Transient Voltage Suppressors (TVS)
SMDJ Series
Description
The SMDJ series is designed specifically to protect sensitive
electronic equipment from voltage transients induced by
lightning and other transient voltage events.
Features
l Low profile package
l Matte tin lead–free Plated
l Halogen free and RoHS compliant
Electrical symbol
l Low incremental surge resistance
l Typical IR less than 2μA above 10V
l Compatible with industrial standard package DO
DO-214AB
l For surface mounted applications to optimize board space
BI
l 3000W peak pulse power capability with at 10/1000μs
Anode
Cathode
waveform, repetition rate (duty cycle): 0.01%
UNI
l High temperature soldering:260°C/10
0 seconds at terminals
Part Number Code
S
M
D
J
Series code
x
x
x
C
Reverse
Stand-Off
Voltage
A
5% Voltage
Tolerance
Blank:Uni-Directional
C:Bi-Directional
Mechanical Characteristics
Rating
Symbol
Value
Units
Peak Pulse Power Dissipation at TA=25ºC by 10/1000μs Waveform (Fig.2)(Note
1), (Note 2)
PPP
3000
W
Power Dissipation on Infinite Heat Sink at TL=75°C(Fig.6)
PD
6.5
W
Peak Forward Surge Current, 8.3ms Single Half Sine Wave (Note 3)
IFSM
300
A
TJ
-55 to 150
°C
TSTG
-55 to 150
°C
Operating Temperature Range
Storage Temperature Range
Notes:
1. Non-repetitive
repetitive current pulse , per Fig. 4 and derated above TA = 25°C per Fig. 3.
2. Mounted on 5.0x5.0mm copper pad to each terminal.
3. Measured on 8.3ms single half sine wave or equivalent square wave for unidirectional device only.
Specifications are subject to change without notice.
Please refer to http://www.ruilon.com.cn for current information.
Revised: 2018-06-22
Page:1
SMDJ Series
Electrical Characteristics
Type Number
Reverse
Stand-Off
Voltage
Marking
VR
Breakdown
Voltage
VBR @IT
Min
Max
Test
Current
Max.
Max.
Clamping Peak Pulse Reverse
Voltage
Current
Leakage
10/1000
10/1000μs
10/1000μs
IT
VC@IPP
IPP
IR@VR
UNI
BI
UNI
BI
V
V
V
mA
V
A
µA
SMDJ5.0A
SMDJ5.0CA
RDE
DDE
5.0
6.4
7.0
10
9.2
326.09
800
SMDJ6.0A
SMDJ6.0CA
RDG
DDG
6.0
6.67
7.37
10
10.3
291.26
800
SMDJ6.5A
SMDJ6.5CA
RDK
DDK
6.5
7.22
7.98
10
11.2
267.86
500
SMDJ7.0A
SMDJ7.0CA
PDM
DDM
7.0
7.78
8.6
10
12.0
250.0
200
SMDJ7.5A
SMDJ7.5CA
PDP
DDP
7.5
8.33
9.21
1
12.9
