SiT5357AE-FQ-30N0-100.000000X
    SITIME(赛特时脉)
    SMD5032_10P
    XTAL OSC TCXO 100.0000MHZ LVCMOS
SiT5357AE-FQ-30N0-100.000000X 数据手册
SiT5357 60 MHz – 220 MHz, ±0.1 to ±0.25 ppm, Stratum 3 Elite Platform Precision Super-TCXO Features Description The SiT5357 is a ±100 ppb precision MEMS Super-TCXO that is fully compliant to Telcordia GR-1244-CORE Stratum 3 oscillator specifications. Engineered for best dynamic performance, the SiT5357 is ideal for high reliability telecom, wireless and networking, industrial, precision GNSS and audio/video applications. Leveraging SiTime’s unique DualMEMS® temperature sensing and TurboCompensation® technologies, the SiT5357 delivers the best dynamic performance for timing stability in the presence of environmental stressors such as air flow, temperature perturbation, vibration, shock, and electromagnetic interference. This device also integrates multiple on-chip regulators to filter power supply noise, eliminating the need for a dedicated external LDO. The SiT5357 offers three device configurations that can be ordered using Ordering Codes for: 1) TCXO with non-pullable output frequency, 2) VCTCXO allowing voltage control of output frequency, 3) DCTCXO enabling digital control of output frequency using an I2C interface, pullable to 5 ppt (parts per trillion) resolution. The SiT5357 can be factory programmed for any combination of frequency, stability, voltage, and pull range. Programmability enables designers to optimize clock configurations while eliminating long lead times and customization costs associated with quartz devices where each frequency is custom built. ◼ ◼ ◼ ◼ ◼ ◼ ◼ ◼ ◼ ◼ ◼ ◼ ◼ ◼ Output 60–189 MHz, and 208–220 MHz, in 1 Hz steps Factory programmable options for short lead time Best dynamic stability under airflow, thermal shock ▪ ±100 ppb stability across temperature ▪ ±1 ppb/C typical frequency slope (ΔF/ΔT) ▪ 1.5e-11 ADEV at 10 second averaging time -40°C to +105°C operating temperature No activity dips or micro jumps Resistant to shock, vibration and board bending On-chip regulators eliminate the need for external LDOs 2.5 V, 2.8 V, 3.0 V and 3.3 V supply voltage LVCMOS output Digital frequency pulling (DCTCXO) via I 2C ▪ Digital control of output frequency and pull range ▪ Up to ±3200 ppm pull range ▪ Frequency pull resolution down to 5 ppt 2.5 V, 2.8 V, 3.0 V and 3.3 V supply voltage LVCMOS output RoHS and REACH compliant Pb-free, Halogen-free, Antimony-free Applications ◼ ◼ ◼ ◼ ◼ ◼ ◼ 4G/5G radio, Small cell IEEE1588 boundary and grandmaster clocks Synchronous Ethernet Optical transport – SONET/SDH, OTN, Stratum 3 DOCSIS 3.x remote PHY Precision GNSS systems Test and measurement Related products for automotive applications. Refer to Manufacturing Guideline for proper reflow profile and PCB cleaning recommendations to ensure best performance. For aerospace and defense applications SiTime recommends using only Endura™ SiT5347. Block Diagram 5.0 mm x 3.2 mm Package Pinout SDA / NC OE / VC / NC 1 9 VDD SCL / NC 2 8 NC NC 3 7 NC GND 4 6 CLK 10 5 A0 / NC Figure 1. SiT5357 Block Diagram Rev 1.07 Figure 2. Pin Assignments (Top view) (Refer to Table 11 for Pin Descriptions) 1 January 2023 www.sitime.com SiT5357 60 MHz – 220 MHz, ±0.1 to ±0.25 ppm, Stratum 3 Elite Platform Precision Super-TCXO Ordering Information The part number guide illustrated below is for reference only, in which boxes identify order codes having more than one option. To customize and build an exact part number, use the SiTime Part Number Generator. To validate the part number, use the SiTime Part Number Decoder. Package Size "F": 5.0 mm x 3.2 mm Pin 1 Function – TCXO mode only Output Waveform "-" : LVCMOS[1] "E": Output Enable "N": No Connect Silicon Revision Letter Part Family TCXO VCTCXO DCTCXO SiT5357AC - FQ - 33 E 0 - 98.123456 T SiT5357AC - FQ - 33 V T - 98.123456 T SiT5357AC - FQG33 J R - 98.123456 T "I": Industrial, -40 to 85°C "C": Extended Commercial, -20 to 70°C "E": Extended Industrial, -40 to 105°C Packaging "T": 12 mm Tape & Reel, 3 ku reel "Y": 12 mm Tape & Reel, 1 ku reel “X”: 12 mm Tape & Reel, 250 u reel (blank): bulk[2] Frequency Stability Frequency "Q": for ±0.1 ppm "P": for ±0.2 ppm "N": for ±0.25 ppm 60.000001 MHz to 189.000000 MHz 208.000000 MHz to 220.000000 MHz Temperature Range Pull Range – DCTCXO mode only I2C Address Mode – DCTCXO mode only "T": ±6.25 ppm "R": ±10 ppm "Q": ±12.5 ppm "M": ±25 ppm "B": ±50 ppm "C": ±80 ppm "E": ±100 ppm "F": ±125 ppm “0”, “1”, “2”, “3”, “4”, “5”, “6”, “7”, “8”, “9”, “A”, “B”, “C”, “D”, “E”, “F”: Order code representing hex value of I2C address. When the I2C address is factory programmed using this code, pin A0 is no connect (NC). “G”: I2C pin addressable mode. Address is set by the logic on A0 pin. "G": "H": "X": "L": "Y": "S": "Z": "U": ±150 ppm ±200 ppm ±400 ppm ±600 ppm ±800 ppm ±1200 ppm ±1600 ppm ±3200 ppm Pin 1 Function – DCTCXO mode only Supply Voltage "I": Output Enable "J": No Connect, software OE control "25": 2.5 V ±10% "28": 2.8 V ±10% "30": 3.0 V ±10% "33": 3.3 V ±10% Notes: 1. “-“ corresponds to the default rise/fall time for LVCMOS output as specified in Table 1 (Electrical Characteristics). Contact SiTime for other rise/fall time options for best EMI or driving multiple loads. For differential outputs, contact SiTime. 2. Bulk is available for sampling only. Rev 1.07 Page 2 of 37 www.sitime.com SiT5357 60 MHz – 220 MHz, ±0.1 to ±0.25 ppm, Stratum 3 Elite Platform Precision Super-TCXO TABLE OF CONTENTS Description ................................................................................................................................................................................... 1 Features....................................................................................................................................................................................... 1 Applications ................................................................................................................................................................................. 1 Block Diagram ............................................................................................................................................................................. 1 5.0 mm x 3.2 mm Package Pinout ............................................................................................................................................... 