SMCJ24CA
SMCJ24CA
    SET(赛尔特)
    SMC(DO-214AB)
    SMCJ24CA
SMCJ24CA 数据手册
瞬态抑制二极管 TVS Diodes SMCJ Series Transient Voltage Suppression Diodes TVS 概述 Description ● 低浪涌电阻 ● 优异的箝位性能 ● 小型化紧凑封装,内部结构去应力设计 ● 12 V以上电压规格对应漏电典型值低于1.0 μA ● 重复率0.01% 的10/1000 μS 波形对应峰值脉冲功率1500 W ● 表贴应用,节约空间 ● 典型的故障模式为电压或电流超过额定而导致的短路 ● IEC 61000-4-2 ESD 30 kV (空气),30 kV (接触) ● 数据线EFT保护符合IEC 61000-4-4 ● 快速响应时间 ● 玻璃钝化保护 ● 回流焊高温保证:260 °C/30 s 瞬态抑制二极管 (TVS) 是一种电路保护元件,它可以削 ● 温度系数典型值0.1% 弱或过滤突增的瞬态电压(过压),在浪涌到来瞬间几纳 ● 密封材料阻燃等级V-0 秒时间内发生雪崩击穿,将浪涌电流引至接地端,并将 ● 湿度敏感等级符合MSL 等级1 电压箝位在安全范围内,从而实现了高效能的电压保 ● 引脚镀雾锡 护。 ● 无卤素,符合RoHS要求 Transient Voltage Suppressor (TVS) is a circuit ● protection component that either attenuates (reduces) 无铅E3:二级互连引线无铅,端子镀锡(Sn) (IPC/JEDEC J-STD609A.01) or filters a transient voltage spike (overvoltage), TVS ● Low incremental surge resistance diodes provide critical protection by going into ● Excellent clamping capability avalanche breakdown within no more than a few ● Low profile package with built-in strain relief nanoseconds after a strike, clamping the transient ● Typical IR less than 1.0 μA above 12 V voltage, and routing its current to the ground. ● 1500 W peak pulse power capability with a 10/1000 μS Waveform, repetition rate (duty cycle): 0.01% 应用 Applications ● For surface mounted applications to optimize board space ● Typical failure mode is short from over-specified voltage or current ● IEC 61000-4-2 ESD 30 kV (Air), 30 kV (Contact) ● EFT protection of data lines in accordance with IEC ● 通信设备 Communication Equipment ● 安防 Security & Protection ● 工控设备 Industrial Control Equipment ● 电源 Power Supply 汽车电子 ● Very fast response time ● Automotive Electronics 新能源设备 ● Glass passivated chip junction ● New Energy High temperature to reflow soldering guaranteed: 260 ● 防雷保护 ● Lightning Protection 61000-4-4 °C/30sec ● 功能图 Functional Diagram VBR @ TJ= VBR@25 °C x (1+αT x (TJ - 25)) (αT:Temperature Coefficient, typical value is 0.1%) ● Plastic package is flammability rated V-0 per Underwriters Laboratories 负极 Cathode 正极 Anode 单向 Uni-Directional ● Meet MSL level1, per J-STD-020 ● Matte tin lead–free plated ● Halogen free and RoHS compliant ● Pb-free E3 means 2nd level interconnect is Pb-free and the terminal finish material is tin(Sn) (IPC/JEDEC J-STD-609A.01) 双向 Bi-Directional +86 592-571-5838 www.SETsafe.com www.SETfuse.com 厦门赛尔特电子有限公司版权所有 All Rights Reserved by Xiamen SET Electronics