SIT2021AM-S2-33N-127.872000
    SITIME(赛特时脉)
    SOT-23-5
    XTAL OSC XO 127.8720MHZ LVCMOS
SIT2021AM-S2-33N-127.872000 数据手册
SiT2021B High Frequency, -55°C to +125°C, SOT23 Oscillator Features ◼ ◼ ◼ ◼ ◼ ◼ ◼ ◼ Applications Frequencies between 119.342001 MHz to 137 MHz accurate to 6 decimal places Operating temperature from -55°C to 125°C Supply voltage of 1.8 V or 2.5 V to 3.3 V Excellent total frequency stability as low as ±20 ppm Low power consumption of 4.9 mA typical at 1.8 V LVCMOS/LVTTL compatible output 5-pin SOT23-5 package: 2.9 mm x 2.8 mm RoHS and REACH compliant, Pb-free, Halogen-free and Antimony-free ◼ Ruggedized equipment in harsh operating environment Related products for automotive applications. For aerospace and defense applications SiTime recommends using only Endura™ SiT2045. Electrical Specifications All Min and Max limits are specified over temperature and rated operating voltage with 15 pF output load unless otherwise stated. Typical values are at 25°C and nominal supply voltage. Table 1. Electrical Characteristics Parameters Output Frequency Range Frequency Stability Operating Temperature Range Supply Voltage Current Consumption OE Disable Current Standby Current Duty Cycle Rise/Fall Time Symbol f F_stab Min. 119.342001 Typ. Max. Unit Frequency Range – 137 MHz Frequency Stability and Aging – +20 ppm -20 -25 – +25 ppm -30 – +30 ppm -50 – +50 ppm Refer to Table 14 for the exact list of supported frequencies Inclusive of Initial tolerance at 25°C, 1st year aging at 25°C, and variations over operating temperature, rated power supply voltage and load (15 pF ± 10%). T_use -55 Operating Temperature Range – +125 °C Vdd 1.62 Supply Voltage and Current Consumption 1.8 1.98 V Idd I_od I_std 2.25 2.5 2.75 V 2.52 2.8 3.08 V 2.7 3.0 3.3 V 2.97 3.3 3.63 V 2.25 – 3.63 V – 6.2 8 mA No load condition, f = 125 MHz, Vdd = 2.8 V, 3.0 V or 3.3 V – 5.4 7 mA No load condition, f = 125 MHz, Vdd = 2.5 V – 4.9 6 mA No load condition, f = 125 MHz, Vdd = 1.8 V – – 4.7 mA Vdd = 2.5 V to 3.3 V, OE = Low, Output in high Z state. – – 4.5 mA Vdd = 1.8 V, OE = Low, Output in high Z state. – 2.6 8.5 A – 1.4 5.5 A Vdd = 2.5 V, ST = Low, Output is weakly pulled down – 0.6 4.0 A Vdd = 1.8 V, ST = Low, Output is weakly pulled down LVCMOS Output Characteristics – 55 % Vdd = 2.8 V to 3.3 V, ST = Low, Output is weakly pulled down DC 45 Tr, Tf – 1.0 2.0 ns Vdd = 2.5 V, 2.8 V, 3.0 V or 3.3 V, 20% - 80% – 1.3 2.5 ns Vdd = 1.8 V, 20% - 80% – 1.0 3 ns Vdd = 2.25 V - 3.63 V, 20% - 80% IOH = -4 mA (Vdd = 3.0 V or 3.3 V) IOH = -3 mA (Vdd = 2.8 V or 2.5 V) IOH = -2 mA (Vdd = 1.8 V) IOL = 4 mA (Vdd = 3.0 V or 3.3 V) IOL = 3 mA (Vdd = 2.8 V or 2.5 V) IOL = 2 mA (Vdd = 1.8 V) Output High Voltage VOH 90% – – Vdd Output Low Voltage VOL – – 10% Vdd Rev 1.03 Condition 1 January 2023 All Vdds www.sitime.com SiT2021B High Frequency, -55°C to +125°C, SOT23 Oscillator Table 1. Electrical Characteristics (continued) Parameters Symbol Min. Typ. Max. Unit Condition Input Characteristics Input High Voltage VIH 70% – – Vdd Pin 1, OE or ST Input Low Voltage VIL – – 30% Vdd Pin 1, OE or ST Input Pull-up Impedance Z_in 50 87 150 k Pin 1, OE logic high or logic low, or ST logic high 2 – – M Pin 1, ST logic low Startup and Resume Timing Startup Time Enable/Disable Time Resume Time T_start – – 5 ms T_oe – – 130 ns Measured from the time Vdd reaches its rated minimum value f = 119.342001 MHz. For other frequencies, T_oe = 100 ns + 3 * clock periods T_resume – – 5 ms Measured from the time ST pin crosses 50% threshold Jitter RMS Period Jitter T_jitt Peak-to-peak Period Jitter T_pk RMS Phase Jitter (random) T_phj – 1.6 2.5 ps f = 125 MHz, Vdd = 2.5 V, 2.8 V, 3.0 V or 3.3 V – 1.8 3 ps f = 125 MHz, Vdd = 1.8 V – 12 20 ps f = 125 MHz, Vdd = 2.5 V, 2.8 V, 3.0 V or 3.3 V – 14 25 ps f = 125 