ZPSA40-28
ZPSA40-28
    TDK(东电化)
    40W AC-DC电源模块
ZPSA40-28 数据手册
• Wide Range AC Input • Low Profile, Industry Standard Footprint • Global Safety Agency Compliance • RoHS Compliant Key Market Segments & Applications Video/Audio Routers Datacom Point of Sale Test and Measurement LED Signs ZPSA40 & 60 Series 2" x 4" 40W to 60W AC-DC Power Supplies ZPSA40 & 60 Features and Benefits Features • Industry Standard Footprint • Up to 88% efficiency • Broad Product Range • Meets EN61000-4 Immunity Specifications ITEMS Input Voltage range Inrush Current (132/265VAC) Input Current (115/230VAC) Leakage Current Temperature Coefficient Voltage Accuracy Minimum Load Load Regulation Line Regulation Ripple & Noise (1) Short Circuit Protection Overvoltage Protection Hold Up Time (Typ) LED Indicator Operating Temperature Storage Temperature Humidity (non condensing) Cooling Withstand Voltage Isolation Resistance Vibration (non operating) Shock Safety Agency Approvals Conducted & Radiated EMI Immunity Weight (Typ) Size (WxLxH) Warranty MODEL Benefits • Available to Second Source • Less System Heating • Optimization of Power Supply to System • Greater Reliability A A mA A mV V ms - g mm yrs ZPSA40 < 1.2A 90 - 264VAC (47 - 440Hz) or 120 - 370VDC 25 / 50 ZPSA60 < 1.4A 0.8mA max (264VAC, 60Hz) ±0.05%/°C ±1% None ±1% ±0.5% 1% or 50mV whichever is greater Continuous - hiccup mode Typically 110-130% of nominal 8ms at 115VAC input Green LED = OK 0 to +70°C with derating -20 to +85°C 10 - 95% RH Convection Input to Ground 1.5kVAC, Input to Output 3kVAC, Output to Ground 500VAC for 1 min. >100MΩ at 25C & 70%RH, Output to Ground 500VDC 23.52m/s2 (10 - 55Hz: constant sweep 1 min X, Y, Z for 1 hour) < 196.1 m/s2 (20G) IEC/UL/CSA/EN62368-1, 60950-1, CE Mark EN55022-B, FCC Class B EN61000-4-2,-3,-4,-5,-6,-8 130g 101.6 X 50.8 X 27.1 (including underside components ) 2 Notes: (1) Measured with 0.1µF ceramic & 10µF electrolytic at 20MHz BW ZPSA40 & 60 Series 1 M ode l Se l e c tor Model ZPSA40-3R3 ZPSA60-3R3 ZPSA40-5 ZPSA60-5 ZPSA40-9 ZPSA60-9 ZPSA40-12 ZPSA60-12 ZPSA40-15 ZPSA60-15 ZPSA40-24 ZPSA60-24 ZPSA40-28 ZPSA60-28 ZPSA40-30 ZPSA60-30 ZPSA40-36 ZPSA60-36 ZPSA40-48 ZPSA60-48 Notes: V1 V1 V1 V1 V1 V1 V1 V1 V1 V1 V1 V1 V1 V1 V1 V1 V1 V1 V1 V1 Output Voltage (V) 3.3 3.3 5.0 5.0 9.0 9.0 12.0 12.0 15.0 15.0 24.0 24.0 28.0 28.0 30.0 30.0 36.0 36.0 48.0 48.0 Maximum Output (A) 6.0 8.0 6.0 8.0 4.45 6.67 3.34 5.0 2.67 4.0 1.67 2.5 1.43 2.14 1.33 2.0 1.11 1.67 0.834 1.25 (2) Average not to exceed max power,
ZPSA40-28 价格&库存
很抱歉,暂时无法提供与“ZPSA40-28”相匹配的价格&库存,您可以联系我们找货
