深圳市首韩科技有限公司
SHENZHEN SHOUHAN TECHNOLOGYCO.,LTD
Tel: 0755-27597601 Fax: 0755-27597491
承
认
书
产品名称 Project:
科
规格型号 Part No:
有
户 Customer:
技
客
限
公
司
SPECIFICATION FOR APPROVAL
贴片电感
韩
CYH127-10UH
首
贵公司承认印 Approal slgnatures
签
章/Signatures
深
圳
市
料 号/Part No.
日期 Date:
拟制/Drawn
李春风
审核/Check
钟华华
批准/Approved
罗孝金
深圳市首韩科技有限公司
1.Features
①. High performance (Isat) realize by metal dust core .
②. Low profile: Thickness max.2.0~5.0mm.
③. Low loss and low resistance.
④. Capable of corresponding high frequency 1MHz~5MHz.
⑤ Ultra low buzz noise, due to composite construction.
⑥. The products contain no lead and also support lead-free soldering.
司
2.Applications area
Ideally used in NB/Desktop/server/Graphic card, LCD TV/Projector, etc as DC-DC Converter.
C
D
B
科
技
E
有
A
公
Externl Dimensions (unit : mm )
限
3.
4. Product Code
127
100
圳
市
CYH
首
韩
注:印2号(宽2.9*高1.6)宋体
UNIT: mm
A:12.3(Max)
B:8.0(Max)
C:5.0
D:7.6
E:12.0
F:5.4
G:2.9
H:7.0
I:12.8
M
Code 代码
TOLERANCE 公差
INDUCTANCE VALUE 电感值
深
DIMENSIONS 尺寸
SERIAL CODE 系列代码
• 电感值Inductance Value
(1R0:1.0uH; 100: 10uH; 101:100uH)
Tolerance 公差
J
±5%
K
±10%
L
±15%
M
±20%
P
±25%
N
±30%
深圳市首韩科技有限公司
5. Electrical
Characteristics
NOMINAL
INDUCTANCE Test Freq. (kHz/v)
( uH )
DCR
(Ω)MAX
IDC
(A)MAX
1.0
100/0.25
6.50m
10.40
CYH127-1R5N
1.5
100/0.25
8.50m
9.20
CYH127-2R2N
2.2
100/0.25
11.00m
8.40
CYH127-2R7N
2.7
100/0.25
12.20m
7.80
CYH127-3R3N
3.3
100/0.25
13.00m
CYH127-3R9N
3.9
100/0.25
14.00m
CYH127-4R7N
4.7
100/0.25
15.80m
6.80
CYH127-5R6N
5.6
100/0.25
16.70m
6.70
CYH127-6R8N
6.8
100/0.25
18.40m
6.50
CYH127-7R6N
7.6
100/0.25
20.00m
5.90
CYH127-100M
10
100/0.25
CYH127-120M
12
100/0.25
CYH127-150M
15
CYH127-180M
18
CYH127-220M
22
CYH127-270M
27
CYH127-330M
CYH127-390M
7.60
26.00m
4.90
100/0.25
28.60m
4.50
100/0.25
39.20m
3.90
100/0.25
43.20m
3.60
100/0.25
51.09m
3.30
33
100/0.25
64.80m
3.00
39
100/0.25
72.90m
2.75
47
100/0.25
100.00m
2.50
56
100/0.25
110.00m
2.35
CYH127-680M
68
100/0.25
140.00m
2.10
CYH127-820M
82
100/0.25
160.00m
1.95
CYH127-101M
100
100/0.25
220.00m
1.70
CYH127-121M
120
100/0.25
250.00m
1.60
CYH127-151M
150
100/0.25
280.00m
1.42
CYH127-181M
180
100/0.25
290.00m
1.30
CYH127-221M
220
100/0.25
299.00m
1.16
CYH127-271M
270
100/0.25
403.00m
1.06
CYH127-331M
330
100/0.25
455.00m
950m
CYH127-391M
390
100/0.25
494.00m
880m
CYH127-471M
470
100/0.25
689.00m
790m
CYH127-561M
560
100/0.25
793.00m
730m
CYH127-470M
深
市
CYH127-560M
• Notes
1. All test data is referenced to 25 °C ambient
科
技
5.40
首
23.40m
韩
7.20
圳
有
公
司
CYH127-1R0N
限
PART No.
深圳市首韩科技有限公司
2. Operating temperature range - 55 °C to + 125 °C
3. Irms (A):DC current (A) that will cause an approximate ΔT of 40 °C(reference ambient temperature is 25 °C)
4. Isat(A):DC current (A) that will cause L0 to drop approximately 30 %
5. The part temperature (ambient + temp rise) should not exceed 125 °C under worst case operating conditions.
Circuit design, component placement, PWB trace size and thickness, airflow and other cooling provisions
all affect the part temperature. Part temperature should be verified in the end application.
6.Absolute maximum voltage 30VDC
司
6.Minimum Packaging and storage
D
规 格
尺寸
C
7"
Φ330±2.0
Φ178±2.0
限
A
13"
B
B
Φ90 ± 2.0
C
2.3
有
A
公
• 包装Packing
• Tape Carrier Packaging:
Standard Quantity
(pcs/reel)
CYH73
1000
CYH74
1000
韩
CYH125
Type
科
Type
技
D
21.5
500/盘
Standard Quantity
(pcs/reel)
CYH127
500
CYH129
500
深
圳
市
• Tearing Off Force
首
500
The force for tearing off cover tape is 15 to 60 grams in the arrow direction under the following conditions
Room
Temp. (
5~35
Room Humidity
45~85
Room atm
(hPa)
860~1060
Tearing Speed
mm/min
300
• Application Notice
Storage Conditions To maintain the solderability of terminal electrodes:
1. Temperature and humidity conditions: Less than 30℃ and 70% RH.
2. Recommended products should be used within 6 months form the time of delivery.
3. The packaging material should be kept where no chlorine or sulfur exists in the air.
Transportation
1. Products should be handled with care to avoid damage or contamination from perspiration and skin oils .
2. The use of tweezers or vacuum pick up is strongly recommended for individual components. Bulk handling
should ensure that abrasion and mechanical shock are minimized.
很抱歉,暂时无法提供与“CYH127-10UH”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.88536
- 50+1.49341
- 150+1.32549
- 500+1.11586
- 2500+1.02255
- 5000+0.96657
- 国内价格
- 5+2.32768
- 50+1.83121
- 150+1.61852
- 500+1.34488
- 2500+1.22669
- 5000+1.15580
