode filter for distortion-free removal of noise from
transmitted signals. Best common mode filter for transmission of
high quality signals.
• Best filter for countering the common mode noise resulting from
data signal processing by PCs, phone equipment, etc.
• Highly appropriate for IC board mounting due to DIP type structure.
• Due to a maximum current tolerance of 2A, can also be used to
counter power line noise.
RECOMMENDED SOLDERING CONDITION
RECOMMENDED FLOW TEMPERATURE PROFILE
FOR LEAD-FREE SOLDER
Peak
260˚C max.
Natural
cooling
100 to 150˚C
60 to 120s
APPLICATIONS
Personal computers, telephones, LANs, ISDNs, digital PBXs, electronic games, CTVs, CD-ROM drives, 8mm video equipment, and
other electronic devices
10s max.
Time (s)
PACKAGING STYLE AND QUANTITIES(Tube style)
Quantity
80 pieces
80 pieces
80 pieces
40 pieces
40 pieces
20 pieces
SHAPES AND DIMENSIONS
TRANSFER MOLD
ZJY51R5-2P-01, -2PB-01, -2PL-01
ZJY51R5-4P-01, -M4PA-01
8
4 3
1
G
5
16
4
A
G
F
8
A
G
D
C
B
I
I
D
1
I
E
H
E
9
B
B
C
D
1 2
A
PLASTIC CASE
ZJY51R5-8PA-01
C
Part No.
ZJY51R5-2P-01
ZJY51R5-2PB-01
ZJY51R5-2PL-01
ZJY51R5-4P-01
ZJY51R5-M4PA-01
ZJY51R5-8PA-01
F
H
Weight: 0.4g
E
0 to 15˚
0 to 15˚
F
H
0 to 15˚
Weight: 1.6g
Weight: 0.8g
Dimensions in mm
Part No.
A max.
B max.
C max.
D max.
ZJY51R5-2P-01, -2PB-01, -2PL-01∗
5.5
6.86
4.57
5.84
10.5
6.86
4.57
5.84
ZJY51R5-8PA-01
23.5
7
4.6
6.3
∗ The "-01" designation at the end of the product code indicates Lead-free compatible product.
CIRCUIT DIAGRAMS
E
0.5
0.5
0.5
F±0.25
2.54
2.54
2.54
G
7.62
7.62
7.62
H
0.25
0.25
0.25
I
2.54
2.54
2.54
ZJY51R5-8PA-01
L1 L 2
4 3
L1 L 2 L 3 L 4
8 7 6 5
L1 L 2 L 3 L 4 L5 L 6 L 7 L 8
16 15 14 13 12 11 10 9
1 2
1 2 3 4
1 2
3 4
5 6
7 8
001-03 / 20110928 / e9722_zjy.fm
(2/2)
ELECTRICAL CHARACTERISTICS
Part No.
Rated voltage Edc(V)
Rated current (A)
Test voltage Edc(V)
[Between terminals for 5s]
Insulation resistance (MΩ)
[Between terminals at DC.50V for 1min]
DC resistance (Ω ) [Each line]
Operating temperature range (°C)
Storage temperature range(After mount)(°C)
Impedance (Ω ) [+5 to +35°C]
∗1
∗2
ZJY51R5-2P-01,
-4P-01
50
2
50
2
50
2
50
0.5
50
0.5
125
125
250
125
250
100 min.
100 min.
100 min.
100 min.
100 min.
0.12 max.
–25 to +85
–25 to +85
200 min.
[20 to 300MHz]
0.12 max.
–25 to +85
–25 to +85
300 min.
[6 to 20MHz]
0.10 max.
–25 to +85
–25 to +85
100 min.
[20 to 100MHz]
0.25 max.
–25 to +85
–25 to +85
200 min.
[20 to 300MHz]
0.07 max.
–25 to +85
–25 to +85
200 min.
[20 to 300MHz]
ZJY51R5-2PB-01∗1 ZJY51R5-2PL-01∗2 ZJY51R5-M4PA-01 ZJY51R5-8PA-01
This type has improved low-range characteristics.
This type is wrapped separately (for communication lines).
TYPICAL ELECTRICAL CHARACTERISTICS
IMPEDANCE CHARACTERISTICS (for 1 element)
ZJY51R5-2P-01, -4P-01, -8PA-01
ZJY51R5-2PB-01
10000
1000
Common mode
Impedance (Ω)
Impedance (Ω)
1000
100
Differential mode
10
1
1
3
10
30
100
Frequency (MHz)
10000
Common mode
100
Differential mode
10
300
1
1
1000
1000
Impedance (Ω)
10000
ZJY51R5-2PL-01
3
10
30
100
Frequency (MHz)
ZJY51R5-M4PA-01
Common mode
100
Differential mode
10
300
1000
1
1
3
10
30
100
Frequency (MHz)
300
1000
MEASURING CIRCUIT
10000
Impedance (Ω)
1000
Vector
impedance
meter
Common mode
100
Vector impedance meter (YHP 4191A equivalent)
Measuring at each Common mode choke coil
Differential mode
10
1
1
3
10
30
100
Frequency (MHz)
300
1000
TYPICAL APPLICATION
An application example showing how radiation noise is prevented
when transmitter and receiver are connected via twisted pair
cables.
Transmitter
Receiver
很抱歉,暂时无法提供与“ZJY51R5-M4PA-01”相匹配的价格&库存,您可以联系我们找货
