UMW
R
UMW SMDJ5.0A(CA) THRU SMDJ170A(CA)
Features
SMC(DO-214AB)
For surface mounted applications in order to optimize board
space Low profile package
Cathode Band
Built-in strain relief
Glass passivated junction
0.155(3.94)
0.246(6.22)
0.130(3.30)
0.220(5.59)
Low inductance
Excellent clamping capability
0.280(7.11)
3000W peak pulse power capability at 10/1000μs waveform,
0.260(6.60)
0.012(0.305)
repetition rate (duty cycle): 0.01%
Fast response time
0.006(0.152)
0.103(2.62)
0.079(2.06)
Typical IR less than 1μA above 10V
High Temperature soldering: 260℃/10 seconds at terminals
Plastic package has underwriters laboratory flammability 94V-0
0.060(1.52)
0.030(0.76)
0.008(0.2)
0(0)
0.320(8.13)
0.305(7.75)
Mechanical Data
Dimensions in inches and (millimeters)
Case : JEDEC SMC molded plastic body
Terminals : Solderable per MIL-STD-750,Method 2026
Polarity : Polarity symbol marking on body
Mounting Position : Any
Weight : 0.003 ounce, 0.095 grams
Standard Packaging: 12mm tape (EIA STD RS-481)
Applications
I/O interface
AC/DC power supply
Low frequency signal transmission line (RS232, RS485, etc.)
MAXIMUM RATINGS AND CHARACTERISTICS
Ratings at 25℃ ambient temperature unless otherwise specified.
Peak pulse power dissipation at 10/1000μs waveform
(Note1, Note2 )
PPPM
Maximum Instantaneous Forward Voltage at
100A for Unidirectional only
VF
PM(AV)
Steady state power dissipation at TA=50℃
Peak forward surge current, 8.3ms single half sine-wave
superimposed on rated load, (JEDEC Method) (N ote3 )
Operating junction and Storage Temperature Range.
Typical thermal resistance junction to lead
1
W
3.5
V
6.5
W
IFSM
300
A
TJ,TSTG
-65 to +150
RθJL
15
℃/W
RθJA
75
℃/W
Typical thermal resistance junction to ambient
Notes: 1. Non-repetitive current pulse , per Fig. 3 and derated above T = 25OC p e r F i g . 2 .
A
2. Measured on 8.3ms single half sine wave or equivalent square wave for unidirectional
device only,duty cycle=4 per minute maximum.
www.umw-ic.com
3000
友台半导体有限公司
UMW
R
Electrical Characteristics (TA=25℃℃)
Part
Number
(Uni)
SMDJ5.0A
SMDJ6.0A
SMDJ6.5A
SMDJ7.0A
SMDJ7.5A
SMDJ8.0A
SMDJ8.5A
SMDJ9.0A
SMDJ10A
SMDJ11A
SMDJ12A
SMDJ13A
SMDJ14A
SMDJ15A
SMDJ16A
SMDJ17A
SMDJ18A
SMDJ20A
SMDJ22A
SMDJ24A
SMDJ26A
SMDJ28A
SMDJ30A
SMDJ33A
SMDJ36A
SMDJ40A
SMDJ43A
SMDJ45A
SMDJ48A
SMDJ51A
SMDJ54A
SMDJ58A
SMDJ60A
SMDJ64A
SMDJ70A
SMDJ75A
SMDJ78A
SMDJ85A
SMDJ90A
SMDJ100A
SMDJ110A
SMDJ120A
SMDJ130A
SMDJ150A
SMDJ160A
SMDJ170A
Part
Number
(Bi)
SMDJ5.0CA
SMDJ6.0CA
SMDJ6.5CA
SMDJ7.0CA
