SIT1618BE-73-33E-25.000000
    SITIME(赛特时脉)
    SMD2016_4P
    MEMS OSC XO 25.0000MHZ LVCMOS LV
SIT1618BE-73-33E-25.000000 数据手册
SiT1618B Standard Frequency, High Temperature Oscillator Features Applications ◼ 33 standard frequencies between 7.3728 MHz and 48 MHz ◼ Supply voltage of 1.8 V or 2.5 V to 3.3 V continuous ◼ Industrial, medical, automotive, avionics and other high temperature applications ◼ Operating temperature from -40°C to 125°C. For -55°C option, refer to SiT8920 and SiT8921 ◼ Industrial sensors, PLC, motor servo, outdoor networking equipment, medical video cam, asset tracking systems, etc. ◼ Excellent total frequency stability as low as ±20 ppm ◼ Low power consumption of 3.5 mA typical at 1.8 V Related products for automotive applications. ◼ LVCMOS/LVTTL compatible output ◼ Industry-standard packages: 2.0 x 1.6, 2.5 x 2.0, 3.2 x 2.5, 5.0 x 3.2, 7.0 x 5.0 mm x mm For aerospace and defense applications SiTime recommends using only Endura™ SiT8944. ◼ Instant samples with Time Machine II and Field Programmable oscillators ◼ RoHS and REACH compliant, Pb-free, Halogen-free and Antimony-free ◼ For AEC-Q100 oscillators, refer to SiT8924 and SiT8925 Electrical Specifications Table 1. Electrical Characteristics All Min and Max limits are specified over temperature and rated operating voltage with 15 pF output load unless otherwise stated. Typical values are at 25°C and nominal supply voltage. Parameters Symbol Min. Typ. Max. Unit Condition Frequency Range Output Frequency Range f 33 standard frequencies between 7.3728 MHz and 48 MHz MHz Refer to Table 13 for the exact list of supported frequencies Frequency Stability and Aging Frequency Stability F_stab -20 – +20 ppm -25 – +25 ppm -30 – +30 ppm -50 – +50 ppm Inclusive of Initial tolerance at 25°C, 1st year aging at 25°C, and variations over operating temperature, rated power supply voltage and load. Operating Temperature Range Operating Temperature Range (ambient) T_use -40 – +105 °C Extended Industrial -40 – +125 °C Automotive Supply Voltage and Current Consumption Supply Voltage Current Consumption OE Disable Current Standby Current Rev 1.04 Vdd Idd I_OD I_std 1.62 1.8 1.98 V 2.25 2.5 2.75 V 2.52 2.8 3.08 V 2.7 3.0 3.3 V 2.97 3.3 3.63 V 2.25 – 3.63 V – 3.8 4.7 mA No load condition, f = 20 MHz, Vdd = 2.8 V or 3.3 V – 3.6 4.5 mA No load condition, f = 20 MHz, Vdd = 2.5 V – 3.5 4.5 mA No load condition, f = 20 MHz, Vdd = 1.8 V – – 4.5 mA Vdd = 2.5 V to 3.3 V, OE = Low, Output in high-Z state – – 4.3 mA Vdd = 1.8 V. OE = Low, Output in high-Z state – 2.6 8.5 A Vdd = 2.8 V to 3.3 V, ST = Low, Output is weakly pulled down – 1.4 5.5 A Vdd = 2.5 V, ST = Low, Output is weakly pulled down – 0.6 4.0 A Vdd = 1.8 V, ST = Low, Output is weakly pulled down 1 January 2023 www.sitime.com SiT1618B Standard Frequency, High Temperature Oscillator Table 1. Electrical Characteristics (continued) Parameters Symbol Min. Typ. Max. Unit Condition LVCMOS Output Characteristics DC 45 – 55 % All Vdds Tr, Tf – 1.0 2.0 ns Vdd = 2.5 V, 2.8 V, 3.0 V or 3.3 V, 20% - 80% – 1.3 2.5 ns Vdd = 1.8 V, 20% - 80% – 1.0 3 ns Vdd = 2.25 V - 3.63 V, 20% - 80% Duty Cycle Rise/Fall Time Output High Voltage VOH 90% – – Vdd IOH = -4 mA (Vdd = 3.0 V or 3.3 V) IOH = -3 mA (Vdd = 2.8 