1 Ordering Information .................................................................................................................................................................... 2 Electrical Characteristics.............................................................................................................................................................. 4 Device Configurations and Pin-outs ............................................................................................................................................. 9 Pin-out Top Views................................................................................................................................................................. 9 Test Circuit Diagrams for LVCMOS Outputs .............................................................................................................................. 10 Waveforms................................................................................................................................................................................. 11 Timing Diagrams ........................................................................................................................................................................ 11 Stability Diagrams ...................................................................................................................................................................... 11 Typical Performance Plots ......................................................................................................................................................... 12 Architecture Overview ................................................................................................................................................................ 15 Frequency Stability ............................................................................................................................................................. 15 Output Frequency and Format ............................................................................................................................................ 15 Output Frequency Tuning ................................................................................................................................................... 15 Pin 1 Configuration (OE, VC, or NC) .................................................................................................................................. 16 Device Configurations ................................................................................................................................................................ 16 TCXO Configuration ........................................................................................................................................................... 16 VCTCXO Configuration ...................................................................................................................................................... 17 DCTCXO Configuration ...................................................................................................................................................... 18 VCTCXO-Specific Design Considerations ................................................................................................................................. 19 Linearity .............................................................................................................................................................................. 19 Control Voltage Bandwidth ................................................................................................................................................. 19 FV Characteristic Slope KV ................................................................................................................................................. 19 Pull Range, Absolute Pull Range ........................................................................................................................................ 20 DCTCXO-Specific Design Considerations ................................................................................................................................. 21 Pull Range and Absolute Pull Range .................................................................................................................................. 21 Output Frequency ............................................................................................................................................................... 22 I2C Control Registers .......................................................................................................................................................... 24 Register Descriptions.......................................................................................................................................................... 24 Register Address: 0x00. Digital Frequency Control Least Significant Word (LSW) ............................................................ 24 Register Address: 0x01. OE Control, Digital Frequency Control Most Significant Word (MSW) ......................................... 25 Register Address: 0x02. DIGITAL PULL RANGE CONTROL[18] ........................................................................................ 26 Serial Interface Configuration Description .......................................................................................................................... 27 Serial Signal Format ........................................................................................................................................................... 27 Parallel Signal Format ........................................................................................................................................................ 28 Parallel Data Format ........................................................................................................................................................... 28 I2C Timing Specification ...................................................................................................................................................... 30 I2C Device Address Modes ................................................................................................................................................. 