SMDJ33CA
SMDJ33CA
    AM(安美)
    SMC(DO-214AB)
    双向TVS 33V截止 峰值脉冲电流:56.3A@10/1000US
SMDJ33CA 数据手册
SMDJ SERIES Transient Voltage Suppressors Features Uni-directional ◆3000W peak pulse power capability at 10/1000μs waveform, Repetition rate (duty cycle):0.01% ◆For surface mounted applications to optimize board space ◆Low incremental surge impedance ◆Excellent clamping capability ◆Photo Glass and LPCVD process ◆Fast response time:typically less than 1ps from 0V to BV min. ◆Typical IR less than 2μA above 12V. ◆High Temperature soldering guaranteed: 260℃/40 seconds at terminals ◆Plastic package has underwriters laboratory flammability 94V-0 ◆Meets MSL level 1, per J-STD-020. ◆Meet Halogen free and RoHS compliant Bi-directional ◆AEC-Q101 qualified available Automotive product No.: base P/N-H Mechanical Data ◆Case: JEDEC DO-214AB ◆Polarity: Color band denotes positive end (cathode) except bi-directional models ◆Weight:About 0.21g Partnumber Coding System SMDJ XXX C A 5% VBR VOLTAGE TOLERANCE BI-DIRECTIONAL Blank:UNI-DIRECTIONAL VRWM VOLTAGE SERIES Application ◆Power Supply: DC12V/24V、The DC48V of POE RJ45 etc. ◆Communication: RS485、 RS232 etc Document Number:8060002 Revision:21-Apr-28 An hui Anmei Semiconductor Co.,Ltd. www.amsemi.com.cn ~1~ SMDJ SERIES Maximum Ratings and Characteristics Parameters at 25℃ ambient temperature unless otherwise Noted. Rating Symbol Value Units Peak pulse power dissipation at 10/1000μs waveform (Note1, Note2, Fig.1) PPPM Minimum 3000 Watts Peak pulse current of at 10/1000μs waveform (Note 1, Fig.3) IPPM See Table Amps PM(AV) 6.5 Watts VF 3.5 V IFSM 300 Amps TJ,TSTG -55 to +150 ℃ Steady state power dissipation at TA=50℃ (Fig.5) Maximum Instantaneous Forward Voltage at 100A for Unidirectional Only Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load, (JEDEC Method) (Note3, Fig.6) Operating junction and Storage Temperature Range. Notes: 1. Non-repetitive current pulse, per Fig.3 and derated above TA=25℃ per Fig.2. 2. Mounted on 8.0mm×8.0mm copper pads to each terminal. 3. 8.3ms single half sine-wave, or equivalent square wave, duty cycle=4 pulses per minutes maximum. Dimensions (DO-214AB/SMC) Millimeters Symbol Cathode Band A C I B H D F E G Document Number:8060002 Revision:21-Apr-28 J K J Inches Min. Max. Min. Max. A 2.90 3.20 0.114 0.126 B 6.60 7.11 0.260 0.280 C 5.59 6.22 0.220 0.245 D 2.06 2.62 0.079 0.103 E 0.76 1.52 0.030 0.060 F - 0.203 - 0.008 G 7.75 8.130 0.305 0.320 H 0.152 0.305 0.006 0.012 I 3.30 - 0.129 - J 2.40 - 0.094 - K - 4.20 - 0.165 An hui Anmei Semiconductor Co.,Ltd. www.amsemi.com.cn ~2~ SMDJ SERIES Electrical Characteristics Part Number Device Marking Code Reverse Stand-Off Voltage Breakdown Voltage @IT Test Current Maximum Clamping Voltage @IPP Peak Pulse Current Reverse Leakage @VRWM Unidirection al SMDJ5.0A Bidirectional UNI