1.5SMC39CA(MS)
1.5SMC39CA(MS)
    MSKSEMI(美森科)
    SMC(DO-214AB)
    双向TVS 33.3V截止 峰值浪涌电流:28.2A@10/1000US
1.5SMC39CA(MS) 数据手册
1.5SMCXXXA(CA)(MS) Product specification 1.5SMCXXXA(CA)(MS) Features  Mechanical Data For surface mounted applications in order to optimize board  space Case: JEDEC DO-214AB. Molded plastic over glass passivated junction  Low profile package  Built-in strain relief  Glass passivated junction  Low inductance  Excellent clamping capability  1500W peak pulse power capability at 10/1000μs waveform,    repetition rate (duty cycle): 0.01%  Applications  Fast response time  Typical IR less than 1μA above 12V  High Temperature soldering: 260℃/10 seconds at terminals  Plastic package has underwriters laboratory flammability    94V-0  Meets MSL level 1, per J-STD-020  Safety certification: UL: E244458 Terminal: Solder plated, solderable per MIL-STD-750, Method 2026 Polarity: Color band denotes cathode except bi-directional models Standard Packaging: 16mm tape (EIA STD RS-481) Weight: 0.26g I/O interface AC/DC power supply Low frequency signal transmission line (RS232, RS485, etc.) Reference News PACKAGE OUTLINE PIN CONFIGURATION Marking Information MSKSEMI Unipolar ***C J MSKSEMI ***AS J Bipolar Part number code 1.5SMC Series Code XXX A (CA) (MS) Brand identity Bidirectiona VBR Voltage 5% VBR Voltage Tolerance Copyright© Msksemi Incorporated www.msksemi.com 1.5SMCXXXA(CA)(MS) Maximum Ratings and Characteristics Ratings at 25℃ ambient temperature unless otherwise specified. Rating Symbol Value Units Peak pulse power dissipation at 10/1000μs waveform (Note1, Note2, Fig.1) PPPM 1500 Watts Peak pulse current of at 10/1000μs waveform (Note 1, Fig.3) IPPM See Table Amps PM(AV) 6.5 Watts IFSM 200 Amps TJ,TSTG -55 to +150 ℃ Typical thermal resistance junction to lead RθJL 15 ℃/W Typical thermal resistance junction to ambient RθJA 75 ℃/W Steady state power dissipation at TA=50℃ (Fig.5) Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load, (JEDEC Method) (Note3, Fig.6) Operating junction and Storage Temperature Range. Notes: 1. Non-repetitive current pulse, per Fig.3 and derated above TA=25℃ per Fig.2. 2. Mounted on 8.0mm×8.0mm copper pads to each terminal. 3. 8.3ms single half sine-wave, or equivalent square wave, duty cycle=4 pulses per minutes maximum. Electrical Characteristics (TA=25 ) Part Number Device Marking Code Reverse Stand-Off Voltage Breakdown Voltage @IT Test Current Maximum Clamping Voltage@IPP Peak Pulse Current Reverse Leakage @ VRWM Unidirectional Bidirectional UNI BI VRWM(V) VBR(V) IT(mA) VC(V) IPP(A) IR(μA) 1.5SMC6.8A 1.5SMC6.8CA 6V8A 6V8C 5.80 6.45~7.14 10 10.5 144.8 1000 1.5SMC7.5A 1.5SMC7.5CA 7V5A 7V5C 6.40 7.13~7.88 10 11.3 134.5 500 1.5SMC8.2A 1.5SMC8.2CA 8V2A 8V2C 7.02 7.79~8.61 10 12.1 125.6 200 1.5SMC9.1A 1.5SMC9.1CA 9V1A 9V1C 7.78 8.65~9.55 1 13.4 113.4 50 1.5SMC10A 1.5SMC10CA 10A 10C 8.55 9.50~10.50 1 14.5 104.8 10 1.5SMC11A 1.5SMC11CA 11A 11C 9.40 10.50~11.60 1 15.6 97.4 5 1.5SMC12A 