31 Schematic Example ............................................................................................................................................................ 32 Dimensions and Patterns ........................................................................................................................................................... 33 Layout Guidelines ...................................................................................................................................................................... 34 Manufacturing Guidelines .......................................................................................................................................................... 34 Additional Information ................................................................................................................................................................ 35 Revision History ......................................................................................................................................................................... 36 Rev 1.07 Page 3 of 37 www.sitime.com SiT5357 60 MHz – 220 MHz, ±0.1 to ±0.25 ppm, Stratum 3 Elite Platform Precision Super-TCXO Electrical Characteristics All Min and Max limits are specified over temperature and rated operating voltage with 15 pF output load unless otherwise stated. Typical values are at 25°C and 3.3V Vdd. Table 1. Output Characteristics Parameters Symbol Min. Typ. Max. Unit Condition Frequency Coverage Nominal Output Frequency Range F_nom 60.000001 – 189 MHz 208 – 220 MHz Temperature Range Operating Temperature Range T_use -20 – +70 °C Extended Commercial, ambient temperature -40 – +85 °C Industrial, ambient temperature -40 – +105 °C Extended Industrial, ambient temperature Frequency Stability - Stratum 3+ Grade – ±0.1 ppm Referenced to (max frequency + min frequency)/2 over the rated temperature range, in TCXO, DCTCXO, or VCTCXO (VCTCXO with ±6.25 ppm pull range, Vc=Vdd/2) – – ±0.3 ppm Initial frequency at 25°C at 48 hours after 2 reflows – ±0.7 ±3.6 ppb Vdd ±5% F_load – ±0.2 ±1.5 ppb 15 pF ±10% ΔF/ΔT – ±0.9 ±2 ppb/°C 0.5°C/min temperature ramp rate, -20 to 85°C – ±1 ±3.5 ppb/°C 0.5°C/min temperature ramp rate, -40 to -20°C – ±0.9 ±3.3 ppb/°C 0.5°C/min temperature ramp rate, 85 to 105°C – ±0.008 ±0.02 ppb/s 0.5°C/min temperature ramp rate, -20 to 85°C – ±0.01 ±0.035 ppb/s 0.5°C/min temperature ramp rate, -40 to -20°C – ±0.008 ±0.028 ppb/s 0.5°C/min temperature ramp rate, 85 to 105°C F_24_Hold – – ±0.15 ppm Inclusive of frequency variation due to temperature, ±10% supply variation, ±1.5 pF load variation and 24-hour aging F_hys – ±25 ±42 ppb -40 to 105°C, 0.5°C/min ramp rate, defined as ±ΔF/2 as shown in Figure 13, contact SiTime for lower hysteresis – ±15 ±27 ppb -40 to 85°C, 0.5°C/min ramp rate, defined as ±ΔF/2 as shown in Figure 13, contact SiTime for lower hysteresis – ±10 ±20 ppb -20 to 70°C, 0.5°C/min ramp rate, defined as ±ΔF/2 as shown in Figure 13, contact SiTime for lower hysteresis F_stab – Initial Tolerance F_init Supply Voltage Sensitivity F_Vdd Output Load Sensitivity Frequency vs. Temperature Slope Frequency Stability over Temperature Dynamic Frequency Change during Temperature Ramp 24-hour holdover Stability Hysteresis Over Temperature F_dynamic One-Day Aging F_1d – ±0.5 ±2.0 ppb At 85°C, after 30-days of continued operation. Aging is measured with respect to day 31. One-Year Aging F_1y – ±57 ±230 ppb 5-Year Aging F_5y – ±73 ±320 ppb At 85°C, after 2-days of continued operation. Aging is measured with respect to day 3. 10-Year Aging F_10y – ±80 ±360 ppb 20-Year Aging F_20y – ±87 ±400 ppb Allan deviation ADEV – 1.5e-11 – – 10 second averaging time [3] Frequency Stability - Stratum 3 Grade Initial Tolerance F_init – – ±1 ppm Initial frequency at 25°C at 48 hours after 2 reflows Supply Voltage Sensitivity F_Vdd – ±4.7 ±10.4 ppb Vdd ±5% Output Load Sensitivity F_load – ±1.3 ±4.2 ppb 15 pF ±10% Frequency Stability over Temperature F_stab – – ±0.2 ppm – – ±0.25 ppm Referenced to (max frequency + min frequency)/2 over the rated temperature range. Vc=Vdd/2 for VCTCXO ΔF/ΔT – ±6.4 ±10 ppb/°C Dynamic Frequency Change during Temperature Ramp F_dynamic – ±0.05 ±0.08 ppb/s 0.5°C/min temperature ramp rate 24-hour holdover Stability F_24_Hold – – ±0.28 ppm Inclusive of frequency variation due to temperature, ±10% supply variation, ±1.5 pF load variation and 24-hour aging F_1d – ±3 ±5 ppb At 25°C, after 30-days of continued operation. Aging is measured with respect to day 31 One-Year Aging F_1y – ±1 – ppm 20-Year Aging F_20y – ±2 – ppm At 25°C, after 2-days of continued operation. Aging is measured with respect to day 3 F_tot_20y – – ±4.6 ppm Frequency vs. Temperature Slope One-Day Aging 20-Year Total Stability Rev 1.07 Page 4 of 37 -40 to 105°C Complies with Stratum 3, per GR-1244-CORE. Actual performance is better www.sitime.com SiT5357 60 MHz – 220 MHz, ±0.1 to ±0.25 ppm, Stratum 3 Elite Platform Precision Super-TCXO Table 1. Output Characteristics (continued) Parameters Symbol Min. Typ. Max. Unit Condition LVCMOS Output Characteristics Duty Cycle DC 45 – 55 % 60 to 150 MHz 42 – 55 % 150 to 189 MHz, 200 to 220 MHz 10% - 90% Vdd Rise/Fall Time Tr, Tf 0.8 1.2 1.9 ns Output Voltage High VOH 90% – – Vdd IOH = +3 mA Output Voltage Low VOL – – 10% Vdd IOL = -3 mA Z_out_c – 17 – Ohms Impedance looking into output buffer, Vdd = 3.3 V – 17 – Ohms Impedance looking into output buffer, Vdd = 3.0 V – 18 – Ohms Impedance looking into output buffer, Vdd = 2.8 V – 19 – Ohms Impedance looking into output buffer, Vdd = 2.5 V Output Impedance Start-up Characteristics Start-up Time Output Enable Time Time to Rated Frequency Stability T_start – 2.5 3.5 T_oe – – T_stability – 5 ms Time to first pulse, measured from the time Vdd reaches 90% of its final value. Vdd ramp time = 100 µs from 0 V to Vdd 285 ns See Timing Diagrams section below 45 ms Time to first accurate pulse within rated stability, measured from the time Vdd reaches 90% of its final value. Vdd ramp time = 100 µs Note: 3. Measured 2 hours after startup in a temperature chamber with a constant temperature in still air. Rev 1.07 Page 5 of 37 www.sitime.com SiT5357 60 MHz – 220 MHz, ±0.1 to ±0.25 ppm, Stratum 3 Elite Platform Precision Super-TCXO Table 2. DC Characteristics Parameters Symbol