TD3083(SL)(T1)-GV
TD3083(SL)(T1)-GV
    LIGHTNING(天电光电)
    SMD-6P
    红外发射管 SMD-6 6V
TD3083(SL)(T1)-GV 数据手册
TD303X,TD304X,TD306X,TD308X Series www.tdled.com DIP6, DC Input, Zero-Cross Photo TRIAC Coupler SCHEMATIC Description The TD303X, TD304X and TD306X and TD308X series combine an AlGaAs infrared emitting diode as the emitter which is optically coupled to a monolithic silicon zero-cross photo triac in a 1 6 2 5 3 4 plastic DIP4 package with different lead forming options. PIN DEFINITION Features  High isolation 5000 VRMS  DC input with zero-cross photo triac output  Operating temperature range - 40 °C to 100 °C  REACH & RoHS compliance  MSL class 1  Regulatory Approvals 1. Anode 2. Cathode 3. NC 4. Terminal 5. Substrate 6. Terminal PACKAGE OUTLINE  UL - UL1577  VDE - EN60747-5-5(VDE0884-5)  CQC – GB4943.1, GB8898 Applications  Solenoid/valve controls  Lighting controls  Motor controls  Temperature controls  Static AC power switches  Solid state relays  Interfacing microprocessors to 115 to 240VAC peripherals Document No:DWI-10037 Rev: A05 Release Date: 2023/10/07 1 TD303X,TD304X,TD306X,TD308X Series www.tdled.com DIP6, DC Input, Zero-Cross Photo TRIAC Coupler ABSOLUTE MAXIMUM RATINGS PARAMETER SYMBOL VALUE UNIT Forward Current IF 60 mA Reverse Voltage VR 6 V Junction Temperature Tj 125 °C Input Power Dissipation PI 100 mW NOTE INPUT OUTPUT TD303X Off-state Output Terminal Voltage TD304X TD306X 250 VDRM TD308X 400 600 V 800 Peak Repetitive Surge Current PW=100μs, 120pps ITSM 1 A On-State RMS Current IT(RMS) 100 mA Junction Temperature Tj 125 °C Output Power Dissipation PO 300 mW Total Power Dissipation Ptot 400 mW Isolation Voltage Viso 5000 Vrms Operating Temperature Topr -40~100 °C Storage Temperature Tstg -55~125 °C Soldering Temperature Tsol 260 °C COMMON 1 2 Note 1. AC For 1 Minute, R.H. = 40 ~ 60% Note 2. For 10 seconds Document No:DWI-10037 Rev: A05 Release Date: 2023/10/07 2 TD303X,TD304X,TD306X,TD308X Series www.tdled.com DIP6, DC Input, Zero-Cross Photo TRIAC Coupler ELECTRICAL OPTICAL CHARACTERISTICS at Ta=25°C PARAMETER SYMBOL MIN. TYP. MAX. UNIT TEST CONDITION NOTE INPUT Forward Voltage VF - 1.24 1.4 V IF=10mA Reverse Current IR - - 10 μA VR=6V Input Capacitance Cin - 8.5 250 pF V=0, f=1kHz OUTPUT Peak Off-state Current, Either Direction Peak On-state Current, Either Direction Critical Rate of Rise of Off-state Voltage IDRM - - 500 nA VTM - 1.59 2.5 V dV/dt 1000 - - V/μs VDRM=Rated VDRM IF=0 3 ITM=100mA VPEAK =400V, IF =0 4 TRANSFER CHARACTERISTICS TD3031,TD3041, LED Trigger Current TD3061,TD3081 TD3032,TD3042, TD3062.TD3082 IFT TD3033,TD3043, TD3063,TD3083 Holding Current IH Isolation Resistance Riso Floating Capacitance CIO - - 15 - - 10 - - 5 - 237 - μA - Ω DC500V, 40 ~ 60% R.H. - pF V=0, f=1MHz 10^12 10^14 - 0.4 Terminal Voltage = 3V mA ITM=100mA ZERO-CROSSING CHARACTERISTICS Inhibit Voltage VINH - - 20 V Leakage in Inhibited State IDRM2 - - 500 μA IF=Rated IFT IF=Rated IFT VDRM=Rated VDRM Note3. Test voltage must be applied within dV/dt rating. Note4. Refer to Fig.15 & Fig.16 Document No:DWI-10037 Rev: A05 Release Date: 2023/10/07 3 TD303X,TD304X,TD306X,TD308X Series www.tdled.com DIP6, DC Input, Zero-Cross Photo TRIAC Coupler CHARACTERISTIC CURVES Fig.1 Forward Current vs. Ambient Temperature Fig.2 On-state Terminal Current vs. Ambient Temperature Fig.3 Forward Current vs. Forward Voltage Fig.4 Off-state Terminal Current vs. Ambient Temperature Fig.5 Normalized Off-state Terminal Voltage vs. Ambient Temperature Fig.6 Normalized Trigger Current vs. LED Trigger Pulse Width Document No:DWI-10037 Rev: A05 Release Date: 2023/10/07 