232.56
100
SMDJ8.0A
SMDJ8.0CA
PDR
DDR
8.0
8.89
9.83
1
13.6
220.59
50
SMDJ8.5A
SMDJ8.5CA
PDT
DDT
8.5
9.44
10.4
1
14.4
208.33
SMDJ9.0A
SMDJ9.0CA
PDV
DDV
9.0
10.0
11.1
1
15.4
194.81
10
SMDJ10A
SMDJ10CA
PDX
DDX
10.0
11.1
12.3
1
17.0
176.47
5
SMDJ11A
SMDJ11CA
PDZ
DDZ
11.0
12.2
13.5
1
18.2
164.84
2
SMDJ12A
SMDJ12CA
PEE
DEE
12.0
13.3
14.7
1
19.9
150.75
2
SMDJ13A
SMDJ13CA
PEG
DEG
13.0
14.4
15.9
1
21.5
139.53
2
SMDJ14A
SMDJ14CA
PEK
DEK
14.0
15.6
17.2
1
23.2
129.31
2
SMDJ15A
SMDJ15CA
PEM
DEM
15.0
16.7
18.5
1
24.4
122.95
2
SMDJ16A
SMDJ16CA
PEP
DEP
16.0
17.8
19.7
1
26.0
115.38
2
SMDJ17A
SMDJ17CA
PER
DER
17.0
18.9
20.9
1
27.6
108.70
2
SMDJ18A
SMDJ18CA
PET
DET
18.0
20.0
22.1
1
29.2
102.74
2
SMDJ19A
SMDJ19CA
PEB
DEB
19.0
21.1
23.3
1
30.8
97.47
2
SMDJ20A
SMDJ20CA
PEV
DEV
20.0
22.2
24.5
1
32.4
92.59
2
SMDJ22A
SMDJ22CA
PEX
DEX
22.0
24.4
26.9
1
35.5
84.51
2
SMDJ24A
SMDJ24CA
PEZ
DEZ
24.0
26.7
29.5
1
38.9
77.12
2
SMDJ26A
SMDJ26CA
PFE
DFE
26.0
28.9
31.9
1
42.1
71.26
2
SMDJ28A
SMDJ28CA
PFG
DFG
28.0
31.1
34.4
1
45.4
66.08
2
SMDJ30A
SMDJ30CA
PFK
DFK
30.0
33.3
36.8
1
48.4
61.98
2
SMDJ33A
SMDJ33CA
PFM
DFM
33.0
36.7
40.6
1
53.3
56.29
2
SMDJ36A
SMDJ36CA
PFP
DFP
36.0
40.0
44.2
1
58.1
51.64
2
SMDJ40A
SMDJ40CA
PFR
DFR
40.0
44.4
49.1
1
64.5
46.51
2
SMDJ43A
SMDJ43CA
PFT
DFT
43.0
47.8
52.8
1
69.4
43.23
2
SMDJ45A
SMDJ45CA
PFV
DFV
45.0
50.0
55.3
1
72.7
41.27
2
SMDJ48A
SMDJ48CA
PFX
DFX
48.0
53.3
58.9
1
77.4
38.76
2
Revised: 2018-06-22
Page:2
SMDJ Series
Type Number
Reverse
Stand-Off
Voltage
Marking
VRWM
Breakdown
Voltage
VBR @IT
Min
Max
Test
Current
Max.
Max.
Voltage
Current
Leakage
10/1000
10/1000μs
10/1000μs
IT
VC@IPP
IPP
IR@VRWM
UNI
BI
UNI
BI
V
V
V
mA
V
A
µA
SMDJ51A
SMDJ51CA
PFZ
DFZ
51.0
56.7
62.7
1
82.4
36.41
2
SMDJ54A
SMDJ54CA
PGE
DGE
54.0
60.0
66.3
1
87.1
34.44
2
SMDJ58A
SMDJ58CA
PGG
DGG
58.0
64.4
71.2
1
93.6
32.05
2
SMDJ60A
SMDJ60CA
PGK
DGK
60.0
66.7
73.7
1
96.8
30.99
2
SMDJ64A
SMDJ64CA
PGM
DGM
64.0
71.1
78.6
1
103.0
29.13
2
SMDJ70A
SMDJ70CA
PGP
DGP
70.0
77.8
86.0
1
113.0
26.55
2
SMDJ75A
SMDJ75CA
PGR
DGR
75.0
83.3
92.1
1
121.0
24.79
2
SMDJ78A
SMDJ78CA
PGT
DGT
78.0
86.7
95.8
1
126.0
23.81
2
SMDJ80A
SMDJ80CA
PGB
DGB
80.0
88.8
97.6
1
129.6
23.15
2
SMDJ85A
SMDJ85CA
PGV
DGV
85.0
94.4
104.0