SMDJ7.5CA
SMDJ8.0CA
SMDJ8.5CA
SMDJ9.0CA
SMDJ10CA
SMDJ11CA
SMDJ12CA
SMDJ13CA
SMDJ14CA
SMDJ15CA
SMDJ16CA
SMDJ17CA
SMDJ18CA
SMDJ20CA
SMDJ22CA
SMDJ24CA
SMDJ26CA
SMDJ28CA
SMDJ30CA
SMDJ33CA
SMDJ36CA
SMDJ40CA
SMDJ43CA
SMDJ45CA
SMDJ48CA
SMDJ51CA
SMDJ54CA
SMDJ58CA
SMDJ60CA
SMDJ64CA
SMDJ70CA
SMDJ75CA
SMDJ78CA
SMDJ85CA
SMDJ90CA
SMDJ100CA
SMDJ110CA
SMDJ120CA
SMDJ130CA
SMDJ150CA
SMDJ160CA
SMDJ170CA
UNI
BI
Reverse
Stand off
Voltage
VR
(Volts)
RDE
RDG
RDK
PDM
PDP
PDR
PDT
PDV
PDX
PDZ
PEE
PEG
PEK
PEM
PEP
PER
PET
PEV
PEX
PEZ
PFE
PFG
PFK
PFM
PFP
PFR
PFT
PFV
PFX
PFZ
RGE
PGG
PGK
PGM
PGP
PGR
PGT
PGV
PGX
PGZ
PHE
PHG
PHK
PHM
PHP
PHR
DDE
DDG
DDK
DDM
DDP
DDR
DDT
DDV
DDX
DDZ
DEE
DEG
DEK
DEM
DEP
DER
DET
DEV
DEX
DEZ
DFE
DFG
DFK
DFM
DFP
DFR
DFT
DFV
DFX
DFZ
DGE
DGG
DGK
DGM
DGP
DGR
DGT
DGV
DGX
DGZ
DHE
DHG
DHK
DHM
DHP
DHR
5.0
6.0
6.5
7.0
7.5
8.0
8.5
9.0
10.0
11.0
12.0
13.0
14.0
15.0
16.0
17.0
18.0
20.0
22.0
24.0
26.0
28.0
30.0
33.0
36.0
40.0
43.0
45.0
48.0
51.0
54.0
58.0
60.0
64.0
70.0
75.0
78.0
85.0
90.0
100.0
110.0
120.0
130.0
150.0
160.0
170.0
Marking
Breakdown
Voltage VBR
(Volts) @ IT
MIN
MAX
6.40
6.67
7.22
7.78
8.33
8.89
9.44
10.00
11.10
12.20
13.30
14.40
15.60
16.70
17.80
18.90
20.00
22.20
24.40
26.70
28.90
31.10
33.30
36.70
40.00
44.40
47.80
50.00
53.30
56.70
60.00
64.40
66.70
71.10
77.80
83.30
86.70
94.40
100.00
111.00
122.00
133.00
144.00
167.00
178.00
189.00
7.00
7.37
7.98
8.60
9.21
9.83
10.40
11.10
12.30
13.50
14.70
15.90
17.20
18.50
19.70
20.90
22.10
24.50
26.90
29.50
31.90
34.40
36.80
40.60
44.20
49.10
52.80
55.30
58.90
62.70
66.30
71.20
73.70
78.60
86.00
92.10
95.80
104.00
111.00
123.00
135.00
147.00
159.00
185.00
197.00
209.00
Maximum Maximum Maximum
Test
Agency
Peak
Reverse
Current Clamping
Approval
Voltage VC
Pulse
Leakage IR
IT
@ Ipp
Current Ipp
@ VR
(mA)
(V)
(A)
(μA)
10
10
10
10
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
9.2
10.3
11.2
12.0
12.9
13.6
14.4
15.4
17.0
18.2
19.9
21.5
23.2
24.4
26.0
27.6
29.2
32.4
35.5
38.9
42.1
45.4
48.4
53.3
58.1
64.5
69.4
72.7
77.4
82.4
87.1
93.6
96.8
103.0
113.0
121.0
126.0
137.0
146.0
162.0
177.0
193.0
209.0
243.0
259.0
275.0
326.1
291.3
267.9
250.0
232.6
220.6
208.3
194.8
176.5
164.8
150.8
139.5
129.3
123.0
115.4
108.7
102.7
92.6
84.5
77.1
71.3
66.1
62.0
56.3
51.6
46.5
43.2
41.3
38.8
36.4
34.4
32.1
31.0
29.1
26.5
24.8
23.8
21.9
20.5
18.5
16.9
15.5
14.4
12.3
11.6
10.9
800
800
500
200
100
50
5
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
For parts without A , the VBR is ± 10%, and VC is 5% higher than A parts.
