5.0SMDJ SERIES
Surface Mount Transient Voltage Suppressor Diodes
Uni-directional
Features
● UL recognition, file # E517074
● 5000 W peak pulse power capability with a
10/1000 μs waveform
● Low leakage
● Uni and Bidirectional unit
● Excellent clamping capability
● Very fast response time
● Meets MSL level 1
● AEC-Q101 qualified
Typical Applications
Use in sensitive electronics protection against voltage transients
induced by inductive load switching and lighting on ICs, MOSFET,
signal lines of sensor units for consumer, computer, industrial,
telecommunication.
Bi-directional
Mechanical Data
● Package: DO-214AB (SMC)
Molding compound meets UL 94 V-0 flammability
rating, RoHS-compliant
● Terminals: Tin plated leads, solderable per J-STD002 and JESD22-B102
● Polarity: For uni-directional types the band denotes
cathode end, no marking on bi-directional types
■Maximum Ratings (Ta=25℃ Unless otherwise specified)
PARAMETER
Peak power dissipation, with a 10/1000μs waveform
Peak pulse current, with a 10/1000μs waveform
UNIT
PPPM
W
5000
IPPM
A
See Next Table
PD
W
6.5
IFSM
A
300
TJ,TSTG
-55 to +150
(1)(2)
(1)
(2)
Power dissipation, on infinite heat sink at T =75℃
L
Peak forward surge current, 8.3 ms single half sine-wave unidirectional only
(3)
Operating junction and storage temperature range
Max
SYMBOL
■Electrical Characteristics(Ta=25℃ Unless otherwise specified)
PARAMETER
Maximum instantaneous forward voltage at 100A for unidirectional only(4)
SYMBOL
UNIT
VALUE
VFM
V
3.5/5.0
江苏正芯电子科技有限公司
www.zhengxinsemi.com
■Thermal Characteristics (Ta=25℃ Unless otherwise specified)
PARAMETER
Thermal Resistance(Typical)
SYMBOL
UNIT
Conditions
VALUE
RθJ-A(5)
℃/W
junction to ambient
75
℃/W
junction to lead
15
℃/W
junction to case
13
(5)
RθJ-L
(5)
RθJ-C
Notes:
(1)
(2)
(3)
(4)
(5)
Non-repetitive current pulse, per Fig. 3 and derated above TA = 25℃ per Fig.2.
Mounted on 0.31 x 0.31" (8.0 x 8.0 mm) copper pads to each terminal
Measured on 8.3ms single half sine-wave or equivalent square wave,duty cycle=4 pulses per minute maximum.
VF=3.5V Max for devices of VBR≤85V,and VF=5.0V Max for devices of VBR>85V.
Mounted on minimum recommended pad layout.
■Electrical Characteristics (TA=25℃ unless otherwise noted)
Part Number
(Uni)
Part Number
(Bi)
Breakdown Voltage VBR@IT
Min(V)
(1)
Max (V)
IT (mA)
Maximum
Reverse
Leakage IR
@ VRWM (μA)
Working Peak
Reverse
Voltage
