7W-64.000MBD-T
7W-64.000MBD-T
    TXC(台晶)
    SMD7050_4P
    XTAL OSC XO 64.0000MHZ CMOS SMD
7W-64.000MBD-T 数据手册
Think of Frequency Think of SMD Crystal OscillatorsCMOS Output 7.0 x 5.0 x 1.3 mm 7W Series come visit our site http://www.txccorp.com Oscillators Series Features .Small SMD seam sealed clock crystal oscillator units. 4 EL0 0 D 0 C TX 66.0 .High precision characteristic covering up to wide frequency range. .Designed for automatic mounting and reflow soldering. .Tri-State function available. .Supply voltage range : 1.8 V ~ 5 V. .High stability, low jitter, low power consumption. .Main application : wireless communication, PC, and LCDM. .RoHS Compliant / Pb Free. Electrical Specifications Remark : Specification subject to change without prior notice. Please confirm with our sales. http://www.txccorp.com Item / Type 7W Output Type CMOS Output Load 15 pF Supply Voltage 15 pF , 30 pF 15 pF , 50 pF Fundamental / 3rd Overtone Oscillation Mode 1.8 V 2.5 V , 2.8 V , 3.3 V Frequency Range 1 ~ 170 MHz Frequency Stability ± 25 ppm , ± 50 ppm Operating Temperature Range - 10 ~ + 70 ℃ , - 40 ~ + 85 ℃ Storage Temperature Range - 55 ~ + 125 ℃ Voltage Vol ( Max. ) / Voh ( Min. ) 0.1 VDD / 0.9 VDD Rise ( Tr ) / Fall ( Tf ) Time 8 ns Max. Supply Current 20 mA Max. Symmetry 40 ~ 55 % , 40 ~ 60 % Start-up Time 5 ms Max. Phase Jitter ( 12 KHz ~ 20 MHz ) 1 ps Max. Aging ( at 25 ℃ ) ± 3 ppm / year Max. 5V Dimensions Units: mm 46
7W-64.000MBD-T
物料型号:TXC DEL04 66.000
器件简介:小型SMD密封晶体振荡器单元,具有高精度特性,覆盖广泛的频率范围,设计用于自动贴装和回流焊接。
引脚分配:1: ENABLE CONTROL, 2: GND, 3: OUT, 4: VDD
参数特性: - 工作频率范围:1-170MHz - 频率稳定性:±25ppm, ±50ppm - 工作温度范围:10-+70°C, -40-+85°C - 存储温度范围:-55-+125°C - 供电电压:1.8V, 2.5V, 2.8V, 3.3V, 5V - 功耗:最大20mA - 启动时间:最大5ms - 相位抖动:最大1ps - 老化率:最大±3ppm/年
功能详解:具有高稳定性、低抖动、低功耗的特点,支持三态功能。
应用信息:主要应用于无线通信、个人电脑和液晶显示器模块。
封装信息:7.0 x 5.0 x 1.3 mm,SMD封装。
7W-64.000MBD-T 价格&库存
很抱歉,暂时无法提供与“7W-64.000MBD-T”相匹配的价格&库存,您可以联系我们找货
