10MHz Low Noise/
Low G-Sensitivity OCXO
NA-10M-6800 series
Actual Size
FEATURE
Low Phase Noise
Small Hermetically Sealed Package
Tight Frequency Stability
Low Power Consumption
Fast Warm-up Time
Electrical Frequency Tuning Input
Reference Voltage Output
RoHS-Compliant (lead-free)
RoHS Compliant
T YPICAL APPLICATION
Instrument Reference
Microwave Communication
Clock Reference for Microwave Signal Source
Test & Measurement
Telecom Systems
Radar Systems
DIMENSION (mm)
[ TOP VIEW ]
[ BOTTOM VIEW ]
[ SIDE VIEW ]
Note: not all combination of options are available. Other specifications may be available upon request.
www.taitien.com
sales@taitien.com.tw
XO-0123
Rev(8) 02/2023
131
ELECTRICAL SPECIFICATION
Test conditions: VDC = +12 V; VCO = +5 V; at +25 ± 3°C unless otherwise identified
OUTPUT (PIN = “R.F. OUTPUT”)
Parameter
Min.
Frequency (Fo)
Typ.
Max.
10.000000
Unit
Test Condition
MHz
@ +25 ±1 C
Initial Accuracy
-0.1
+0.1
ppm
after turn on power 60 minutes
Vco=+5V
Waveform
Sine wave
Level
+8
dBm
Load
50
Harmonics
-30
dBc
Spurious
-80
dBc
Max.
Unit
±5, ±10, ±20, ±30, ±50, ±100
ppb
-20 C ~ +70 C
-40 C ~ +85 C
C
10Hz to 1MHz from carrier
FREQUENCY STABILIT Y
Parameter
Min.
Ambient
Typ.
Test Condition
referred to 25 C
Refer to Table 1 : Ordering Information
Aging
Daily
-0.5
+0.5
ppb
Yearly
-50
+50
ppb
10 Years
-0.3
+0.3
ppm
-1
+1
ppb
±5% change
ppb
root Allan variance for =1 sec
Voltage
Short term
0.002
after 30 days
Load
-1
+1
ppb
±5% change
Warm-up
-50
+50
ppb
in 5 minutes @ +25 ±1 C
1
ppb/g
G-Sensitivity
(each axis)
Phase Noise (Max.)
referred to 1 hour
Option, Refer to Table 1 : Ordering Information
Option A
Option B
Option C
Option D
-105
-110
-115
-118
dBc/Hz
@ 1Hz
-135
-140
-142
-146
dBc/Hz
@ 10Hz
-155
-155
-155
-160
dBc/Hz
@ 100Hz
-165
-165
-165
-166
dBc/Hz
@ 1KHz
-170
-170
-170
-169
dBc/Hz
@ 10KHz
-170
-170
-170
-170
dBc/Hz
@ 100KHz
-170
-170
-170
-170
dBc/Hz
@ 1MHz
ELECTRICAL FREQUENCY ADJUSTMENT (PIN = “VCO INPUT”)
Parameter
Min.
Tuning Range
±0.4*
Control Voltage
0.5
Slope
Max.
Unit
ppm
+9.5
V
+10
Test Condition
Referenced to frequency at nominal Center Voltage
Positive
Center Voltage
Linearity
Typ.
+5.0
-10
V
* Sufficient to adjust the oscillator to nominal frequency for 10 years. Some unit will have ±0.7ppm tuning range.
132
www.taitien.com
XO-0123
Rev(8) 02/2023
INPUT POWER (PIN = “+VDC”)
Parameter
Min.
Typ.
Max.
Unit
Voltage
+11.4
+12
+12.6
V
Test Condition
Current
2.0
Steady State
400
During Warm-Up
@ +25 C, operating -20 C ~ +70 C
W
2.3
@ +25 C, operating -40 C ~ +85 C
mA
500
Refer to Table 1 :
REFERENCE VOLTAGE (PIN = "REFERENCE VOLTAGE")
Parameter
Min.
Typ.
Max.
Voltage
+9.25
+9.5
+9.75
V
100
Ohm
Source Resistance
10
Load Impedance
Units
Test Condition
Kohm
ENVIRONMENTAL
Parameter
Reference Std.
Operable Temperature
-45 C to +90 C
Storage Temperature
-50 C to +95 C
Test Condition
Note 1
Humidity
MIL-STD-202, Method 103
Test Condition A
95% RH @ +40 C,non-condensing,240 hours
Vibration (non-operating)
MIL-STD-202, Method 201
0.06” Total p-p, 10 to 55 Hz
Shock (non-operating)
MIL-STD-202, Method 213,
Test Condition J
30g, 11ms, half-sine
Note 1 : Output maintained over this temperature range. Other requirements of this specification may not be met when operating outside the
temperature range in 2.1.
Table 1 : ORDERING INFORMATION
Temp. ( C)
Ambient
Option
±30 ppb
-20 C ~+70oC
±20 ppb
±10 ppb
±5 ppb
±100 ppb
-40oC~+85oC
±50 ppb
±30 ppb
±20 ppb
Phase Noise Option
A
B
C
D
g-Sensitivity
Option
NA-10M-6810
NA-10M-6815
NA-10M-6820
NA-10M-6825
NA-10M-6830
NA-10M-6835
NA-10M-6840
NA-10M-6845
NA-10M-6860
NA-10M-6865
NA-10M-6870
NA-10M-6875
NA-10M-6880
NA-10M-6885
NA-10M-6890
NA-10M-6895
NA-10M-6811
NA-10M-6816
NA-10M-6821
NA-10M-6826
NA-10M-6831
NA-10M-6836
NA-10M-6841
NA-10M-6846
NA-10M-6861
NA-10M-6866
NA-10M-6871
NA-10M-6876
NA-10M-6881
NA-10M-6886
NA-10M-6891
NA-10M-6896
NA-10M-6812
NA-10M-6817
NA-10M-6822
NA-10M-6827
NA-10M-6832
NA-10M-6837
NA-10M-6842
NA-10M-6847
NA-10M-6862
NA-10M-6867
NA-10M-6872
NA-10M-6877
NA-10M-6882
NA-10M-6887
NA-10M-6892
NA-10M-6897
NA-10M-6813
NA-10M-6823
NA-10M-6833
NA-10M-6843
Y
N
Y
N
Y
N
Y
N
Y
N
Y
N
Y
N
Y
N
www.taitien.com
XO-0123
Rev(8) 02/2023
133
Phase Noise Test Data
134
www.taitien.com
XO-0123
Rev(8) 02/2023
很抱歉,暂时无法提供与“NA-10M-6822”相匹配的价格&库存,您可以联系我们找货
