ZWS10-30B Series
https://product.tdk.com/en/power/zws-b
www.emea.lambda.tdk.com/zws-b
6.6 to 30W Single Output,
High Reliability Power Supplies
The ZWS-B industrial grade power supplies are used in a wide range of applications where equipment down-time cannot be tolerated during years of
operation. Globally, process control, machinery, semiconductor fabrication and test and measurement equipment manufacturers depend upon the ZWS-B
to provide a reliable source of power. Conservatively rated electrolytic capacitor temperatures offer improved field life-times of up to 10 years. Available in
three power levels, 10W, 15W and 30W, the series provides a choice of 3.3 to 24V outputs. L bracket and cover mechanical configurations are available,
in addition to a double sided board coating option.
Features
Benefits
• 10 Year Electrolytic Capacitor Lifetimes
• Improved Field Life
• Convection Cooled
• Reduced Dirt and Dust Contamination
• Curve B Radiated and Conducted EMI
• Easier System Compliance
• 5 year Warranty
• Low Cost of Ownership
Model Selector
Model
Output
Voltage
(V)
Adjustment
Range
(V)
Maximum
Current
(A)
ZWS10B-3
ZWS15B-3
ZWS30B-3
ZWS10B-5
ZWS15B-5
ZWS30B-5
ZWS10B-12
ZWS15B-12
ZWS30B-12
ZWS10B-15
ZWS15B-15
ZWS30B-15
ZWS10B-24
ZWS15B-24
ZWS30B-24
3.3
3.3
3.3
5
5
5
12
12
12
15
15
15
24
24
24
2.97-3.63
2.97-3.63
2.97-3.63
4.5-5.5
4.5-5.5
4.5-5.5
10.8-13.2
10.8-13.2
10.8-13.2
13.5-16.5
13.5-16.5
13.5-16.5
21.6-26.4
21.6-26.4
21.6-26.4
2
3
6
2
3
6
0.9
1.3
2.5
0.7
1
2
0.5
0.7
1.3
ZWS
30
Nominal power:
10, 15, 30
-B -
Maximum
Maximum
Over Current Over Voltage
Output Power Ripple & Noise Protection
Protection
(W)
(mV)
(A)
(V)
6.6
9.9
19.8
10
15
30
10.8
15.6
30
10.5
15
30
12
16.8
31.2
3
Output voltage:
3 (3.3V), 5, 12, 15, 24
120
120
120
120
120
120
150
150
150
150
150
150
150
150
150
>2.1
>3.15
>6.3
>2.1
>3.15
>6.3
>0.95
>1.37
>2.63
>0.74
>1.05
>2.1
>0.53
>0.74
>1.37
Efficiency
(Typ) (%)
(100/200Vac)
4.0-5.25
4.0-5.25
4.0-5.25
5.75-7.0
5.75-7.0
5.75-7.0
13.8-16.2
13.8-16.2
13.8-16.2
17.3-20.3
17.3-20.3
17.3-20.3
27.6-32.4
27.6-32.4
27.6-32.4
70 / 70
70 / 71
75 / 77
77 / 78
76 / 78
80 / 82
82 / 83
80 / 83
84 / 86
83 / 84
81 / 84
85 / 87
84 / 85
82 / 85
86 / 88
Suffix
Blank
/A
/L
/CO2
Description
Open frame
L-bracket & cover
L-bracket
Double sided PCB coating
Option combinations are available, please contact your local sales office
ZWS10-30B Series
1
Specifications
Model
ZWS10B
ZWS15B
ZWS30B
Input
Input Voltage Range (Operating)(1)
Vac
85 - 265
Nominal Input Voltage Range
Vac
100 - 240 (Note: Safety certified for 90-264Vac only)
Input Frequency
Hz
47 - 63
DC Input Voltage Range
Vdc
120 - 370 (Note: Safety certified for AC input only)
3.3V: 0.18 / 0.11
3.3V: 0.24 / 0.15
3.3V: 0.5 / 0.3
Input Current (100/200Vac)
A
5-24V: 0.25 / 0.13
5-48V: 0.34 / 0.17
5-48V: 0.65 / 0.35
Inrush Current at 200Vac (typ) (Cold Start)
A
30
Leakage Current (230Vac 60Hz)
mA
很抱歉,暂时无法提供与“ZWS150BAF-15/A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1056.531501+136.38940
- 10+1037.4146010+133.92160
