SIT9001AI-33-33E3-33.000000Y
    SITIME(赛特时脉)
    SMD5032_4P
    XTAL OSC XO 33.0000MHZ LVCMOS
SIT9001AI-33-33E3-33.000000Y 数据手册
SiT9001 High Performance Spread Spectrum Oscillator The Smart Timing Choice The Smart Timing Choice Features Applications  Frequency range from 1 MHz to 200 MHz  Set-top boxes and LCD displays  Center Spread Modulation: ±0.25%, ±0.5%, ±1%  Scanners, printers and copiers  Down Spread Modulation: -0.5%, -1%, -2%; spread disable option available  Interface controllers and graphics cards  PCI, CPU and memory buses  Power down or output enable option available  Routers and modems  Frequency stability: ±25 ppm, ±50 ppm and ±100 ppm (Spread = OFF)  Operating voltage: 1.8V or 2.5 or 3.3 V; other voltages up to 3.63 V (contact SiTime)  Operating temperature range: Industrial, -40°C to +85°C, Extended Commercial, -20°C to +70°C  Industry-standard packages: 2.5 x 2.0, 3.2 x 2.5, 5.0 x 3.2, 7.0 x 5.0 mm x mm  Pb-free, RoHS and REACH compliant  High drive option: 30pF load (contact factory)  30 ps Ultra-low cycle-to-cycle jitter DC Electrical Characteristics Parameters Symbol Min. Typ. Max. Unit Condition Vdd = 3.3V ±10%, -40°C to 85°C Output Voltage High VOH 90 – – %Vdd IOH = -9 mA Output Voltage Low VOL – – 10 %Vdd IOL = 9 mA Input Voltage High VIH 70 – – %Vdd Pin 1 Input Voltage Low VIL – – 30 %Vdd Operating Current Idd – – 27 mA Output frequency = 30 MHz, 15 pF load – – 34 mA Output frequency = 125 MHz, 15 pF load – 30 50 µA Output is weakly pulled down, ST = GND – – 10 ms Time from minimum power supply voltage to the first cycle (Guaranteed no runt pulses) Standby Current I_std Power Up Time Pin 1 Vdd = 2.5V ±10%, -40°C to 85°C Output Voltage High VOH 90 – – %Vdd IOH = -7 mA Output Voltage Low VOL – – 10 %Vdd IOL = 7 mA Input Voltage High VIH 70 – – %Vdd Pin 1 Input Voltage Low VIL – – 30 %Vdd Operating Current Idd – – 26 mA Output frequency = 30 MHz, 15 pF load – – 31 mA Output frequency = 125 MHz, 15 pF load – 30 50 µA Output is weakly pulled down, ST = GND ms Time from minimum power supply voltage to the first cycle (Guaranteed no runt pulses) Standby Current I_std Power Up Time – – 10 Pin 1 Vdd = 1.8V ±5%, -40°C to 85°C Output Voltage High VOH 90 – – %Vdd IOH = -5 mA Output Voltage Low VOL – – 10 %Vdd IOL = 5mA Input Voltage High VIH 70 – – %Vdd Pin 1 Input Voltage Low VIL – – 30 %Vdd Operating Current Idd – – 26 mA Output frequency = 30 MHz, 15 pF load – – 31 mA Output frequency = 125 MHz, 15 pF load – 30 50 µA Output is weakly pulled down, ST = GND – – 10 ms Time from minimum power supply voltage to the first cycle (Guaranteed no runt pulses) Standby Current Power Up Time SiTime Corporation Rev. 1.2 I_std 990 Almanor Avenue Sunnyvale, CA 94085 Pin 1 (408) 328-4400 www.sitime.com Revised September 17, 2014 SiT9001 High Performance Spread Spectrum Oscillator The Smart Timing Choice The Smart Timing