1.5SMC12CA 12A 12C 10.20 11.40~12.60 1 16.7 91.0 5 1.5SMC13A 1.5SMC13CA 13A 13C 11.10 12.40~13.70 1 18.2 83.5 1 1.5SMC15A 1.5SMC15CA 15A 15C 12.80 14.30~15.80 1 21.2 71.7 1 1.5SMC16A 1.5SMC16CA 16A 16C 13.60 15.20~16.80 1 22.5 67.6 1 1.5SMC18A 1.5SMC18CA 18A 18C 15.30 17.10~18.90 1 25.2 60.3 1 1.5SMC20A 1.5SMC20CA 20A 20C 17.10 19.00~21.00 1 27.7 54.9 1 1.5SMC22A 1.5SMC22CA 22A 22C 18.80 20.90~23.10 1 30.6 49.7 1 1.5SMC24A 1.5SMC24CA 24A 24C 20.50 22.80~25.20 1 33.2 45.8 1 1.5SMC27A 1.5SMC27CA 27A 27C 23.10 25.70~28.40 1 37.5 40.5 1 1.5SMC30A 1.5SMC30CA 30A 30C 25.60 28.50~31.50 1 41.4 36.7 1 1.5SMC33A 1.5SMC33CA 33A 33C 28.20 31.40~34.70 1 45.7 33.3 1 1.5SMC36A 1.5SMC36CA 36A 36C 30.80 34.20~37.80 1 49.9 30.5 1 1.5SMC39A 1.5SMC39CA 39A 39C 33.30 37.10~41.00 1 53.9 28.2 1 Copyright© Msksemi Incorporated www.msksemi.com 1.5SMCXXXA(CA)(MS) Part Number Device Reverse Breakdown Marking Stand-Off Voltage Code Voltage @IT Test Current Maximum Peak Reverse Clamping Pulse Leakag Voltage@IPP Current e @ VRWM Unidirectional Bidirectional UNI BI VRWM(V) VBR(V) IT(mA) VC(V) IPP(A) IR(μA) 1.5SMC43A 1.5SMC43CA 43A 43C 36.80 40.90~45.20 1 59.3 25.6 1 1.5SMC47A 1.5SMC47CA 47A 47C 40.20 44.70~49.40 1 64.8 23.5 1 1.5SMC51A 1.5SMC51CA 51A 51C 43.60 48.50~53.60 1 70.1 21.7 1 1.5SMC56A 1.5SMC56CA 56A 56C 47.80 53.20~58.80 1 77.0 19.7 1 1.5SMC62A 1.5SMC62CA 62A 62C 53.00 58.90~65.10 1 85.0 17.9 1 1.5SMC68A 1.5SMC68CA 68A 68C 58.10 64.60~71.40 1 92.0 16.5 1 1.5SMC75A 1.5SMC75CA 75A 75C 64.10 71.30~78.80 1 103.0 14.8 1 1.5SMC82A 1.5SMC82CA 82A 82C 70.10 77.90~86.10 1 113.0 13.5 1 1.5SMC91A 1.5SMC91CA 91A 91C 77.80 86.50~95.50 1 125.0 12.2 1 1.5SMC100A 1.5SMC100CA 100A 100C 85.50 95.00~105.00 1 137.0 11.1 1 1.5SMC110A 1.5SMC110CA 110A 110C 94.00 105.00~116.00 1 152.0 10.0 1 1.5SMC120A 1.5SMC120CA 120A 120C 102.00 114.00~126.00 1 165.0 9.2 1 1.5SMC130A 1.5SMC130CA 130A 130C 111.00 124.00~137.00 1 179.0 8.5 1 1.5SMC150A 1.5SMC150CA 150A 150C 128.00 143.00~158.00 1 207.0 7.3 1 1.5SMC160A 1.5SMC160CA 160A 160C 136.00 152.00~168.00 1 219.0 6.9 1 1.5SMC170A 1.5SMC170CA 170A 170C 145.00 162.00~179.00 1 234.0 6.5 1 1.5SMC180A 1.5SMC180CA 180A 180C 154.00 171.00~189.00 1 246.0 6.2 1 1.5SMC200A 1.5SMC200CA 200A 200C 171.00 190.00~210.00 1 274.0 5.5 1 1.5SMC220A 1.5SMC220CA 220A 220C 185.00 209.00~231.00 1 328.0 4.6 1 1.5SMC250A 1.5SMC250CA 250A 250C 214.00 237.00~263.00 1 344.0 4.4 1 1.5SMC300A 1.5SMC300CA 300A 300C 256.00 285.00~315.00 1 414.0 3.7 1 1.5SMC350A 1.5SMC350CA 350A 350C 300.00 332.00~368.00 1 482.0 3.2 1 1.5SMC400A 1.5SMC400CA 400A 400C 342.00 380.00~420.00 1 548.0 2.8 1 1.5SMC440A 1.5SMC440CA 440A 440C 376.00 418.00~462.00 1 602.0 2.5 1 1.5SMC480A 1.5SMC480CA 480A 480C 408.00 456.00~504.00 1 658.0 2.3 1 1.5SMC510A 1.5SMC510CA 510A 510C 434.00 485.00~535.00 1 698.0 2.1 1 1.5SMC530A 1.5SMC530CA 530A 530C 450.00 503.50~556.50 1 725.0 2.1 1 1.5SMC540A 1.5SMC540CA 540A 540C 459.00 513.00~567.00 1 740.0 2.0 1 1.5SMC550A 1.5SMC550CA 550A 550C 467.00 522.50~577.50 