• PFC
• Wide Range AC Input
• Low Profile, Industry Standard Footprint
• Global Safety Agency Compliance
• RoHS Compliant
Key Market Segments & Applications
Video/Audio Routers
Datacom
Point of Sale
Test & Measurement
LED Signs and Lighting
ZPS100 Series
3" x 5" 100W AC-DC
Power Supplies
ZPS100 Features and Benefits
Features
Benefits
• Industry Standard Footprint
• Up to 85% efficiency
• Broad product range
• Meets EN61000-4 immunity
• Available to second source
• Less system heating
• Optimisation of power supply to system
• Greater reliability
Specifications
MODEL
ITEMS
Input Voltage range
Inrush Current (132/264VAC)
Input Current (115/230VAC)
Temperature Coefficient
Voltage Accuracy
Minimum Load
Load Regulation
Line Regulation
Ripple & Noise
(1)
Short Circuit Protection
Overvoltage Protection
Hold Up Time (Typ)
LED Indicator
Operating Temperature
Storage Temperature
Humidity (non condensing)
Cooling
Withstand Voltage
Isolation Resistance
Vibration (non operating)
Shock
Class 1
Conducted & Radiated EMI
Immunity
Weight (Typ)
Size (WxLxH)
Warranty
Notes:
ZPS100
A
A
A
mV
V
ms
g
mm
90 - 264VAC (47 - 440Hz) or 120 - 370VDC
25 / 50 (cold start)
1.1 / 0.6
±0.05%/°C
±1%
None
±1%
±0.5%
1% or 50mV whichever is greater
Continuous - hiccup mode
Typically 110-130% of nominal
8ms at 115VAC input
Green LED = OK
0 to +70°C with derating
-20 to +85°C
10 - 95% RH
Convection
Input to Ground 1.5kVAC, Input to Output 3kVAC, Output to Ground 500VAC for 1 min.
>100M at 25C & 70%RH, Output to Ground 500VDC
23.52m/s2 (10 - 55Hz: constant sweep 1 min X, Y, Z for 1 hour)
< 196.1 m/s2 (20G)
UL60950, CSA60950, EN60950-1 Class 1 , CE Mark (LVD)
EN55022-B, FCC Class B
EN61000-4-2,-3,-4,-5,-6,-8
385g
127 X 76.2 X 34 (including underside components )
2 Year
(1) Measured with 0.1uF ceramic & 10uF electrolytic at 20MHz BW
ZPS100 Series
1
M ode l Se l e c tor
Model
ZPS100-3R3
ZPS100-5
ZPS100-9
ZPS100-12
ZPS100-15
ZPS100-18
ZPS100-24
ZPS100-28
ZPS100-48
Output
Voltage (V)
Maximum
Output (A)
3.3
5
9
12
15
18
24
28
48
8.4
6.7
5.6
4.2
3.6
2.1
V1
V1
V1
V1
V1
V1
V1
V1
V1
INTERMEDIATE VOLTAGES AVAILABLE
PLEASE CONSULT SALES
For full data and drawings please visit
www.emea.tdk-lambda.com/www/zp
Derating Curve ZPS100 Series
ZPS100-3R3 -5 -9 -48 DERATING CURVE
ZPS100-12 -15 -18 -24 -28 DERATING CURVE
2
ZPS100 Series
Outline Drawing ZPS100 Series
Outline Drawing ZPS100-5 Series
Input Connector Mates with Molex Housing 09-50-3031 and Molex 2478 Series Crimp Terminal
Output Connector Mates with Molex Housing 09-50-1081 and Molex 5194 Series Crimp Terminal
ZPS100 Series
3
TDK-LAMBDA EMEA
www.emea-tdk-lambda.com
TDK-Lambda France SAS
TDK-Lambda Italy
ZAC des Delaches
BP 1077-Gometz-le-Chatel
91940 Les Ulis
France
Tel: +33 1 60 12 71 65
Fax: +33 1 60 12 71 66
france@fr.tdk-lambda.com
www.fr.tdk-lambda.com
Via dei Lavoratori 128/130
20092 Cinisello Balsamo (MI)
Italy
Tel: +39 02 61 29 38 63
Fax: +39 02 61 29 09 00
info.italia@it.tdk-lambda.com
www.it.tdk-lambda.com
TDK-Lambda Germany GmbH
TDK-Lambda UK Ltd.
Karl-Bold-Strasse 40
77855 Achern
Germany
Tel: +49 7841 666 0
Fax: +49 7841 5000
info.germany@de.tdk-lambda.com
www.de.tdk-lambda.com
Kingsley Avenue
Ilfracombe
Devon EX34 8ES
United Kingdom
Tel: +44 (0) 12 71 85 66 66
Fax: +44 (0) 12 71 86 48 94
powersolutions@uk.tdk-lambda.com
www.uk.tdk-lambda.com
Austria Sales Office
Aredstrasse 22
2544 Leobersdorf
Austria
Tel: +43 2256 655 84
Fax: +43 2256 645 12
Nemic Lambda Ltd.
Kibbutz Givat
Hashlosha 48800
Israel
Tel: +9 723 902 4333
Fax: +9 723 902 4777
info@nemic.co.il
www.nemic.co.il
LOCAL DISTRIBUTION
ZPS100 Feb10 v2
4
ZPS100 Series
很抱歉,暂时无法提供与“ZPS100-24”相匹配的价格&库存,您可以联系我们找货