BI VRWM(V) VBR(V) IT(mA) VC(V) IPP(A) IR(μA) SMDJ5.0CA RDE DDE 5.0 6.40~7.00 10 9.2 326.1 800 SMDJ6.0A SMDJ6.0CA RDG DDG 6.0 6.67~7.37 10 10.3 291.3 800 SMDJ6.5A SMDJ6.5CA RDK DDK 6.5 7.22~7.98 10 11.2 267.9 500 SMDJ7.0A SMDJ7.0CA PDM DDM 7.0 7.78~8.60 10 12.0 250.0 200 SMDJ7.5A SMDJ7.5CA PDP DDP 7.5 8.33~9.21 1 12.9 232.6 100 SMDJ8.0A SMDJ8.0CA PDR DDR 8.0 8.89~9.83 1 13.6 220.6 50 SMDJ8.5A SMDJ8.5CA PDT DDT 8.5 9.44~10.40 1 14.4 208.3 20 SMDJ9.0A SMDJ9.0CA PDV DDV 9.0 10.00~11.10 1 15.4 194.8 10 SMDJ10A SMDJ10CA PDX DDX 10.0 11.10~12.30 1 17.0 176.5 5 SMDJ11A SMDJ11CA PDZ DDZ 11.0 12.20~13.50 1 18.2 164.8 2 SMDJ12A SMDJ12CA PEE DEE 12.0 13.30~14.70 1 19.9 150.8 2 SMDJ13A SMDJ13CA PEG DEG 13.0 14.40~15.90 1 21.5 139.5 2 SMDJ14A SMDJ14CA PEK DEK 14.0 15.60~17.20 1 23.2 129.3 2 SMDJ15A SMDJ15CA PEM DEM 15.0 16.70~18.50 1 24.4 123.0 2 SMDJ16A SMDJ16CA PEP DEP 16.0 17.80~19.70 1 26.0 115.4 2 SMDJ17A SMDJ17CA PER DER 17.0 18.90~20.90 1 27.6 108.7 2 SMDJ18A SMDJ18CA PET DET 18.0 20.00~22.10 1 29.2 102.7 2 SMDJ20A SMDJ20CA PEV DEV 20.0 22.20~24.50 1 32.4 92.6 2 SMDJ22A SMDJ22CA PEX DEX 22.0 24.40~26.90 1 35.5 84.5 2 SMDJ24A SMDJ24CA PEZ DEZ 24.0 26.70~29.50 1 38.9 77.1 2 SMDJ26A SMDJ26CA PFE DFE 26.0 28.90~31.90 1 42.1 71.3 2 SMDJ28A SMDJ28CA PFG DFG 28.0 31.10~34.40 1 45.4 66.1 2 SMDJ30A SMDJ30CA PFK DFK 30.0 33.30~36.80 1 48.4 62.0 2 SMDJ33A SMDJ33CA PFM DFM 33.0 36.70~40.60 1 53.3 56.3 2 SMDJ36A SMDJ36CA PFP DFP 36.0 40.00~44.20 1 58.1 51.6 2 SMDJ40A SMDJ40CA PFR DFR 40.0 44.40~49.10 1 64.5 46.5 2 SMDJ43A SMDJ43CA PFT DFT 43.0 47.80~52.80 1 69.4 43.2 2 SMDJ45A SMDJ45CA PFV DFV 45.0 50.00~55.30 1 72.7 41.3 2 SMDJ48A SMDJ48CA PFX DFX 48.0 53.30~58.90 1 77.4 38.8 2 SMDJ51A SMDJ51CA PFZ DFZ 51.0 56.70~62.70 1 82.4 36.4 2 SMDJ54A SMDJ54CA PGE DGE 54.0 60.00~66.30 1 87.1 34.4 2 SMDJ58A SMDJ58CA PGG DGG 58.0 64.40~71.20 1 93.6 32.1 2 SMDJ60A SMDJ60CA PGK DGK 60.0 66.70~73.70 1 96.8 31.0 2 SMDJ64A SMDJ64CA PGM DGM 64.0 71.10~78.60 1 103.0 29.1 2 SMDJ70A SMDJ70CA PGP DGP 70.0 77.80~86.00 1 113.0 26.5 2 SMDJ75A SMDJ75CA PGR DGR 75.0 83.30~92.10 1 121.0 24.8 2 Document Number:8060002 Revision:21-Apr-28 An hui Anmei Semiconductor Co.,Ltd. www.amsemi.com.cn ~3~ SMDJ SERIES Part Number Device Marking Code Reverse Stand-Off Voltage Breakdown Voltage @IT Test Current Maximum Clamping Voltage @IPP Peak Pulse Current Reverse Leakage @VRWM Unidirection al SMDJ78A Bidirectiona l SMDJ78CA UNI BI VRWM(V) VBR(V) IT(mA) VC(V) IPP(A) IR(μA) PGT DGT 78.0 86.70~95.80 1 126.0 23.8 2 SMDJ85A SMDJ85CA PGV DGV 85.0 94.40~104.00 1 137.0 21.9 2 SMDJ90A SMDJ90CA PGX DGX 90.0 100.00~111.00 1 146.0 20.5 2 SMDJ100A SMDJ100CA PGZ A SMDJ110C A PHE A SMDJ120C A PHG DGZ 100.0 111.00~123.00 1 162.0 18.5 2 DHE 110.0 122.00~135.00 1 177.0 16.9 2 DHG 120.0 133.00~147.00 1 193.0 15.5 2 DHK 130.0 144.00~159.00 1 209.0 14.4 