1 760.0 2.0 1 Copyright© Msksemi Incorporated www.msksemi.com 1.5SMCXXXA(CA)(MS) Ratings and Characteristic Curves (TA=25℃ unless otherwise noted) Figure 1. Peak Pulse Power Rating Curve Figure 2. Pulse Derating Curve Peak Pulse Power (P PP ) or Current (I PP ) Derating in Percentage % PPPM - Peak Pulse Power (kW) 100 10 1 0.2×0.2 ″(5.0×5.0mm) Copper Pad Area 0.1 1 10 100 100 80 60 40 20 0 1000 0 td-Pulse Width (µs) 125 150 175 Bi-directional V=0V 10000 Uni-directional V=0V Cj (pF) IPPM - Peak Pulse Current, %I RSM 100 100000 Peak Value I PPM 100 Half Value I PPM (IPPM /2) 1000 Uni-directional @V R 100 50 10/1000µs Waveform as defined by R.E.A 0 1 1.0 2.0 3.0 Bi-directional @V 10 td 0 4.0 R TJ=25℃ f=1.0MHz Vsig=50mVp-p 1 10 100 1000 VBR-Reverse Breakdown Voltage (V) t-Time (ms) Figure 5. Steady State Power Dissipation Derating Curve Figure 6. Maximum Non-Repetitive Forward Surge Current Uni-Directional Only 200 IFSM - Peak Forward Surve Current (A) 7 PM(AV), Steady State Power Dissipation (W) 75 Figure 4. Typical Junction Capacitance TJ=25℃ Pulse Width(t d) is defined as the point where the peak current decays to 50% of I PPM tr=10µs 50 TA-Ambient Temperature ( ℃) Figure 3. Pulse Waveform 150 25 6 5 4 3 2 1 0 0 25 50 75 100 125 TA-Ambient Temperature ( ℃) Copyright© Msksemi Incorporated 150 175 180 160 140 120 100 80 60 40 20 0 1 10 Number of Cycles at 60Hz 100 www.msksemi.com 1.5SMCXXXA(CA)(MS) Recommended Soldering Conditions Reflow Soldering Critical Zone TL to TP tP TP Ramp-up TL tL Temperature TS max TS min Ramp-down tS Preheat 25 t 25℃ to Peak Time Recommended Conditions Profile Feature Pb-Free Assembly Average ramp-up rate (TL to TP) 3℃/second max. Preheat -Temperature Min (TS min) -Temperature Max (TS max) -Time (min to max) (tS) 150℃ 200℃ 60-180 seconds TS max to TL -Ramp-up Rate 3℃/second max. Time maintained above: -Temperature (TL) -Time (tL) 217℃ 60-150 seconds Peak Temperature (TP) 260℃ Time within 5℃ of actual Peak Temperature (tP) Ramp-down Rate Time 25℃ to Peak Temperature Copyright© Msksemi Incorporated 20-40 seconds 6℃/second max. 8 minutes max. www.msksemi.com 1.5SMCXXXA(CA)(MS) PACKAGE MECHANICAL DATA B Dimensions H F A C Ref. D G E J K L J Millimeters Min. Max. Min. Max. A 5.75 6.25 0.226 0.246 B 6.90 7.40 0.272 0.291 C 2.75 3.25 0.108 0.128 D 0.95 1.52 0.037 0.060 E 7.70 8.20 0.303 0.323 F 0.051 0.203 0.002 0.008 G 0.15 0.31 0.006 0.012 H 2.15 2.62 0.085 0.103 J 2.40 L 0.094 0.165 4.20 K DO-214AB (SMC) Inches 3.30 0.130 REEL SPECIFICATION P/N 1.5SMCXXXA(CA)(MS) Copyright© Msksemi Incorporated PKG QTY SMC 3000 www.msksemi.com 1.5SMCXXXA(CA)(MS) Attention ■ Any and all MSKSEMI Semiconductor products described or contained herein do not handle applications that require extremely high levels of reliability, such as life-support have specifications that can systems, aircraft's control systems, or other applications whose failure can be reasonably expected to result in serious physical and/or material