Our Performance Your Reputation
Oven Controlled Crystal Oscillator
NA-10 MHz-2400 series
2400 Series-square wave in 25.4x25.4mm DIP package
NA-10M-2400 series oscillators is designed for applications where space is at a
premium and good frequency stability is required. The oscillators can be used in many
communications applications. A choice of quartz resonators offers a variety of
performance versus cost options to fit most applications.
RoHS Compliant Standard
ELECTRICAL SPECIFICATIONS
1.
OUTPUT (PIN = “R.F. OUTPUT”)
Parameter
1.1.
Min.
Frequency
Typ.
Max.
10.000000
Unit
Test Condition
MHz
@ +25 ±1C
1.2.
Initial Accuracy
-0.1
+0.1
ppm
after turn on power 15 ±1 minutes
90 days following date code
VCO Input at Center Voltage ±0.001V
1.3.
Waveform
Rectangular
Level
CMOS
“1” level
1.4.
+2.6
+3.3
“0” level
1.5.
Load
1.6.
Duty cycle
1.7.
Rise/fall time
1.8.
Spurious
2.
15
45
50
V
pF
55
@ +1.65V
6
ns
10% to 90%
-60
dBc
Max.
Unit
FREQUENCY STABILITY
Parameter
2.1.
V
+0.4
Min.
Ambient
Aging
2.2.
Typ.
±3, ±5, ±10
ppb
-30 ~ +70
-40 ~ +85
C
Test Condition
referenced to 25C
Refer to Table 1 : Ordering Information
-0.5
+0.5
ppb
per day, at time of shipment
after 30 days
Daily
-0.5
+0.5
ppb
Yearly
-50
+50
ppb
10 Years
-0.3
+0.3
ppm
-0.5
+0.5
ppb
2.3.
Voltage
±5% change
2.4.
Short term
0.05
ppb/s
2.5.
Load
-0.5
+0.5
ppb
±5% change
2.6.
Warm-up
-10
+10
ppb
in 10 minutes @ +25 ±1C
root Allan variance
http://www.taitien.com E-Mail: sales@taitien.com.tw
Specifications subject to change without notice
referenced to 1 hour
Page 1of 3
Rev(2) 03/2023
Parameter
2.7.
3.
Min.
Phase Noise
Max.
Unit
Test Condition
-95
-90
dBc/Hz
@ 1Hz
-125
-120
dBc/Hz
@ 10Hz
-140
-135
dBc/Hz
@ 100Hz
-148
-145
dBc/Hz
@ 1KHz
-156
-155
dBc/Hz
@ 10KHz
-158
-155
dBc/Hz
@ 100KHz
ELECTRICAL FREQUENCY ADJUSTMENT (PIN = “VCO INPUT”)
Parameter
3.1.
Tuning Range
3.2.
Control Voltage
3.3.
Slope
3.4.
Center Voltage
Min.
Typ.
Max.
Unit
-0.5
ppm
VCO @ Min. Voltage
ppm
VCO @ Max. Voltage
+0.5
V
V
Test Condition
Linearity
-10
3.6.
Input Impedance
100
Optional, Refer to Table 1 : Ordering Information
+2.5
V
+2.0
V
+10
INPUT POWER (PIN = “+VDC”)
Min.
Typ.
Max.
Unit
4.1.
Voltage
+4.75
+5.0
+5.25
V
4.2.
Current
800
mA
@ turn on
4.3.
Steady State
1.3
W
@ +25C
Test Condition
REFERENCE VOLTAGE (PIN = "REFERENCE VOLTAGE")
(Optional Function. Refer to Table 1 : Ordering Information.)
5.1.
5.2.
6.
Note 1
kΩ
Parameter
5.
Referenced to frequency at nominal
Center Voltage
Positive
3.5.
4.
Typ.
Parameter
Min.
Typ.
Max.
Voltage
+3.8
+4
+4.2
Load
9
Units
V
Test Condition
Over temperature range in 2.1.
kΩ
ENVIRONMENTAL
Parameter
6.1.
Operating Temperature
6.2.
Storage Temperature
Reference Std.
-40C to +85C
Test Condition
Note 2
-55C to +105C
6.3.
Humidity
MIL-STD-202, Method 103
Test Condition A
6.4.
Vibration (non-operating)
MIL-STD-202, Method 201
0.06” Total p-p, 10 to 55 Hz
6.5.
Shock (non-operating)
MIL-STD-202, Method 213,
Test Condition J
30g, 11ms, half-sine
Note 1.
Note 2.
95% RH @ +40C,non-condensing,240 hours
When not connected, VCO INPUT is internally held at this voltage.
Output maintained over this temperature range. Other requirements of this specification may not be met when operating outside the
Page 2of 3
Rev(2) 03/2023
Table 1 : ORDERING INFORMATION
TAITIEN
Model No.
ppb
±3
±5
±10
NA-10M-2400
NA-10M-2403
NA-10M-2450
NA-10M-2453
NA-10M-2401
NA-10M-2404
NA-10M-2451
NA-10M-2454
NA-10M-2402
NA-10M-2405
NA-10M-2452
NA-10M-2455
Control
Voltage
Reference
Voltage
+2.5V
N/A
+2.0V
+4.0V
Temp. (℃)
-30~+70
-40~+85
-30~+70
-40~+85
OUTLINE DRAWING
Page 3of 3
Rev(2) 03/2023
很抱歉,暂时无法提供与“NA-10M-2454”相匹配的价格&库存,您可以联系我们找货