MHz, Vdd = 1.8V – 0.5 0.8 ps f = 125 MHz, Integration bandwidth = 900 kHz to 7.5 MHz – 1.3 2 ps f = 125 MHz, Integration bandwidth = 12 kHz to 20 MHz Table 2. Pin Description Pin Symbol 1 GND Power 2 NC No Connect Top View Functionality Output Enable OE / / NC NC GND Electrical ground No connect H[1]: specified frequency output L: output is high impedance. Only output driver is disabled. H or Open[1]: specified frequency output 3 OE/ ST ̅ ̅ ̅ /NC Standby No Connect L: output is low (weak pull down). Device goes to sleep mode. Supply current reduces to I_std. Any voltage between 0 and Vdd or Open[1]: Specified frequency output. Pin 3 has no function. 4 VDD Power Power supply voltage[2] 5 OUT Output Oscillator output VDD OUT Figure 1. Pin Assignments Notes: 1. In OE or ST mode, a pull-up resistor of 10 kΩ or less is recommended if pin 3 is not externally driven. If pin 3 needs to be left floating, use the NC option. 2. A capacitor of value 0.1 µF or higher between Vdd and GND is required. Rev 1.03 Page 2 of 16 www.sitime.com SiT2021B High Frequency, -55°C to +125°C, SOT23 Oscillator Table 3. Absolute Maximum Limits Attempted operation outside the absolute maximum ratings may cause permanent damage to the part. Actual performance of the IC is only guaranteed within the operational specifications, not at absolute maximum ratings. Min. Max. Unit Storage Temperature Parameter -65 150 °C Vdd -0.5 4 V Electrostatic Discharge – 2000 V Soldering Temperature (follow standard Pb free soldering guidelines) – 260 °C – 150 °C Junction Temperature [3] Note: 3. Exceeding this temperature for extended period of time may damage the device. Table 4. Thermal Consideration[4] Package JA, 4 Layer Board JC, Bottom (°C/W) (°C/W) SOT23-5 421 175 Note: 4. Refer to JESD51 for JA and JC definitions, and reference layout used to determine the JA and JC values in the above table. Table 5. Maximum Operating Junction Temperature[5] Max Operating Temperature (ambient) Maximum Operating Junction Temperature 125°C 135°C Note: 5. Datasheet specifications are not guaranteed if junction temperature exceeds the maximum operating junction temperature. Table 6. Environmental Compliance Parameter Condition/Test Method Mechanical Shock MIL-STD-883F, Method 2002 Mechanical Vibration MIL-STD-883F, Method 2007 Temperature Cycle JESD22, Method A104 Solderability MIL-STD-883F, Method 2003 Moisture Sensitivity Level MSL1 @ 260°C Rev 1.03 Page 3 of 16 www.sitime.com SiT2021B High Frequency, -55°C to +125°C, SOT23 Oscillator Test Circuit and Waveform[6] Vout Test Point Vdd tr 15 pF (including probe and fixture capacitance) 80% Vdd 4 5 1 2 tf 0.1µF 3 50% Power Supply 20% Vdd High Pulse (TH) Period Vdd 1kΩ Low Pulse (TL) OE/ST Function Figure 2. Test Circuit Figure 3. Output Waveform Note: 6. Duty Cycle is computed as Duty Cycle = TH/Period. Timing Diagrams 90% Vdd Vdd Vdd 50% Vdd [7] T_start Pin 4 Voltage No Glitch during start up T_resume ST Voltage CLK Output CLK Output HZ HZ T_start: Time to start from power-off T_resume: Time to resume from ST Figure 4. Startup Timing (OE/ ST Mode) Figure 6. Standby Resume Timing ( ST Mode Only) Vdd Vdd 50% Vdd OE Voltage 50% Vdd T_oe OE Voltage T_oe CLK Output CLK Output HZ HZ T_oe: Time to re-enable the clock output T_oe: Time to put the output in High Z mode Figure 7. OE Disable Timing (OE Mode Only) Figure 5. OE Enable Timing (OE Mode Only) Note: 7. SiT2021 has “no runt” pulses and “no glitch” output during startup or resume. Rev 1.03 Page 4 of 16 www.sitime.com SiT2021B High Frequency, -55°C to +125°C, SOT23 Oscillator Performance Plots[8] 6.5 6.3 Frequency (ppm) 6.1 Idd (mA) 5.9 5.7 5.5 5.3 5.1 4.9 4.7 4.5 115 117 119 121 123 125 127 129 131 133 135 137 Temperature (°C) Figure 8. Idd vs Frequency Figure 9. Frequency vs Temperature 55 54 Duty cycle (%) RMS period jitter (ps) 53 52 51 50 49 48 47 46 45 115 Figure 10. RMS Period Jitter vs Frequency 117 119 121 123 125 127 129 131 133 135 137 Figure 11. Duty Cycle vs Frequency 2.5 2.0 1.5 1.0 0.5 0.0 -55 -45 -35 -25 -15 Figure 12. 