V or Vdd = 2.5 V) IOH = -2 mA (Vdd = 1.8 V) Output Low Voltage VOL – – 10% Vdd IOL = 4 mA (Vdd = 3.0 V or 3.3 V) IOL = 3 mA (Vdd = 2.8 V or 2.5 V) IOL = 2 mA (Vdd = 1.8 V) Input High Voltage VIH 70% – – Vdd Pin 1, OE or ST Input Low Voltage VIL – – 30% Vdd Pin 1, OE or ST Input Pull-up Impedance Z_in 50 87 150 k Pin 1, OE logic high or logic low, or ST logic high 2 – – M Pin 1, ST logic low Input Characteristics Startup and Resume Timing T_start – – 5 ms Measured from the time Vdd reaches its rated minimum value T_oe – – 162 ns f = 48 MHz. For other frequencies, T_oe = 100 ns + 3 * clock periods T_resume – – 5 ms Measured from the time ST pin crosses 50% threshold Startup Time Enable/Disable Time Resume Time Jitter RMS Period Jitter T_jitt Peak-to-peak Period Jitter T_pk RMS Phase Jitter (random) T_phj – 1.6 2.5 ps f = 20 MHz, Vdd = 2.5 V, 2.8 V, 3.0 V or 3.3 V – 1.9 4 ps f = 20 MHz, Vdd = 1.8 V – 12 20 ps f = 20 MHz, Vdd = 2.5 V, 2.8 V, 3.0 V or 3.3 V – 14 30 ps f = 20 MHz, Vdd = 1.8 V – 0.5 0.8 ps f = 40 MHz, Integration bandwidth = 900 kHz to 7.5 MHz – 1.3 2 ps f = 40 MHz, Integration bandwidth = 12 kHz to 20 MHz Table 2. Pin Description Pin 1 Symbol OE/ST ̅ ̅ ̅ /NC Top View Functionality Output Enable H[1]: specified frequency output L: output is high impedance. Only output driver is disabled. Standby H[1]: specified frequency output L: output is low (weak pull down). Device goes to sleep mode. Supply current reduces to I_std. No Connect OE/ST ̅ ̅ ̅ /NC Any voltage between 0 and Vdd or Open[1]: Specified frequency output. Pin 1 has no function. 2 GND Power 3 OUT Output Electrical ground Oscillator output 4 VDD Power Power supply voltage[2] Figure 1. Pin Assignments Notes: 1. In OE or ST mode, a pull-up resistor of 10 kΩ or less is recommended if pin 1 is not externally driven. If pin 1 needs to be left floating, use the NC option. 2. A capacitor of value 0.1 µF or higher between Vdd and GND is required. Rev 1.04 Page 2 of 18 www.sitime.com SiT1618B Standard Frequency, High Temperature Oscillator Table 3. Absolute Maximum Limits Attempted operation outside the absolute maximum ratings may cause permanent damage to the part. Actual performance of the IC is only guaranteed within the operational specifications, not at absolute maximum ratings. Parameter Min. Max. Unit Storage Temperature -65 150 °C Vdd -0.5 4 V Electrostatic Discharge – 2000 V Soldering Temperature (follow standard Pb free soldering guidelines) – 260 °C [3] – 150 °C Junction Temperature Note: 3. Exceeding this temperature for extended period of time may damage the device. Table 4. Thermal Consideration[4] JC, Bottom Package JA, 4 Layer Board (°C/W) JA, 2 Layer Board (°C/W) 7050 142 273 30 5032 97 199 24 3225 109 212 27 2520 117 222 26 2016 152 252 36 (°C/W) Note: 4. Refer to JESD51 for JA and JC definitions, and reference layout used to determine the JA and JC values in the above table. Table 5. Maximum Operating Junction Temperature[5] Max Operating Temperature(ambient) Maximum Operating Junction Temperature 105°C 115°C 125°C 135°C Note: 5. Datasheet specifications are not guaranteed if junction temperature exceeds the maximum operating junction temperature. Table 6. Environmental Compliance Parameter Condition/Test Method