SMCJ SERIES
Transient Voltage Suppressors
Features
Uni-directional
◆1500W peak pulse power capability at 10/1000μs waveform,
Repetition rate (duty cycle):0.01%
◆For surface mounted applications to optimize board space
◆Low incremental surge impedance
◆Excellent clamping capability
◆Photo Glass and LPCVD process
◆Fast response time:typically less than 1ps from 0V to BV min.
◆Typical IR less than 1μA above 11V.
◆High Temperature soldering guaranteed: 260℃/40 seconds at terminals
◆Plastic package has underwriters laboratory flammability 94V-0
◆Meets MSL level 1, per J-STD-020.
◆Meet Halogen free and RoHS compliant
◆AEC-Q101 qualified available
◆Automotive product No.: base P/N-H
Bi-directional
Mechanical Data
◆Case: JEDEC DO-214AB
◆Polarity: Color band denotes positive end (cathode)
except bi-directional models ◆Weight:About 0.21g
Partnumber Coding System
SMCJ XXX C A
5% VBR VOLTAGE TOLERANCE
BI-DIRECTIONAL
Blank:UNI-DIRECTIONAL
VRWM VOLTAGE
SERIES
Application
◆Power Supply: DC12V MOSEFT Relay etc.
Document Number:8060003
Revision:21-Apr-28
An hui Anmei Semiconductor Co.,Ltd.
www.amsemi.com.cn
~1~
SMCJ SERIES
Maximum Ratings and Characteristics
Parameters at 25℃ ambient temperature unless otherwise Noted.
Rating
Symbol
Value
Units
Peak pulse power dissipation at 10/1000μs waveform
(Note1, Note2, Fig.1)
PPPM
Minimum 1500
Watts
Peak pulse current of at 10/1000μs waveform (Note 1, Fig.3)
IPPM
See Table
Amps
PM(AV)
6.5
Watts
VF
3.5/5.0
V
IFSM
200
Amps
TJ,TSTG
-55 to +150
Steady state power dissipation at TA=50℃ (Fig.5)
Maximum Instantaneous Forward Voltage at 100A for
Unidirectional
Only
Peak forward surge current, 8.3ms single half sine-wave
superimposed on rated load, (JEDEC Method) (Note3, Fig.6)
Operating junction and Storage Temperature Range.
Notes: 1. Non-repetitive current pulse, per Fig.3 and derated above TA=25℃ per Fig.2.
2. Mounted on 8.0mm×8.0mm copper pads to each terminal.
3. 8.3ms single half sine-wave, or equivalent square wave, duty cycle=4 pulses per minutes maximum.
4.VF
很抱歉,暂时无法提供与“SMCJ33A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.69282
- 50+0.54767
- 150+0.47510
- 500+0.42066
- 3000+0.37714
- 6000+0.35532