VRWM (V)
Maximum
Reverse
Surge
(2)
Current IPP
(A)
Maximum
Clamping
Voltage Vc
@ IPP
(V)
5.0SMDJ11A
5.0SMDJ11CA
12.2
13.5
1.0
800.0
11.0
274.7
18.2
5.0SMDJ12A
5.0SMDJ12CA
13.3
14.7
1.0
800.0
12.0
251.3
19.9
5.0SMDJ13A
5.0SMDJ13CA
14.4
15.9
1.0
500.0
13.0
232.6
21.5
5.0SMDJ14A
5.0SMDJ14CA
15.6
17.2
1.0
200.0
14.0
215.5
23.2
5.0SMDJ15A
5.0SMDJ15CA
16.7
18.5
1.0
100.0
15.0
204.9
24.4
5.0SMDJ16A
5.0SMDJ16CA
17.8
19.7
1.0
50.0
16.0
192.3
26
5.0SMDJ17A
5.0SMDJ17CA
18.9
20.9
1.0
20.0
17.0
181.2
27.6
5.0SMDJ18A
5.0SMDJ18CA
20.0
22.1
1.0
10.0
18.0
171.2
29.2
5.0SMDJ19A
5.0SMDJ19CA
21.1
23.3
1.0
10.0
19.0
162.3
30.8
5.0SMDJ20A
5.0SMDJ20CA
22.2
24.5
1.0
5.0
20.0
154.3
32.4
5.0SMDJ22A
5.0SMDJ22CA
24.4
26.9
1.0
5.0
22.0
140.8
35.5
5.0SMDJ24A
5.0SMDJ24CA
26.7
29.5
1.0
5.0
24.0
128.5
38.9
5.0SMDJ26A
5.0SMDJ26CA
28.9
31.9
1.0
5.0
26.0
118.8
42.1
5.0SMDJ28A
5.0SMDJ28CA
31.1
34.4
1.0
5.0
28.0
110.1
45.4
5.0SMDJ30A
5.0SMDJ30CA
33.3
36.8
1.0
5.0
30.0
103.3
48.4
5.0SMDJ33A
5.0SMDJ33CA
36.7
40.6
1.0
5.0
33.0
93.8
53.3
5.0SMDJ36A
5.0SMDJ36CA
40.0
44.2
1.0
5.0
36.0
86.1
58.1
5.0SMDJ40A
5.0SMDJ40CA
44.4
49.1
1.0
5.0
40.0
77.5
64.5
5.0SMDJ43A
5.0SMDJ43CA
47.8
52.8
1.0
5.0
43.0
72.0
69.4
5.0SMDJ45A
5.0SMDJ45CA
50.0
55.3
1.0
5.0
45.0
68.8
72.7
5.0SMDJ48A
5.0SMDJ48CA
53.3
58.9
1.0
5.0
48.0
64.6
77.4
5.0SMDJ51A
5.0SMDJ51CA
56.7
62.7
1.0
5.0
51.0
60.7
82.4
5.0SMDJ54A
5.0SMDJ54CA
60.0
66.3
1.0
5.0
54.0
57.4
87.1
5.0SMDJ58A
5.0SMDJ58CA
64.4
71.2
1.0
5.0
58.0
53.4
93.6
5.0SMDJ60A
5.0SMDJ60CA
66.7
73.7
1.0
5.0
60.0
51.7
96.8
5.0SMDJ64A
5.0SMDJ64CA
71.1
78.6
1.0
5.0
64.0
48.5
103
5.0SMDJ70A
5.0SMDJ70CA
77.8
86.0
1.0
5.0
70.0
44.2
113
5.0SMDJ75A
5.0SMDJ75CA
83.3
92.1
1.0
5.0
75.0
41.3
121
5.0SMDJ78A
5.0SMDJ78CA
86.7
95.8
1.0
5.0
78.0
39.7
126
江苏正芯电子科技有限公司
5.0SMDJ80A
5.0SMDJ80CA
88.96
97.6
1.0
5.0
80.0
38.6
129.6
Working Peak
Reverse
Voltage
VRWM (V)
Maximum
Reverse
Surge
(2)
Current IPP
(A)
Maximum
Clamping
Voltage Vc
@ IPP
(V)
Min(V)
Max (V)
IT (mA)
Maximum
Reverse
Leakage IR
@ VRWM (μA)
5.0SMDJ85CA
94.4
104.0
1.0
5.0
85.0
36.5
137
5.0SMDJ90A
5.0SMDJ90CA
100.0
111.0
1.0
5.0
90.0
34.2
146
5.0SMDJ100A
5.0SMDJ100CA
111.0
123.0
1.0
5.0
100.0
30.9
162
5.0SMDJ110A
5.0SMDJ110CA
122.0
135.0
1.0
5.0
110.0
28.2
177
5.0SMDJ120A
5.0SMDJ120CA
133.0
147.0
1.0
5.0
120.0
25.9
193
5.0SMDJ130A
5.0SMDJ130CA
144.0
159.0
1.0
5.0
130.0
23.9
209
5.0SMDJ140A
5.0SMDJ140CA
155.0
171.0
1.0