Co., Ltd. 2021-2023 V2.1 E-mail : sales@SETfuse.com 1 TVS 特性 Features 瞬态抑制二极管 TVS Diodes SMCJ Series Transient Voltage Suppression Diodes 封装尺寸 Package Outline Dimensions (DO-214AB) W1 W Symbol L H TVS D T L2 L1 A E B C 公制(毫米) Millimeters 英制(英寸) Inches Min. Max. Min. Max. L 6.600 7.110 0.260 0.280 W 5.590 6.220 0.220 0.245 W1 2.900 3.200 0.114 0.126 H 2.060 2.620 0.079 0.103 T 0.1520 0.305 0.006 0.012 L1 7.750 8.130 0.305 0.320 L2 0.760 1.520 0.030 0.060 D - 0.203 - 0.008 A - 4.200 - 0.165 B 2.400 - 0.094 - C 2.400 - 0.094 - E 3.300 - 0.129 - 焊盘布局 Mounting Pad Layout +86 592-571-5838 www.SETsafe.com www.SETfuse.com 厦门赛尔特电子有限公司版权所有 All Rights Reserved by Xiamen SET Electronics Co., Ltd. 2021-2023 V2.1 E-mail : sales@SETfuse.com 2 TVS 符号 瞬态抑制二极管 TVS Diodes SMCJ Series Transient Voltage Suppression Diodes 额定参数与特性 Maximum Ratings and Characteristics 符号 Symbol 值 Value 单位 Unit PPPM 1500 W 10/1000 μS 脉冲波形(1)(2)(Fig.4)下,峰值脉冲功率耗 (Fig.2)- 双芯片器件 Peak Pulse Power Dissipation(Fig.2) by 10/1000 uS Test Waveform(1)(2)(Fig.4) Stacked Die Parts (5) PPPM 2000 W 峰值功耗 ,无限散热,TL=50 °C Peak Power Dissipation on Infinite Heat Sink at TL=50 °C PD 6.5 W IFSM 200 A 正向瞬态峰值电压 @ IF=100 A ,仅适用于单向产品(4) Maximum Instantaneous Forward Voltage at 100 A for Unidirectional Only (4) VF 3.5/5.0 V 工作温度范围 Operating Temperature Range TJ -65 to 150 °C 存储温度范围 Storage Temperature Range TSTG -65 to 175 °C 典型热阻(结至引线) Typical Thermal Resistance Junction to Lead RθJL 15 °C/W 典型热阻(结至环境) Typical Thermal Resistance Junction to Ambient RθJA 75 °C/W 参数 Parameter 10/1000 μS 脉冲波形(1)(2)(Fig.1)下,峰值脉冲功率耗-单芯片器件 Peak Power Dissipation with a 10/1000 μS waveform(1)(2)(Fig.1)-Single Die Parts TVS 正向脉冲电流峰值,额定负载叠加8.3 ms 单半正弦波测得(JEDEC方法) Peak Forward Surge Current,8.3 ms single half sinewave superimposed on rated load (JEDEC Method)(3) 注释 Notes 1. 参照图4非重复性脉冲电流波形,初始结温25 °C 以图3所示曲线降额(环境温度TA=25 ℃ )。 Non-repetitive current pulse, per Fig. 4 and derated above TJ (initial)=25 °C per Fig. 2. 测试安装于8.0 mm 2 焊盘。 Mounted on 8.0 mm 2 land areas. 3. 叠加波形为8.3 ms单个半周期正弦波或等幅方波 , 最长周期4次/min。 Measured of 8.3 ms single half sine-wave or equivalent square wave, duty cycle=4 pulses per minute 4. 单芯片VF< 3.5 V,叠层芯片VF< 5.0 V。 VF < 3.5 V for single die parts and VF< 5.0 V for stacked-die parts. +86 592-571-5838 www.SETsafe.com www.SETfuse.com 厦门赛尔特电子有限公司版权所有 All Rights Reserved by Xiamen SET Electronics Co., Ltd. 2021-2023 V2.1 E-mail : sales@SETfuse.com 3 TVS (除另有注释,默认TA=25 ℃ Ratings at 25 °C ambient temperature unless otherwise specified.) 