DS12W THRU DS120W SOD123FL
Surface Mount Schottky Barrier Rectifier
Pinning
Reverse Voltage - 20 to 200 V
1.Cathode
Forward Current - 1 A
2.Anode
1
FEATURES
Metal silicon junction, majority carrier conduction
For surface mounted applications
Low power loss, high efficiency
2
SOD123FL
High forward surge current capability
Marking Code
For use in low voltage, high frequency inverters,
free wheeling, and polarity protection applications
DS12W
K12
S12
DS14W
K14
S14
Lead free in comply with EU RoHS 2011/65/EU directives
DS16W
K16
S16
MECHANICAL DATA
Case: SOD-123FL
Terminals: Solderable per MIL-STD-750, Method 2026
DS18W
K18
S18
DS110W
K110
S110
DS112W
K112
S112
DS115W
K115
S115
DS120W
K120
S120
Approx. Weight: 15mg / 0.00048oz
Absolute Maximum Ratings and Electrical characteristics
Ratings at 25 ° ambient temperature unless otherwise specified.Single phase, half wave, 60Hz resistive or inductive load,
for capacitive load, derate by 20 %
Parameter
Symbols
DS12W
DS14W
DS16W
DS18W
DS110W
DS112W
DS115W
DS120W
Units
Maximum Repetitive Peak Reverse Voltage
VRRM
60
80
100
120
150
200
V
Maximum RMS voltage
VRMS
14
28
42
56
70
84
105
140
V
Maximum DC Blocking Voltage
VDC
60
80
100
120
150
200
V
Maximum Average Forward Rectified Current
IF(AV)
Peak Forward Surge Current, 8.3ms Single Half Sinewave Superimposed On Rated Load (JEDEC method)
IFSM
Maximum Instantaneous Forward Voltage at 1 A
VF
Maximum Instantaneous Reverse Current TA = 25°C
at Rated DC Reverse Voltage
TA = 100°C
IR
Typical Junction Capacitance(1)
Cj
Typical Thermal Resistance
(2)
Operating Junction Temperature Range
Storage Temperature Range
1.0
A
40
0.55
30
0.70
0.3
10
110
A
0.85
0.90
0.2
5
0.1
2
80
V
mA
pF
RθJA
100
°C/W
Tj
-55 ~ +150
°C
Tstg
-55 ~ +150
°C
(1)Measured at 1 MHz and applied reverse voltage of 4 V D.C
(2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas.
www.yfwdiode.com
1/3
Dongguan YFW Electronics Co, Ltd.
Fig.2 Typical Reverse Characteristics
Instaneous Reverse Current ( μA)
Fig.1 Forward Current Derating Curve
Average Forward Current (A)
1.2
1.0
0.8
0.6
0.4
0.2
Single phase half-wave 60 Hz
0.0
25
50
75
100
125
150
10 4
10 3
T J =100°C
10 2
T J =25°C
10 1
10 0
Fig.3 Typical Forward Characteristic
80
100
Fig.4 Typical Junction Capacitance
500
Junction Capacitance ( pF)
1.0
DS12W/DS14W
DS16W/DS18W
DS110W/DS112W
DS115W/DS120W
0.1
0.2
0.6
0.8
1.0
1.2
1.4
1.6
T J =25°C
200
100
50
DS12W/DS14W
DS16W-DS120W
10
1.8
1
0.1
100
10
Instaneous Forward Voltage (V)
Reverse Voltage (V)
Fig.5 Maximum Non-Repetitive Peak
Forward Surage Current
Fig.6- Typical Transient Thermal Impedance
Transient Thermal Impedance( °C /W)
Instaneous Forward Current (A)
60
Percent of Rated Peak Reverse Voltage(%)
Case Temperature (°C)
Peak Forward Surage Current (A)
40
DS12W-DS18W
DS110W-DS120W
40
30
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
10
100
Number of Cycles at 60Hz
www.yfwdiode.com
1000
100
10
1
0.01
0.1
1
10
100
t, Pulse Duration(sec)
2/3
SOD-123FL
Package Outline
Plastic surface mounted package; 2 leads
∠ALL ROUND
C
A
∠ALL ROUND
VM
D
E
A
g
g
pad
e
E
A
pad
HE
Top View
A
C
D
E
e
g
HE
max
1.3
0.20
2.9
1.9
1.1
0.9
3.8
min
0.9
0.12
2.6
1.7
0.8
0.7
3.5
max
43
7.9
114
75
43
35
150
min
35
4.7
102
67
31
28
138
UNIT
mm
mil
Bottom View
7°
The recommended mounting pad size
1.2
(47)
2.0
(79)
1.2
(47)
1.2
(47)
Unit: mm
(mil)
Summary of Packing Options
Package
SOD-123FL
www.yfwdiode.com
Packing Description
Packing Quantity
Industry Standard
Tape/Reel,13”reel
10000
EIA-481-1
Tape/Reel,7”reel
3000
EIA-481-1
3/3
很抱歉,暂时无法提供与“DS120W”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.19576
- 300+0.12778
- 1200+0.12586
- 3000+0.11011
- 国内价格
- 10+0.24419
- 100+0.19354
- 300+0.16535
- 3000+0.14472
- 6000+0.13014
- 9000+0.12215