20%-80% Rise Time vs Temperature (125 MHz Output) Rev 1.03 -5 5 15 25 35 45 55 65 75 85 95 105 115 125 Figure 13. 20%-80% Fall Time vs Temperature (125 MHz Output) Page 5 of 16 www.sitime.com SiT2021B High Frequency, -55°C to +125°C, SOT23 Oscillator Performance Plots[8] 2.8 V 3.0 V 1.8 V 3.3 V 2.5 V 2.8 V 3.0 V 3.3 V IPJ (ps) 2.5 V IPJ (ps) 1.8 V Frequency (MHz) Frequency (MHz) Figure 15. RMS Integrated Phase Jitter Random (900 kHz to 20 MHz) vs Frequency [9] Figure 14. RMS Integrated Phase Jitter Random (12 kHz to 20 MHz) vs Frequency [9] Notes: 8. All plots are measured with 15 pF load at room temperature, unless otherwise stated. 9. Phase noise plots are measured with Agilent E5052B signal source analyzer. Integration range is up to 5 MHz for carrier frequencies up to 40 MHz. Rev 1.03 Page 6 of 16 www.sitime.com SiT2021B High Frequency, -55°C to +125°C, SOT23 Oscillator Programmable Drive Strength The SiT2021 includes a programmable drive strength feature to provide a simple, flexible tool to optimize the clock rise/fall time for specific applications. Benefits from the programmable drive strength feature are: ◼ Improves system radiated electromagnetic interference (EMI) by slowing down the clock rise/fall time. ◼ Improves the downstream clock receiver’s (RX) jitter by decreasing (speeding up) the clock rise/fall time. ◼ Ability to drive large capacitive loads while maintaining full swing with sharp edge rates. For more detailed information about rise/fall time control and drive strength selection, see the SiTime Application Notes section. The SiT2021 can support up to 30 pF in maximum capacitive loads with up to 3 additional drive strength settings. Refer to the Rise/Tall Time Tables (Table 7 to 11) to determine the proper drive strength for the desired combination of output load vs. rise/fall time. SiT2021 Drive Strength Selection Tables 7 through 11 define the rise/fall time for a given capacitive load and supply voltage. 1. Select the table that matches the SiT2021 nominal supply voltage (1.8 V, 2.5 V, 2.8 V, 3.0 V, 3.3 V). 2. Select the capacitive load column that matches the application requirement (5 pF to 30 pF) 3. Under the capacitive load column, select the desired rise/fall times. 4. The left-most column represents the part number code for the corresponding drive strength. 5. Add the drive strength code to the part number for ordering purposes. EMI Reduction by Slowing Rise/Fall Time Figure 16 shows the harmonic power reduction as the rise/fall times are increased (slowed down). The rise/fall times are expressed as a ratio of the clock period. For the ratio of 0.05, the signal is very close to a square wave. For the ratio of 0.45, the rise/fall times are very close to neartriangular waveform. These results, for example, show that the 11th clock harmonic can be reduced by 35 dB if the rise/fall edge is increased from 5% of the period to 45% of the period. trise=0.05 trise=0.1 trise=0.15 trise=0.2 trise=0.25 trise=0.3 trise=0.35 trise=0.4 trise=0.45 10 Harmonic amplitude (dB) 0 -10 -20 Calculating Maximum Frequency Based on the rise and fall time data given in Tables 7 through 11, the maximum frequency the oscillator can operate with guaranteed full swing of the output voltage over temperature can be calculated as the following: 1 Max Frequency = 5 x Trf_20/80 where Trf_20/80 is the typical value for 20%-80% rise/fall time. -30 -40 Example 1 -50 Calculate fMAX for the following condition: -60 -70 -80 1 3 5 7 9 11 Harmonic number Figure 16. Harmonic EMI reduction as a Function of Slower Rise/Fall