ZUP/NC402
ZUP/NC402
    TDK(东电化)
    ZUP/NC402
ZUP/NC402 数据手册
• Constant Voltage / Constant Current • Last Setting Memory • Digital Meters • Built-in RS232 & RS485 • Bench or Rack Mount • Embedded Microprocessor Controller • Voltage up to 120V, Current up to 132A ZUP Series Zero Up Programmable Power Supplies Specifications MODELS ITEMS Cond. Load Regulation CV Line Regulation CV Recovery Time (1) CV Temperature Coefficient CV Temperature Drift (2) CV Up programming response time CV Down prog. resp. time (CV) Full Down prog. resp. time (CV) Zero Load Regulation Line Regulation Temperature Coefficient Temperature Drift (2) Prog Voltage resolution Prog Voltage accuracy Prog Current resolution Prog Current accuracy Overvoltage Shutdown Thermal Protection Display - Voltage Display - Current Display - Status Remote On/Off Output Good Voltage & Current Programming Remote Sense Communication Interface Series & Parallel Operation AC Input Voltage range Inrush Current (100/200VAC) (3) Hold Up Time (Typ) at 100VAC Power Factor Correction Temperature Range Humidity (non condensing) Cooling Withstand Voltage Isolation Resistance Vibration & Shock (non-op.) Safety Agency Approvals Conducted & Radiated EMI CC CC CC CC V ms Ω - Warranty yrs ZUP6 1ms 250ms ZUP10 ZUP20 ZUP36 ZUP60 ZUP80 ZUP120 2mV + 0.005% over 0 - 100% load change 1mV + 0.005% over 85 - 132 or 170 - 265VAC constant load 0.5ms 0.2ms 30ppm/°C following 30 minute warm up 0.01% + 2mV change in output 50 - 60ms 80ms 50ms (70ms ZUP60-14) 350ms 400ms 500ms 750ms 800ms 120ms 1000ms 0.01% + 5mA on 200W and 400W models, 0.07% + 10mA on 800W models 0.01% + 2mA on 200W and 400W models, 0.01% + 5mA on 800W models 100ppm/°C from rated current after 30 minute warm up time 0.02% + 5mA, 200W and 400W models, 0.05% + 10mA, 800W models Better than 0.028% of rated voltage .02%+5mV. .02%+8mV. .02%+12mV .02%+20mV .02%+35mV .02%+50mV .02%+80mV Better than 0.03% of rated current 0.4% + 40mA 0 - 7.5 0 - 13 0 - 24 0 - 40 0 - 66 0 - 88 0 - 132 Over temperature protected 3 digits (6, 20, 36, 60, 80V models), 3.5 digits (10, 120V models). Accuracy 0.2% ± 2 digits 3 digits, (3.5 digits 132A model). Accuracy 0.5% ± 3 digits CV / CC, Alarm, Foldback, Local/Remote, On/Off TTL signal or dry contact relay Open Collector By either Voltage (0-4V) or Resistance (0-4k) Up to 0.5V compensation per output cable RS232 & RS485 standard Series: Up to two units; Parallel: Up to five units in master-slave configuration 85-265VAC (47-63Hz) 15/30A, 200W models, 15A, 400W models, 30A, 800W models 20 Complies with EN61000-3 Class A (0.99 typ) Operating: 0°C - 50°C; Storage: -20°C to +70°C Operating: 30°C - 90% RH, Storage 10°C - 95%RH Internal fan Input to Ground 2kVAC, Input to Output 3kVAC, Output to Ground 500VAC for 1 min. >100MΩ at 25°C & 70%RH Vibration:10-55Hz(1 min.) 2G constant X, Y, Z, when correctly mounted; Shock:
ZUP/NC402 价格&库存
很抱歉,暂时无法提供与“ZUP/NC402”相匹配的价格&库存,您可以联系我们找货
ZUP/NC402
  • 1+478.470991+62.08122