瞬态抑制二极管 TVS Diodes SMCJ Series Transient Voltage Suppression Diodes 型号规则 Part Numbering System SMCJ XX C A 产品系列 Product Series 反向关断电压 Reverse Stand-off Voltage C: 双向 Bi-directional None: 单向 uni-direction TVS TVS 5% VBR 电压容差 5% VBR Voltage tolerance 标记 Marking 阴极线 Cathode Band SET SET XXX YMXXX YMXXX 商标 Trademark +86 592-571-5838 XXX 日期代码 Data Code 标记代码 Marking Code 商标 Trademark 日期代码 Data Code Y-年 Year Y-年 Year M-月 Month M-月 Month XXX-批次号 Lot code XXX-批次号 Lot code www.SETsafe.com www.SETfuse.com 标记代码 Marking Code 厦门赛尔特电子有限公司版权所有 All Rights Reserved by Xiamen SET Electronics Co., Ltd. 2021-2023 V2.1 E-mail : sales@SETfuse.com 4 瞬态抑制二极管 TVS Diodes SMCJ Series Transient Voltage Suppression Diodes 术语 Glossary 项目 Item 描述 Description 箝位电压 Clamping Voltage VC TVS在低差阻区域内的电压,用于限制设备两端的电压。 Voltage across TVS in a region of low differential resistance that serves to limit the voltage across the device terminals. 反向关断电压 Reverse Stand-off Voltage TVS TVS VR TVS 在没有导通状态下最高电压。 Maximum voltage that can be applied to the TVS without operation. 注:也用VWM(最高直流工作电压)表示,也称为截止电压(Vso)。 NOTE : It is also shown as VWM (maximum working voltage (maximum d.c. voltage)) and known as rated standoff voltage (Vso). 反向漏电流 Reverse Leakage Current IR 量测VR的电流。 Current measured at VR. 注:也用ID 待机电流表示。 NOTE : Also shown as ID for stand-by current. 击穿电压 Breakdown Voltage VBR 在击穿区以指定电流IT (测试电流)通过TVS的电压。 Voltage across TVS at a specified current IT (test current) in the breakdown region. 额定随机重复峰值脉冲电流 Rated Random Recurring Peak Impulse Current IPPM 施加在设备上的随机重复峰值脉冲电流的最大额定值。 Maximum-rated value of random recurring peak impulse current that may be applied to a device. 额定平均功率 Rated Average Power Dissipation PM(AV) 所有电源(包括瞬态电流和待机电流)在短时间内平均产生的最大额定功耗。 Maximum-rated value of power dissipation resulting from all sources, including transients and standby current, averaged over a short period of time. 额定随机重复峰值脉冲功率 Rated Random Recurring Peak Impulse Power Dissipation PPPM 额定随机重复峰值脉冲电流(IPPM) 和规定的最大箝位电压(VC)乘积的最大额定值。 Maximum-rated value of the product of rated random recurring peak impulse current (IPPM) multiplies by specified maximum clamping voltage (VC). 电容 Capacitance CJ 在规定的频率和电压下所测量的TVS电容。 