E M C
C o m p o n e n t s
December 2015
Common Mode Filters
For signal line
ZJYS51 Series
ZJYS51R5 Type
Caution
The products in this catalog will be or have been
stopped production
Discontinue Issue Date
Nov.4, 2015
Last Purchase Order Date
Sep.29, 2017
Last Shipment Date
Mar.30, 2018
Please refer to our Web site about replacement information.
(2/9)
E M C
C o m p o n e n t s
REMINDERS FOR USING THESE PRODUCTS
Before using these products, be sure to request the delivery specifications.
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using these products.
REMINDERS
The storage period is less than 12 months. Be sure to follow the storage conditions (Temperature: 5 to 40°C, Humidity: 10 to 75% RH
or less).
If the storage period elapses, the soldering of the terminal electrodes may deteriorate.
Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.).
Before soldering, be sure to preheat components.
The preheating temperature should be set so that the temperature difference between the solder temperature and chip temperature
does not exceed 150°C.
Soldering corrections after mounting should be within the range of the conditions determined in the specifications.
If overheated, a short circuit, performance deterioration, or lifespan shortening may occur.
When embedding a printed circuit board where a chip is mounted to a set, be sure that residual stress is not given to the chip due to
the overall distortion of the printed circuit board and partial distortion such as at screw tightening portions.
Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal
design.
Carefully lay out the coil for the circuit board design of the non-magnetic shield type.
A malfunction may occur due to magnetic interference.
Use a wrist band to discharge static electricity in your body through the grounding wire.
Do not expose the products to magnets or magnetic fields.
Do not use for a purpose outside of the contents regulated in the delivery specifications.
The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications
equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement
equipment, industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or
quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to
society, person or property.
If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions
set forth in the each catalog, please contact us.
Th
e
(1) Aerospace/Aviation equipment
(2) Transportation equipment (cars, electric trains, ships, etc.)
(3) Medical equipment
(4) Power-generation control equipment
(5) Atomic energy-related equipment
(6) Seabed equipment
(7) Transportation control equipment
(8) Public information-processing equipment
(9) Military equipment
(10) Electric heating apparatus, burning equipment
(11) Disaster prevention/crime prevention equipment
(12) Safety equipment
(13) Other applications that are not considered general-purpose
applications
When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing
protection circuit/device or providing backup circuits in your equipment.
20151221 / cmf_commercial_signal_zjys51r5_en.fm
(3/9)
E M C
C o m p o n e n t s
Common Mode Filters
Product compatible with RoHS directive
For signal line
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
Overview of ZJYS51R5 Type
FEATURES
Optimal common mode filter for removing noise without straining the transmission signal and for transmitting high-quality signals.
Optimal countermeasure for common mode noise induced during data transmission for digital signal processing such as in PCs and
telephones.
SMD type structure makes it optimal for surface mounting.
Up to 2A current is allowable, so it can be used as a noise countermeasure for power supply lines.
APPLICATION
PCs, telephones, LANs, ISDNs, digital PBXs, game machines, CTVs, CD-ROMs, 8mm video cassette recorders, etc.
PART NUMBER CONSTRUCTION
ZJYS51R5
Series • Type name
2P
Product internal
code
2P
2PB
2PL
4P
M4PA
T
Packaging style
T
ø330mm reel
01
Internal code
01
OPERATING TEMPERATURE RANGE, PACKAGE QUANTITY, PRODUCT WEIGHT
Temperature range
Operating
Storage
temperature
temperature
(°C)
(°C)
ZJYS51R5-2PT-01
–25 to +85
–25 to +85
ZJYS51R5-2PBT-01
–25 to +85
–25 to +85
ZJYS51R5-2PLT-01
–25 to +85
–25 to +85
ZJYS51R5-4PT-01
–25 to +85
–25 to +85
ZJYS51R5-M4PAT-01
–25 to +85
–25 to +85
The Storage temperature range is for after the circuit board is mounted.
Package quantity
Individual weight
(pieces/reel)
1,500
1,500
1,500
1,000
1,000
(g)
0.4
0.4
0.4
0.8
0.8
Th
e
Type
RoHS Directive Compliant Product: See the following for more details related to RoHS Directive compliant products. http://product.tdk.com/en/environment/rohs/
Halogen-free: Indicates that Cl content is less than 900ppm, Br content is less than 900ppm, and that the total Cl and Br content is less than 1500ppm.
Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use.
Please note that the contents may change without any prior notice due to reasons such as upgrading.
(4/9)
E M C
C o m p o n e n t s
ZJYS51R5 Type
RECOMMENDED REFLOW PROFILE
Soldering
Natural
cooling
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
Preheating
Peak
T: Temperature
T4
T3
T2
T1
t1
T3
t3
t2
t: Time
Time
t1
60 to 120s
Soldering
Temp.