Min. Typ. Max. Unit Condition Supply Voltage Supply Voltage Vdd 2.25 2.5 2.75 V 2.52 2.8 3.08 V 2.7 3.0 3.3 V 2.97 3.3 3.63 V Contact SiTime for 2.25 V to 3.63 V continuous supply voltage support Current Consumption Current Consumption OE Disable Current Idd I_od – 48 62 mA F_nom = 100 MHz, No Load, TCXO and DCTCXO modes – 52 66 mA F_nom = 100 MHz, No Load, VCTCXO mode – 45 52 mA OE = GND, output weakly pulled down. TCXO, DCTCXO – 49 56 mA OE = GND, output weakly pulled down. VCTCXO mode Typ. Max. Unit Table 3. Input Characteristics Parameters Symbol Min. Condition Input Characteristics – OE Pin Input Impedance Z_in 75 – – kΩ Input High Voltage VIH 70% – – Vdd Input Low Voltage VIL – – 30% Vdd Internal pull up to Vdd Frequency Tuning Range – Voltage Control or I2C mode Pull Range Absolute Pull Range[4] PR APR ±6.25 – – ppm VCTCXO mode. Contact SiTime for ±12.5 and ±25 ppm ±6.25 ±10 ±12.5 ±25 ±50 ±80 ±100 ±125 ±150 ±200 ±400 ±600 ±800 ±1200 ±1600 ±3200 – – ppm DCTCXO mode ±5.31 – – ppm ±0.1 ppm F_stab, DCTCXO, VCTCXO for PR = ±6.25 ppm ±3.05 – – ppm ±0.2 ppm F_stab, DCTCXO, VCTCXO for PR = ±6.25 ppm ±3.00 – – ppm ±0.25 ppm F_stab, DCTCXO, VCTCXO for PR = ±6.25 ppm Upper Control Voltage VC_U 90% – – Vdd VCTCXO mode Lower Control Voltage VC_L – – 10% Vdd VCTCXO mode Control Voltage Input Impedance VC_z 8 – – MΩ VCTCXO mode Control Voltage Input Bandwidth VC_bw – 10 – kHz VCTCXO mode; contact SiTime for other bandwidth options 1.0 % Frequency Control Polarity F_pol Pull Range Linearity PR_lin Positive – 0.5 VCTCXO mode VCTCXO mode I2C Interface Characteristics, 200 Ohm, 550 pF (Max I2C Bus Load) Bus Speed F_I2C ≤ 400 kHz Over rated frequency range (F_rated) ≤ 1000 kHz Over operating frequency range (F_oper) Input Voltage Low VIL_I2C – – 30% Vdd DCTCXO mode Input Voltage High VIH_I2C 70% – – Vdd DCTCXO mode Output Voltage Low VOL_I2C – – 0.4 V DCTCXO mode IL 0.5 – 24 µA 0.1 VDD< VOUT < 0.9 VDD. Includes typical leakage current from 200 kΩ pull resister to VDD. DCTCXO mode CIN – – 5 pF DCTCXO mode Input Leakage current Input Capacitance Note: 4. PR = PR – initial tolerance – 20-year aging – frequency stability over temperature. Refer to Table 14 for APR with respect to other pull range options. Rev 1.07 Page 6 of 37 www.sitime.com SiT5357 60 MHz – 220 MHz, ±0.1 to ±0.25 ppm, Stratum 3 Elite Platform Precision Super-TCXO Table 4. Jitter & Phase Noise, -40°C to 85°C Parameters Symbol Min. Typ. Max. Unit Condition Jitter T_phj – 0.31 0.48 ps F_nom = 100 MHz, Integration bandwidth = 12 kHz to 20 MHz RMS Period Jitter T_jitt_per – 1.0 1.8 ps F_nom = 100 MHz, population 10 k Peak Cycle-to-Cycle Jitter T_jitt_cc – 6.6 13.4 ps F_nom = 100 MHz, population 1 k, measured as absolute value 1 Hz offset – -61 -54 dBc/Hz 10 Hz offset – -89 -83 dBc/Hz 100 Hz offset – -107 -103 dBc/Hz 1 kHz offset – -128 -124 dBc/Hz 10 kHz offset – -133 -131 dBc/Hz 100 kHz offset – -133 -130 dBc/Hz 1 MHz offset – -150 -146 dBc/Hz 5 MHz offset – -157 -151 dBc/Hz 10 MHz offset – -157 -152 dBc/Hz 20 MHz offset – -159 -152 dBc/Hz – -91 -86 dBc Min. Typ. Max. Unit RMS Phase Jitter (random) Phase Noise T_spur Spurious F_nom = 100 MHz TCXO and DCTCXO modes, and VCTCXO mode with ±6.25 ppm pull range F_nom = 100 MHz, 1 kHz to 40 MHz offsets Table 5. Jitter & Phase Noise, -40°C to 105°C Parameters Symbol Condition Jitter T_phj – 0.31 0.50 ps F_nom = 100 MHz, Integration bandwidth = 12 kHz to 20 MHz RMS Period Jitter T_jitt_per – 1.0 1.8 ps F_nom = 100 MHz, population 10 k Peak Cycle-to-Cycle Jitter T_jitt_cc – 6.6 13.4 ps F_nom = 100 MHz, population 1 k, measured as absolute value 1 Hz offset – -61 -54 dBc/Hz 10 Hz offset – -89 -83 dBc/Hz 100 Hz offset – -107 -103 dBc/Hz 1 kHz offset – -128 -124 dBc/Hz 10 kHz offset – -133 -131 dBc/Hz 100 kHz offset – -133 -130 dBc/Hz 1 MHz offset – -150 -144 dBc/Hz 5 MHz offset – -157 -150 dBc/Hz 10 MHz offset – -157 -150 dBc/Hz 20 MHz offset – -159 -150 dBc/Hz – -91 -85 dBc RMS Phase Jitter (random) Phase Noise Spurious Rev 1.07 T_spur Page 7 of 37 F_nom = 100 MHz TCXO and DCTCXO modes, and VCTCXO mode with ±6.25 ppm pull range F_nom = 100 MHz, 1 kHz to 40 MHz offsets www.sitime.com SiT5357 60 MHz – 220 MHz, ±0.1 to ±0.25 ppm, Stratum 3 Elite Platform Precision Super-TCXO Table 6. Absolute Maximum Limits Attempted operation outside the absolute maximum ratings may cause permanent damage to the part. Actual performance of the IC is only guaranteed within the operational specifications, not at absolute maximum ratings. Parameter Test Conditions Storage Temperature Continuous Power Supply Voltage Range (Vdd) Human Body Model (HBM) ESD Protection JESD22-A114 Soldering Temperature (follow standard Pb-free soldering guidelines) Value Unit -65 to 125 °C -0.5 to 4 V 2000 V 260 °C 130 °C Input Voltage, Maximum Any input pin Vdd + 0.3 V Input Voltage, Minimum Any input pin -0.3 V Junction Temperature[5] Note: 5. Exceeding this temperature for an extended period of time may damage the device. Table 7. Thermal Considerations[6] Package JA[7] (°C/W) JC, Bottom (°C/W) Ceramic 5.0 mm x 3.2 mm 54 15 Note: 6. Measured in still air. Refer to JESD51 for θJA and θJC definitions. 7. Devices soldered on a JESD51 2s2p compliant board. Table 8. Maximum Operating Junction Temperature[8] Max Operating Temperature (ambient) Maximum Operating Junction Temperature 70°C 80°C 85°C 95°C 105°C 115°C Note: 8. Datasheet specifications are not guaranteed if junction temperature exceeds the maximum operating junction temperature. Table 9. Environmental Compliance Value Unit Mechanical Shock Resistance Parameter MIL-STD-883F, Method 2002 30000 g Mechanical Vibration Resistance MIL-STD-883F, Method 2007 70 g Temperature Cycle JESD22, Method A104 – – Solderability MIL-STD-883F, Method 2003 – – Moisture Sensitivity Level MSL1 @260°C – – Rev 1.07 Test Conditions Page 8 of 37 www.sitime.com SiT5357 60 MHz – 220 MHz, ±0.1 to ±0.25 ppm, Stratum 3 Elite Platform Precision Super-TCXO Device Configurations and Pin-outs Table 10. Device Configurations I2C Programmable Parameters Configuration Pin 1 Pin 5 TCXO OE/NC NC – – VCTCXO VC NC DCTCXO OE/NC A0/NC Frequency Pull Range, Frequency Pull Value, Output Enable control. Pin-out Top Views OE/NC 1 NC 9 VDD VC 1 2 8 NC NC NC 3 7 NC GND 4 6 CLK 10 5 SDA NC NC OE / NC 1 NC SCL 7 NC 6 CLK 9 VDD 2 8 NC 3 GND 4 10 5 9 VDD 2 8 NC NC 3 7 NC GND 4 6 CLK 5 A0 / NC NC Figure 4. VCTCXO NC Figure 3. TCXO 10 Figure 5. DCTCXO Table 11. Pin Description Pin 1 2 Symbol OE/NC [11]/VC SCL / NC [11] I/O Internal Pull-up/Pull Down Resistor OE – Input 100 kΩ Pull-Up No Connect – H or L or Open: No effect on output frequency or other device functions VC – Input – Control Voltage in VCTCXO Mode SCL – Input 200 kΩ Pull-Up No Connect [11] 3 NC 4 GND 5 A0 / NC[11] Function H[9]: specified frequency output L: output is high impedance. Only output driver is disabled. I2C serial clock input. H or L or Open: No effect on output frequency or other device functions No Connect – H or L or Open: No effect on output frequency or other device functions Power – Connect to ground Device I2C address when the address selection mode is via the A0 pin. This pin is NC when the I2C device address is specified in the ordering code. A0 Logic Level I2C Address 0 1100010 1 1101010 A0 – Input 100 kΩ Pull-Up NC – No Connect – H or L or Open: No effect on output frequency or other device functions. 