For bidirectional type having VR of 10 volts and less, the IR limit is double.
www.umw-ic.com
2
友台半导体有限公司
R
UMW
Figure 1 - Peak Pulse Power Rating Curve
Figure 2 - Pulse Derating Curve
100
Peak Pulse Power (PPP) or
Current (IPP) Derating in
Percentage %
PPPM-Peak Pulse Power (KW)
1000
100
10
1
80
60
40
0.31x0.31" (8.0x8.0mm)
Copper Pad Area
0.1
0.000001
0.00001
0.0001
Figure 3 - Pulse Waveform
75
100
125
150
175
Figure 4 - Typical Junction Capacitance
100000
150
tr=10μsec
TJ=25°C
Pulse Width(td) is defined
as the point where the peak
current decays to 50% of IPPM
Peak Value
IPPM
100
Bi-directional V= OV
10000
Uni-directional V= OV
Cj (pF)
IPPM- Peak Pulse Current, % IRSM
50
TA - Ambient temperature (ºC)
td-Pulse Width (Sec.)
Half Value
IPPM IPPM
2
50
1000
Uni-directional @ VR
100
10/1000μsec. Waveform
as defined by R.E.A
Bi-directional @ VR
10
td
1.0
3.0
1
1.0
4.0
10.0
100.0
1000.0
VBR - Reverse Breakdown Voltage (V)
t-Time (ms)
Figure 6 - Maximum Non-Repetitive Peak Forward
Surge Current Uni-Directional only
Figure 5 - Steady State Power Derating Curve
6.5
6
5.5
5
4.5
4
3.5
3
2.5
2
1.5
1
0.5
IFSM - Peak Forward Surge Current
(A)
PM(AV), Steady Sate Power
Dissipation (W)
25
50
75
100
125
150
250
200
150
100
50
1
TA - Ambient Temperature(ºC)
www.umw-ic.com
300
10
100
Number of Cycles at 60 Hz
3
友台半导体有限公司
UMW
R
Figure 6. Maximum Non-Repetitive Forward
Surge Current Uni-Directional Only
PM(AV), Steady State Power Dissipation (W)
Figure 5. Steady State Power Dissipation Derating
Curve
Reflow Soldering
Recommended Conditions
Profile Feature
Pb-Free Assembly
Average ramp-up rate (TL to TP)
3℃/second max.
Preheat
-Temperature Min (TS min)
-Temperature Max (TS max)
-Time (min to max) (tS)
150℃
200℃
60-180 seconds
TS max to TL
-Ramp-up Rate
3℃/second max.
Time maintained above:
-Temperature (TL)
-Time (tL)
217℃
60-150 seconds
Peak Temperature (TP)
260℃
Time within 5℃ of actual Peak Temperature (tP)
Ramp-down Rate
6℃/second max.
Time 25℃ to Peak Temperature
www.umw-ic.com
20-40 seconds
8 minutes max.
4
友台半导体有限公司
UMW
R
ORDERING INFORMATION
Order Code
Package
Baseqty
Deliverymode
UMW SMDJxxA
SMC
3000
Tape and reel
UMW SMDJxxCA
SMC
3000
Tape and reel
www.umw-ic.com
5
友台半导体有限公司
很抱歉,暂时无法提供与“SMDJ5.0A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.90126
- 50+0.68494
- 150+0.57672
- 500+0.49562
- 3000+0.43071
- 6000+0.39820
- 国内价格
- 1+0.68420
- 200+0.47080
- 1500+0.42900
- 3000+0.40040