Mechanical Shock MIL-STD-883F, Method 2002 Mechanical Vibration MIL-STD-883F, Method 2007 Temperature Cycle JESD22, Method A104 Solderability MIL-STD-883F, Method 2003 Moisture Sensitivity Level MSL1 @ 260°C Rev 1.04 Page 3 of 18 www.sitime.com SiT1618B Standard Frequency, High Temperature Oscillator Test Circuit and Waveform[6] Vdd Vout 4 Power Supply Test Point 3 tf 80% Vdd 15pF (including probe and fixture capacitance) 0.1 uF 2 1 tr 50% 20% Vdd High Pulse (TH) Low Pulse (TL) Period Vdd OE/ST Function 1 kΩ Figure 3. Waveform Figure 2. Test Circuit Note: 6. Duty Cycle is computed as Duty Cycle = TH/Period. Timing Diagrams 90% Vdd Vdd Vdd 50% Vdd Pin 4 Voltage T_start [7] No Glitch during start up T_resume ST Voltage CLK Output CLK Output HZ HZ T_resume: Time to resume from ST T_start: Time to start from power-off Figure 4. Startup Timing (OE/ST Mode) Figure 5. Standby Resume Timing (ST Mode Only) Vdd Vdd 50% Vdd OE Voltage OE Voltage T_oe 50% Vdd T_oe CLK Output CLK Output HZ HZ T_oe: Time to re-enable the clock output T_oe: Time to put the output in High Z mode Figure 6. OE Enable Timing (OE Mode Only) Figure 7. OE Disable Timing (OE Mode Only) Note: 7. SiT1618 has “no runt” pulses and “no glitch” output during startup or resume. Rev 1.04 Page 4 of 18 www.sitime.com SiT1618B Standard Frequency, High Temperature Oscillator Performance Plots[8] 1.8 V 2.5 V 2.8 V 3V DUT1 DUT8 DUT15 DUT22 3.3 V 5.0 4.8 DUT2 DUT9 DUT16 DUT23 DUT3 DUT10 DUT17 DUT24 DUT4 DUT11 DUT18 DUT25 DUT5 DUT12 DUT19 DUT6 DUT13 DUT20 DUT7 DUT14 DUT21 25 4.6 20 Frequency (ppm) Idd (mA) 4.4 4.2 4.0 3.8 3.6 3.4 15 10 5 0 -5 -10 -15 3.2 -20 3.0 10 15 20 25 30 35 40 45 -25 50 ‐40 ‐20 0 20 40 60 80 100 120 Temperature (°C) Figure 8. Idd vs Frequency Figure 9. Frequency vs Temperature 1.8 V 2.5 V 2.8 V 15 20 25 3.0 V 3.3 V 55 54 Duty cycle (%) RMS period jitter (ps) 53 52 51 50 49 48 47 46 45 10 Figure 10. RMS Period Jitter vs Frequency 2.5 V 2.8 V 3.0 V 3.3 V 1.8 V 2.5 2.5 2.0 2.0 1.5 1.0 0.5 40 45 50 2.5 V 2.8 V 3.0 V 3.3 V 1.5 1.0 0.5 0.0 0.0 -40 -20 0 20 40 60 80 100 -40 120 Figure 12. 20%-80% Rise Time vs Temperature Rev 1.04 35 Figure 11. Duty Cycle vs Frequency Fall time (ns) Rise time (ns) 1.8 V 30 -20 0 20 40 60 80 100 120 Figure 13. 20%-80% Fall Time vs Temperature Page 5 of 18 www.sitime.com SiT1618B Standard Frequency, High Temperature Oscillator IPJ (ps) IPJ (ps) Performance Plots[8] (continued) Figure 14. RMS Integrated Phase Jitter Random (12 kHz to 20 MHz) vs Frequency[9] Figure 15. RMS Integrated Phase Jitter Random (900 kHz to 20 MHz) vs Frequency[9] Notes: 8. All plots are measured with 15 pF load at room temperature, unless otherwise stated. 9. Phase noise plots are measured with Agilent E5052B signal source analyzer. Integration range is up to 5 MHz for carrier frequencies below 40 MHz. Rev 1.04 Page 6 of 18 www.sitime.com SiT1618B Standard Frequency, High Temperature Oscillator Programmable Drive Strength The SiT1618 includes a programmable drive strength feature to provide a simple, flexible tool to optimize the clock rise/fall time for specific applications. Benefits from the programmable drive strength feature are: ◼ Improves system radiated electromagnetic interference (EMI) by slowing down the clock