ZWS300BAF Series
300W Single Output, Convection Cooled Power Supplies
Features
u Universal Input (85 - 265VAC)
u Power Factor Corrected
u Convection cooling
u Five year warranty
u Less than 0.5mA earth leakage current
Key Market Segments & Applications
Specifications
Model
Input Voltage
Input Current
Inrush Current (1)(2)
Power Factor
Leakage Current
Temperature Coefficient
Overcurrent Protection (3)
Overvoltage Protection
Hold Up Time (Typ) (1)
Efficiency (1)
Remote On/Off
Operating Temperature
Storage Temperature
Humidity (non condensing)
Cooling
Withstand Voltage
V
A
A
mA
%/°C
V
ms
°C
°C
%RH
Isolation Resistance
Vibration (non operating)
Shock
Safety Agency Certifications
Conducted & Radiated EMI
Immunity
Weight (Typ)
g
Size (WxHxD)
in (mm)
Warranty
yrs
ZWS300BAF
85-265VAC (47-63Hz), 120-370VDC
3.5 / 1.8
15 / 30
0.98 at 100VAC, 0.93 at 200VAC, Meets EN61000-3-2
0.5mA Max. Typically 0.2mA (100VAC), 0.4mA (230VAC)
116% of rated output current
24V: 28.8-33.6V, 36V: 41.4-48.6V, 48V: 55.2-64.8V
18ms at 100VAC input
88 / 91%
Optional, contact factory
-10°C to +70°C, derate linearly to 40% load from 45°C to 70°C
-30 to +75°C
Operating: 30 - 90%RH, Storage: 10 - 90%RH
Convection
Input to Ground 2kVAC (20mA), Input to Output 3kVAC (20mA), Output to Ground 500VAC
(20mA) for 1 min.
>100M at 25°C & 70%RH, Output to Ground 500VDC
10 - 55Hz (1 minute sweep), 19.6m/s2 constant X, Y, Z 1 hour each
< 196.1 m/s2
UL60950-1, CSA60950-1, EN60950-1, EN50178 OV II, CE Mark
EN55011/EN55022-B, FCC Class B, VCCI-B
EN61000-4-2 (lvl2, 3), -3 (lvl 3), -4 (lvl 3), -5 (lvl 3, 4), -6 (lvl 3), -8 (lvl 4), -11; EN61000-6-2
540g
3.31 x 1.65 x 7.09” (84 x 42 x 180)
Five Years
Notes:
(1) 100 / 200VAC Input
(2) 25°C ambient (cold start)
(3) Avoid prolonged operartion in overload
1-800-526-2324 • www.us.tdk-lambda.com/lp/
116
Disclaimer: us.tdk-lambda.com/lp/legal.htm
ZWS300BAF Series
Model Selector
Model
ZWS300BAF24
ZWS300BAF36
ZWS300BAF48
Output
Voltage
24V
36V
48V
Adjustment
Range
21.6 - 27.5V
32.4 - 39.6V
39.5 - 52.8V
Max
Current
12.5A
8.4A
6.3A
Max
Power
300W
302.4W
302.4W
Line Reg
(mV)
96
144
192
Load Reg
(mV)
150
240
240
Ripple &
Noise (mV)
150
250
250
Outline Drawing
Similar Products
ZWS-B, -BAF, -BP
HWS
EFE
CFE400M
10W to 240W Single output
15W to 1800W Single Output, Enclosed
300W to 400W Single Output, Medical & ITE
For Additional Information, please visit
us.tdk-lambda.com/lp/products/zws-series.htm
Options
Suffix
/L
/A
/R
/T
/CO2
Example
Description
JST Connectors
L Bracket
Cover & L Bracket
Remote On/Off
Screw Terminals
PCB Coating
ZWS300BAF24/TL
117
Revision p2: Oct 2012
很抱歉,暂时无法提供与“ZWS300BAF-48/TA”相匹配的价格&库存,您可以联系我们找货
