CONSMA008-G
SMA RF Interface, Jack, 50 Ω, Threaded, 18 GHz Operating Frequency, 1 Position,
Printed Circuit Board, Board Mount, -65 – 165 °C [-85 – 329 °F]
CONSMA008-G
ACTIVE
TE Internal #: CONSMA008-G
Frequency, 1 Position, Printed Circuit Board, Board Mount, -65 –
View on TE.com >
Connectors > RF Connectors > Coax Connectors
RF Interface: SMA
RF Connector Style: Jack
Impedance: 50 Ω
RF Connector Coupling Mechanism: Threaded
Operating Frequency: 18 GHz
Features
Product Type Features
Connector Product Type
Connector Assembly
RF Interface
SMA
RF Connector Style
Jack
Sealable
No
Connector & Contact Terminates To
Configuration Features
PCB Mount Orientation
Vertical
Number of Positions
1
Number of Coaxial Contacts
1
Electrical Characteristics
Impedance
50 Ω
Body Features
Cable Connector Orientation
Straight
Body Material
Brass
Body Material Finish
Plated
Body Plating Material
Gold
Contact Features
RF Connector Center Contact Plating Material
RF800
Connector
For support call+1
522 6752 Center Contact Material
Gold
Beryllium Copper
11/20/2023 01:49AM | Page 1
CONSMA008-G
Gold
RF Connector Center Contact Material
Beryllium Copper
Termination Features
Termination Method to Printed Circuit Board
Through Hole - Solder
Termination Method to Wire & Cable
Solder
Mechanical Attachment
Threaded
Connector Mounting Type
Board Mount
RF Contact Captivation Method
Mechanical
Detent
Without
Usage Conditions
Operating Temperature Range
-65 – 165 °C[-85 – 329 °F]
Operation/Application
Operating Frequency
18 GHz
Circuit Application
Signal
Packaging Features
Packaging Quantity
100
Packaging Method
Tray
Other
Lockwasher Material
Brass
Dielectric Material
PTFE
Product Compliance
For compliance documentation, visit the product page on TE.com>
EU RoHS Directive 2011/65/EU
Compliant with Exemptions
EU ELV Directive 2000/53/EC
Not Yet Reviewed
China RoHS 2 Directive MIIT Order No 32, 2016
Restricted Materials Above Threshold
EU REACH Regulation (EC) No. 1907/2006
Current ECHA Candidate List: JUNE 2023
(235)
Not Yet Reviewed
Halogen Content
Not Yet Reviewed for halogen content
Solder Process Capability
Not reviewed for solder process capability
Product Compliance Disclaimer
This information is provided based on reasonable inquiry of our suppliers and represents our current actual knowledge
For support call+1 800 522 6752
11/20/2023 01:49AM | Page 2
CONSMA008-G
based on the information they provided. This information is subject to change. The part numbers that TE has identified as
EU RoHS compliant have a maximum concentration of 0.1% by weight in homogenous materials for lead, hexavalent
chromium, mercury, PBB, PBDE, DBP, BBP, DEHP, DIBP, and 0.01% for cadmium, or qualify for an exemption to these
limits as defined in the Annexes of Directive 2011/65/EU (RoHS2). Finished electrical and electronic equipment products
will be CE marked as required by Directive 2011/65/EU. Components may not be CE marked.Additionally, the part
numbers that TE has identified as EU ELV compliant have a maximum concentration of 0.1% by weight in homogenous
materials for lead, hexavalent chromium, and mercury, and 0.01% for cadmium, or qualify for an exemption to these limits
as defined in the Annexes of Directive 2000/53/EC (ELV). Regarding the REACH Regulations, TE’s information on SVHC in
articles for this part number is still based on the European Chemical Agency (ECHA) ‘Guidance on requirements for
substances in articles’(Version: 2, April 2011), applying the 0.1% weight on weight concentration threshold at the finished
product level. TE is aware of the European Court of Justice ruling of September 10th, 2015 also known as O5A (Once An
Article Always An Article) stating that, in case of ‘complex object’, the threshold for a SVHC must be applied to both the
product as a whole and simultaneously to each of the articles forming part of its composition. TE has evaluated this ruling
based on the new ECHA “Guidance on requirements for substances in articles” (June 2017, version 4.0) and will be
updating its statements accordingly.
Compatible Parts
TE Part # ADP-SMAM-MCXF
TE Part # ADP-SMAM-MCXM
TE Part # ADP-SMAM-MMXF
TE Part # ADP-SMAM-MMXM
SMA Plug to MCX Jack
SMA Plug to MCX Plug
SMA Jack to MMCX Jack
SMA Plug to MMCX Plug
TE Part # ADP-SMAM-RPSF
TE Part # ADP-SMAM-RPSF-G
TE Part # ADP-SMAM-SMAF-T-G
TE Part # ADP-SMAM-SMAM
RP-SMA Jack to RP-SMA Jack
SMA Plug to RP-SMA Jack
SMA Plug to SMA Jack (2) Tee
SMA Plug to SMA Plug
TE Part # ADP-SMAM-SMAM-G
TE Part # ADP-SMAM-SMBF-G
TE Part # ADP-SMAM-SMBM-G
TE Part # ADP-SMAM-UFLF
SMA Plug to SMB Jack
SMA Plug to SMB Plug
SMA Plug to U.FL/MHF1 Jack
11/20/2023 01:49AM | Page 3
CONSMA008-G
TE Part # L9000012-01
TE Part # L9000011-01
TE Part # L9000017-01
TE Part # L9000021-01
Antenna 1/2 Wave Whip 1.4GHz SMA
Antenna 1/2 Wave Whip Swivel 1.4
GHz SMA
Antenna 1/2 Wave Whip 2.4GHz SMA
TE Part # L9000020-01
TE Part # L9000024-01
TE Part # L9000026-01
TE Part # L9000028-01
Antenna 1/2 Wave Whip Swivel 2.4
Antenna 1/4 Wave R-Angle 2.4GHz
Antenna 1/2 Wave R-Angle 2.4GHz
SMA
SMA
GHz SMA
Customers Also Bought
TE Part #5553811-2
TE Part #745191-7
TE Part #2267078-3
TE Part #5-5176264-8
ASSY, EMI RCPT,24 POSN, SCR LK
50 RCPT SP/MS STD
TMS1T5B2M6RE
06 AMPMODU 2MM DR VERT MNT LF
TE Part #3-2176403-8
TE Part #ADP-BNCF-BNCF-B
TE Part #OTX-433-HH-KF5-MS
3550 36R 1%
BNC Jack to BNC Jack Bulkhead
Remote MS 433MHz OOK AM 5Btn KF
TX EU
Documents
Datasheets & Catalog Pages
SMA FEMALE PCB MOUNT EXTENDED
English
Standard vs. Reverse Polarity (RP) SMA Connectors
English
The FCC Road Part 15 From Concept to Approval
English
RF Coaxial Connector Gender Naming
English
11/20/2023 01:49AM | Page 4
CONSMA008-G
English
RF 101 Information for the RF Challenged
English
11/20/2023 01:49AM | Page 5
