NA-10M-6876
NA-10M-6876
    TAITIEN(泰艺)
    XO-5P_25.4X25.4MM_TM
    XTAL OSC OCXO 10.0000MHZ SNWV TH
NA-10M-6876 数据手册
10MHz Low Noise/ Low G-Sensitivity OCXO NA-10M-6800 series Actual Size FEATURE - Low Phase Noise Small Hermetically Sealed Package Tight Frequency Stability Low Power Consumption Fast Warm-up Time Electrical Frequency Tuning Input Reference Voltage Output RoHS-Compliant (lead-free) RoHS Compliant T YPICAL APPLICATION - Instrument Reference Microwave Communication Clock Reference for Microwave Signal Source Test & Measurement Telecom Systems Radar Systems DIMENSION (mm) [ TOP VIEW ] [ BOTTOM VIEW ] [ SIDE VIEW ] Note: not all combination of options are available. Other specifications may be available upon request. www.taitien.com sales@taitien.com.tw XO-0123 Rev(8) 02/2023 131 ELECTRICAL SPECIFICATION Test conditions: VDC = +12 V; VCO = +5 V; at +25 ± 3°C unless otherwise identified OUTPUT (PIN = “R.F. OUTPUT”) Parameter Min. Frequency (Fo) Typ. Max. 10.000000 Unit Test Condition MHz @ +25 ±1 C Initial Accuracy -0.1 +0.1 ppm after turn on power 60 minutes Vco=+5V Waveform Sine wave Level +8 dBm Load 50 Harmonics -30 dBc Spurious -80 dBc Max. Unit ±5, ±10, ±20, ±30, ±50, ±100 ppb -20 C ~ +70 C -40 C ~ +85 C C 10Hz to 1MHz from carrier FREQUENCY STABILIT Y Parameter Min. Ambient Typ. Test Condition referred to 25 C Refer to Table 1 : Ordering Information Aging Daily -0.5 +0.5 ppb Yearly -50 +50 ppb 10 Years -0.3 +0.3 ppm -1 +1 ppb ±5% change ppb root Allan variance for =1 sec Voltage Short term 0.002 after 30 days Load -1 +1 ppb ±5% change Warm-up -50 +50 ppb in 5 minutes @ +25 ±1 C 1 ppb/g G-Sensitivity (each axis) Phase Noise (Max.) referred to 1 hour Option, Refer to Table 1 : Ordering Information Refer to Table 1 : Ordering Information Option A Option B Option C Option D -105 -110 -115 -118 dBc/Hz @ 1Hz -135 -140 -142 -146 dBc/Hz @ 10Hz -155 -155 -155 -160 dBc/Hz @ 100Hz -165 -165 -165 -166 dBc/Hz @ 1KHz -170 -170 -170 -169 dBc/Hz @ 10KHz -170 -170 -170 -170 dBc/Hz @ 100KHz -170 -170 -170 -170 dBc/Hz @ 1MHz ELECTRICAL FREQUENCY ADJUSTMENT (PIN = “VCO INPUT”) Parameter Min. Tuning Range ±0.4* Control Voltage 0.5 Slope Max. Unit ppm +9.5 V +10 % Test Condition Referenced to frequency at nominal Center Voltage Positive Center Voltage Linearity Typ. +5.0 -10 V * Sufficient to adjust the oscillator to nominal frequency for 10 years. Some unit will have ±0.7ppm tuning range. Note: not all combination of options are available. Other specifications may be available upon request. 132 www.taitien.com sales@taitien.com.tw XO-0123 Rev(8) 02/2023 INPUT POWER (PIN = “+VDC”) Parameter Min. Typ. Max. Unit Voltage +11.4 +12 +12.6 V Test Condition Current 2.0 Steady State 400 During Warm-Up @ +25 C, operating -20 C ~ +70 C W 2.3 @ +25 C, operating -40 C ~ +85 C @ +25 C, operating -20 C ~ +70 C mA 500 Refer to Table 1 : Ordering Information @ +25 C, operating -40 C ~ +85 C REFERENCE VOLTAGE (PIN = "REFERENCE VOLTAGE") Parameter Min. Typ. Max. Voltage +9.25 +9.5 +9.75 V 100 Ohm Source Resistance 10 Load Impedance Units Test Condition Kohm ENVIRONMENTAL Parameter Reference Std. Operable Temperature -45 C to +90 C Storage Temperature -50 C to +95 C Test Condition Note 1 Humidity MIL-STD-202, Method 103 Test Condition A 95% RH @ +40 C,non-condensing,240 hours Vibration (non-operating) MIL-STD-202, Method 201 0.06” Total p-p, 10 to 55 Hz Shock (non-operating) MIL-STD-202, Method 213, Test Condition J 30g, 11ms, half-sine Note 1 : Output maintained over this temperature range. Other requirements of this specification may not be met when operating outside the temperature range in 2.1. Table 1 : ORDERING INFORMATION Temp. ( C) Ambient Option ±30 ppb -20 C ~+70oC ±20 ppb ±10 ppb ±5 ppb ±100 ppb -40oC~+85oC ±50 ppb ±30 ppb ±20 ppb Phase Noise Option A B C D g-Sensitivity Option NA-10M-6810 NA-10M-6815 NA-10M-6820 NA-10M-6825 NA-10M-6830 NA-10M-6835 NA-10M-6840 NA-10M-6845 NA-10M-6860 NA-10M-6865 NA-10M-6870 NA-10M-6875 NA-10M-6880 NA-10M-6885 NA-10M-6890 NA-10M-6895 NA-10M-6811 NA-10M-6816 NA-10M-6821 NA-10M-6826 NA-10M-6831 NA-10M-6836 NA-10M-6841 NA-10M-6846 NA-10M-6861 NA-10M-6866 NA-10M-6871 NA-10M-6876 NA-10M-6881 NA-10M-6886 NA-10M-6891 NA-10M-6896 NA-10M-6812 NA-10M-6817 NA-10M-6822 NA-10M-6827 NA-10M-6832 NA-10M-6837 NA-10M-6842 NA-10M-6847 NA-10M-6862 NA-10M-6867 NA-10M-6872 NA-10M-6877 NA-10M-6882 NA-10M-6887 NA-10M-6892 NA-10M-6897 NA-10M-6813 NA-10M-6823 NA-10M-6833 NA-10M-6843 - Y N Y N Y N Y N Y N Y N Y N Y N Note: not all combination of options are available. Other specifications may be available upon request. www.taitien.com sales@taitien.com.tw XO-0123 Rev(8) 02/2023 133 Phase Noise Test Data Note: not all combination of options are available. Other specifications may be available upon request. 134 www.taitien.com sales@taitien.com.tw XO-0123 Rev(8) 02/2023
NA-10M-6876 价格&库存
很抱歉,暂时无法提供与“NA-10M-6876”相匹配的价格&库存,您可以联系我们找货
