ZJYS51R5-M4PAT-01
ZJYS51R5-M4PAT-01
    TDK(东电化)
    ZJYS51R5-M4PAT-01
ZJYS51R5-M4PAT-01 数据手册
E M C C o m p o n e n t s May 2016 Common Mode Filters For signal line ZJYS51 Series ZJYS51R5 Type Caution The products in this catalog will be or have been stopped production Discontinue Issue Date Nov.4, 2015 Last Purchase Order Date Sep.29, 2017 Last Shipment Date Mar.30, 2018 Please refer to our Web site about replacement information. (2/9) E M C C o m p o n e n t s REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. pr od u st cts op w pe il d lb pr e od or uc ha tio ve n be en SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using these products. REMINDERS The storage period is less than 12 months. Be sure to follow the storage conditions (Temperature: 5 to 40°C, Humidity: 10 to 75% RH or less). If the storage period elapses, the soldering of the terminal electrodes may deteriorate. Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.). Before soldering, be sure to preheat components. The preheating temperature should be set so that the temperature difference between the solder temperature and chip temperature does not exceed 150°C. Soldering corrections after mounting should be within the range of the conditions determined in the specifications. If overheated, a short circuit, performance deterioration, or lifespan shortening may occur. When embedding a printed circuit board where a chip is mounted to a set, be sure that residual stress is not given to the chip due to the overall distortion of the printed circuit board and partial distortion such as at screw tightening portions. Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal design. Carefully lay out the coil for the circuit board design of the non-magnetic shield type. A malfunction may occur due to magnetic interference. Use a wrist band to discharge static electricity in your body through the grounding wire. Do not expose the products to magnets or magnetic fields. Do not use for a purpose outside of the contents regulated in the delivery specifications. The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions set forth in the each catalog, please contact us. Th e (1) Aerospace/Aviation equipment (2) Transportation equipment (cars, electric trains, ships, etc.) (3) Medical equipment (4) Power-generation control equipment (5) Atomic energy-related equipment (6) Seabed equipment (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing protection circuit/device or providing backup circuits in your equipment. 20160524 / cmf_commercial_signal_zjys51r5_en.fm (3/9) E M C C o m p o n e n t s Common Mode Filters Product compatible with RoHS directive For signal line pr od u st cts op w pe il d lb pr e od or uc ha tio ve n be en Overview of ZJYS51R5 Type FEATURES Optimal common mode filter for removing noise without straining the transmission signal and for transmitting high-quality signals. Optimal countermeasure for common mode noise induced during data transmission for digital signal processing such as in PCs and telephones. SMD type structure makes it optimal for surface mounting. Up to 2A current is allowable, so it can be used as a noise countermeasure for power supply lines. APPLICATION PCs, telephones, LANs, ISDNs, digital PBXs, game machines, CTVs, CD-ROMs, 8mm video cassette recorders, etc. PART NUMBER CONSTRUCTION ZJYS51R5 - Series • Type name 2P Product internal code 2P 2PB 2PL 4P M4PA T Packaging style T ø330mm reel - 01 Internal code 01 OPERATING TEMPERATURE RANGE, PACKAGE QUANTITY, PRODUCT WEIGHT Temperature range Operating Storage temperature temperature (°C) (°C) ZJYS51R5-2PT-01 –25 to +85 –25 to +85 ZJYS51R5-2PBT-01 –25 to +85 –25 to +85 ZJYS51R5-2PLT-01 –25 to +85 –25 to +85 ZJYS51R5-4PT-01 –25 to +85 –25 to +85 ZJYS51R5-M4PAT-01 –25 to +85 –25 to +85 The Storage temperature range is for after the circuit board is mounted. Package quantity Individual weight (pieces/reel) 1,500 1,500 1,500 1,000 1,000 (g) 0.4 0.4 0.4 0.8 0.8 Th e Type RoHS Directive Compliant Product: See the following for more details related to RoHS Directive compliant products. http://product.tdk.com/en/environment/rohs/ Halogen-free: Indicates that Cl content is less than 900ppm, Br content is less than 900ppm, and that the total Cl and Br content is less than 1500ppm. