SMCJ54CA
SMCJ54CA
    JUXING(钜兴)
    SMC(DO-214AB)
    双向TVS 54V截止 峰值脉冲电流:17.3A
SMCJ54CA 数据手册
SMCJ Series Surface Mount Transient Voltage Suppressor Power 1500W FEATURES PINNING • 1500W peak pulse power capability at 10/1000μs waveform, repetition rate (duty cycles):0.01% • Excellent clamping capability • Low incremental surge resistance • Typical IR less than 1μA when VBR min>12V • For surface mounted applications to optimize board space • Low profle package • Built-in strain relief • Typical failure mode is short from over-specifed voltage or current • Whisker test is conducted based on JEDEC JESD201A per its table 4a and 4c • IEC-61000-4-2 ESD 30kV(Air), 30kV (Contact) • ESD protection of data lines in accordance with IEC 61000-4-2 • EFT protection of data lines in accordance with IEC 61000-4-4 • Fast response time: typically less than 1.0ps from 0V to BV min • Glass passivated chip junction • High temperature to reflow soldering guaranteed: 260°C/40sec • VBR @ TJ= VBR@25°C x (1+αT x (TJ - 25))(αT:Temperature Coeffcient, typical value is 0.1%) • Plastic package is flammability rated V-0 per Underwriters Laboratories • Meet MSL level1, per J-STD-020, LF maximun peak of 260°C • Matte tin lead–free plated • RoHS compliant • Pb-free E3 means 2nd level interconnect is Pb-free and the terminal fnish material is tin(Sn) (IPC/JEDEC J-STD-609A.01) Maximum Ratings and Thermal Characteristics PIN DESCRIPTION 1 Cathode 2 Anode 2 Unipolar 1 Bipolar Simplified outline SMC and symbol MECHANICAL DATA • Case: SMC • Terminals: Solderable per MIL-STD-750, Method 2026 • Approx. Weight: 0.22g (0.0077oz) (TA=25℃ unless otherwise noted) Symbol Value Unit Peak Pulse Power Dissipation at T A =25°C Tp=1mS (Note 1) P PPM 1500 W Peak Forward Surge Current, 8.3ms Single Half Sine Wave Superimposed on Rated Load(JEDEC method)(Note2,3)Unidirectional only I FSM 200 A Maximum Instantaneous Forward Voltage at 100A for Unidirectional only (Note 4) VF 3.5/5.0 V T j T STG -55 to 150 ℃ Parameter Operating Junction and Storage Temperature Range NOTES: 1. Non-repetitive current pulse , per Fig. 3 and derated above TJ (initial) =25°C per Fig. 2. 2. Measured on 8.3ms single half sine wave or equivalent square wave for unidirectional device only, duty cycle=4 per minute maximum. 3. VF < 3.5V for single die parts and VF< 5.0V for stacked-die parts. 4. The PPPM of stacked-die parts is 2000W and please contact littelfuse for the detail stacked-die parts. 