HHXE160ARA471MJA0G
HHXE160ARA471MJA0G
    NCC(贵弥功)
    AEC-D10X10MM_SM
    470 µF 16 V 铝聚合物电容器 径向,Can - SMD 18 毫欧 135°C 时为 4000 小时
HHXE160ARA471MJA0G 数据手册
CONDUCTIVE POLYMER HYBRID ALUMINUM ELECTROLYTIC CAPACITORS Surface Mount HXE Series ・High ripple current model is now available for JC5 size. ・High reliability is realized by hybrid electrolyte ・Endurance with ripple current : 2,000 to 4,000 hours at 135℃ ・Rated voltage range : 16 to 63Vdc, Capacitance range : 22 to 560μF ・For high temperature and high reliability applications. (Automotive equipment, Base station equipment, etc.) ・RoHS2 Compliant ・Halogen Free ・AEC-Q200 compliant : Please contact Chemi-Con for more details, test data, information. HXE Higher temperature Higher ripple HXC ◆SPECIFICATIONS Items Characteristics Category Temperature Range Rated Voltage Range Capacitance Tolerance Leakage Current -55 to +135℃ 16 to 63Vdc ±20% (M) I=0.01CV or 3μA, whichever is greater Where, I : Max. leakage current (μA) , C: Nominal capacitance(μF), V : Rated voltage(V) Rated voltage(Vdc) 16V 25V 35V 50V 63V tanδ 0.16 0.14 0.12 0.10 0.08 (Max.) Dissipation Factor (tanδ) Low Temperature Characteristics (Max. Impedance Ratio) Endurance (at 20℃, 120Hz) (at 20℃ after 2 minutes) (at 20℃, 120Hz) Z(-25℃)/Z(+20℃)≦1.5 Z(-55℃)/Z(+20℃)≦2.0 (at 100kHz) The following specifications shall be satisfied when the capacitors are restored to 20℃ after subjected to DC voltage with the rated ripple current is applied (the peak voltage shall not exceed the rated voltage) for 4,000 hours (F61, F80 : 2,000 hours) at 125℃ or 135℃. Capacitance change ≦±30% of the initial value D.F. (tanδ) ≦ 200% of the initial specified value ESR ≦ 200% of the initial specified value Leakage current ≦ The initial specified value The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours at 135℃ without voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to item 4.1 of JIS C 5101-4. Capacitance change ≦±30% of the initial value D.F. (tanδ) ≦ 200% of the initial specified value ESR ≦ 200% of the initial specified value Leakage current ≦ The initial specified value The following specifications shall be satisfied when the capacitors are restored to 20℃ after subjecting them to the DC rated voltage at 85℃, 85% RH for 2,000 hours. Appearance No significant damage Capacitance change ≦ ±30% of the initial value D.F.(tanδ) ≦ 200% of the initial specified value ESR ≦ 200% of the initial specified value Leakage current ≦ The initial specified value Shelf Life Bias Humidity Test ◆DIMENSIONS [mm] ● Terminal ● Terminal ● Size ● Size (Except F61 to HA0) (Except F61 to HA0) 0.3max. L±0.3 (Note) 0.3max. φD±0.5 P C±0.2 B±0.2 φD±0.5 W L±0.3 (Note) Note : L±0.5 for HA0 to JH0 A±0.2 Note : L±0.5 for HA0 to JH0 2 3 4 H HXE 5 6 7 8 9 10 RA 11 12 A±0.2 Size Code F61 F80 HA0 JA0 JC5 JH0 φD 6.3 6.3 8 10 10 10 L 5.8 7.7 10.0 10.0 12.5 16.5 A 6.6 6.6 8.3 10.3 10.3 10.3 B 6.6 6.6 8.3 10.3 10.3 10.3 C 7.2 7.2 9.0 11.0 11.0 11.0 W 0.5 to 0.8 0.5 to 0.8 0.7 to 1.1 0.7 to 1.1 0.7 to 1.1 1.0 to 1.3 P 1.9 1.9 3.1 4.5 4.5 4.2 : Dummy terminals ◆MARKING ◆PART NUMBERING SYSTEM 1 W P C±0.2 Vent Vent Code : G(Vibration resistant structure) code : F61 to JH0 B±0.2 Code : A code : F61 to JH0 13 14 M 15 16 17 18 G Supplement code Size code Capacitance tolerance code Capacitance code (ex. 47µF:470, 100µF:101) Taping code Terminal code (A, G) Voltage code (ex. 35V:350, 50V:500) Series code