5.0
140.0
22.0
226.8
5.0SMDJ150A
5.0SMDJ150CA
167.0
185.0
1.0
5.0
150.0
20.6
243
5.0SMDJ160A
5.0SMDJ160CA
178.0
197.0
1.0
5.0
160.0
19.3
259
5.0SMDJ170A
5.0SMDJ170CA
189.0
209.0
1.0
5.0
170.0
18.2
275
5.0SMDJ180A
5.0SMDJ180CA
200.2
220.0
1.0
5.0
180.0
17.1
291.6
5.0SMDJ190A
5.0SMDJ190CA
211.0
232.0
1.0
5.0
190.0
16.2
307.8
5.0SMDJ200A
5.0SMDJ200CA
224.0
247.0
1.0
5.0
200.0
15.4
324
5.0SMDJ220A
5.0SMDJ220CA
246.0
272.0
1.0
5.0
220.0
14.0
356
5.0SMDJ250A
5.0SMDJ250CA
279.0
309.0
1.0
5.0
250.0
12.3
405
5.0SMDJ300A
5.0SMDJ300CA
335.0
371.0
1.0
5.0
300.0
10.3
486
5.0SMDJ350A
5.0SMDJ350CA
391.0
432.0
1.0
5.0
350.0
8.8
567
5.0SMDJ400A
5.0SMDJ400CA
447.0
494.0
1.0
5.0
400.0
7.7
648
5.0SMDJ440A
5.0SMDJ440CA
492.0
543.0
1.0
5.0
440.0
7.0
713
Part Number
(Uni)
Part Number
(Bi)
5.0SMDJ85A
(1)
Notes:
(1) Pulse Test:tp≤50ms Pulse test: tp≤50ms.
(2) Surge current waveform per Fig. 3 and derated per Fig.2.
■Ordering Information (Example)
PREFERED P/N
PACKAG
E CODE
UNIT WEIGHT(g)
MINIMUM
PACKAGE(pcs)
INNER BOX
QUANTITY(pcs)
OUTER CARTON
QUANTITY(pcs)
DELIVERY MODE
5.0SMDJ SERIES
F1
Approximate 0.270
3000
6000
42000
13” reel
■ Characteristics(Typical)
FIG2: Pulse Power or Current vs. Initial Junction Temperature
100
Non- Repet itive Pulse
Wav eform shown in Fige.3
TA=25℃
PPP or IPP(%)
PPPM(KW)
FIG1:Peak Pulse Power Rating Curve
100
75
10
50
1.0
25
0.1
0.31×0.31"(8.0×8.0mm)
Copper Pad Areas
0.1μs
1μs
10μs
100μs
1.0ms
10ms
td(μs)
50
75
100
125
150
175
200
TJ(℃)
江苏正芯电子科技有限公司
FIG3: Pulse Waveform
tr=10μs
Rth(℃/W)
IPPM(%)
150
FIG4:Typical Transient Thermal Impedance
TJ=25℃
Pulse Width(td) is defined as
the Point where the Peak
Current Decays to 50% of IPPM
Peak Value
IPPM
100
100
10
Half Value - IPP
2
IPPM
50
1
10/1000μs Waveform as
Defined by R.E.A.
td
2.0
3.0
4.0
0.1
0.001
0.01
0.1
1
10
100
1000
t(ms)
TJ= TJMax.
8.3 ms Single Half Sin e-W av e
250
PD(W)
IFSM(A)
FIG5: Maximum Non-Repetitive Surge Current
300
tp(s)
FIG6:Steady State Power Dissipation
7
6
5
200
4
150
3
100
2
50
1
100
Number of Cycles
50
75
100
125
150
175
200
TL(℃)
■ Outline Dimensions
DO-214AB(SMC)
DO-214AB (SMC)
Dim
Min
Max
A
6.60
7.11
B
2.85
3.27
C
5.59
6.22
D
7.75
8.13
E
1.99
2.61
F
0.15
0.31
G
0.76
1.52
H
0.05
0.20
Dimensions in millimeters
江苏正芯电子科技有限公司
■ Suggested pad layout
P2
Q1
Dim
Min
P1
9.9
P2
3.84
Q1
3.03
Q2
3.82
Q2
P1
江苏正芯电子科技有限公司
很抱歉,暂时无法提供与“5.0SMDJ180CA”相匹配的价格&库存,您可以联系我们找货
