7X-64.000MBD-T
7X-64.000MBD-T
    TXC(台晶)
    SMD3225_4P
    XTAL OSC XO 64.0000MHZ CMOS SMD
7X-64.000MBD-T 数据手册
7X MHz CMOS Oscillator Features Applications Frequency range : 1MHz to 133MHz SMD seam sealing ceramic package Supply voltage : 1.8V ~ 3.3V CMOS output Tri-state function available External dimensions (mm) L : 3.2 x W : 2.5 x H : 1.0 RoHS compliant & Pb free Networking, Server, Storage Wireless communications Fibre channel, Ethernet, SATA, SAS, PCI-E, USB, WLAN, xDSL, xPON PC mainboard, Notebook, HDD, SSD, Graphics card, Computer peripherals Audio, Video, Gaming, Printer, DSC, IP CAM, Consumer products Electrical Characteristics Item Frequency Range (F0) Frequency Stability (Fstab) Operating Temperature Range (T OTR) Supply Voltage (VDD) Current Consumption (IDD) 7X 1MHz ~ 133MHz ±50 , ±25 ppm -10°C ~ +70°C; Note [1] ±50 , ±25 , ±20 ppm -40°C ~ +85°C; Note [1] -10°C ~ +70°C -40°C ~ +85°C 1.8V, 2.5V, 3.3V 1MHz ~ 75MHz 15 mA Max. 75MHz ~ 133MHz CMOS Output Load (CL) 15 pF Output Voltage High (VOH) 90% VDD Min. Output Voltage Low (VOL) 10% VDD Max. Rise & Fall Time (Tr / Tf) 8 ns Max. Phase Jitter, RMS Aging (Faging) Storage Temperature Range (T STR) VDD ± 10% 10 mA Max. Output Type Duty Cycle Start-up Time Enable Voltage High, Logic "1" Enable Voltage Low, Logic "0" Conditions 45% ~ 55% 5 ms Max. 70% VDD Min. 30% VDD Max. 1 ps Max. ±3 ppm Max. 10% ~ 90% of VDD Input to Pin1 Note [2] Note [3] at 25°C±3°C,first year -55°C ~ +125°C Notes: [1] Inclusive of frequency tolerance at 25°C, 1st year aging at 25°C, and variations over operating temperature, supply voltage, and load. [2] Output will be enabled if Pin1 is Logic "1" or open; Output will be disabled if Pin1 is Logic "0". [3] Freq. 10MHz~40MHz, integrated 12kHz~5MHz; Freq. >40MHz, integrated 12kHz~20MHz. Rev. 1.04-a Page 1 www.txccrystal.com 7X MHz CMOS Oscillator Dimensions (Unit: mm) Ordering Information 7X - 30.000M B E - T Frequency in Hz Packaging Method T Please contact us for available frequencies Frequency Stability Supply Voltage B C D Rev. 1.04-a Tape & Reel 3.3 V 2.5 V 1.8 V A D E Page 2 ± 25 ppm (-10˚C ~ +70˚C) ± 25 ppm (-40˚C ~ +85˚C) ± 50 ppm (-40˚C ~ +85˚C) www.txccrystal.com 7X MHz CMOS Oscillator Packing (Unit: mm) Reflow Profile Solder melting point : 220°C ± 10°C, 60 sec. Min. Peak temperature : 260°C ± 10°C, 10 sec. Min. (°C) 10 sec 260 220 180 150 120 sec Rev. 1.04-a 60 sec Page 3 Time (sec) www.txccrystal.com
7X-64.000MBD-T
物料型号:7X系列MHz CMOS Oscillator
器件简介:该振荡器提供1MHz至133MHz的频率范围,采用SMD密封陶瓷封装,供电电压为1.8V至3.3V,具有CMOS输出。
引脚分配:1号引脚为使能控制(ENABLE CONTROL),2号引脚接地(GND),3号引脚为输出(OUT),4号引脚为供电(VDD)。
参数特性:包括频率稳定性、工作温度范围、供电电压、最大电流消耗、输出类型、输出负载、高/低输出电压、上升/下降时间、占空比、启动时间、使能电压逻辑、相位抖动、老化率和存储温度范围。
功能详解:文档提供了详细的电气特性表,包括频率范围、频率稳定性、工作温度范围、供电电压、最大电流消耗、输出类型、输出负载、高/低输出电压、上升/下降时间、占空比、启动时间、使能电压逻辑、相位抖动和老化率。
应用信息:适用于网络、服务器、存储、无线通信、PCI-E、USB、WLAN、xDSL、xPON、光纤通道、以太网、SATA、SAS、音频、视频、游戏、打印机、DSC、IP摄像头、消费产品、显卡、电脑外设、PC主板、笔记本电脑、硬盘驱动器、固态硬盘等。
封装信息:提供了封装的外部尺寸和建议的布局。
7X-64.000MBD-T 价格&库存
很抱歉,暂时无法提供与“7X-64.000MBD-T”相匹配的价格&库存,您可以联系我们找货
