ZPS60-3R3
ZPS60-3R3
    TDK(东电化)
    40W至60W AC-DC电源模块
ZPS60-3R3 数据手册
ZPS40/60 Series 2 x 4” 40W to 60W AC-DC Power Supplies Features  Single Outputs  Wide Range AC Input  Low profile, Industry Standard Footprint  Global Safety Agency Compliance  EN61000-4 Immunity  Up to 88% efficiency Key Market Segments & Applications Specifications Model Input Voltage range Inrush Current (132/265VAC) Input Current (115/230VAC) Temperature Coefficient Voltage Accuracy Minimum Load Load Regulation Line Regulation Ripple & Noise (1) Short Circuit Protection Overvoltage Protection Hold Up Time (Typ) LED Indicator Operating Temperature (2) Storage Temperature Humidity (non condensing) Cooling Withstand Voltage Isolation Resistance Vibration (non operating) Shock Safety Agency Approvals Conducted & Radiated EMI Immunity Weight (Typ) Size (WxLxH) Warranty ZPS40 ZPS60 90 - 264VAC (47 - 440Hz) or 120 - 370VDC 25 / 50 (cold start) 1.6 / 1.0 ±0.05%/°C ±1% None ±1% ±0.5% 1% or 50mV whichever is greater Continuous - hiccup mode Typically 110-130% of nominal 8ms at 115VAC input Green LED = OK 0 to +70°C, derate linearly to 50% load from 50°C to 70°C -20 to +85°C 10 - 95% RH Convection Input to Ground 1.5kVAC, Input to Output 3kVAC, Output to Ground 500VAC for 1 min. >100M at 25C & 70%RH, Output to Ground 500VDC 23.52m/s2 (10 - 55Hz: constant sweep 1 min X, Y, Z for 1 hour) < 196.1 m/s2 (20G) UL60950, CSA60950, EN60950, CE Mark (LVD) EN55022-B, FCC Class B EN61000-4-2,-3,-4,-5,-6,-8 g (oz) 170g (6oz) in 2 x 4 x 1.2 (including underside components ) yrs Two Year A A % A % % mV V ms - Notes: (1) Measured with 0.1uF ceramic & 10uF electrolytic at 20MHz BW (2) ZPS40 (3.3V to 9V models), ZPS60 (3.3V to 12V models) derate linearly to 25% load from 40°C to 70°C 1-800-526-2324 • www.us.tdk-lambda.com/lp/ 152 Disclaimer: us.tdk-lambda.com/lp/legal.htm ZPS40/60 Series 2 Output Module Codes Note: 6.0 8.0 6.0 8.0 4.45 6.67 3.34 5.0 2.67 4.0 1.67 2.5 1.33 2.0 1.11 1.67 0.834 1.25 7.2 8.5 7.2 9.0 5.34 8.0 4.0 6.0 3.2 4.8 2.0 3.0 1.6 2.4 1.33 2.0 1.0 1.5 20.0 26.0 30.0 40.0 40.0 60.0 40.0 60.0 40.0 60.0 40.0 60.0 40.0 60.0 40.0 60.0 40.0 60.0 Eff. (%) 74 74 78 78 82 82 84 84 85 85 86 86 86 86 87 87 88 88 4.00 (101.60) 0.150 (3.80) 3.70 (94.00) LED ACN Vout (+) ACL Vout (-) 2.00 (50.80) 3.3 3.3 5.0 5.0 9.0 9.0 12.0 12.0 15.0 15.0 24.0 24.0 30.0 30.0 36.0 36.0 48.0 48.0 Peak Output (A)(3) Pwr(W) 0.150 (3.80) V1 V1 V1 V1 V1 V1 V1 V1 V1 V1 V1 V1 V1 V1 V1 V1 V1 V1 Max. O/P(A) 1.70 (43.20) Single Output ZPS40-3R3 ZPS60-3R3 ZPS40-5 ZPS60-5 ZPS40-9 ZPS60-9 ZPS40-12 ZPS60-12 ZPS40-15 ZPS60-15 ZPS40-24 ZPS60-24 ZPS40-30 ZPS60-30 ZPS40-36 ZPS60-36 ZPS40-48 ZPS60-48 O/P(V) 1.20 (30.48) Model ZPS Outline Drawing VR For Additional Information, please visit us.tdk-lambda.com/lp/products/zp-series.htm (3) Average not to exceed max power,
ZPS60-3R3 价格&库存
很抱歉,暂时无法提供与“ZPS60-3R3”相匹配的价格&库存,您可以联系我们找货