5.For bidirectional type having VR of 10 volts and less, the IR limit is double 6.For parts without A , the VBR is ± 10% and VC is 5% higher than with A parts version: 02 http://www.trr-jx.com Characteristics at Ta = 25°C Marking Type Reverse Stand-off Voltage Breakdown Voltage Test Current Max Clamping Voltage Peak Pulse Current Maximum Reverse Leakage V RMW V BR @ I T IT V C @ I PP I PP IR UNI BI V Min(V) Max(V) mA V A μA SMCJ5.0CA GDE BDE 5 6.4 7 10 9.2 163 800 SMCJ6.0CA GDG BDG 6 6.67 7.37 10 10.3 145.7 800 SMCJ6.5A SMCJ6.5CA GDK BDK 6.5 7.22 7.98 10 11.2 134 500 SMCJ7.0A SMCJ7.0CA GDM BDM 7 7.78 8.6 10 12 125 200 SMCJ7.5A SMCJ7.5CA GDP BDP 7.5 8.33 9.21 1 12.9 116.3 100 SMCJ8.0A SMCJ8.0CA GDR BDR 8 8.89 9.83 1 13.6 110.3 50 BDT UNI SMCJ5.0A SMCJ6.0A BI SMCJ8.5A SMCJ8.5CA GDT 8.5 9.44 10.4 1 14.4 104.2 20 SMCJ9.0A SMCJ9.0CA GDV BDV 9 10 11.1 1 15.4 97.4 10 SMCJ10A SMCJ10CA GDX BDX 10 11.1 12.3 1 17 88.3 5 SMCJ11A SMCJ11CA GDZ BDZ 11 12.2 13.5 1 18.2 82.5 1 SMCJ12A SMCJ12CA GEE BEE 12 13.3 14.7 1 19.9 75.4 1 SMCJ13CA GEG BEG 13 14.4 15.9 1 21.5 69.8 1 SMCJ13A SMCJ14A SMCJ14CA GEK BEK 14 15.6 17.2 1 23.2 64.7 1 SMCJ15A SMCJ15CA GEM BEM 15 16.7 18.5 1 24.4 61.5 1 SMCJ16A SMCJ16CA GEP BEP 16 17.8 19.7 1 26 57.7 1 SMCJ17A SMCJ17CA GER BER 17 18.9 20.9 1 27.6 54.4 1 SMCJ18CA GET BET 18 20 22.1 1 29.2 51.4 1 SMCJ18A SMCJ20A SMCJ20CA GEV BEV 20 22.2 24.5 1 32.4 46.3 1 SMCJ22A SMCJ22CA GEX BEX 22 24.4 26.9 1 35.5 42.3 1 SMCJ24A SMCJ24CA GEZ BEZ 24 26.7 29.5 1 38.9 38.6 1 SMCJ26A SMCJ26CA GFE BFE 26 28.9 31.9 1 42.1 35.7 1 SMCJ28CA GFG BFG 28 31.1 34.4 1 45.4 33.1 1 BFK SMCJ28A SMCJ30A SMCJ30CA GFK 30 33.3 36.8 1 48.4 31 1 SMCJ33A SMCJ33CA GFM BFM 33 36.7 40.6 1 53.3 28.2 1 SMCJ36A SMCJ36CA GFP BFP 36 40 44.2 1 58.1 25.9 1 SMCJ40A SMCJ40CA GFR BFR 40 44.4 49.1 1 64.5 23.3 1 SMCJ43A SMCJ43CA GFT BFT 43 47.8 52.8 1 69.4 21.7 1 SMCJ45CA GFV BFV 45 50 55.3 1 72.7 20.6 1 SMCJ45A SMCJ48A SMCJ48CA GFX BFX 48 53.3 58.9 1 77.4 19.4 1 SMCJ51A SMCJ51CA GFZ BFZ 51 56.7 62.7 1 82.4 18.2 1 SMCJ54A SMCJ54CA GGE BGE 54 60 66.3 1 87.1 17.3 1 SMCJ58A SMCJ58CA GGG BGG 58 64.4 71.2 1 93.6 16.1 1 SMCJ60CA GGK BGK 60 66.7 73.7 1 96.8 15.5 1 SMCJ60A SMCJ64A SMCJ64CA GGM BGM 64 71.1 78.6 1 103 14.6 1 SMCJ70A SMCJ70CA GGP BGP 70 77.8 86 1 113 13.3 1 SMCJ75A SMCJ75CA GGR BGR 75 83.3 92.1 1 121 12.4 1 SMCJ78A SMCJ78CA GGT BGT 78 86.7 95.8 1 126 11.9 1 SMCJ85CA GGV BGV 85 94.4 104 1 137 11 1 SMCJ85A SMCJ90A SMCJ90CA GGX BGX 90 100 111 1 146 10.3 1 SMCJ100A SMCJ100CA GGZ BGZ 100 111 123 1 162 9.3 1 SMCJ110A SMCJ110CA GHE BHE 110 122 135 1 177 8.5 1 SMCJ120A SMCJ120CA GHG BHG 120 133 147 1 193 7.8 1 SMCJ130A