TWEAMDJANF-30.720000 数据手册
TW Type High Precision
5.0 x 3.2 mm SMD Voltage Controlled
Temperature Compensated
Crystal Oscillator
Actual Size
FEATURE
- Conforms to AEC-Q200
- Typical 5.0 x 3.2 x 1.85 mm ceramic SMD package.
- ±0.28ppm, -40°C~+85°C ; ±0.05ppm, -10°C~+70°C
- CMOS and Clipped Sine wave (without DC-cut capacitor) output optional.
TYPICAL APPLICATION
- Base Stations, Stratum 3
RoHS Compliant
- Femtocell
DIMENSION (mm)
SOLDER PAD L AYOUT (mm)
[ BOTTOM VIEW ]
[ TOP VIEW ]
2.6
1.2
5.0± 0.2
#4
3.72
#3
2.3
#1
#2
#2
0.8 ±0.15
1.4
3.2± 0.2
#4
#1
Function
Pin#
0.55
1
1.85 ±0.1
2
3
4
1.05
1.1 ±0.15
[ SIDE VIEW ]
0.25±0.04
#4
#3
#3
Vcon:VC-TCXO
GND/NC:TCXO
GND
OUTPUT
VDD
#1
#2
1.33
To ensure optimal oscillator performance, place a by-pass capacitor of 0.1μF
as close to the part as possible between Vdd and GND pads.
ELECTRICAL SPECIFICATION
2.5V
Parameter
Supply Voltage Variation (VDD)
Frequency Range
Standard Frequency (for CMOS)
Standard Frequency (for Clipped Sine Wave)
Frequency Tolerance*
Frequency Stability
Vs Supply Voltage (±5%) change
Vs Load (±10%) change
Vs Aging (@1st year)
Supply Current (CMOS output)
10 MHz Fo 40 MHz
40 MHz
Min.
VDD-5%
10
_
_
_
8
90%VDD
_
6
5
_
Output Level (Clipped Sine Wave)
90%VDD
_
_
mA
5
10%VDD
55
_
0.5
±5.0
100
_
_
-125
-145
-150
2.5
_
_
V
Vp-p
Standard frequencies are frequencies which the crystal has been designed and does not imply a stock position.
dBc/Hz
5
125
-55
V
ppm
kΩ
-125
-145
-150
_
5
125
-55
ppm
15pF
10 KΩ // 10pF
2.5
0.5
±5.0
100
±0.2
±0.2
±1.0
6
45
0.8
_
ppm
8
15pF
10 KΩ // 10pF
Load (CMOS)
Load (Clipped Sine Wave)
Control Voltage Range (VCTCXO)
Pulling Range (VCTCXO)
Vc Input Impedance (VCTCXO)
100 Hz
Phase Noise @ 10 MHz
1 kHz
10 kHz
Start time
Storage Temp. Range
V
±2.0
_
_
_
_
10%VDD
55
45
0.8
Unit
MHz
_
_
_
±0.2
±0.2
±1.0
_
_
_
Supply Current (Clipped Sine Wave)
Max.
VDD+5%
52
10, 12.8,13, 19.2, 20, 25, 26, 30.72
_
±2.0
_
Fo 52 MHz
Output Level (CMOS) Output High (Logic “1”)
Output Low (Logic “0”)
Duty
3.3V
Max.
Min.
VDD+5%
VDD-5%
52
10
mSec
°C
Frequency at 25°C, 1 hour after reflow.
Frequency Stability vs. Temperature Range
Temp. (°C)
ppm
±0.05
±0.1
±0.2
±0.28
±0.5
-10 ~ +70
-20 ~ +70
-40 ~ +85
○: Available △:Conditional X: Not available
Note: not all combination of options are available. Other specifications may be available upon request.
www.taitien.com
sales@taitien.com.tw
XO-0084
Rev(18) 06/2023
97
TWEAMDJANF-30.720000 价格&库存
很抱歉,暂时无法提供与“TWEAMDJANF-30.720000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+63.05040
- 10+57.57480
- 30+54.23760
- 100+51.44040