1
137.0
21.9
2
SMDJ90A
SMDJ90CA
PGX
DGX
90.0
100.0
111.0
1
146.0
20.55
2
SMDJ100A
SMDJ100CA
PGZ
DGZ
100.0
111.0
123.0
1
162.0
18.52
2
SMDJ110A
SMDJ110CA
PHE
DHE
110.0
122.0
135.0
1
177.0
16.95
2
SMDJ120A
SMDJ120CA
PHG
DHG
120.0
133.0
147.0
1
193.0
15.54
2
SMDJ130A
SMDJ130CA
PHK
DHK
130.0
144.0
159.0
1
209.0
14.35
2
SMDJ140A
SMDJ140CA
PHB
DHB
140.0
155.0
171.0
1
226.8
13.23
2
SMDJ150A
SMDJ150CA
PHM
DHM
150.0
167.0
185.0
1
243.0
12.35
2
SMDJ160A
SMDJ160CA
PHP
DHP
160.0
178.0
197.0
1
259.0
11.58
2
SMDJ170A
SMDJ170CA
PHR
DHR
170.0
189.0
209.0
1
275.0
10.91
2
SMDJ180A
SMDJ180CA
PHT
DHT
180.0
200.0
220.0
1
291.6
10.29
2
SMDJ190A
SMDJ190CA
PHV
DHV
190.0
211.0
232.0
1
307.8
9.75
2
SMDJ200A
SMDJ200CA
PHW
DHW
200.0
224.0
247.0
1
324.0
9.26
2
SMDJ220A
SMDJ220CA
PHX
DHX
220.0
246.0
272.0
1
356.0
8.43
2
SMDJ250A
SMDJ250CA
PHZ
DHZ
250.0
279.0
309.0
1
405.0
7.41
2
SMDJ300A
SMDJ300CA
PJE
DJE
300.0
335.0
371.0
1
486.0
6.17
2
SMDJ350A
SMDJ350CA
PJG
DJG
350.0
391.0
432.0
1
567.0
5.29
2
SMDJ400A
SMDJ400CA
PJK
DJK
400.0
447.0
494.0
1
648.0
4.63
2
SMDJ440A
SMDJ440CA
PJM
DJM
440.0
492.0
543.0
1
713.0
4.21
2
Notes: For bidirectional type having VR of 10V and less, the IR limit is double.
Revised: 2018-06-22
Page:3
SMDJ Series
I-V Curve Characteristics
Uni-directional
I
Bi-directional
IPP
VC VBR VR
IR VF
IT
IT
IR
VC VBR VR
V
IR
IT
VR VBR VC
V
IPP
IPP
PPPM Peak Pulse Power Dissipation -- Max power dissipation
VR Stand-off Voltage -- Maximum voltage that can be applied to the TVS without operation
VBR Breakdown Voltage -- Maximum voltage that flows though the TVS at a specified test current (I T)
VC Clamping Voltage -- Peak voltage measured across the TVS at a specified Ippm (peak impulse current)
IR Reverse Leakage Current -- Current measured at VR
VF Forward Voltage Drop for Uni-directional
directional
Ratings and Characteristic Curves (TA=25°C unless otherwise noted)
Figure 1 - TVS Transients Clamping Waveform
Figure 2 - Peak Pulse Power Rating Curve
100
PPPM-Peak Pulse Power (kW)
Voltage or Current
Voltage Transients
Voltage Across TVS
Current Through TVS
stacked-die, 4KW
at 10x1000μs, 25°C
10
Single die, 3KW
at 10x1000μs, 25°C
1
TJ initial = Tamb
0.1
0.001
Time
0.01
0.
