• Wide Range AC Input
• Low Profile, Industry Standard Footprint
• Global Safety Agency Compliance
• RoHS Compliant
Key Market Segments & Applications
Video/Audio Routers
Datacom
Point of Sale
Test and Measurement
LED Signs and Lighting
ZPSA20 Series
2" x 3.5" 20W AC-DC
Power Supplies
ZPSA20 Features and Benefits
Features
• Industry Standard Footprint
• Up to 82% efficiency
• Broad Product Range
• Meets EN61000-4 Immunity
Specifications
ITEMS
Input Voltage range
(1)
Inrush Current
Input Current (115/230VAC)
Leakage Current
Temperature Coefficient
Voltage Accuracy
Minimum Load
Load Regulation
Line Regulation
Ripple & Noise
(2)
Short Circuit Protection
Overvoltage Protection
Hold Up Time (Typ)
Operating Temperature
Storage Temperature
Humidity (non condensing)
Cooling
Withstand Voltage
Isolation Resistance
Vibration (non operating)
Shock
Safety Agency Approvals
Conducted & Radiated EMI
Immunity
Weight (Typ)
Size (WxLxH)
Warranty
Notes:
Benefits
• Available to Second Source
• Less System Heating
• Optimization of Power Supply to System
• Greater Reliability
MODEL
A
A
mA
A
mV
V
ms
g
mm
yrs
(1) Safety certified for 47 - 63Hz input only
ZPSA20
85 - 264VAC (47 - 440Hz) or 120 - 370VDC
40A max at 240VAC input, 25°C ambient cold start,
0.4 / 0.25
0.6mA maximum (264VAC, 60Hz)
±0.05%/°C
±1%
None
±1%
±0.5%
1% or 50mV whichever is greater
Continuous - hiccup mode
Typically 110-130% of nominal
12ms at 115VAC input
0 to +70°C with derating
-20 to +85°C
10 - 95% RH
Convection
Input to Ground 1.5kVAC, Input to Output 3kVAC, Output to Ground 500VAC for 1 min.
>100ΩM at 25°C & 70%RH, Output to Ground 500VDC
23.52m/s2 (10 - 55Hz: constant sweep 1 min X, Y, Z for 1 hour)
< 196.1 m/s2 (20G)
IEC/UL/CSA/EN62368-1, 60950-1, CE Mark
EN55022-B, FCC Class B
EN61000-4-2,-3,-4,-6,-8
100g
88.9 X 50.8 X 20.32 (including underside components )
2
(2) Measured with 0.1µF ceramic & 10µF electrolytic at 20MHz BW
ZPSA20 Series
1
M ode l Se l e c tor
Model
ZPSA20-3R3
ZPSA20-5
ZPSA20-9
ZPSA20-12
ZPSA20-15
ZPSA20-24
Notes:
V1
V1
V1
V1
V1
V1
Output
Voltage (V)
3.3
5.0
9.0
12.0
15.0
24
Maximum
Output (A)
4.4
4.4
2.4
1.8
1.4
0.9
6.6
6.6
4.0
2.7
2.1
1.4
(1) Average not to exceed max power,
很抱歉,暂时无法提供与“ZPSA20-15”相匹配的价格&库存,您可以联系我们找货
