Transient Voltage Suppressor
SMC(DO-214AB)
Thin type
Insulation Safety certification
OCP
OVP
Control
Wide input range
General Semiconductor
SMC (DO-214AB)
Cathode
Anode
(unidirectional)
(bidirectional)
Surface-Mount
Available
Package: SMC plastic package.
Lead Finish: Matte Tin
Case Material: Epoxy Molding Compound.
UL Flammability Classification Rating 94V-0
Moisture Sensitivity: Level 1 per J-STD-020
SMC(DO-214AB) Transient Voltage Suppressor www.taisko.com taisko@taisko.comko.com
1
SMC(DO-214AB)
Thin type
OCP
OVP
Control
Wide input range
Description
SMCJ Series transient voltage suppressors are excellent
overvoltage protective devices.
The Series is designed specifically to protect sensitive electronic
equipment from voltage transients induced by lightning and other transient
voltage events.
Features
Excellent clamping capability
Low leakage current
Low capacitance
High surge capability
Glass passivated chip
Epoxy resin package
Built-in strain relief
Will not fatigue
RoHS Compliant
Fast response time:
Mechanical Characteristics
typically less than 1.0ps from 0 Volts to VBR min
Applications
Telecom
Computer
Industrial electronic
Consumer electronic
Electrical Parameters
Parameter
Definition
+I
CJ
Junction Capacitance - typical capacitance measured
with 0V or VR bias
IPP
Peak Pulse Current - maximum rated peak impulse
current
VC
Clamping Voltage - Peak voltage measured across the
suppressor at a specified Ippm (peak impulse current)
VBR
Breakdown Voltage - Maximum voltage that flows
though the TVS at a specified test current (IT)
IR
Leakage Current - maximum peak off-state current
measured at VR
VR
Peak Off-state Voltage - maximum voltage that can be
applied while maintaining off state
VF
Uni
Ipp
Bi
IT
IR
VR
VBR
VC
+V
Summary of Packing Options
Package
SMC
Packing Description
Packing Quantity
Industry Standard
Tape/Reel,13" reel
3000
EIA-481-1
Tape/Reel,7" reel
500
EIA-481-1
2
SMC(DO-214AB)
Thin type
OVP
OCP
Control
Wide input range
Absolute Maximum Ratings (TA=25℃ unless otherwise noted)
Parameter
Symbol
Value
Units
Remarks
PPPM
1500
W
(Note1)(Note2)
Steady State Power Dissipation
PD
6.5
W
(Note3)
Peak Forward Surge Current
IFSM
200
A
(Note4)
Maximum Instantaneous Forward Voltage at 100A
VFM
3.5/5
V
(Note5)
Typical Thermal Resistance Junction to Lead
RθJL
15
℃/W
Typical Thermal Resistance Junction to Ambient
RθJA
75
℃/W
TJ
-55 to 150
TSTG
-55 to 150
Peak Pulse Power Dissipation
Operating Temperature Range
Storage Temperature Range
Notes1: Non-repetitive current pulse , 10/1000us Waveform.
Notes2: Mounted on copper pad area of 8×8mm to each terminal.
Notes3: Infinite HeatS ink at TA=50°C
Notes4: Measured on 8.3ms single half sine wave or equivalent square wave, duty cycle=4 perm inute maximum.
Notes5: For UnidirectionalOnly, VFM
很抱歉,暂时无法提供与“SMCJ5.0CA”相匹配的价格&库存,您可以联系我们找货
