E M C
C o m p o n e n t s
December 2015
Common Mode Filters
For automobile signal line
ZJYS81 Series
ZJYS81R5 Type
Caution
The products in this catalog will be or have been
stopped production
Discontinue Issue Date
Nov.4, 2015
Last Purchase Order Date
Sep.29, 2017
Last Shipment Date
Mar.30, 2018
Please refer to our Web site about replacement information.
(2/7)
E M C
C o m p o n e n t s
REMINDERS FOR USING THESE PRODUCTS
Before using these products, be sure to request the delivery specifications.
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using these products.
REMINDERS
The storage period is less than 12 months. Be sure to follow the storage conditions (Temperature: 5 to 40°C, Humidity: 10 to 75% RH
or less).
If the storage period elapses, the soldering of the terminal electrodes may deteriorate.
Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.).
Before soldering, be sure to preheat components.
The preheating temperature should be set so that the temperature difference between the solder temperature and chip temperature
does not exceed 150°C.
Soldering corrections after mounting should be within the range of the conditions determined in the specifications.
If overheated, a short circuit, performance deterioration, or lifespan shortening may occur.
When embedding a printed circuit board where a chip is mounted to a set, be sure that residual stress is not given to the chip due to
the overall distortion of the printed circuit board and partial distortion such as at screw tightening portions.
Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal
design.
Carefully lay out the coil for the circuit board design of the non-magnetic shield type.
A malfunction may occur due to magnetic interference.
Use a wrist band to discharge static electricity in your body through the grounding wire.
Do not expose the products to magnets or magnetic fields.
Do not use for a purpose outside of the contents regulated in the delivery specifications.
The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications
equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement
equipment, industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or
quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to
society, person or property.
If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions
set forth in the each catalog, please contact us.
Th
e
(1) Aerospace/Aviation equipment
(2) Transportation equipment (electric trains, ships, etc.)
(3) Medical equipment
(4) Power-generation control equipment
(5) Atomic energy-related equipment
(6) Seabed equipment
(7) Transportation control equipment
(8) Public information-processing equipment
(9) Military equipment
(10) Electric heating apparatus, burning equipment
(11) Disaster prevention/crime prevention equipment
(12) Safety equipment
(13) Other applications that are not considered general-purpose
applications
When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing
protection circuit/device or providing backup circuits in your equipment.
20151221 / cmf_automotive_signal_zjys81r5_en.fm
(3/7)
E M C
C o m p o n e n t s
Common Mode Filters
Product compatible with RoHS directive
AEC-Q200
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
Overview of ZJYS81R5 Type
FEATURES
Optimal common mode filter for removing noise without straining the transmission signal and for transmitting high-quality signals.
Optimal countermeasure for common mode noise induced during data transmission for digital signal processing such as in CAN-bus
systems.
SMD type structure makes it optimal for surface mounting.
APPLICATION
CAN-bus systems, etc,
PART NUMBER CONSTRUCTION
ZJYS81R5
Series • Type name
2P
L
Number of lines
Winding type
2P
2 lines
L
Non code
25
Split coil
Bifilar coil
Product internal
code
25
T
Packaging style
T
ø330mm reel
G01
Internal code
G01
OPERATING TEMPERATURE RANGE, PACKAGE QUANTITY, PRODUCT WEIGHT
Temperature range
Operating
Storage
temperature
temperature
(°C)
(°C)
ZJYS81R5
–40 to +125
–40 to +125
The Storage temperature range is for after the circuit board is mounted.
Package quantity
Individual weight
(pieces/reel)
1,500
(g)
0.4
Th
e
Type
RoHS Directive Compliant Product: See the following for more details related to RoHS Directive compliant products. http://product.tdk.com/en/environment/rohs/
Halogen-free: Indicates that Cl content is less than 900ppm, Br content is less than 900ppm, and that the total Cl and Br content is less than 1500ppm.
Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use.
Please note that the contents may change without any prior notice due to reasons such as upgrading.
(4/7)
E M C
C o m p o n e n t s
ZJYS81R5 Type
RECOMMENDED REFLOW PROFILE
Soldering
Natural
cooling
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
Preheating
Peak
T: Temperature
T4
T3
T2
T1
t1
T3
t3
t2
t: Time
Time
t1
60 to 120s
Soldering
Temp.
Time
T3
t2
230°C
10 to 30s
Peak
Temp.
T4
245°C
Time
t3
5s
Th
e
Preheating
Temp.
T1
T2
150°C
180°C
(5/7)
E M C
C o m p o n e n t s
ZJYS81R5 Type
SHAPE & DIMENSIONS
4
6max.
1
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
Marking: TDK
Marking: Product internal code
Marking: Production date code
2
3
0.25
5.0max.
7.1max.
9±0.5
0.6±0.2
1.3
2.54±0.25
Dimensions in mm
Dimensions in mm
CIRCUIT DIAGRAM
1
4
2
3
• No polarity
Th
e
6.7
9.9
1.8
2.54
RECOMMENDED LAND PATTERN
(6/7)
E M C
C o m p o n e n t s
ZJYS81R5 Type
ELECTRICAL CHARACTERISTICS
CHARACTERISTICS SPECIFICATION TABLE
DC resistance
Rated current
Insulation
resistance
Rated voltage
Part No.
[10MHz]
(: ) min.
500
1000
600
1000
(: )max.
0.15
0.25
0.25
0.3
(A)max.
0.5
0.5
0.5
0.5
(M: )min.
100
100
100
100
(V)max.
80
80
80
80
ZJYS81R5-2P24T-G01
ZJYS81R5-2P50T-G01
ZJYS81R5-2PL25T-G01
ZJYS81R5-2PL51T-G01
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
Common mode impedance
(: ) typ.
1000
2000
1000
2000
○ Measurement equipment
Measurement item
Product No.
4991A
DC resistance
4338A
Insulation resistance
4339A
* Equivalent measurement equipment may be used.
Manufacturer
Agilent Technologies
IMPEDANCE VS. FREQUENCY CHARACTERISTICS
100000
PL51 Differential mode
Impedance (Ω)
10000
PL25 Differential mode
P50 Common mode
PL51 Common mode
PL25 Common mode
1000
P24 Common mode
100
P50 Differential mode
P24 Differential mode
Th
e
10
1
10
100
1000
Frequency (MHz)
Product No.
Manufacturer
4991A
(7/7)
E M C
C o m p o n e n t s
ZJYS81R5 Type
PACKAGING STYLE
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
REEL DIMENSIONS
2.0±0.5
E
A
W1
ø330±4/–2 16.4+2/–0
W2
N
E
22.4max. ø100±1 2 typ.
N
Type
ZJYS81R5
1.0
ø13.0±0.5
W1
ø21.0±0.8
W2
A
Dimensions in mm
TAPE DIMENSIONS
t
P0
B
W
F
P2
E
øD0
A
K
P1
Dimensions in mm
Type
ZJYS81R5
A
6.0±0.1
B
9.8±0.1
øD0
1.5+0.1/0
E
1.75±0.1
F
7.5±0.1
P0
4.0±0.1
P1
8.0±0.1
P2
2.0±0.1
W
16.0+0.3/–0.1
K
5.20±0.1
t
0.40±0.05
500 to 560
160min.
Taping
240min.
Th
e
Drawing direction
ZJYS81R5-2PL51T-G01 价格&库存
很抱歉,暂时无法提供与“ZJYS81R5-2PL51T-G01”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+3.13820
- 30+3.02770
- 100+2.80670
- 500+2.58570
- 1000+2.47520