Category EX) 35V270µF 47E 270 V HE ●Rated voltage symbol Rated voltage (Vdc) 16 25 35 50 63 Symbol C E V H J Please refer to "Product code guide (conductive polymer hybrid type)" Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001X 2023 CONDUCTIVE POLYMER HYBRID ALUMINUM ELECTROLYTIC CAPACITORS Surface Mount HXESeries ◆STANDARD RATINGS WV (Vdc) Cap (μF) Size code 82 150 270 470 560 56 100 220 330 470 560 47 68 150 270 330 470 33 47 56 68 100 120 150 220 22 33 33 47 56 82 100 150 16 25 35 50 63 ESR (mΩmax./20℃, 100kHz) F61 F80 HA0 JA0 JC5 F61 F80 HA0 JA0 JC5 JH0 F61 F80 HA0 JA0 JC5 JH0 HA0 HA0 JA0 HA0 JA0 JA0 JC5 JH0 HA0 HA0 JA0 HA0 JA0 JA0 JC5 JH0 45 27 20 18 15 50 30 22 20 16 14 60 35 22 20 17 14 30 30 25 30 25 25 19 16 40 40 30 40 30 30 22 16 Rated ripple current (mArms/100kHz) 125℃ 135℃ 1,700 2,500 3,050 3,400 4,200 1,400 2,100 2,900 3,300 4,050 4,300 1,400 2,100 2,900 3,300 3,950 4,300 2,400 2,400 2,900 2,400 2,900 2,900 3,700 4,100 2,100 2,100 2,600 2,100 2,600 2,600 3,450 4,100 950 1,450 1,700 2,100 2,550 900 1,400 1,600 2,000 2,500 2,500 900 1,400 1,600 2,000 2,400 2,500 1,250 1,250 1,600 1,250 1,600 1,600 2,250 2,400 1,100 1,100 1,400 1,100 1,400 1,400 2,100 2,400 Part No. HHXE160□RA820MF61G HHXE160□RA151MF80G HHXE160□RA271MHA0G HHXE160□RA471MJA0G HHXE160□RA561MJC5G HHXE250□RA560MF61G HHXE250□RA101MF80G HHXE250□RA221MHA0G HHXE250□RA331MJA0G HHXE250□RA471MJC5G HHXE250□RA561MJH0G HHXE350□RA470MF61G HHXE350□RA680MF80G HHXE350□RA151MHA0G HHXE350□RA271MJA0G HHXE350□RA331MJC5G HHXE350□RA471MJH0G HHXE500□RA330MHA0G HHXE500□RA470MHA0G HHXE500□RA560MJA0G HHXE500□RA680MHA0G HHXE500□RA101MJA0G HHXE500□RA121MJA0G HHXE500□RA151MJC5G HHXE500□RA221MJH0G HHXE630□RA220MHA0G HHXE630□RA330MHA0G HHXE630□RA330MJA0G HHXE630□RA470MHA0G HHXE630□RA560MJA0G HHXE630□RA820MJA0G HHXE630□RA101MJC5G HHXE630□RA151MJH0G □ : Enter the appropriate terminal code. ◆RATED RIPPLE CURRENT MULTIPLIERS ・Frequency Multipliers Capacitance(µF) Frequency(Hz) 22 to 33 47 to 150 220 to 560 120 0.07 0.10 0.13 1k 0.30 0.40 0.45 5k 0.50 0.60 0.65 10k 0.60 0.70 0.75 20k 0.70 0.80 0.85 30k 0.75 0.80 0.85 100k to 500k 1.00 1.00 1.00 Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001X 2023 CONDUCTIVE POLYMER HYBRID ALUMINUM ELECTROLYTIC CAPACITORS Product Guide ■ Always read "Notes on Use" before using the product in order to enable you to use the product correctly and prevent any faults and accidents from occurring. ■ Request the Product Specification on the product of NIPPON CHEMI-CON CORPORATION to refer to it as well as this brochure prior to the order of the products. Some specific notes on use of the ordered product may be described in the specifications. ■ The products listed in this catalog are designed and manufactured for general electronics equipment use and are not intended for use in applications that can adversely affect human life; where the malfunction of equipment may cause damage to life or property. In addition, our products are not intended to be used in specific applications that may cause a major social impact. Please consult with us in advance of usage of our products in the following listed applications. ① Aerospace equipment ② Power generation equipment such as thermal power, nuclear power etc. ③ Medical equipment ④ Transport equipment (automobiles, trains, ships, etc.) ⑤ Transportation control equipment ⑥ Disaster prevention / crime prevention equipment ⑦ Highly