SMCJ130CA GHK BHK 130 144 159 1 209 7.2 1 BHM SMCJ150A SMCJ150CA GHM 150 167 185 1 243 6.2 1 SMCJ160A SMCJ160CA GHP BHP 160 178 197 1 259 5.8 1 SMCJ170A SMCJ170CA GHR BHR 170 189 209 1 275 5.5 1 SMCJ180A SMCJ180CA GHT BHT 180 201 222 1 292 5.1 1 SMCJ200A SMCJ200CA GHV BHV 200 224 247 1 324 4.6 1 SMCJ220CA GHX BHX 220 246 272 1 356 4.2 1 SMCJ220A SMCJ250A SMCJ250CA GHZ BHZ 250 279 309 1 405 3.7 1 SMCJ300A SMCJ300CA GJE BJE 300 335 371 1 486 3.1 1 SMCJ350A SMCJ350CA GJG BJG 350 391 432 1 567 2.6 1 SMCJ400A SMCJ400CA GJK BJK 400 447 494 1 648 2.3 1 SMCJ440CA GJM BJM 440 492 543 1 713 2.1 1 SMCJ440A SMCJ Series Surface Mount Transient Voltage Suppressor Power 1500W Characteristic Curves (TA=25 ℃ unless otherwise noted) Fig.2 Pulse Waveform P PPM,PEAK PULSE FORWARD ,kW Fig.1 Peak Pulse Power Rating Curve 150 100 10 1 0.31x0.31" (80 x 80mm) Copper pad Area T A =25°C t f =10us I ppm ,Peak Pulse Current (%) Non-Repetive Pulse.Wavefom Shown in Figure.3 T A=25°C Pulse Width (td) is Defined as the Point where the Peak. Current Decayst to 50% of Ipp Peak Value 100 80 Half Value-I pp /2 60 10/1000usec Waveform as Defined bye R.E.A. 40 20 td 0 00 0.1 10 1 100 1000 0 10000 Fig.4 Typical Junction Capacitance 100000 Bi-directional V= 0V 100 10000 Cj (pF) PEAK PULSE POWER(P PP)OR CURRENT(I PP) DERATINGIN PERCENTAGE% 4.0 T,TIME,ms Fig.3 Forward Current Derating Curve 80 60 Uni-directional V=0V 1000 Uni-directional @ V R 100 40 Bi-directional @ V R Tj=25℃ 10 20 f = 1MHz Vsig=mVp-p 1 0 25 50 75 100 125 150 175 T A,AMBIENT TEMPERATURE,°C 240 200 160 120 80 40 T J=T Jmax 8.3ms Single Half Sinepwave JEDEC Method 0 1 10 Number of Cycles at 60Hz http://www.trr-jx.com 1 10 100 V BR - Reverse Breakdown Voltage (V) Fig.5 Maximum Non-Repetitive Peak Forward Surge Current I FSM,PEAK FORWARD SURGE CURRENT, AMPERES 3.0 2.0 1.0 t d,PULSE WIDTH ,us version: 02 I ppm 100 1000 SMCJ Series Surface Mount Transient Voltage Suppressor Power 1500W PACKAGE OUTLINE SMC Plastic surface mounted package; 2 leads E A A1 A C b D L E1 VM A SMC mechanical data A E D E1 A1 C L b max 2.62 7.1 6.2 8.1 0.21 0.31 1.7 3.25 min 2.00 6.6 5.6 7.8 0.05 0.15 1.0 2.75 max 103 280 244 319 8.3 12 59 128 min 79 260 220 307 2.0 5.9 32 108 UNIT mm mil The recommended mounting pad size 3.8 (150) 4.1 (160) 4.3 (170) 4.1 (160) mm Unit : (mil) version: 02 http://www.trr-jx.com
SMCJ54CA 价格&库存
很抱歉,暂时无法提供与“SMCJ54CA”相匹配的价格&库存,您可以联系我们找货
SMCJ54CA
    • 5+0.74344
    • 50+0.58770
    • 150+0.50983
    • 500+0.45144
    • 3000+0.40466
    • 6000+0.38127
    库存:2847