6 CLK Output – LVCMOS 7 NC[11] No Connect – H or L or Open: No effect on output frequency or other device functions 8 NC [11] No Connect – H or L or Open: No effect on output frequency or other device functions 9 VDD Power – Connect to power supply[10] SDA / NC [11] SDA – Input/Output 200 kΩ Pull Up 10 NC – No Connect – I2C Serial Data. H or L or Open: No effect on output frequency or other device functions. Notes: 9. In OE mode for noisy environments, a pull-up resistor of 10 kΩ or less is recommended if pin 1 is not externally driven. If pin 1 needs to be left floating, use the NC option. 10. A 0.1 μF capacitor in parallel with a 10 μF capacitor are required between VDD and GND. The 0.1 μF capacitor is recommended to place close to the device, and place the 10 μF capacitor less than 2 inches away. 11. All NC pins can be left floating and do not need to be soldered down. Rev 1.07 Page 9 of 37 www.sitime.com SiT5357 60 MHz – 220 MHz, ±0.1 to ±0.25 ppm, Stratum 3 Elite Platform Precision Super-TCXO Test Circuit Diagrams for LVCMOS Outputs VDD 9 + 8 7 VDD 6 10 10µF 1 5 2 3 9 + 0.1µF Power Supply - Test Point CLK (including probe and fixture capacitance) 4 8 7 6 2 3 4 Test Point 0.1µF Power Supply 15pF CLK 10 5 10µF - 1 15pF (including probe and fixture capacitance) Control Voltage Vdd OE Function VC Function Figure 7. LVCMOS Test Circuit (VC Function) Figure 6. LVCMOS Test Circuit (OE Function) VDD 9 + 8 7 6 2 3 4 0.1µF Power Supply 10 10µF - Test Point CLK 5 1 15pF (including probe and fixture capacitance) Any state or floating NC Function Figure 8. LVCMOS Test Circuit (NC Function) VDD 9 + 8 7 6 A0/NC 0.1µF Power Supply - Test Point CLK 10 10µF SDA 1 [11] Any state or floating NC Function 5 2 3 4 15pF (including probe and fixture capacitance) SCL Figure 9. LVCMOS Test Circuit (I2C Control), DCTCXO mode for AC and DC Measurements Note: 12. SDA is open-drain and may require pull-up resistor if not present in I2C test setup. Rev 1.07 Page 10 of 37 www.sitime.com SiT5357 60 MHz – 220 MHz, ±0.1 to ±0.25 ppm, Stratum 3 Elite Platform Precision Super-TCXO Waveforms tr tf 90 % Vdd 50 % Vdd 10 % Vdd High Pulse (TH) Low Pulse (TL) Period Figure 10. LVCMOS Waveform Diagram[13] Note: 13. Duty Cycle is computed as Duty Cycle = TH/Period. Timing Diagrams 90% Vdd Vdd Vdd 50% Vdd T_start Vdd Pin Voltage OE Voltage T_oe CLK Output CLK Output HZ HZ T_oe: Time to re-enable the clock output T_start: Time to start from power-off Figure 12. OE Enable Timing (OE Mode Only) Figure 11. Startup Timing Stability Diagrams Figure 13. Illustration of hysteresis, where ΔF is max frequency difference between up and down cycles across temperature Rev 1.07 Page 11 of 37 www.sitime.com SiT5357 60 MHz – 220 MHz, ±0.1 to ±0.25 ppm, Stratum 3 Elite Platform Precision Super-TCXO Typical Performance Plots Breezy Air Still Air Breezy Air Still Air TDEV (s) Allan Deviation 1E-09 1E-10 1E-11 1E-12 0.033 1E-11 1 10 100 1000 0.33 3.3 Still Air ITU-T G.8262, EEC2 Frequency deviation (ppb) MTIE (s) 1E-08 1E-09 1E-10 1E-11 3.3 33 330 2.5 100 1E-07 0.33 3300 0 -50 -100 -40 Figure 16. MTIE (0.1 Hz loop bandwidth, ±0.1 ppm) [14] 2.5 V -20 0 Frequency deviation (ppm) Frequency vs. Temperature Slope (ppb/°C) 3.3 V 0.5 -0.5 -1.5 -2.5 -20 0 20 40 60 80 20 40 Temperature (°C) 60 80 100 Figure 17. Frequency vs Temperature (±0.1 ppm), 105°C 1.5 -40 3.3 50 Observation interval (s) 2.5 330 Figure 15. TDEV (0.1 Hz loop bandwidth, ±0.1 ppm) [14] Figure 14. ADEV (±0.1 ppm) [14] Breezy Air 33 Averaging time (s) Time (s) 10 8 6 4 2 0 -2 -4 -6 -8 -10 0.3 100 Temperature (°C) 0.6 0.9 1.2 1.5 1.8 2.1 2.4 2.7 Control Voltage (V) Figure 18. Freq. vs. Temp. Slope (ΔF/ΔT), ±0.1 ppm device Figure 19. VCTCXO frequency pull characteristic 5 50 4 40 3 30 Frequency drift (ppb) Aging rate (ppb/day) ITU-T G.8262, EEC2 1E-08 1E-10 2 1 0 -1 -2 -3 20 10 0 -10 -20 -30 -40 -4 -50 -5 30 35 40 45 Day 50 55 60 Figure 20. 1-day aging rate after 30 days, 0.1 ppm device Rev 1.07 Page 12 of 37 30 40 50 60 Day Figure 21. Frequency drift after 30 days [15] www.sitime.com SiT5357 60 MHz – 220 MHz, ±0.1 to ±0.25 ppm, Stratum 3 Elite Platform Precision Super-TCXO Typical Performance Plots (continued) 3.3 V Frequency sensitivity (ppb) Frequency sensitivity (ppb) 2.5 V 0.25 0.2 0.15 0.1 0.05 0 -0.05 -0.1 -0.15 -0.2 -0.25 2.5 V 2 1.5 1 0.5 0 -0.5 -1 -1.5 -2 -10 -5 0 5 10 -10 -5 Load variation (%) 2.5 V 55 2.8 V 5 10 3.0 V Figure 23. VDD sensitivity (±0.1 ppm) 3.3 V 2.5 V 2.8 V 3.0 V 3.3 V Current consumption (mA) 58 53 Duty cycle (%) 0 Power supply voltage variation (%) Figure 22. Load sensitivity (±0.1 ppm) 51 49 47 45 56 54 52 50 48 46 44 42 40 70 90 110 130 150 170 190 210 70 90 110 Frequency (MHz) 2.5 V 2.8 V 130 150 170 190 210 Frequency (MHz) Figure 24. Duty Cycle (LVCMOS) 3.0 V Figure 25. IDD DCTCXO (LVCMOS) 3.3 V 2.5 V 2.8 V 3.0 V 3.3 V 60 Current consumption (mA) 58 Current consumption (mA) 3.3 V 56 54 52 50 48 46 44 42 40 58 56 54 52 50 48 46 70 90 110 130 150 170 190 210 70 90 110 Frequency (MHz) Figure 26. IDD TCXO (LVCMOS) 2.5 V 500 2.8 V 130 150 170 190 210 Frequency (MHz) Figure 27. IDD VCTCXO (LVCMOS) 3.0 V 3.3 V 2.5 V 3.3 V Period Jitter (ps MS) Phase Jitter (fs RMS) 1.90 400 300 200 100 1.70 1.50 1.30 1.10 0.90 0.70 0.50 0 70 90 110 130 150 170 190 70 210 Frequency (MHz) 110 130 150 170 190 210 Frequency (MHz) Figure 28. RMS Phase Jitter, DCTCXO, TCXO (LVCMOS) Rev 1.07 90 Page 13 of 37 Figure 29. RMS Period Jitter (LVCMOS) www.sitime.com SiT5357 60 MHz – 220 MHz, ±0.1 to ±0.25 ppm, Stratum 3 Elite Platform Precision Super-TCXO Typical Performance Plots (continued) 2.5 V 2.8 V 3.0 V 3.3 V Frequency deviation (ppm) Phase Jitter (fs RMS) 500 400 300 200 100 0 70 120 170 220 6.25 5 3.75 2.5 1.25 0 -1.25 -2.5 -3.75 -5 -6.25 -6.25 Frequency (MHz) -5 -3.75 -2.5 -1.25 0 1.25 2.5 3.75 5 6.25 DCTCXO pull (ppm) Figure 30. RMS Phase Jitter, VCTCXO (LVCMOS) Figure 31. DCTCXO frequency pull characteristic Note: 14. Measured 24 hours after start up in a temperature chamber with constant temperature. 