SIT9001AC-23-33D4-12.500000Y 数据手册
SiT9001
High Performance Spread Spectrum Oscillator
The Smart Timing Choice
Features
Applications
Frequency range from 1 MHz to 200 MHz
Set-top boxes and LCD displays
Center Spread Modulation: ±0.25%, ±0.5%, ±1%
Scanners, printers and copiers
Down Spread Modulation: -0.5%, -1%, -2%;
spread disable option available
Interface controllers and graphics cards
PCI, CPU and memory buses
Power down or output enable option available
Routers and modems
Frequency stability: ±25 ppm, ±50 ppm and ±100 ppm
(Spread = OFF)
Operating voltage: 1.8V or 2.5 or 3.3 V; other voltages up to 3.63 V
(contact SiTime)
Operating temperature range: Industrial, -40°C to +85°C, Extended
Commercial, -20°C to +70°C
Industry-standard packages: 2.5 x 2.0, 3.2 x 2.5, 5.0 x 3.2,
7.0 x 5.0 mm x mm
Pb-free, RoHS and REACH compliant
High drive option: 30pF load (contact factory)
30 ps Ultra-low cycle-to-cycle jitter
DC Electrical Characteristics
Parameters
Symbol
Min.
Typ.
Max.
Unit
Condition
Vdd = 3.3V ±10%, -40°C to 85°C
Output Voltage High
VOH
90
%Vdd
IOH = -9 mA
Output Voltage Low
VOL
10
%Vdd
IOL = 9 mA
Input Voltage High
VIH
70
%Vdd
Pin 1
Input Voltage Low
VIL
30
%Vdd
Operating Current
Idd
27
mA
Output frequency = 30 MHz, 15 pF load
34
mA
Output frequency = 125 MHz, 15 pF load
30
50
µA
Output is weakly pulled down, ST = GND
10
ms
Time from minimum power supply voltage to the first cycle
(Guaranteed no runt pulses)
Standby Current
I_std
Power Up Time
Pin 1
Vdd = 2.5V ±10%, -40°C to 85°C
Output Voltage High
VOH
90
%Vdd
IOH = -7 mA
Output Voltage Low
VOL
10
%Vdd
IOL = 7 mA
Input Voltage High
VIH
70
%Vdd
Pin 1
Input Voltage Low
VIL
30
%Vdd
Operating Current
Idd
26
mA
31
mA
30
50
µA
ms
Standby Current
I_std
Power Up Time
10
Pin 1
Vdd = 1.8V ±5%, -40°C to 85°C
Output Voltage High
VOH
90
%Vdd
IOH = -5 mA
Output Voltage Low
VOL
10
%Vdd
IOL = 5mA
Input Voltage High
VIH
70
%Vdd
Pin 1
Input Voltage Low
VIL
30
%Vdd
Operating Current
Idd
26
mA
31
mA
30
50
µA
10
ms
Standby Current
Power Up Time
SiTime Corporation
Rev. 1.2
I_std
990 Almanor Avenue
Sunnyvale, CA 94085
Pin 1
(408) 328-4400
www.sitime.com
Revised September 17, 2014
SiT9001
AC Electrical Characteristics
Parameters
Symbol
Min.
Typ.
Max.
Unit
Condition
Clock Output Frequency
Fout
Clock Output Duty Cycle
1
200
MHz
45
50
55
40
60
Output frequency = 75 MHz to 200 MHz
tr
1.0
1.5
ns
15 pF Load, 20% to 80% Vdd
tf
1.0
1.5
ns
15 pF Load, 80% to 20% Vdd
Tccj
22
29
ps
Spread = OFF, Output frequency = 133.33 MHz
22
29
ps
Spread = ON, Output frequency = 133.33 MHz
2% down spread
DC
Clock Output Rise Time
Clock Output Fall Time
Cycle-to-cycle Jitter
Output frequency = 1 MHz to 75 MHz
Fout
DC
1
200
45
50
55
MHz
Output frequency = 1 MHz to 125 MHz
40
60
Output frequency = 125 MHz to 200 MHz
tr
1.0
1.5
ns
tf
1.0
1.5
ns
Tccj
26
37
ps
26
37
ps
2% down spread
Fout
1
200
MHz
45
50
55
40
60
tr
1.0
1.5
ns
tf
1.0
1.5
ns
Tccj
45
57
ps
45
57
ps
2% down spread
DC
Pin Configuration
Pin
Symbol
Functionality
Standby
1
ST/OE/SD
Output Enable
SD (Down Spread)
only
Top View
H or Open[1]: specified frequency output
L: output is low (weak pull down). Oscillator stops
L: output is high impedance.
Standby/ Output Enable/ Spread Disable.
ST/OE/SD
1
4
VDD
GND
2
3
SS_OUT
H or Open: Spread = ON
L: Spread =OFF
2
GND
Power
Connect to Ground
3
SS_OUT
Output
1 to 200 MHz Spread Spectrum Clock Output
4
VDD
Connect to 1.8V or 2.5V or 3.3V
Note:
1. A pull-up resistor of
SIT9001AC-23-33D4-12.500000Y 价格&库存
很抱歉,暂时无法提供与“SIT9001AC-23-33D4-12.500000Y”相匹配的价格&库存,您可以联系我们找货