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160524 / cmf_commercial_signal_zjys51r5_en.fm (4/9) E M C C o m p o n e n t s ZJYS51R5 Type RECOMMENDED REFLOW PROFILE Soldering Natural cooling pr od u st cts op w pe il d lb pr e od or uc ha tio ve n be en Preheating Peak T: Temperature T4 T3 T2 T1 t1 T3 t3 t2 t: Time Time t1 60 to 120s Soldering Temp. Time T3 t2 230°C 10 to 30s Peak Temp. T4 245°C Time t3 5s Th e Preheating Temp. T1 T2 150°C 180°C Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160524 / cmf_commercial_signal_zjys51r5_en.fm (5/9) E M C C o m p o n e n t s ZJYS51R5-2PT-01, -2PBT-01, -2PLT-01 SHAPE & DIMENSIONS 5.5max. 3 pr od u st cts op w pe il d lb pr e od or uc ha tio ve n be en 4 Marking: TDK Marking: Product internal code Marking: Production date code 9±0.5 2 6.86max. 0.25 4.57max. 5.08max. 1 2.54±0.25 1.3 (0.6) Dimensions in mm RECOMMENDED LAND PATTERN CIRCUIT DIAGRAM 3 6.7 9.9 4 1.6 1.8 2 1 • No polarity Dimensions in mm Th e 2.54 Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160524 / cmf_commercial_signal_zjys51r5_en.fm (6/9) E M C C o m p o n e n t s ZJYS51R5-2PT-01, -2PBT-01, -2PLT-01 ELECTRICAL CHARACTERISTICS CHARACTERISTICS SPECIFICATION TABLE ZJYS51R5-2PT-01 50 2 ZJYS51R5-2PBT-01 1 50 2 ZJYS51R5-2PLT-01 2 50 2 125 125 250 100 min. 100 min. 100 min. 0.12 max. 200 min.[20 to 300MHz] 0.12 max. 300 min.[6 to 20MHz] 0.10 max. 100 min.[20 to 100MHz] pr od u st cts op w pe il d lb pr e od or uc ha tio ve n be en Part No. Rated voltage Edc(V) Rated current (A) Test voltage Edc(V) [Between terminals for 5s] Insulation resistance (M: ) [Between terminals at DC.50V for 1min] DC resistance (: ) [1 line] Impedance (: )[+5 to +35°C] ○ Measurement equipment Measurement item Product No. Common mode impedance 4991A DC resistance 4338A Insulation resistance 4339A * Equivalent measurement equipment may be used. Manufacturer Agilent Technologies Agilent Technologies Agilent Technologies IMPEDANCE VS. FREQUENCY CHARACTERISTICS (FOR 1 ELEMENT) 10000 Impedance (Ω) 1000 2PT Common mode 2PB Common mode 2PL Common mode 100 2PL Differential mode 10 2PT Differential mode 2PB Differential mode Th e 1 1 3 10 30 Frequency (MHz) 100 300 1000 ○ Measurement equipment Product No. Manufacturer 4991A Agilent Technologies * Equivalent measurement equipment may be used. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160524 / cmf_commercial_signal_zjys51r5_en.fm (7/9) E M C C o m p o n e n t s ZJYS51R5-4PT-01, -M4PAT-01 SHAPE & DIMENSIONS 10.5max. 7 6 5 pr od u st cts op w pe il d lb pr e od or uc ha tio ve n be en 8 Marking: Production date code Marking: Product internal code 1 3 2 9±0.5 4 0.25 5.08max. 4.57max. 6.86max. 2.54±0.25 1.3 (0.6) Dimensions in mm RECOMMENDED LAND PATTERN CIRCUIT DIAGRAM ZJYS51R5-4PT-01 7 6 5 3 4 8 7 6 5 3 4 6.7 9.9 8 ZJYS51R5-M4PAT-01 1.6 1.8 2.54 2.54 2.54 2 1 • No polarity 2 1 • No polarity Th e Dimensions in mm Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160524 / cmf_commercial_signal_zjys51r5_en.fm (8/9) E M C C o m p o n e n t s ZJYS51R5-4PT-01, -M4PAT-01 ELECTRICAL CHARACTERISTICS CHARACTERISTICS SPECIFICATION TABLE ZJYS51R5-4PT-01 50 2 ZJYS51R5-M4PAT-01 50 0.5 125 125 100 min. 100 min. 0.12 max. 200 min.[20 to 300MHz] 600 typ. [100MHz] 0.25 max. 200 min.[20 to 300MHz] 600 typ. [100MHz] pr od u st cts op w pe il d lb pr e od or uc ha tio ve n be en Part No. Rated voltage Edc(V) Rated current (A) Test voltage Edc(V) [Between terminals for 5s] Insulation resistance (M: ) [Between terminals at DC.50V for 1min] DC resistance (: ) [1 line] Impedance (: )[+5 to +35°C] ○ Measurement equipment Measurement item Product No. Common mode impedance 4991A DC resistance 4338A Insulation resistance 4339A * Equivalent measurement equipment may be used. Manufacturer Agilent Technologies Agilent Technologies Agilent Technologies IMPEDANCE VS. FREQUENCY CHARACTERISTICS (FOR 1 ELEMENT) 10000 Impedance (Ω) 1000 100 10 4PT Common mode M4PA Common mode 4PT Differential mode M4PA Differential mode Th e 1 1 3 10 30 Frequency (MHz) 100 300 1000 ○ Measurement equipment Product No. Manufacturer 4991A Agilent Technologies * Equivalent measurement equipment may be used. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160524 / cmf_commercial_signal_zjys51r5_en.fm (9/9) E M C C o m p o n e n t s ZJYS51R5 Type PACKAGING STYLE pr od u st cts op w pe il d lb pr e od or uc ha tio ve n be en REEL DIMENSIONS 2.0±0.5 E N Type A W1 W2 N E ZJYS51R5-2 ø330±4/–2 16.4+2/–0 22.4max. ø100±1 2 typ. ZJYS51R5-4P,M4PA ø330±4/–2 16.4+2/–0 22.4max. ø100±1 2 typ. 1.0 ø13.0±0.5 W1 ø21.0±0.8 W2 A Dimensions in mm TAPE DIMENSIONS t P0 B W F P2 E øD0 A K P1 Dimensions in mm Type ZJYS51R5-2 ZJYS51R5-4P,M4PA A 5.8±0.1 9.8±0.1 B 9.8±0.1 10.5±0.1 øD0 1.5+0.1/0 1.5+0.1/0 E 1.75±0.1 1.75±0.1 F 7.5±0.1 7.5±0.1 P0 4.0±0.1 4.0±0.1 P1 8.0±0.1 12.0±0.1 P2 2.0±0.1 2.0±0.1 W 16.0±0.3 16.0±0.3 K 5.2 5.2 t 0.4 0.4 500 to 560 160min. Taping 240min. Th e Drawing direction Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160524 / cmf_commercial_signal_zjys51r5_en.fm
ZJYS51R5-M4PAT-01 价格&库存
很抱歉,暂时无法提供与“ZJYS51R5-M4PAT-01”相匹配的价格&库存,您可以联系我们找货