15. Plotted with respect to the frequency measurement at the end of the 30th day. Rev 1.07 Page 14 of 37 www.sitime.com SiT5357 60 MHz – 220 MHz, ±0.1 to ±0.25 ppm, Stratum 3 Elite Platform Precision Super-TCXO Architecture Overview Functional Overview Based on SiTime’s innovative Elite Platform®, the SiT5357 delivers exceptional dynamic performance, i.e. resilience to environmental stressors such as shock, vibration, and fast temperature transients. Underpinning the Elite platform are SiTime’s unique DualMEMS® temperature sensing architecture and TurboCompensation® technologies. The SiT5357 is designed for maximum flexibility with an array of factory programmable options, enabling system designers to configure this precision device for optimal performance in a given application. DualMEMS is a noiseless temperature compensation scheme. It consists of two MEMS resonators fabricated on the same die substrate. The TempFlat® MEMS resonator is designed with a flat frequency characteristic over temperature whereas the temperature sensing resonator is by design sensitive to temperature changes. The ratio of frequencies between these two resonators provides an accurate reading of the resonator temperature with 20 µK resolution. By placing the two MEMS resonators on the same die, this temperature sensing scheme eliminates any thermal lag and gradients between resonator and temperature sensor, thereby overcoming an inherent weakness of legacy quartz TCXOs. The DualMEMS temperature sensor drives a state-of-theart CMOS temperature compensation circuit. The TurboCompensation design, with >100 Hz compensation bandwidth, achieves a dynamic frequency stability that is far superior to any quartz TCXO. The digital temperature compensation enables additional optimization of frequency stability and frequency slope over temperature within any chosen temperature range for a given system design. The Elite platform also incorporates a high resolution, low noise frequency synthesizer along with the industry standard I2C bus. This unique combination enables system designers to digitally control the output frequency in steps as low as 5 ppt and over a wide range up to ±3200 ppm. For more information regarding the Elite platform and its benefits please visit: ◼ SiTime's breakthroughs section ◼ TechPaper: DualMEMS Temperature Sensing Technology ◼ TechPaper: DualMEMS Resonator TDC Rev 1.07 Frequency Stability The SiT5357 comes in three factory-trimmed stability grades that are optimized for different applications. Both Stratum 3+ and Stratum 3 devices are compliant with Stratum 3 stability of ±4.6 ppm over 20 years. Table 12. Stability Grades vs. Ordering Codes Frequency Slope (ΔF/ΔT) Frequency Stability Over Temperature Ordering Code Stratum 3+ ±3.5 ppb/C ±0.1 ppm Q Stratum 3 ±10 ppb/C ±0.2 ppm P ±0.25 ppm N Grade ◼ ◼ Stratum 3+ grade with ΔF/ΔT of ±3.5 ppb/C is engineered to provide significantly better performance than legacy quartz TCXOs in time and phase synchronization applications such as IEEE1588, small cells, and 5G C-RAN (cloud RAN). Stratum 3 grade is designed to replace classic Stratum 3 TCXOs in applications such as SyncE with better dynamic performance and shorter lead time. Output Frequency and Format The SiT5357 can be factory programmed for an output frequency without sacrificing lead time or incurring an upfront customization cost typically associated with customfrequency quartz TCXOs. Output Frequency Tuning In addition to the non-pullable TCXO, the SiT5357 can also support output frequency tuning through either an analog control voltage (VCTCXO), or I2C interface (DCTCXO). The I2C interface enables 16 factory programmed pull-range options from ±6.25 ppm to ±3200 ppm. The pull range can also be reprogrammed via I2C to any supported pull-range value. Refer to Device Configuration section for details. Page 15 of 37 www.sitime.com SiT5357 60 MHz – 220 MHz, ±0.1 to ±0.25 ppm, Stratum 3 Elite Platform Precision Super-TCXO Pin 1 Configuration (OE, VC, or NC) Device Configurations Pin 1 of the SiT5357 can be factory programmed to support three modes: Output Enable (OE), Voltage Control (VC), or No Connect (NC). The SiT5357 supports 3 device configurations – TCXO, VCTCXO, and DCTCXO. The TCXO and VCTCXO options are directly compatible with the quartz TCXO and VCTCXO. The DCTCXO configuration provides performance enhancement by eliminating VCTCXO’s sensitivity to control voltage noise with an I 2C digital interface for frequency tuning. Table 13. Pin Configuration Options Pin 1 Configuration Operating Mode Output OE TCXO/DCTCXO Active or High-Z NC TCXO/DCTCXO Active VC VCTCXO Active When pin 1 is configured as OE pin, the device output is guaranteed to operate in one of the following two states: ◼ Clock output with the frequency specified in the part number when Pin 1 is pulled to logic high ◼ Hi-Z mode with weak pull down when pin 1 is pulled to logic low. When pin 1 is configured as NC, the device is guaranteed to output the frequency specified in the part number at all times, regardless of the logic level on pin 1. In the VCTCXO configuration, the user can fine-tune the output frequency from the nominal frequency specified in the part number by varying the pin 1 voltage. The guaranteed allowable variation of the output frequency is specified as pull range. A VCTCXO part number must contain a valid pull-range ordering code. Figure 32. Block Diagram – TCXO TCXO Configuration The TCXO generates a fixed frequency output, as shown in Figure 32. The frequency is specified by the user in the frequency field of the device ordering code and then factory programmed. Other factory programmable options include supply voltage, and pin 1 functionality (OE or NC). Refer to the Ordering Information section at the end of the datasheet for a list of all ordering options. Rev 1.07 Page 16 of 37 www.sitime.com SiT5357 60 MHz – 220 MHz, ±0.1 to ±0.25 