rise/fall time. ◼ Improves the downstream clock receiver’s (RX) jitter by decreasing (speeding up) the clock rise/fall time. ◼ Ability to drive large capacitive loads while maintaining full swing with sharp edge rates. For more detailed information about rise/fall time control and drive strength selection, see the SiTime Application Notes section. EMI Reduction by Slowing Rise/Fall Time Figure 16 shows the harmonic power reduction as the rise/ fall times are increased (slowed down). The rise/fall times are expressed as a ratio of the clock period. For the ratio of 0.05, the signal is very close to a square wave. For the ratio of 0.45, the rise/fall times are very close to near-triangular waveform. These results, for example, show that the 11th clock harmonic can be reduced by 35 dB if the rise/fall edge is increased from 5% of the period to 45% of the period. trise=0.05 trise=0.1 trise=0.15 trise=0.2 trise=0.25 trise=0.3 trise=0.35 trise=0.4 trise=0.45 10 Harmonic amplitude (dB) 0 -10 -20 The SiT1618 can support up to 60 pF or higher in maximum capacitive loads with drive strength settings. Refer to the Rise/Tall Time Tables (Table 7 to 11) to determine the proper drive strength for the desired combination of output load vs. rise/fall time. SiT1618 Drive Strength Selection Tables 7 through 11 define the rise/fall time for a given capacitive load and supply voltage. 1. Select the table that matches the SiT1618 nominal supply voltage (1.8 V, 2.5 V, 2.8 V, 3.0 V, 3.3 V). 2. Select the capacitive load column that matches the application requirement (5 pF to 60 pF) 3. Under the capacitive load column, select the desired rise/fall times. 4. The left-most column represents the part number code for the corresponding drive strength. 5. Add the drive strength code to the part number for ordering purposes. Calculating Maximum Frequency Based on the rise and fall time data given in Tables 7 through 11, the maximum frequency the oscillator can operate with guaranteed full swing of the output voltage over temperature can be calculated: Max Frequency = 1 5 x Trf_20/80 where Trf_20/80 is the typical value for 20%-80% rise/fall time. -30 -40 Example 1 -50 Calculate fMAX for the following condition: -60 ◼ -70 -80 ◼ 1 3 5 7 9 11 Harmonic number Figure 16. Harmonic EMI reduction as a Function of Slower Rise/Fall Time ◼ Vdd = 1.8 V (Table 7) Capacitive Load: 30 pF Desired Tr/f time = 3 ns (rise/fall time part number code = E) fMAX = 48.000000 where 48 MHz is highest available frequency for this device. Jitter Reduction with Faster Rise/Fall Time Part number for the above example: Power supply noise can be a source of jitter for the downstream chipset. One way to reduce this jitter is to speed up the rise/fall time of the input clock. Some chipsets may also require faster rise/fall time in order to reduce their sensitivity to this type of jitter. Refer to the Rise/Fall Time Tables (Table 7 to Table 11) to determine the proper drive strength. SiT1618BIE12-18E-48.000000 Drive strength code is inserted here. Default setting is “-” High Output Load Capability The rise/fall time of the input clock varies as a function of the actual capacitive load the clock drives. At any given drive strength, the rise/fall time becomes