Capacitance across the TVS measured at a specified frequencyx and voltage. —(GB-T 18802.321 / IEC 61643-321 / JESD210A) +86 592-571-5838 www.SETsafe.com www.SETfuse.com 厦门赛尔特电子有限公司版权所有 All Rights Reserved by Xiamen SET Electronics Co., Ltd. 2021-2023 V2.1 E-mail : sales@SETfuse.com 5 瞬态抑制二极管 TVS Diodes SMCJ Series Transient Voltage Suppression Diodes 项目 Item 描述 Description 正向浪涌峰值电压 Peak Forward Surge Voltage VFS 在指定的正向浪涌电流(IFS)和持续时间下,通过TVS的峰值电压。 Peak voltage across TVS for a specified forward surge current (IFS) and time duration. 注:也用VF 表示。 NOTE : Also shown as VF. 正向浪涌电流 Forward Surge Current 在正向导通区域通过TVS的脉冲电流。 Pulsed current through TVS in the forward conducting region. 注:也用IF表示。 NOTE : Also shown as IF. 击穿电压温度系数 Temperature Coefficient of Breakdown Voltage αV(BR) 击穿电压的变化与温度变化的比值。 The change of breakdown voltage divided by the change of temperature. 峰值脉冲电流 Peak pulse Current IPP 施加在TVS上的峰值脉冲电流,以确定箝位电压VC 的特定波形。 Peak pulse current value applied across the TVS to determine the clamping voltage VC for a specified wave shape. 脉冲直流测试电流 Pulsed D.C. Test Current IT 测量击穿电压VBR的试测试电流。该电流值由制造商确定,通常以脉冲持续时间小于40 ms的毫安级电流给出。 Test current for measurement of the breakdown voltage VBR. This is defined by the manufacturer and usually given in milliamperes with a pulse duration of less than 40 ms. 注:也用IBR表示。 NOTE : Also shown as IBR . —(GB-T 18802.321 / IEC 61643-321 / JESD210A) +86 592-571-5838 www.SETsafe.com www.SETfuse.com 厦门赛尔特电子有限公司版权所有 All Rights Reserved by Xiamen SET Electronics Co., Ltd. 2021-2023 V2.1 E-mail : sales@SETfuse.com 6 TVS TVS IFS 瞬态抑制二极管 TVS Diodes SMCJ Series Transient Voltage Suppression Diodes 型号 Part Number 标记代码 Device Marking Code 击穿电压 Breakdown Voltage VBR@IT TVS Min Uni Bi Uni Bi SMCJ5.0A SMCJ5.0CA GDE BDE 6.4 SMCJ6.0A SMCJ6.0CA GDG BDG SMCJ6.5A SMCJ6.5CA GDK SMCJ7.0A SMCJ7.0CA SMCJ7.5A Max 反向关断 最大反向 最大峰值 最大箝位 电流 电压 Test Reverse Current Stand-off IT Voltage VR 漏电流 Max. Reverse Leakage IR@VR 脉冲电流 Max. Peak Pulse Current IPP 电压 Max. Clamping Voltage VC@IPP (mA) (V) (μA) (A) (V) 7.0 10 5 800 163 9.2 6.67 7.37 10 6 800 145.7 10.3 BDK 7.22 7.98 10 6.5 500 134 11.2 GDM BDM 7.78 8.6 10 7 200 125 12 SMCJ7.5CA GDP BDP 8.33 9.21 1 7.5 100 116.3 12.9 SMCJ8.0A SMCJ8.0CA GDR BDR 8.89 9.83 1 8 50 110.3 13.6 SMCJ8.5A SMCJ8.5CA GDT BDT 9.44 10.4 1 8.5 20 104.2 14.4 SMCJ9.0A SMCJ9.0CA GDV BDV 10 11.1 1 9 10 97.4 15.4 SMCJ10A SMCJ10CA GDX BDX 11.1 12.3 1 10 5 88.3 17 SMCJ11A SMCJ11CA GDZ BDZ 12.2 13.5 1 11 1 82.5 18.2 SMCJ12A SMCJ12CA GEE BEE 13.3 14.7 1 12 1 75.4 19.9 SMCJ13A SMCJ13CA GEG