4 TD303X,TD304X,TD306X,TD308X Series www.tdled.com DIP6, DC Input, Zero-Cross Photo TRIAC Coupler CHARACTERISTIC CURVES Fig.7 Normalized Trigger Current vs. Ambient Temperature Fig.8 On-state Terminal Voltage vs. Ambient Temperature Fig.9 On-state Terminal Voltage vs. On-state Terminal Current Fig.10 Holding Current vs. Ambient Temperature Fig.11 Normalized Inhibit Voltage vs. Ambient Temperature Fig.12 Normalized Leakage in Inhibit State vs. Ambient Temperature Document No:DWI-10037 Rev: A05 Release Date: 2023/10/07 5 TD303X,TD304X,TD306X,TD308X Series www.tdled.com DIP6, DC Input, Zero-Cross Photo TRIAC Coupler CHARACTERISTIC CURVES Fig.13 Turn On Time vs. Forward Current Fig.14 Turn On Time vs. Ambient Temperature TEST CIRCUITS Fig.15 Test Circuits of Turn On Time Fig.16 Waveforms of Turn On Time Fig.17 Test Circuits of dV/dt Fig.18 Waveforms of dV/dt Document No:DWI-10037 Rev: A05 Release Date: 2023/10/07 6 TD303X,TD304X,TD306X,TD308X Series www.tdled.com DIP6, DC Input, Zero-Cross Photo TRIAC Coupler PACKAGE DIMENSIONS (Dimensions in mm unless otherwise stated) Standard DIP – Through Hole (DIP Type) Gullwing (400mil) Lead Forming – Through Hole (M Type) Document No:DWI-10037 Rev: A05 Release Date: 2023/10/07 7 TD303X,TD304X,TD306X,TD308X Series www.tdled.com DIP6, DC Input, Zero-Cross Photo TRIAC Coupler PACKAGE DIMENSIONS (Dimensions in mm unless otherwise stated) Surface Mount Lead Forming (S Type) Surface Mount (Low Profile) Lead Forming (SL Type) Document No:DWI-10037 Rev: A05 Release Date: 2023/10/07 8 TD303X,TD304X,TD306X,TD308X Series www.tdled.com DIP6, DC Input, Zero-Cross Photo TRIAC Coupler RECOMMENDED SOLDER MASK (Dimensions in mm unless otherwise stated) Surface Mount Lead Forming & Surface Mount (Low Profile) Lead Forming Surface Mount (Gullwing) Lead Forming Document No:DWI-10037 Rev: A05 Release Date: 2023/10/07 9 TD303X,TD304X,TD306X,TD308X Series www.tdled.com DIP6, DC Input, Zero-Cross Photo TRIAC Coupler TUBE SPECIFICATIONS (Dimensions in mm unless otherwise stated) Standard DIP Option M Document No:DWI-10037 Rev: A05 Release Date: 2023/10/07 10 TD303X,TD304X,TD306X,TD308X Series www.tdled.com DIP6, DC Input, Zero-Cross Photo TRIAC Coupler BOX SPECIFICATIONS (Tube Type) Inner Box  L x W x H = 52.5cm x 10.7cm x 4.7cm Outer Box  L x W x H = 53.5cm x 23.5cm x 25.5cm Document No:DWI-10037 Rev: A05 Release Date: 2023/10/07 11 TD303X,TD304X,TD306X,TD308X Series www.tdled.com DIP6, DC Input, Zero-Cross Photo TRIAC Coupler CARRIER TAPE SPECIFICATIONS (Dimensions in mm unless otherwise stated) Option S(T1) & SL(T1) Option S(T2) & SL(T2) Document No:DWI-10037 Rev: A05 Release Date: 2023/10/07 12 TD303X,TD304X,TD306X,TD308X Series www.tdled.com DIP6, DC Input, Zero-Cross Photo TRIAC Coupler REEL SPECIFICATIONS (Dimensions in mm unless otherwise stated) Option S & Option SL Document No:DWI-10037 Rev: A05 Release Date: 2023/10/07 13 TD303X,TD304X,TD306X,TD308X Series www.tdled.com DIP6, DC Input, Zero-Cross Photo TRIAC Coupler BOX SPECIFICATIONS (Reel Type) Inner Box  L x W x H = 36cm x 36cm x 6.9cm Outer Box  L x W x H = 45cm x 38cm x 38cm Document No:DWI-10037 Rev: A05 Release Date: 2023/10/07 14 TD303X,TD304X,TD306X,TD308X Series www.tdled.com DIP6, DC Input, Zero-Cross Photo TRIAC Coupler ORDERING AND MARKING INFORMATION MARKING INFORMATION TD 30XX V Y A WW ORDERING INFORMATION : Company Abbr. : Part Number & Rank : VDE Option : Fiscal Year : Manufacturing Code : Work Week LABEL INFORMATION TD30XX(Y)(Z)-GV TD – Company Abbr. 30XX – Part Number (31/32/33/41/42/43/61/62/63) Y – Lead Form Option (M/S/SL/None) Z – Tape and