slower as the output load increases. As an example, for a 3.3 V SiT1618 device with default drive strength setting, the typical rise/fall time is 1ns for 15 pF output load. The typical rise/fall time slows down to 2.6 ns when the output load increases to 45 pF. One can choose to speed up the rise/fall time to 1.83 ns by then increasing the drive strength setting on the SiT1618. Rev 1.04 Page 7 of 18 www.sitime.com SiT1618B Standard Frequency, High Temperature Oscillator Rise/Fall Time (20% to 80%) vs CLOAD Tables Table 7. Vdd = 1.8 V Rise/Fall Times for Specific CLOAD Table 8. Vdd = 2.5 V Rise/Fall Times for Specific CLOAD Rise/Fall Time Typ (ns) Drive Strength \ CLOAD L A R B T E U F or "‐": default 5 pF 6.16 3.19 2.11 1.65 0.93 0.78 0.70 0.65 15 pF 11.61 6.35 4.31 3.23 1.91 1.66 1.48 1.30 30 pF 22.00 11.00 7.65 5.79 3.32 2.94 2.64 2.40 Rise/Fall Time Typ (ns) 45 pF 31.27 16.01 10.77 8.18 4.66 4.09 3.68 3.35 60 pF 39.91 21.52 14.47 11.08 6.48 5.74 5.09 4.56 Table 9. Vdd = 2.8 V Rise/Fall Times for Specific CLOAD Drive Strength \ CLOAD L A R B T E or "‐": default U F 5 pF 4.13 2.11 1.45 1.09 0.62 15 pF 8.25 4.27 2.81 2.20 1.28 30 pF 12.82 7.64 5.16 3.88 2.27 45 pF 21.45 11.20 7.65 5.86 3.51 60 pF 27.79 14.49 9.88 7.57 4.45 0.54 0.43 0.34 1.00 0.96 0.88 2.01 1.81 1.64 3.10 2.79 2.54 4.01 3.65 3.32 Table 10. Vdd = 3.0 V Rise/Fall Times for Specific CLOAD Rise/Fall Time Typ (ns) Rise/Fall Time Typ (ns) Drive Strength \ CLOAD 5 pF 15 pF 30 pF 45 pF 60 pF Drive Strength \ CLOAD 5 pF 15 pF 30 pF 45 pF 60 pF L A R B T 3.77 1.94 1.29 0.97 0.55 7.54 3.90 2.57 2.00 1.12 12.28 7.03 4.72 3.54 2.08 19.57 10.24 7.01 5.43 3.22 25.27 13.34 9.06 6.93 4.08 E or "‐": default U F 0.44 0.34 0.29 1.00 0.88 0.81 1.83 1.64 1.48 2.82 2.52 2.29 3.67 3.30 2.99 L A R B T or "‐": default E U F 3.60 1.84 1.22 0.89 0.51 0.38 0.30 0.27 7.21 3.71 2.46 1.92 1.00 0.92 0.83 0.76 11.97 6.72 4.54 3.39 1.97 1.72 1.55 1.39 18.74 9.86 6.76 5.20 3.07 2.71 2.40 2.16 24.30 12.68 8.62 6.64 3.90 3.51 3.13 2.85 Table 11. Vdd = 3.3 V Rise/Fall Times for Specific CLOAD Rise/Fall Time Typ (ns) Drive Strength \ CLOAD L A R B T or "‐": default 5 pF 3.39 1.74 1.16 0.81 0.46 15 pF 6.88 3.50 2.33 1.82 1.00 30 pF 11.63 6.38 4.29 3.22 1.86 45 pF 17.56 8.98 6.04 4.52 2.60 60 pF 23.59 12.19 8.34 6.33 3.84 E U F 0.33 0.28 0.25 0.87 0.79 0.72 1.64 1.46 1.31 2.30 2.05 1.83 3.35 2.93 2.61 Rev 1.04 Page 8 of 18 www.sitime.com SiT1618B Standard Frequency, High Temperature Oscillator Pin 1 Configuration Options (OE, ST ̅ ̅ ̅ , or NC) Pin 1 of the SiT1618 can be factory-programmed to support three modes: Output Enable (OE), standby ( ST ̅ ̅ ̅ ) or No Connect (NC). These modes can also be programmed with the Time Machine using field programmable devices. Output Enable (OE) Mode In the OE mode, applying logic Low to the OE pin only disables the output driver and puts it in Hi-Z mode. The core of the device continues to operate normally. Power consumption is reduced due to the inactivity of the output. When the OE pin is pulled High, the output is typically enabled in
SIT1618BE-73-33E-25.000000 价格&库存
很抱歉,暂时无法提供与“SIT1618BE-73-33E-25.000000”相匹配的价格&库存,您可以联系我们找货
    • 5+7.34500
    • 35+7.00600
    • 100+6.60000
    • 500+6.16000
    • 1000+5.94000
    库存:1000