publicized information processing equipment ⑧ Submarine equipment ⑨ Other applications that are not considered general-purpose applications. ■ The circuits described as examples in this catalog and the "delivery specifications" are featured in order to show the operations and usage of our products, however, this fact does not guarantee that the circuits are available to function in your equipment systems. We are not in any case responsible for any failures or damage caused by the use of information contained herein. You should examine our products, of which the characteristics are described in the "delivery specifications" and other documents, and determine whether or not our products suit your requirements according to the specifications of your equipment systems. Therefore, you bear final responsibility regarding the use of our products. Please make sure that you take appropriate safety measures such as use of redundant design and malfunction prevention measures in order to prevent fatal accidents and/or fires in the event any of our products malfunction. ■ We strongly recommend our customers to purchase Nippon Chemi-Con products only through our official sales channels. We assume no responsibility for any defects or damages caused by using products purchased from outside our official sales channel or of counterfeit goods. In addition, we will ask the customer to pay the investigation cost for products purchased outside our official sales channel. ■ We reserve the right to discontinue production and delivery of products. We do not guarantee that all the products included in this catalog will be available in the future. The aforementioned does not apply in the case of individual agreements deviating from the foregoing for customer-specific products ■ We continually strive to improve the quality and reliability of our products, but in any case that our product does not meet our published specifications, please stop using it promptly and contact us immediately. As for compensation for non-conforming goods delivered by Chemi-Con, we will limit it only to goods found in non-compliance of our published specifications. This may be accomplished by a no cost replacement of non-conforming individual products, a credit of the piece price paid per each individual non-conforming product, or in other ways deemed necessary. In addition, we have an established system with enhanced traceability, therefore we will limit the applicable lot items for any potential compensation. Part Numbering System Part Numbering System (Appendix) Standardization Available Items by Manufacturing Locations Environmental Measures Technical Note Precautions and Guidelines Recommended Soldering Conditions Taping, Lead-preforming, Terminal and Packaging Options Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001X 2023
HHXE160ARA471MJA0G 价格&库存
很抱歉,暂时无法提供与“HHXE160ARA471MJA0G”相匹配的价格&库存,您可以联系我们找货
HHXE160ARA471MJA0G
    • 1+2.86989
    • 200+1.11068
    • 500+1.07158
    • 1000+1.05236
    HHXE160ARA471MJA0G
      HHXE160ARA471MJA0G
      • 1+22.725631+2.93598
      • 10+15.0325710+1.94209
      • 50+11.8450250+1.53029
      • 100+10.83930100+1.40036
      库存:1039
      HHXE160ARA471MJA0G
      • 500+9.10912500+1.17683
      • 1000+8.564611000+1.10648
      • 1500+8.289991500+1.07101
      • 2500+7.983852500+1.03146
      • 3500+7.804013500+1.00822
      • 5000+7.630255000+0.98577
      库存:1039