Time ◼ Vdd = 3.3 V (Table 11) ◼ Capacitive Load: 30 pF ◼ Desired Tr/f time = 1.46 ns (rise/fall time part number code = U) Part number for the above example: Jitter Reduction with Faster Rise/Fall Time SiT2021BIU12-33E-136.986300 Power supply noise can be a source of jitter for the downstream chipset. One way to reduce this jitter is to speed up the rise/fall time of the input clock. Some chipsets may also require faster rise/fall time in order to reduce their sensitivity to this type of jitter. Refer to the Rise/Fall Time Tables (Table 7 to Table 11) to determine the proper drive strength. Drive strength code is inserted here. Default setting is “-” High Output Load Capability The rise/fall time of the input clock varies as a function of the actual capacitive load the clock drives. At any given drive strength, the rise/fall time becomes slower as the output load increases. As an example, for a 3.3V SiT2021 device with default drive strength setting, the typical rise/fall time is 0.46 ns for 5 pF output load. The typical rise/fall time slows down to 1 ns when the output load increases to 15 pF. One can choose to speed up the rise/fall time to 0.72 ns by then increasing the driven strength setting on the SiT2021 to “F.” Rev 1.03 Page 7 of 16 www.sitime.com SiT2021B High Frequency, -55°C to +125°C, SOT23 Oscillator Rise/Fall Time (20% to 80%) vs CLOAD Tables[10] Table 7. Vdd = 1.8 V Rise/Fall Times for Specific CLOAD Rise/Fall Time Typ (ns) Drive Strength \ CLOAD 5 pF 15 pF T E U F or "-": default 0.93 0.78 0.70 0.65 n/a n/a 1.48 1.30 30 pF B T E U or "-": default F 0.97 0.55 0.44 0.34 0.29 n/a 1.12 1.00 0.88 0.81 Rise/Fall Time Typ (ns) Drive Strength \ CLOAD 5 pF 15 pF R B T E U or "-": default F n/a n/a n/a n/a Table 9. Vdd = 2.8 V Rise/Fall Times for Specific CLOAD Rise/Fall Time Typ (ns) Drive Strength \ CLOAD 5 pF 15 pF R 1.29 n/a Table 8. Vdd = 2.5 V Rise/Fall Times for Specific CLOAD 30 pF n/a 1.45 1.09 0.62 0.54 0.43 0.34 n/a n/a 1.28 1.00 0.96 0.88 30 pF n/a n/a n/a n/a n/a n/a Table 10. Vdd = 3.0 V Rise/Fall Times for Specific CLOAD Rise/Fall Time Typ (ns) Drive Strength \ CLOAD 5 pF 15 pF n/a n/a n/a n/a 1.48 R 1.22 n/a 30 pF n/a B T or "-": default E U F 0.89 0.51 0.38 0.30 0.27 n/a 1.00 0.92 0.83 0.76 n/a n/a n/a n/a 1.39 Table 11. Vdd = 3.3 V Rise/Fall Times for Specific CLOAD Rise/Fall Time Typ (ns) Drive Strength \ CLOAD R B T or "-": default E U 5 pF 1.16 0.81 0.46 0.33 0.28 15 pF n/a n/a 1.00 0.87 0.79 30 pF n/a n/a n/a n/a 1.46 F 0.25 0.72 1.31 Note: 10. “n/a” in Table 7 to Table 11 indicates that the resulting rise/fall time from the respective combinati on of the drive strength and output load does not provide rail-to-rail swing and is not available. Rev 1.03 Page 8 of 16 www.sitime.com SiT2021B High Frequency, -55°C to +125°C, SOT23 Oscillator Pin 1 Configuration Options (OE, ST ̅ ̅ ̅ , or NC) Output on Startup and Resume Pin 3 of the SiT2021 can be factory-programmed to support three modes: Output Enable (OE), standby ( ST ) or No Connect (NC). The SiT2021 comes with gated output. Its clock output is accurate to the rated frequency stability within the first pulse from initial device startup or resume from the standby mode. Output Enable (OE) Mode In addition, the SiT2021 supports “no runt” pulses, and “no glitch” output during startup or resume as shown in the waveform captures in Figure 17 and Figure 18. In the OE mode, applying logic Low to the OE pin only disables the output driver and puts it in Hi-Z mode. The core of the device continues to operate normally. Power consumption is reduced due to the inactivity of the output. When the OE pin is pulled High, the output is typically enabled in
SIT2021AM-S2-33N-127.872000 价格&库存
很抱歉,暂时无法提供与“SIT2021AM-S2-33N-127.872000”相匹配的价格&库存,您可以联系我们找货
  • 1+146.994451+18.99640