Choice AC Electrical Characteristics Parameters Symbol Min. Typ. Max. Unit Condition Vdd = 3.3V ±10%, -40°C to 85°C Clock Output Frequency Fout Clock Output Duty Cycle 1 – 200 MHz 45 50 55 % 40 – 60 % Output frequency = 75 MHz to 200 MHz tr – 1.0 1.5 ns 15 pF Load, 20% to 80% Vdd tf – 1.0 1.5 ns 15 pF Load, 80% to 20% Vdd Tccj – 22 29 ps Spread = OFF, Output frequency = 133.33 MHz – 22 29 ps Spread = ON, Output frequency = 133.33 MHz 2% down spread DC Clock Output Rise Time Clock Output Fall Time Cycle-to-cycle Jitter Output frequency = 1 MHz to 75 MHz Vdd = 2.5V ±10%, -40°C to 85°C Clock Output Frequency Fout Clock Output Duty Cycle DC 1 – 200 45 50 55 MHz % Output frequency = 1 MHz to 125 MHz 40 – 60 % Output frequency = 125 MHz to 200 MHz Clock Output Rise Time tr – 1.0 1.5 ns 15 pF Load, 20% to 80% Vdd Clock Output Fall Time tf – 1.0 1.5 ns 15 pF Load, 80% to 20% Vdd Tccj – 26 37 ps Spread = OFF, Output frequency = 133.33 MHz – 26 37 ps Spread = ON, Output frequency = 133.33 MHz 2% down spread Cycle-to-cycle Jitter Vdd = 1.8V ±5%, -40°C to 85°C Clock Output Frequency Fout Clock Output Duty Cycle 1 – 200 MHz 45 50 55 % 40 – 60 % Output frequency = 75 MHz to 200 MHz tr – 1.0 1.5 ns 15 pF Load, 20% to 80% Vdd tf – 1.0 1.5 ns 15 pF Load, 80% to 20% Vdd Tccj – 45 57 ps Spread = OFF, Output frequency = 133.33 MHz – 45 57 ps Spread = ON, Output frequency = 133.33 MHz 2% down spread DC Clock Output Rise Time Clock Output Fall Time Cycle-to-cycle Jitter Output frequency = 1 MHz to 75 MHz Pin Configuration Pin Symbol Functionality Standby 1 ST/OE/SD Output Enable SD (Down Spread) only Top View H or Open[1]: specified frequency output L: output is low (weak pull down). Oscillator stops H or Open[1]: specified frequency output L: output is high impedance. Standby/ Output Enable/ Spread Disable. ST/OE/SD 1 4 VDD GND 2 3 SS_OUT H or Open: Spread = ON L: Spread =OFF 2 GND Power Connect to Ground 3 SS_OUT Output 1 to 200 MHz Spread Spectrum Clock Output 4 VDD Connect to 1.8V or 2.5V or 3.3V Note: 1. A pull-up resistor of
- 物料型号:SiT9001 - 频率范围:1 MHz 至 200 MHz - 展频调制:中心展频调制 ±0.25%, ±0.5%, ±1% 和下行展频调制 -0.5%, -1%, -2%,可选择关闭展频 - 电源电压:1.8V 或 2.5V 或 3.3V,其他电压可至 3.63V(需联系 SiTime) - 工作温度范围:工业级 -40°C 至 +85°C,扩展商业级 -20°C 至 +70°C - 封装信息:2.5 x 2.0, 3.2 x 2.5, 5.0 x 3.2, 7.0 x 5.0 mm x mm,无铅、符合RoHS和REACH标准 - 驱动能力选项:30pF 负载(需联系工厂) - 周期到周期抖动:30 皮秒 超低周期到周期抖动
电气特性参数包括: - 输出电压高 (VOH):90% Vdd - 输出电压低 (VOL):最大 10% Vdd - 输入电压高 (VIH):70% Vdd - 输入电压低 (VIL):最小 30% Vdd - 工作电流 (Idd):在 30 MHz 频率和 15 pF 负载下为 27 mA - 待机电流 (I_std):30 至 50 微安 - 上电时间:从最小电源电压到第一个周期的时间,保证无 runt pulses
引脚分配: - 1:ST/OE/SD(待机/输出使能/展频禁用) - 2:GND(接地) - 3:SS OUT(展频时钟输出) - 4:VDD(电源)
绝对最大值和工作条件详细列出了存储温度、电源电压、静电放电、热阻等参数。
SiT9001通过消除石英晶体,提高了对冲击、应变和湿度的免疫力。如需订购样品,请访问 www.sitime.com 并点击“Request Sample”链接。
SIT9001AI-33-33E3-33.000000Y 价格&库存
很抱歉,暂时无法提供与“SIT9001AI-33-33E3-33.000000Y”相匹配的价格&库存,您可以联系我们找货