ppm, Stratum 3 Elite Platform Precision Super-TCXO VCTCXO Configuration A VCTCXO, shown in Figure 33, is a frequency control device whose output frequency is an approximately linear function of control voltage applied to the voltage control pin. VCTCXOs have a number of use cases including the VCO portion of a jitter attenuation/jitter cleaner PLL Loop. Note that the output frequency of the VCTCXO is proportional to the analog control voltage applied to pin 1. Because this control signal is analog and directly controls the output frequency, care must be taken to minimize noise on this pin. The SiT5357 achieves a 10x better pull range linearity of 250 nsec FM+ (1 MHz) >0 nsec FM (400 KHz) >0 nsec SM (100 KHz) >0 nsec FM+ > 450 nsec FM (400 KHz) > 900 nsec SM (100 KHz) > 3450 nsec tHOLD tVD:AWK tVD:DAT Rev 1.07 NA (s-awk + s-data)/(m-awk/s-data) Page 30 of 37 www.sitime.com SiT5357 60 MHz – 220 MHz, ±0.1 to ±0.25 ppm, Stratum 3 Elite Platform Precision Super-TCXO Table 21. Pin Selectable I2C Address Control[20] I2C Device Address Modes A0 Pin 5 There are two I2C address modes: I2C Address 0 1100010 1 1101010 Notes: 20. Table 21 is only valid for the DCTCXO device option which supports I2C control and A0 Device Address Control Pin. Table 20. Factory Programmed I2C Address Control[19] I2C Address Ordering Code Device I2C Address 0 1100000 1 1100001 2 1100010 3 1100011 4 1100100 5 1100101 6 1100110 7 1100111 8 1101000 9 1101001 A 1101010 B 1101011 C 1101100 D 1101101 E 1101110 F 1101111 Notes: 19. Table 20 is only valid for the DCTCXO device option which supports I2C Control. Rev 1.07 Page 31 of 37 www.sitime.com SiT5357 60 MHz – 220 MHz, ±0.1 to ±0.25 ppm, Stratum 3 Elite Platform Precision Super-TCXO Schematic Example Figure 46. DCTCXO schematic example Rev 1.07 Page 32 of 37 www.sitime.com SiT5357 60 MHz – 220 MHz, ±0.1 to ±0.25 ppm, Stratum 3 Elite Platform Precision Super-TCXO Dimensions and Patterns Package Size – Dimensions (Unit: mm) Recommended Land Pattern (Unit: mm) Rev 1.07 Page 33 of 37 www.sitime.com SiT5357 60 MHz – 220 MHz, ±0.1 to ±0.25 ppm, Stratum 3 Elite Platform Precision Super-TCXO Layout Guidelines ◼ ◼ ◼ Manufacturing Guidelines The SiT5357 uses internal regulators to minimize the impact of power supply noise. For further reduction of noise, it is essential to use two bypass capacitors (0.1 μF and 10 μF). Place the 0.1 μF capacitor as close to the VDD pin as possible, typically within 1 mm to 2 mm. Place the 10 μF capacitor within 2 inches of the device VDD and VSS pins. It is also recommended to connect all NC pins to the ground plane and place multiple vias under the GND pin for maximum heat dissipation. The SiT5357 Super-TCXOs are precision timing devices. Proper PCB solder and cleaning processes must be followed to ensure best performance and long-term reliability. ◼ No Ultrasonic or Megasonic Cleaning: Do not subject the SiT5357 to an ultrasonic or megasonic cleaning environment. Otherwise, permanent damage or long-term reliability issues to the device may result. ◼ No external cover. Unlike legacy quartz TCXOs, the SiT5357 is engineered to operate reliably, without performance degradation in the presence of ambient disturbers such as airflow and sudden temperature changes. Therefore, the use of an external cover typically required by quartz TCXOs is not needed. ◼ Reflow profile: For mounting these devices to the PCB, IPC/JEDEC J-STD-020 compliant reflow profile must be used. Device performance is not guaranteed if soldered manually or with a non-compliant reflow profile. ◼ PCB cleaning: After the surface mount (SMT)/reflow process, solder flux residues may be present on the PCB and around the pads of the device. Excess residual solder flux may lead to problems such as pad corrosion, elevated leakage currents, increased frequency aging, or other performance degradation. For optimal device performance and long-term reliability, thorough cleaning to remove all the residual flux and drying of the PCB is required as shortly after the reflow process as possible. Water soluble flux is recommended. In addition, it is highly recommended to avoid the use of any “no clean” flux. However, if the reflow process necessitates the use of “no clean” flux, then utmost care should be taken to remove all residual flux between SiTime device and the PCB. Note that ultrasonic PCB cleaning should not be used with SiTime oscillators. ◼ For additional manufacturing guidelines and marking/ tape-reel instructions, refer to SiTime Manufacturing Notes. For additional layout recommendations, refer to the Best Design Layout Practices. Rev 1.07 Page 34 of 37 www.sitime.com SiT5357 60 MHz – 220 MHz, ±0.1 to ±0.25 ppm, Stratum 3 Elite Platform Precision Super-TCXO Additional Information Table 22. Additional Information Document Description Download Link ECCN #: EAR99 Five character designation used on the commerce Control List (CCL) to identify dual use items for export control purposes. — HTS Classification Code: 8542.39.0000 A Harmonized Tariff Schedule (HTS) code developed by the World Customs Organization to classify/define internationally traded goods. — Evaluation Boards SiT6722EB Evaluation Board User Manual https://www.sitime.com/support/user-guides Demo Board SiT6702DB Demo Board User Manual https://www.sitime.com/support/user-guides Time Machine II MEMS oscillator programmer http://www.sitime.com/support/time-machine-oscillator-programmer Time Master Web-based Configurator Web tool to establish proper programming https://www.sitime.com/time-master-web-based-configurator Manufacturing Notes Tape & Reel dimension, reflow profile and other manufacturing related info https://www.sitime.com/support/resource-library/manufacturingnotes-sitime-products Qualification Reports RoHS report, reliability reports, composition reports http://www.sitime.com/support/quality-and-reliability Performance Reports Additional performance data such as phase noise, current consumption and jitter for selected frequencies http://www.sitime.com/support/performance-measurement-report Termination Techniques Termination design recommendations http://www.sitime.com/support/application-notes Layout Techniques Layout recommendations http://www.sitime.com/support/application-notes Rev 1.07 Page 35 of 37 www.sitime.com SiT5357 60 MHz – 220 MHz, ±0.1 to ±0.25 ppm, Stratum 3 Elite Platform Precision Super-TCXO Revision History Table 23. Revision History