Additional Resources:
Product Page
3D Model
PCB Footprint
date
08/05/2022
page 1 of 3
SERIES: DS01-254 | DESCRIPTION: DIP SWITCH
FEATURES
• 2.54 mm pitch
• convex or flat bottom option
• 1~12 pole options
• long or short pin option
• raised actuator
• through hole
SPECIFICATIONS
parameter
conditions/description
max
units
rated voltage (per pole)
switching
non-switching
min
typ
24
50
Vdc
Vdc
rated current (per pole)
switching
non-switching
25
100
mA
mA
withstanding voltage
for 1 minute
contact resistance
initial
after life test
insulation resistance
at 500 Vdc
300
Vac
50
100
100
MΩ
operating force
1000
g
2
mm
-40
85
°C
-40
85
switch travel
operating temperature
storage temperature
life
2000
flammability rating
UL94V-0
RoHS
yes
mΩ
mΩ
°C
cycles
SOLDERABILITY
parameter
min
1
hand soldering
for maximum 3 seconds
315
wave soldering1
for maximum 5 seconds
240
Notes:
1. Keep in “off” position during soldering.
PART NUMBER KEY
DS01 X - 254 - X - XX BE
Base Number
Notes:
Base:
“blank” = Flat
C2 = Convex
Pin Length:
S = Short
L = Long
2. Convex base only available in poles 3~12.
cuidevices.com
No. of Poles:
01 07
02 08
03 09
04 10
05 12
06
typ
max
units
320
325
°C
250
260
°C
Product Page
3D Model
PCB Footprint
CUI DEVICES | SERIES: DS01-254 | DESCRIPTION: DIP SWITCH
date 08/05/2022 | page 2 of 3
MECHANICAL DRAWING
units: mm
tolerance:
0.5
很抱歉,暂时无法提供与“DS01C-254-L-04BE”相匹配的价格&库存,您可以联系我们找货
