• Constant Voltage / Constant Current
• Last Setting Memory
• Digital Meters
• Built-in RS232 & RS485
• Bench or Rack Mount
• Embedded Microprocessor Controller
• Voltage up to 120V, Current up to 132A
ZUP Series
Zero Up Programmable Power Supplies
Specifications
MODELS
ITEMS
Cond.
Load Regulation
CV
Line Regulation
CV
Recovery Time (1)
CV
Temperature Coefficient
CV
Temperature Drift (2)
CV
Up programming response time
CV
Down prog. resp. time (CV)
Full
Zero
Load Regulation
Line Regulation
Prog Voltage resolution
Prog Voltage accuracy
Prog Current resolution
Prog Current accuracy
Overvoltage Shutdown
Thermal Protection
Display - Voltage
Display - Current
Display - Status
Remote On/Off
Output Good
Voltage & Current Programming
Remote Sense
Communication Interface
Series & Parallel Operation
AC Input Voltage range
Inrush Current (100/200VAC) (3)
Hold Up Time (Typ) at 100VAC
Power Factor Correction
Temperature Range
Humidity (non condensing)
Cooling
Withstand Voltage
Isolation Resistance
Vibration & Shock (non-op.)
Safety Agency Approvals
Conducted & Radiated EMI
CC
CC
CC
CC
V
ms
Ω
Warranty
yrs
ZUP6
1ms
250ms
ZUP10
ZUP20
ZUP36
ZUP60
ZUP80
ZUP120
2mV + 0.005% over 0 - 100% load change
1mV + 0.005% over 85 - 132 or 170 - 265VAC constant load
0.5ms
0.2ms
30ppm/°C following 30 minute warm up
0.01% + 2mV change in output
50 - 60ms
80ms
50ms (70ms ZUP60-14)
350ms
400ms
500ms
750ms
800ms
120ms
1000ms
0.01% + 5mA on 200W and 400W models, 0.07% + 10mA on 800W models
0.01% + 2mA on 200W and 400W models, 0.01% + 5mA on 800W models
100ppm/°C from rated current after 30 minute warm up time
0.02% + 5mA, 200W and 400W models, 0.05% + 10mA, 800W models
Better than 0.028% of rated voltage
.02%+5mV. .02%+8mV.
.02%+12mV .02%+20mV
.02%+35mV .02%+50mV .02%+80mV
Better than 0.03% of rated current
0.4% + 40mA
0 - 7.5
0 - 13
0 - 24
0 - 40
0 - 66
0 - 88
0 - 132
Over temperature protected
3 digits (6, 20, 36, 60, 80V models), 3.5 digits (10, 120V models). Accuracy 0.2% ± 2 digits
3 digits, (3.5 digits 132A model). Accuracy 0.5% ± 3 digits
CV / CC, Alarm, Foldback, Local/Remote, On/Off
TTL signal or dry contact relay
Open Collector
By either Voltage (0-4V) or Resistance (0-4k)
Up to 0.5V compensation per output cable
RS232 & RS485 standard
Series: Up to two units; Parallel: Up to five units in master-slave configuration
85-265VAC (47-63Hz)
15/30A, 200W models, 15A, 400W models, 30A, 800W models
Complies with EN61000-3 Class A (0.99 typ)
Operating: 0°C - 50°C; Storage: -20°C to +70°C
Operating: 30°C - 90% RH, Storage 10°C - 95%RH
Internal fan
Input to Ground 2kVAC, Input to Output 3kVAC, Output to Ground 500VAC for 1 min.
>100MΩ at 25°C & 70%RH
Vibration:10-55Hz(1 min.) 2G constant X, Y, Z, when correctly mounted; Shock:
很抱歉,暂时无法提供与“ZUP/NC401”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+565.265681+73.36117
- 5+521.421565+67.67100
