SMCJ30CA
SMCJ30CA
    TAISKO(台思科)
    SMC(DO-214AB)
    双向TVS 30V截止 峰值浪涌电流:31A
SMCJ30CA 数据手册
Transient Voltage Suppressor SMC(DO-214AB) Thin type Insulation Safety certification OCP OVP Control Wide input range General Semiconductor SMC (DO-214AB) Cathode Anode (unidirectional) (bidirectional) Surface-Mount      Available Package: SMC plastic package. Lead Finish: Matte Tin Case Material: Epoxy Molding Compound. UL Flammability Classification Rating 94V-0 Moisture Sensitivity: Level 1 per J-STD-020 SMC(DO-214AB) Transient Voltage Suppressor www.taisko.com taisko@taisko.comko.com 1 Transient Voltage Suppressor SMC(DO-214AB) Thin type Insulation Safety certification OCP OVP Control Wide input range Description SMCJ Series transient voltage suppressors are excellent overvoltage protective devices. The Series is designed specifically to protect sensitive electronic equipment from voltage transients induced by lightning and other transient voltage events. Features  Excellent clamping capability  Low leakage current  Low capacitance  High surge capability  Glass passivated chip  Epoxy resin package  Built-in strain relief  Will not fatigue  RoHS Compliant  Fast response time: Mechanical Characteristics  Package: SMC plastic package.  Lead Finish: Matte Tin  Case Material: Epoxy Molding Compound.  UL Flammability Classification Rating 94V-0  Moisture Sensitivity: Level 1 per J-STD-020 typically less than 1.0ps from 0 Volts to VBR min Applications  Telecom  Computer  Industrial electronic  Consumer electronic Electrical Parameters Parameter Definition +I CJ Junction Capacitance - typical capacitance measured with 0V or VR bias IPP Peak Pulse Current - maximum rated peak impulse current VC Clamping Voltage - Peak voltage measured across the suppressor at a specified Ippm (peak impulse current) VBR Breakdown Voltage - Maximum voltage that flows though the TVS at a specified test current (IT) IR Leakage Current - maximum peak off-state current measured at VR VR Peak Off-state Voltage - maximum voltage that can be applied while maintaining off state VF Uni Ipp Bi IT IR VR VBR VC +V Summary of Packing Options Package SMC Packing Description Packing Quantity Industry Standard Tape/Reel,13" reel 3000 EIA-481-1 Tape/Reel,7" reel 500 EIA-481-1 SMC(DO-214AB) Transient Voltage Suppressor www.taisko.com taisko@taisko.comko.com 2 Transient Voltage Suppressor SMC(DO-214AB) Thin type Insulation Safety certification OVP OCP Control Wide input range Absolute Maximum Ratings (TA=25℃ unless otherwise noted) Parameter Symbol Value Units Remarks PPPM 1500 W (Note1)(Note2) Steady State Power Dissipation PD 6.5 W (Note3) Peak Forward Surge Current IFSM 200 A (Note4) Maximum Instantaneous Forward Voltage at 100A VFM 3.5/5 V (Note5) Typical Thermal Resistance Junction to Lead RθJL 15 ℃/W Typical Thermal Resistance Junction to Ambient RθJA 75 ℃/W TJ -55 to 150 ℃ TSTG -55 to 150 ℃ Peak Pulse Power Dissipation Operating Temperature Range Storage Temperature Range Notes1: Non-repetitive current pulse , 10/1000us Waveform. Notes2: Mounted on copper pad area of 8×8mm to each terminal. Notes3: Infinite HeatS ink at TA=50°C Notes4: Measured on 8.3ms single half sine wave or equivalent square wave, duty cycle=4 perm inute maximum. Notes5: For UnidirectionalOnly, VFM
SMCJ30CA 价格&库存
很抱歉,暂时无法提供与“SMCJ30CA”相匹配的价格&库存,您可以联系我们找货
