NI-10M-2800
NI-10M-2800
    TAITIEN(泰艺)
    XO-5P_36.3X27.18MM_TM
    XTAL OSC OCXO 10.0000MHZ LVTTL
NI-10M-2800 数据手册
Our Performance Your Reputation Oven Controlled Crystal Oscillator NI-10 MHz-2800 series 2800 Series in 36.3x27.2mm DIP package NI-10M-2800 series oscillators is designed for applications where space is at a premium and good frequency stability is required. The oscillators can be used in many communications applications. A choice of quartz resonators offers a variety of performance versus cost options to fit most applications. RoHS Compliant Standard ELECTRICAL SPECIFICATIONS 1. OUTPUT (PIN = “R.F. OUTPUT”) Parameter 1.1. Min. Frequency Typ. Max. 10.000000 Unit Test Condition MHz @ +25 ±1C 1.2. Initial Accuracy -0.1 +0.1 ppm after turn on power 15 ±1 minutes  90 days following date code VCO Input at 2.5 ±0.001V 1.3. Waveform Rectangular Level CMOS “1” level 1.4. +2.6 V “0” level 1.5. Load 1.6. Duty cycle 1.7. Rise/fall time 1.8. Spurious 2. V 13.5 15 16.5 pF 45 50 55 % @ +1.65V 6 ns 10% to 90% -60 dBc Max. Unit FREQUENCY STABILITY Parameter 2.1. +0.4 Min. Ambient Aging 2.2. Typ. ±3, ±5, ±10 ppb -30 ~ +70 -40 ~ +85 C Test Condition referenced to 25C Refer to Table 1 : Ordering Information -0.5 +0.5 ppb per day, at time of shipment after 30 days Daily -0.5 +0.5 ppb Yearly -50 +50 ppb 10 Years -0.3 +0.3 ppm -0.5 +0.5 ppb 2.3. Voltage ±5% change 2.4. Short term 0.05 ppb/s 2.5. Load -0.5 +0.5 ppb ±5% change 2.6. Warm-up -10 +10 ppb in 10 minutes @ +25 ±1C root Allan variance http://www.taitien.com E-Mail: sales@taitien.com.tw Specifications subject to change without notice referenced to 1 hour Page 1of 3 Rev(2) 03/2023 Our Performance Your Reputation Parameter 2.7. 3. Min. Phase Noise Max. Unit Test Condition -95 -90 dBc/Hz @ 1Hz -125 -120 dBc/Hz @ 10Hz -140 -135 dBc/Hz @ 100Hz -148 -145 dBc/Hz @ 1KHz -156 -155 dBc/Hz @ 10KHz -158 -155 dBc/Hz @ 100KHz ELECTRICAL FREQUENCY ADJUSTMENT (PIN = “VCO INPUT”) Parameter 3.1. Tuning Range Min. Typ. Max. Unit -0.5 ppm VCO @ 0V ppm VCO @ 5V +0.5 3.2. Control Voltage 3.3. Slope 3.4. Center Voltage 3.5. Linearity -10 3.6. Input Impedance 100 4. Typ. 0 +5.0 V +10 % Test Condition Positive +2.5 V Note 1 kΩ INPUT POWER (PIN = “+VDC”) Parameter Min. Typ. Max. Unit 4.1. Voltage +11.4 +12 +12.6 V 4.2. Current 400 mA @ turn on 4.3. Steady State 1.3 W @ +25C 5. Test Condition REFERENCE VOLTAGE (PIN = "REFERENCE VOLTAGE") (Optional Function. Refer to Table 1 : Ordering Information.) 5.1. 5.2. 6. Referenced to frequency at nominal Center Voltage Parameter Min. Typ. Max. Voltage +4.75 +5 +5.25 Load 9 Units V kΩ Test Condition Over temperature range in 2.1. ENVIRONMENTAL Parameter 6.1. Operating Temperature 6.2. Storage Temperature Reference Std. -40C to +85C Test Condition Note 2 -55C to +105C 6.3. Humidity MIL-STD-202, Method 103 Test Condition A 6.4. Vibration (non-operating) MIL-STD-202, Method 201 0.06” Total p-p, 10 to 55 Hz 6.5. Shock (non-operating) MIL-STD-202, Method 213, Test Condition J 30g, 11ms, half-sine Note 1. Note 2. 95% RH @ +40C,non-condensing,240 hours When not connected, VCO INPUT is internally held at this voltage. Output maintained over this temperature range. Other requirements of this specification may not be met when operating outside the temperature range in 2.1. http://www.taitien.com E-Mail: sales@taitien.com.tw Specifications subject to change without notice Page 2of 3 Rev(2) 03/2023 Our Performance Your Reputation Table 1 : ORDERING INFORMATION TAITIEN Model No. ppb ±3 ±5 ±10 NI-10M-2800 NI-10M-2803 NI-10M-2850 NI-10M-2853 NI-10M-2801 NI-10M-2804 NI-10M-2851 NI-10M-2854 NI-10M-2802 NI-10M-2805 NI-10M-2852 NI-10M-2855 Control Voltage Reference Voltage +2.5V N/A +2.5V +5.0V Temp. (℃) -30~+70 -40~+85 -30~+70 -40~+85 OUTLINE DRAWING http://www.taitien.com E-Mail: sales@taitien.com.tw Specifications subject to change without notice Page 3of 3 Rev(2) 03/2023
NI-10M-2800 价格&库存
很抱歉,暂时无法提供与“NI-10M-2800”相匹配的价格&库存,您可以联系我们找货