BEG 14.4 15.9 1 13 1 69.8 21.5 SMCJ14A SMCJ14CA GEK BEK 15.6 17.2 1 14 1 64.7 23.2 SMCJ15A SMCJ15CA GEM BEM 16.7 18.5 1 15 1 61.5 24.4 SMCJ16A SMCJ16CA GEP BEP 17.8 19.7 1 16 1 57.7 26 SMCJ17A SMCJ17CA GER BER 18.9 20.9 1 17 1 54.4 27.6 SMCJ18A SMCJ18CA GET BET 20 22.1 1 18 1 51.4 29.2 SMCJ20A SMCJ20CA GEV BEV 22.2 24.5 1 20 1 46.3 32.4 SMCJ22A SMCJ22CA GEX BEX 24.4 26.9 1 22 1 42.3 35.5 SMCJ24A SMCJ24CA GEZ BEZ 26.7 29.5 1 24 1 38.6 38.9 SMCJ26A SMCJ26CA GFE BFE 28.9 31.9 1 26 1 35.7 42.1 +86 592-571-5838 www.SETsafe.com www.SETfuse.com (V) 测试 厦门赛尔特电子有限公司版权所有 All Rights Reserved by Xiamen SET Electronics Co., Ltd. 2021-2023 V2.1 E-mail : sales@SETfuse.com 7 TVS 电气特性 ( 除另有注释,默认TA=25 ℃ ) Electrical Characteristics (TA=25 °C unless otherwise noted )Table 1 瞬态抑制二极管 TVS Diodes 型号 Part Number 标记代码 击穿电压 Device Breakdown Voltage Marking Code VBR@IT TVS Min Uni Bi Uni Bi SMCJ28A SMCJ28CA GFG BFG 31.1 SMCJ30A SMCJ30CA GFK BFK SMCJ33A SMCJ33CA GFM SMCJ36A SMCJ36CA SMCJ40A Max 反向关断 最大反向 最大峰值 最大箝位 电流 电压 Test Reverse Current Stand-off IT Voltage VR 漏电流 Max. Reverse Leakage IR@VR 脉冲电流 Max. Peak Pulse Current IPP 电压 Max. Clamping Voltage VC@IPP (mA) (V) (μA) (A) (V) 34.4 1 28 1 33.1 45.4 33.3 36.8 1 30 1 31 48.4 BFM 36.7 40.6 1 33 1 28.2 53.3 GFP BFP 40 44.2 1 36 1 25.9 58.1 SMCJ40CA GFR BFR 44.4 49.1 1 40 1 23.3 64.5 SMCJ43A SMCJ43CA GFT BFT 47.8 52.8 1 43 1 21.7 69.4 SMCJ45A SMCJ45CA GFV BFV 50 55.3 1 45 1 20.6 72.7 SMCJ48A SMCJ48CA GFX BFX 53.3 58.9 1 48 1 19.4 77.4 SMCJ51A SMCJ51CA GFZ BFZ 56.7 62.7 1 51 1 18.2 82.4 SMCJ54A SMCJ54CA GGE BGE 60 66.3 1 54 1 17.3 87.1 SMCJ58A SMCJ58CA GGG BGG 64.4 71.2 1 58 1 16.1 93.6 SMCJ60A SMCJ60CA GGK BGK 66.7 73.7 1 60 1 15.5 96.8 SMCJ64A SMCJ64CA GGM BGM 71.1 78.6 1 64 1 14.6 103 SMCJ70A SMCJ70CA GGP BGP 77.8 86 1 70 1 13.3 113 SMCJ75A SMCJ75CA GGR BGR 83.3 92.1 1 75 1 12.4 121 SMCJ78A SMCJ78CA GGT BGT 86.7 95.8 1 78 1 11.9 126 SMCJ85A SMCJ85CA GGV BGV 94.4 104 1 85 1 11 137 SMCJ90A SMCJ90CA GGX BGX 100 111 1 90 1 10.3 146 SMCJ100A SMCJ100CA GGZ BGZ 111 123 1 100 1 9.3 162 SMCJ110A SMCJ110CA GHE BHE 122 135 1 110 1 8.5 177 SMCJ120A SMCJ120CA GHG BHG 133 147 1 120 1 7.8 193 SMCJ130A SMCJ130CA GHK BHK 144 159 1 130 1 7.2 209 SMCJ150A SMCJ150CA GHM BHM 167 185 1 150 1 6.2 243 +86 592-571-5838 www.SETsafe.com www.SETfuse.com (V) 测试 厦门赛尔特电子有限公司版权所有 All Rights Reserved by Xiamen SET Electronics Co., Ltd. 2021-2023 V2.1 E-mail : sales@SETfuse.com 