8
www.vishay.com
Vishay Spectrol
Trimmer Adjustment Tool
FEATURES
• Extended as well as recessed blade for critical
adjustments
• Designed to adjust trimmers of all sizes
• Available with customer trademark
• Material categorization: for definitions of compliance
please see www.vishay.com/doc?99912
DIMENSIONS in millimeters
0.125 Ø
(3.18)
0.010
(0.25)
BLADE 0.015 (0.37 THICK X 0.080
(2.03) WIDE TYP
0.045
(1.14)
0.115 DIA
(2.92)
Vishay Spectrol
0.050
(1.27)
0.165 Ø
(4.19)
± 0.015
1.000
(25.40)
± 0.015
0.500
(12.70)
± 0.100
5.000
(127.00)
0.255 Ø
(6.48)
Note
• Tolerances: unless otherwise noted decimals ± 0.005.
MECHANICAL SPECIFICATIONS
PACKAGING
Material: glass filled nylon body with corrosion resistant
stainless steel blades
Box of 100 pieces
ORDERING INFORMATION
8
T000
MODEL
TRADEMARK OPTION
T000 Vishay Spectrol trademark
Txxx Customer trademark
T005 No trademark
T006 Same as T000 except no clip
T007 Same as T005 except no clip
Txxx Vishay trademark
SAP PART NUMBERING GUIDELINES
A
C
C
T
R
MODEL
I
T
O
STYLE
B
3
PACKAGING
CODE
T
SPECIAL
See the end of this data book for conversion tables
RELATED DOCUMENTS
APPLICATION NOTES
Potentiometers and Trimmers
www.vishay.com/doc?51001
Guidelines for Vishay Sfernice Resistive and Inductive Components
www.vishay.com/doc?52029
Revison: 25-Jan-15
Document Number: 57015
1
For technical questions, contact: sferpottrimmers@vishay.com
THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT
ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
很抱歉,暂时无法提供与“ACCTRITOB308-T005”相匹配的价格&库存,您可以联系我们找货