2 DHM 150.0 167.00~185.00 1 243.0 12.3 2 DHP 160.0 178.00~197.00 1 259.0 11.6 2 A A PHR SMDJ170C A SMDJ180C A HHT A A HHV SMDJ190C DHR 170.0 189.00~209.00 1 275.0 10.9 2 IHT 180.0 201.00~222.00 1 292.0 10.3 2 IHV 190.0 211.00~233.00 1 308.0 9.7 2 A A HHX SMDJ200C A SMDJ210C A HHZ A A HIE SMDJ220C IHX 200.0 224.00~247.00 1 324.0 9.3 2 IHZ 210.0 237.00~263.00 1 340.0 8.8 2 IIE 220.0 246.00~272.00 1 356.0 8.4 2 SMDJ110A SMDJ120A SMDJ130A SMDJ150A SMDJ160A SMDJ170A SMDJ180A SMDJ190A SMDJ200A SMDJ210A SMDJ220A A A PHK SMDJ130C A SMDJ150C A PHM A SMDJ160CA PHP A Notes: For bidirectional type having VRWM of 10V and less, the IR limit is double. Document Number:8060002 Revision:21-Apr-28 An hui Anmei Semiconductor Co.,Ltd. www.amsemi.com.cn ~4~ SMDJ SERIES Ratings and Characteristic Curves(TA=25℃ unless otherwise noted) Figure 1. Peak Pulse Power Rating Curve Figure 2. Pulse Derating Curve 1 100 10000 1.7 Peak Pulse Power (PPP) or Current (IPP) Derating in Percentage % 100 Peak Power (kW) 10 1 0.1 1 10 100 1000 100 75 50 25 0 10000 0 Pulse Width ,td (μs) 125 150 175 100000 Bi-directional V=0V Peak Value IPPM 100 Uni-directional V=0V Cj (pF) IPPM - Peak Pulse Current, %IRSM 100 10000 Half Value IPPM (IPPM/2) 1000 Uni-direct ional @VR 100 50 10/1000µs Waveform as defined by R.E.A 0 Bi-directional @VR 10 td 0 TJ=25℃ f=1.0MHz Vsig=50mVp-p 1 1.0 2.0 3.0 4.0 1 t-Time (ms) IFSM - Peak Forward Surve Current (A) 6 5 4 3 2 1 0 25 50 75 100 1000 125 150 175 300 270 240 210 180 150 120 90 60 30 0 1 TA-Ambient Temperature (℃) Document Number:8060002 Revision:21-Apr-28 100 Figure 6. Maximum Non-Repetitive Forward Surge Current 7 0 10 VBR-Reverse Breakdown Voltage (V) Figure 5. Steady State Power Dissipation DeratingCurve PM(AV), Steady State Power Dissipation (W) 75 Figure 4. Typical Junction Capacitance TJ=25℃ Pulse Width(td) is defined as the point where the peak current decays to 50% of IPPM tr=10µs 50 TA-Ambient Temperature (℃) Figure 3. Pulse Waveform 150 25 An hui Anmei Semiconductor Co.,Ltd. 10 Number of Cycles at 60Hz 100 www.amsemi.com.cn ~5~ SMDJ SERIES ReflowSoldering Parameters tP TP Critical Zone TL to TP Ramp-up Temperature TL tL TS max Ramp-down TS min tS Preheat 25℃ t 25℃ to Peak Time (t) Reflow Condition Pre heat Lead-free Assembly -Temperature Min (TS min) 150℃ -Temperature Max (TS max) 200℃ -Time (min to max) ( tS) 60-180 seconds Average ramp-up rate (TL to TP) 3℃/second max. TS max to TL -Ramp-up Rate 3℃/second max. Reflow -Temperature (TL) (Liquidus) 217℃ -Time (min to max) (tS) 60-150 seconds Peak Temperature (TP) 260(+0/-5)℃ Time within 5℃ of actual Peak Temperature (tP) 20-40 seconds Ramp-down Rate 6℃/second max. Time 25℃ to Peak Temperature 8 minutes max. Do not exceed 280℃ Reliability Standards Terminal strength MIL-STD-750 Method 2036 Mechanical shock JESD22-B104 Vibration