0.1
1
10
td-Pulse
Pulse Width (ms)
Revised: 2018-06-22
Page:4
SMDJ Series
Ratings and Characteristic Curves (TA=25°C unless otherwise noted) (Continued)
Peak Pulse Power (PPP) or Current (IPP)
Derating in Percentage %
Figure 3 - Pulse Derating Curve
Figure 4 - Pulse Waveform
100
IPPM - Peak Pulse Cur rent, % IRSM
150
80
60
40
tr=10μsec
25
50
75
100
125
Peak Value
IPPM
100
Half Value
IPPM ( IPPM )
2
50
10/1000μsec.Waveform
as defined by R.E.A
td
Bi-directional V=0V
Uni-directional
directional V=0V
1000
Cj (pF)
Uni-directional @VR
100
Bi-directional @VR
10
Tj=25ºC
f=1.0MHz
Vsig=50mVp-p
1
100.0
1000.0
PM(AV), Steady State Power Dissipation (W)
100000
10.0
3.0
4.0
Figure 6 - Steady State Power Derating Curve
Figure 5 - Typical Junction Capacitance
1.0
2.0
t-Time(ms)
TA-Ambient temperature (ºC)
C)
10000
TJ =25°C
Pulse Width(td) is defined
as the point where the peak
current decays to 50% of IPPM
6.5
6.0
5.0
4.0
3.0
2.0
1.0
50
75
100
125
150
175
TA-Ambient Temperature
T
(ºC)
VBR - Reverse Breakdown Voltage (V)
Figure 7 - Maximum Non-Repetitive Surge Current
IFSM - Peak Forward Surve Current
(A)
350
300
250
200
150
100
50
10
100
Number of Cycles at 60 Hz
Revised: 2018-06-22
Page:5
SMDJ Series
Soldering Parameters - Reflow Soldering (Surface Mount Devices)
Reflow Condition
TP
Ramp-up
Critical Zone
TL to TP
TL
Pre
Heat
Temperature
TS(max)
Ramp-down
TS(min)
Preheat
Time to peak temperature
(t 25℃ to peak)
-Temperature
Temperature Min (Ts(min))
150°C
-Temperature Max (Ts(max))
200°C
- Time (min to max) (ts)
60 -180 Seconds
Average ramp up rate ( Liquids
Liquid
Temp TL) to peak
3°C/second max
TS(max) to TL - Ramp-up Rate
3°C/second max
Reflo
w
25
Pb - Free assembly
Time
- Temperature (TL)
(Liquids)
217°C
60 -150 Seconds
Peak Temperature (TP)
260 +0/-5°C
Time within 5°C of actual peak
Temperature (tp)
20 - 40 Seconds
Ramp-down Rate
6°C/second max
Time 25°C to peak Temperature (TP)
8 minutes Max
Do not exceed
260°C
Part Marking System
Cathode band(for Uni-directional products only)
RUILON
XXX XXX
Date Code
Product Code
Marking code
Dimensions
Millimeters
Cathode Band
Inches
DIM
Revised: 2018-06-22
Min
Max
Min
Max
A
2.75
3.25
0.108
0.128
B
6.50
7.15
0.256
0.281
C
5.50
6.22
0.217
0.245
D
1.98
2.70
0.078
0.106
E
0.75
1.52
0.030
0.060
G
7.40
8.40
0.291
0.331
I
3.300
0.129
J
2.400
0.094
K
4.200
0.165
L
2.400
0.094
Page:6
SMDJ Series
Taping and Reel Specifications
Symbol
Millimeters
Inches
W
16±0.3
0.630±0.012
P
8±0.1
±0.1
0.315±0.004
F
7.25±0.1
5±0.1
0.285±0.004
E
1.75±0.1
0.069±0.004
D
1.5+0.1/
1.5+0.1/-0.0
0.059+0.004/-0.0
P0
4±0.1
0.157±0.004
P2
2±0.1
0.079±0.004
D0
16.7±0.15
±0.15
0.657±0.006
D1
178
178±2
7.007±0.079
D2
59.6+1/
+1/-2
2.346+0.039/-0.079
W1
17.2±0.4
±0.4
0.677±0.016
Direction of Unreeling
Part Number
Component
package
Quantity
Packaging option
Packaging specification
SMDJXXXA/CA
DO-214AB(SMC)
B(SMC)
500
Tape&Reel-16mm/7”tape
EIA STD RS-481
Revised: 2018-06-22
Page:7
很抱歉,暂时无法提供与“SMDJ20CA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+2.40084
- 10+1.90512
- 30+1.69128
- 100+1.41912
- 500+1.30248
- 1000+1.23444
