ZPS40/60 Series
2 x 4” 40W to 60W AC-DC Power Supplies
Features
Single Outputs
Wide Range AC Input
Low profile, Industry Standard Footprint
Global Safety Agency Compliance
EN61000-4 Immunity
Up to 88% efficiency
Key Market Segments & Applications
Specifications
Model
Input Voltage range
Inrush Current (132/265VAC)
Input Current (115/230VAC)
Temperature Coefficient
Voltage Accuracy
Minimum Load
Load Regulation
Line Regulation
Ripple & Noise
(1)
Short Circuit Protection
Overvoltage Protection
Hold Up Time (Typ)
LED Indicator
Operating Temperature
(2)
Storage Temperature
Humidity (non condensing)
Cooling
Withstand Voltage
Isolation Resistance
Vibration (non operating)
Shock
Safety Agency Approvals
Conducted & Radiated EMI
Immunity
Weight (Typ)
Size (WxLxH)
Warranty
ZPS40
ZPS60
90 - 264VAC (47 - 440Hz) or 120 - 370VDC
25 / 50 (cold start)
1.6 / 1.0
±0.05%/°C
±1%
None
±1%
±0.5%
1% or 50mV whichever is greater
Continuous - hiccup mode
Typically 110-130% of nominal
8ms at 115VAC input
Green LED = OK
0 to +70°C, derate linearly to 50% load from 50°C to 70°C
-20 to +85°C
10 - 95% RH
Convection
Input to Ground 1.5kVAC, Input to Output 3kVAC, Output to Ground 500VAC for 1 min.
>100M at 25C & 70%RH, Output to Ground 500VDC
23.52m/s2 (10 - 55Hz: constant sweep 1 min X, Y, Z for 1 hour)
< 196.1 m/s2 (20G)
UL60950, CSA60950, EN60950, CE Mark (LVD)
EN55022-B, FCC Class B
EN61000-4-2,-3,-4,-5,-6,-8
g (oz)
170g (6oz)
in
2 x 4 x 1.2 (including underside components )
yrs
Two Year
A
A
A
mV
V
ms
Notes:
(1) Measured with 0.1uF ceramic & 10uF electrolytic at 20MHz BW
(2) ZPS40 (3.3V to 9V models), ZPS60 (3.3V to 12V models) derate linearly to 25% load from 40°C to 70°C
1-800-526-2324 • www.us.tdk-lambda.com/lp/
152
Disclaimer: us.tdk-lambda.com/lp/legal.htm
ZPS40/60 Series
2 Output Module Codes
Note:
6.0
8.0
6.0
8.0
4.45
6.67
3.34
5.0
2.67
4.0
1.67
2.5
1.33
2.0
1.11
1.67
0.834
1.25
7.2
8.5
7.2
9.0
5.34
8.0
4.0
6.0
3.2
4.8
2.0
3.0
1.6
2.4
1.33
2.0
1.0
1.5
20.0
26.0
30.0
40.0
40.0
60.0
40.0
60.0
40.0
60.0
40.0
60.0
40.0
60.0
40.0
60.0
40.0
60.0
Eff.
74
74
78
78
82
82
84
84
85
85
86
86
86
86
87
87
88
88
4.00 (101.60)
0.150 (3.80)
3.70 (94.00)
LED
ACN
Vout (+)
ACL
Vout (-)
2.00 (50.80)
3.3
3.3
5.0
5.0
9.0
9.0
12.0
12.0
15.0
15.0
24.0
24.0
30.0
30.0
36.0
36.0
48.0
48.0
Peak Output
(A)(3) Pwr(W)
0.150 (3.80)
V1
V1
V1
V1
V1
V1
V1
V1
V1
V1
V1
V1
V1
V1
V1
V1
V1
V1
Max.
O/P(A)
1.70 (43.20)
Single Output
ZPS40-3R3
ZPS60-3R3
ZPS40-5
ZPS60-5
ZPS40-9
ZPS60-9
ZPS40-12
ZPS60-12
ZPS40-15
ZPS60-15
ZPS40-24
ZPS60-24
ZPS40-30
ZPS60-30
ZPS40-36
ZPS60-36
ZPS40-48
ZPS60-48
O/P(V)
1.20 (30.48)
Model
ZPS Outline Drawing
VR
For Additional Information, please visit
us.tdk-lambda.com/lp/products/zp-series.htm
(3) Average not to exceed max power,
很抱歉,暂时无法提供与“ZPS40-3R3”相匹配的价格&库存,您可以联系我们找货