JESD22-B103 High Temp. Storage JESD22-A103 High Temp Reverse Bias JESD22-A108 Temperature Cycling JESD22-A104 High Temp High humidityReverse Bias JESD22-A101 Resistance to solder heat JESD22-B106 Document Number:8060002 Revision:21-Apr-28 An hui Anmei Semiconductor Co.,Ltd. www.amsemi.com.cn ~6~ SMDJ SERIES Packaging Part number Compnent Package Quantity Packaging Option Packaging Specification SMDJxxxXX DO-214AB 3000 Tape & Reel-16mm tape/13″ reel EIA STD RS-481 SMDJxxxXX-T7 DO-214AB 500 Tape & Reel-16mm tape/7″ reel EIA STD RS-481 Tape and Reel Specification Document Number:8060002 Revision:21-Apr-28 An hui Anmei Semiconductor Co.,Ltd. www.amsemi.com.cn ~7~ SMDJ SERIES IMPORTANT NOTICE AND DISCLAIMER AM RESERVES THE RIGHT TO MAKE CHANGES TO ALL PRODUCT, PRODUCT SPECIFICATIONS AND DATA WITHOUT NOTICE TO IMPROVE RELIABILITY, FUNCTION OR DESIGN OR OTHERWISE. CUSTOMERS SHOULD OBTAIN AND CONFIRM THE LATEST PRODUCT INFORMATION AND SPECIFICATIONS BEFORE FINAL DESIGN PURCHASE OR USE. AM disclaim any and all liability for any errors, inaccuracies or incompleteness contained in any datasheet or in any other disclosure relating to any product. All information are provided as-is, even it has qualified by the AEC-Q101 which satisfy industrial application requirement, except as expressly stated in this data sheet is applied for automotive grade, AM make no warranties, representation or guarantee, whether express, implied or statutory, including, without limitation, regarding any merchantability, satisfactory quality, or fitness for a particular purpose with respect to AM. AM does not assume any liability or compensation for any application assistance or customer product design, and make no warranty or accept any liability with products, which are purchased or used for any unintended or unauthorized application. Except as expressly indicated in writing, AM products are not designed for use in medical, life-saving, or lifesustaining applications or for any other application in which the failure of the AM product could result in personal injury or death. Customers using or selling AM products not expressly indicated for use in such applications do so at their own risk. Please contact authorized AM personnel to obtain written terms and conditions regarding products designed for such applications. No license, express or implied, by estoppel or otherwise, to any intellectual property rights is granted by this document or by any conduct of AM. Product names and markings noted herein may be trademarks of their respective owners. Document Number:8060002 Revision:21-Apr-28 An hui Anmei Semiconductor Co.,Ltd. www.amsemi.com.cn ~8~
SMDJ33CA 价格&库存
很抱歉,暂时无法提供与“SMDJ33CA”相匹配的价格&库存,您可以联系我们找货
SMDJ33CA
  • 5+0.80547
  • 50+0.70341
  • 150+0.65967
  • 500+0.60513
  • 3000+0.58083
  • 6000+0.56625
库存:2826