Reel Option (T1/T2) G – Green Option (G or None) V – VDE Option (V or None) Packing Quantity Option Quantity Quantity – Inner box Quantity – Outer box None 50 Units/Tube 32 Tubes/Inner box 10 Inner box/Outer box = 16k Units M 50 Units/Tube 32 Tubes/Inner box 10 Inner box/Outer box = 16k Units S(T1) 1000 Units/Reel 3 Reels/Inner box 5 Inner box/Outer box = 15k Units S(T2) 1000 Units/Reel 3 Reels/Inner box 5 Inner box/Outer box = 15k Units SL(T1) 1000 Units/Reel 3 Reels/Inner box 5 Inner box/Outer box = 15k Units SL(T2) 1000 Units/Reel 3 Reels/Inner box 5 Inner box/Outer box = 15k Units Document No:DWI-10037 Rev: A05 Release Date: 2023/10/07 15 TD303X,TD304X,TD306X,TD308X Series www.tdled.com DIP6, DC Input, Zero-Cross Photo TRIAC Coupler REFLOW INFORMATION REFLOW PROFILE Profile Feature Sn-Pb Assembly Profile Pb-Free Assembly Profile Temperature Min. (Tsmin) 100 150°C Temperature Max. (Tsmax) 150 200°C Time (ts) from (Tsmin to Tsmax) 60-120 seconds 60-120 seconds Ramp-up Rate (tL to tP) 3°C/second max. 3°C/second max. Liquidous Temperature (TL) 183°C 217°C Time (tL) Maintained Above (TL) 60 – 150 seconds 60 – 150 seconds Peak Body Package Temperature 235°C +0°C / -5°C 260°C +0°C / -5°C Time (tP) within 5°C of 260°C 20 seconds 30 seconds Ramp-down Rate (TP to TL) 6°C/second max 6°C/second max Time 25°C to Peak Temperature 6 minutes max. 8 minutes max. Document No:DWI-10037 Rev: A05 Release Date: 2023/10/07 16 TD303X,TD304X,TD306X,TD308X Series www.tdled.com DIP6, DC Input, Zero-Cross Photo TRIAC Coupler DISCLAIMER  LIGHTNING is continually improving the quality, reliability, function and design. LIGHTNING reserves the right to make changes without further notices.  The characteristic curves shown in this datasheet are representing typical performance which are not guaranteed.  LIGHTNING makes no warranty, representation or guarantee regarding the suitability of the products for any particular purpose or the continuing production of any product. To the maximum extent permitted by applicable law, LIGHTNING disclaims (a) any and all liability arising out of the application or use of any product, (b) any and all liability, including without limitation special, consequential or incidental damages, and (c) any and all implied warranties, including warranties of fitness for particular  The products shown in this publication are designed for the general use in electronic applications such as office automation, equipment, communications devices, audio/visual equipment, electrical application and instrumentation purpose, non-infringement and merchantability.  This product is not intended to be used for military, aircraft, automotive, medical, life sustaining or lifesaving applications or any other application which can result in human injury or death.  Please contact LIGHTNING sales agent for special application request.  Immerge unit’s body in solder paste is not recommended.  Parameters provided in datasheets may vary in different applications and performance may vary over time. All operating parameters, including typical parameters, must be validated in each customer application by the customer’s technical experts. Product specifications do not expand or otherwise modify LIGHTNING’s terms and conditions of purchase, including but not limited to the warranty expressed therein.  Discoloration might be occurred on the package surface after soldering, reflow or long-time use. It neither impacts the performance nor reliability. Document No:DWI-10037 Rev: A05 Release Date: 2023/10/07 17
TD3083(SL)(T1)-GV 价格&库存
很抱歉,暂时无法提供与“TD3083(SL)(T1)-GV”相匹配的价格&库存,您可以联系我们找货