damage. Consult with your MSKSEMI Semiconductor representative nearest you before using any MSKSEMI Semiconductor products described or contained herein in such applications. ■ MSKSEMI Semiconductor assumes no responsibility for equipment failures that result from using products at values that exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or other parameters) listed in products specificationsof any andall MSKSEMI Semiconductor products described orcontained herein. ■ Specifications of any and all MSKSEMI Semiconductor products described or contained herein stipulate the performance, characteristics, and functions of the described products in the independent state, and are not guarantees of the performance, characteristics, and functions of the described products as mounted in the customer’s products or equipment. To verify symptoms and states that cannot be evaluated in an independent device, the customer should always evaluate and test devices mounted in the customer’sproducts orequipment. ■ MSKSEMI Semiconductor. strives to supply high-quality high-reliability products. However, any and all semiconductor products fail with someprobability. It is possiblethat these probabilistic failures could give rise to accidents or events that could endanger human lives, that could give rise to smoke or fire, or that could cause damage to other property. When designing equipment, adopt safety measures so that these kinds of accidents or events cannot occur. Such measures include but are not limited to protective circuits anderror prevention circuitsfor safedesign, redundant design, and structural design. ■ In the event that any or all MSKSEMI Semiconductor products(including technical data, services) described or contained herein are controlled under any of applicable local export control laws and regulations, such products must not be exported without obtaining the export license from theauthorities concerned in accordance with the above law. ■ No part of this publication may be reproduced or transmitted in any form or by any means, electronic or mechanical, including photocopying and recording, or any information storage or retrieval system, or otherwise, without the prior written permission of MSKSEMI Semiconductor. ■ Information (including circuit diagrams and circuit parameters) herein is for example only ; it is not guaranteed for volume production. MSKSEMI Semiconductor believes information herein is accurate and reliable, but no guarantees are made or implied regarding its use or any infringementsof intellectual property rights or other rightsof third parties. ■ Any and all information described or contained herein are subject to change without notice due to product/technology improvement, etc. Whendesigning equipment, referto the "Delivery Specification" for the MSKSEMI Semiconductor productthat you intend to use. Copyright© Msksemi Incorporated www.msksemi.com
1.5SMC39CA(MS) 价格&库存
很抱歉,暂时无法提供与“1.5SMC39CA(MS)”相匹配的价格&库存,您可以联系我们找货