Version Release Date Change Summary 0.1 10-May-2016 First release, advanced information 0.15 4-Aug-2016 Replaced QFN package with SOIC-8 package Added 10 µF bypass cap requirement Updated test circuits to reflect both new bypass cap requirement and SOIC-8 package Update Table 1 (Electrical Characteristics) 0.16 12-Sep-2016 Updated test circuit diagrams 0.2 21-Sep-2016 Revised Table 1 (Electrical Characteristics) 0.51 20-Aug-2017 Changed to preliminary Added DCTCXO mode Added I2C information Added 5.0 mm x 3.2 mm package information Updated test circuits Updated Table 1 (Electrical Characteristics) Updated part ordering info Misc. corrections 0.52 27-Nov-2017 Updated the Thermal Characteristics table Added more on Manufacturing Guideline section 0.55 5-Feb-2018 Added View labels to Package Drawings Updated links and notes 0.60 1-Mar-2018 1.0 26-Jun-2018 1.01 1.02 1.03 3-Jul-2018 4-Jul-2018 2-Aug-2018 1.04 4-Dec-2018 1.05 28-Mar-2020 1.06 1.07 10-May-2020 1-Jan-2023 Added 105°C support, updated Ordering Information Updated Electrical Characteristics tables. Added Typical Performance Plots. Improved readability. Fixed bad hyperlinks. Updated I2C specifications, Table 3 (Input Characteristics). Updated Mechanical Shock Resistance, Table 9 (Environmental Compliance). Various formatting updates. Updated package outline drawing. Revised phase noise specifications. Updated conditions for one day and one year aging specs. Formatting updates Corrected typos in package drawing dimensions Added nominal value for LVCMOS output impedance Increased Mechanical Shock Resistance to 30000g Added “X” order code for 250u Tape and Reel Improved 24 hour holdover stability specification for 0.2 and 0.25 ppm parts Improved I2C bus frequency specification Updated Manufacturing Guidelines to recommend water soluble flux Corrected typos for write/read I2C polarity Clarified PCB cleaning instructions Added link for SiT6702DB Added ECCN and HTS codes Reduced Initial Tolerance for Stratum 3+ grade Modified supply and load sensitivities Updated typical performance plot for load sensitivity Formatting updates Added note to Theta Ja Changed conditions for 24-hour holdover stability spec Added Allan deviation spec and updated typical plot Updated DCTCXO Delay and Settling Time table Removed frequency support from 200 to 208 MHz Added 5 and 10 year aging specs for Stratum 3+ grade Added max and min aging specs for 1 and 20 years for Stratum 3+ grade, and changed ambient temperature to 85°C Slightly reduced minimum pull range specs and updated Tables 14 and 15 for Stratum 3+ grade Added max and min hysteresis specs for Stratum 3+ grade, clarified conditions with related figure Clarified 24-hour holdover stability spec condition Added max and min input voltage to Absolute Maximum Limits table Updated output impedance typical spec Updated ΔF/ΔT and F_dynamic min and max specs Clarified Initial Tolerance specification condition Relabeled “First Pulse Accuracy” parameter to “Time to Rated Frequency Stability” for clarity Revised Parallel Data Format section description and figures Updated company disclaimer, links, references and icons Rev 1.07 Page 36 of 37 www.sitime.com SiT5357 60 MHz – 220 MHz, ±0.1 to ±0.25 ppm, Stratum 3 Elite Platform Precision Super-TCXO SiTime Corporation, 5451 Patrick Henry Drive, Santa Clara, CA 95054, USA | Phone: +1-408-328-4400 | Fax: +1-408-328-4439 © SiTime Corporation 2016-2023. The information contained herein is subject to change at any time without notice. SiTime assumes no responsibility or liabi lity for any loss, damage or defect of a Product which is caused in whole or in part by (i) use of any circuitry other than circuitry embodied in a SiTime product, (ii) misuse or abuse including static discharge, neglect or accident, (iii) unauthorized modification or repairs which have been soldered or altered during assembly and are not capable of being tested by SiTime under its normal test conditions, or (iv) improper installation, storage, handling, warehousing or transportation, or (v) being subjected to unusual physical, thermal, or electrical stress. Disclaimer: SiTime makes no warranty of any kind, express or implied, with regard to this material, and specifically disclaims any and all express or implied warranties, either in fact or by operation of law, statutory or otherwise, including the implied warranties of merchantability and fitness for use or a particular purpose, and any implied warranty arising from course of dealing or usage of trade, as well as any common-law duties relating to accuracy or lack of negligence, with respect to this material, any SiTime product and any product documentation. This product is not suitable or intended to be used in a life support application or component, to operate nuclear facilities, in military or aerospace applications, or in other mission critical applications where human life may be involved or at stake. All sales are made conditioned upon compliance with the critical uses policy set forth below. CRITICAL USE EXCLUSION POLICY BUYER AGREES NOT TO USE SITIME'S PRODUCTS FOR ANY APPLICATION OR IN ANY COMPONENTS: USED IN LIFE SUPPORT DEVICES, TO OPERATE NUCLEAR FACILITIES, FOR MILITARY OR AEROSPACE USE, OR IN OTHER MISSION CRITICAL APPLICATIONS OR COMPONENTS WHERE HUMAN LIFE OR PROP ERTY MAY BE AT STAKE. For aerospace and defense applications, SiTime recommends using only Endura™ ruggedized products. SiTime owns all rights, title and interest to the intellectual property related to SiTime's products, including any software, firmware, copyright, patent, or trademark. The sale of SiTime products does not convey or imply any license under patent or other rights. SiTime retains the copyright and trademark rights in all documents, catalogs and plans supplied pursuant to or ancillary to the sale of products or services by SiTime. Unless otherwise agreed to in writing by SiTime, any reproduction, modification, translation, compilation, or representation of this material shall be strictly prohibited. Rev 1.07 Page 37 of 37 www.sitime.com
文档中提到的物料型号是STM32F103C8T6,这是一款基于ARM Cortex-M3内核的32位微控制器。
器件简介指出它具有多种通信接口和外设,适用于多种应用场景。
引脚分配表详细列出了各引脚的功能,例如VBAT是电池电源,VDDA是模拟电源,PA0是ADC输入等。
参数特性包括工作电压、工作温度范围、存储器大小等。
功能详解部分介绍了其丰富的外设和接口,如USB、CAN、I2C等。
应用信息说明了该器件适用于工业控制、医疗设备、智能家居等领域。
封装信息指出采用的是LQFP48封装,具有48个引脚。
SiT5357AE-FQ-30N0-100.000000X 价格&库存
很抱歉,暂时无法提供与“SiT5357AE-FQ-30N0-100.000000X”相匹配的价格&库存,您可以联系我们找货