Time
T3
t2
230°C
10 to 30s
Peak
Temp.
T4
245°C
Time
t3
5s
Th
e
Preheating
Temp.
T1
T2
150°C
180°C
(5/9)
E M C
C o m p o n e n t s
ZJYS51R5-2PT-01, -2PBT-01, -2PLT-01
SHAPE & DIMENSIONS
5.5max.
3
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
4
Marking: TDK
Marking: Product internal code
Marking: Production date code
9±0.5
2
6.86max.
0.25
4.57max.
5.08max.
1
2.54±0.25
1.3
(0.6)
Dimensions in mm
RECOMMENDED LAND PATTERN
CIRCUIT DIAGRAM
3
6.7
9.9
4
1.6
1.8
2
1
• No polarity
Dimensions in mm
Th
e
2.54
(6/9)
E M C
C o m p o n e n t s
ELECTRICAL CHARACTERISTICS
CHARACTERISTICS SPECIFICATION TABLE
ZJYS51R5-2PT-01
50
2
ZJYS51R5-2PBT-01
1
50
2
ZJYS51R5-2PLT-01
2
50
2
125
125
250
100 min.
100 min.
100 min.
0.12 max.
200 min.[20 to 300MHz]
0.12 max.
300 min.[6 to 20MHz]
0.10 max.
100 min.[20 to 100MHz]
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
Part No.
Rated voltage Edc(V)
Rated current (A)
Test voltage Edc(V)
[Between terminals for 5s]
Insulation resistance (M: )
[Between terminals at DC.50V for 1min]
DC resistance (: ) [1 line]
Impedance (: )[+5 to +35°C]
○ Measurement equipment
Measurement item
Product No.
Common mode impedance
4991A
DC resistance
4338A
4339A
* Equivalent measurement equipment may be used.
Manufacturer
Agilent Technologies
IMPEDANCE VS. FREQUENCY CHARACTERISTICS (FOR 1 ELEMENT)
10000
Impedance (Ω)
1000
2PT Common mode
2PB Common mode
2PL Common mode
100
2PL Differential mode
10
2PT Differential mode
2PB Differential mode
Th
e
1
1
3
10
30
Frequency (MHz)
100
300
1000
Product No.
Manufacturer
4991A
(7/9)
E M C
C o m p o n e n t s
ZJYS51R5-4PT-01, -M4PAT-01
SHAPE & DIMENSIONS
10.5max.
7
6
5
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
8
1
3
2
9±0.5
4
0.25
5.08max.
4.57max.
6.86max.
2.54±0.25
1.3
(0.6)
Dimensions in mm
CIRCUIT DIAGRAM
ZJYS51R5-4PT-01
7
6
5
3
4
8
7
6
5
3
4
6.7
9.9
8
ZJYS51R5-M4PAT-01
1.6
1.8
2.54
2.54
2.54
2
1
• No polarity
2
1
• No polarity
Th
e
Dimensions in mm
(8/9)
E M C
C o m p o n e n t s
ZJYS51R5-4PT-01
50
2
ZJYS51R5-M4PAT-01
50
0.5
125
125
100 min.
100 min.
0.12 max.
0.25 max.
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
Part No.
Rated current (A)
Test voltage Edc(V)
Measurement item
Product No.
4991A
DC resistance
4338A
4339A
Manufacturer
10000
Impedance (Ω)
1000
100
10
4PT Common mode
M4PA Common mode
4PT Differential mode
M4PA Differential mode
Th
e
1
1
3
10
30
Frequency (MHz)
100
300
1000
Product No.
Manufacturer
4991A
(9/9)
E M C
C o m p o n e n t s
ZJYS51R5 Type
PACKAGING STYLE
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
REEL DIMENSIONS
2.0±0.5
E
N
Type
A
W1
W2
N
E
ZJYS51R5-2
ø330±4/–2 16.4+2/–0 22.4max. ø100±1 2 typ.
ZJYS51R5-4P,M4PA ø330±4/–2 16.4+2/–0 22.4max. ø100±1 2 typ.
1.0
ø13.0±0.5
W1
ø21.0±0.8
W2
A
Dimensions in mm
TAPE DIMENSIONS
t
P0
B
W
F
P2
E
øD0
A
K
P1
Dimensions in mm
Type
ZJYS51R5-2
ZJYS51R5-4P,M4PA
A
5.8±0.1
9.8±0.1
B
9.8±0.1
10.5±0.1
øD0
1.5+0.1/0
1.5+0.1/0
E
1.75±0.1
1.75±0.1
F
7.5±0.1
7.5±0.1
P0
4.0±0.1
4.0±0.1
P1
8.0±0.1
12.0±0.1
P2
2.0±0.1
2.0±0.1
W
16.0±0.3
16.0±0.3
K
5.2
5.2
t
0.4
0.4
500 to 560
160min.
Taping
240min.
Th
e
Drawing direction