8 TVS SMCJ Series Transient Voltage Suppression Diodes 瞬态抑制二极管 TVS Diodes 型号 Part Number 标记代码 Device Marking Code 击穿电压 Breakdown Voltage VBR@IT TVS Min Uni Bi Uni Bi SMCJ160A SMCJ160CA GHP BHP 178 SMCJ170A SMCJ170CA GHR BHR SMCJ180A SMCJ180CA GHT SMCJ200A SMCJ200CA SMCJ220A Max 测试 反向关断 最大反向 最大峰值 最大箝位 电流 电压 Test Reverse Current Stand-off IT Voltage VR 漏电流 Max. Reverse Leakage IR@VR 脉冲电流 Max. Peak Pulse Current IPP 电压 Max. Clamping Voltage VC@IPP (V) (mA) (V) (μA) (A) (V) 197 1 160 1 5.8 259 189 209 1 170 1 5.5 275 BHT 201 222 1 180 1 5.1 292 GHV BHV 224 247 1 200 1 4.6 324 SMCJ220CA GHX BHX 246 272 1 220 1 4.2 356 SMCJ250A SMCJ250CA GHZ BHZ 279 309 1 250 1 3.7 405 SMCJ300A SMCJ300CA GJE BJE 335 371 1 300 1 3.1 486 SMCJ350A SMCJ350CA GJG BJG 391 432 1 350 1 2.6 567 SMCJ400A SMCJ400CA GJK BJK 447 494 1 400 1 2.3 648 SMCJ440A SMCJ440CA GJM BJM 492 543 1 440 1 2.1 713 注释 Notes: 1.对于VR为10 V及更低的双向产品,IR值需乘以两倍。 For bidirectional type having VR of 10 volts and less, the IR should be doubled. 2.对于没有A的产品,VBR范围为±10%且VC也比有A的产品高5%,当前不推荐没有A的产品用于新设计,带A的产品推荐优先选用。 For parts without A in the PN, the VBR tolerance is ± 10% and VC is 5% higher than parts with A. The parts without A are currently available, but not recommended for new designs. The parts with A are preferred. +86 592-571-5838 www.SETsafe.com www.SETfuse.com 厦门赛尔特电子有限公司版权所有 All Rights Reserved by Xiamen SET Electronics Co., Ltd. 2021-2023 V2.1 E-mail : sales@SETfuse.com 9 TVS SMCJ Series Transient Voltage Suppression Diodes 瞬态抑制二极管 TVS Diodes SMCJ Series Transient Voltage Suppression Diodes 伏安特性曲线 I-V Curve Characteristics IF 单向 Uni-directional VC 双向 Bi-directional VBR VWM IPP IT ID VC VBR VWM ID VF IT ID IT IPP TVS TVS IPP VWM VBR VC 参考性能曲线(除有另外注释,默认TA=25 ℃ ) Performance Curve for Reference(TA=25 °C unless otherwise noted) 脉冲峰值功率 PPPM - Peak Pulse Power (KW) 电压/电流 Voltage or Current Voltage Transient Voltage Across TVS Current Throuth TVS Time 100 TJ (initial)=Tamb Stacked die,2kW At 10×1000µs,25 °C 10 Signal die,1.5 KW At 10×1000µs,25 °C 1.0 0.1 0.01 0.001 0.1 1 10 td – 脉宽 Pulse Width (ms) FIGURE 2 峰值脉冲功率额定曲线 Peak Pulse Power Rating Curve 15 100 80 60 40 20 0 0 25 50 75 100 120 150 175 TJ –初始结温 Initial Junction Temperature (°C ) IPPM - 峰值脉冲电流 Peak Pulse Current, % IRSM 降额百分比 Peak Pulse Power (PPP) or Current (IPPM) Derating in Percentage, % FIGURE 1 TVS瞬态箝位波形 TVS Transients Clamping Waveform Tr=10μs TJ = 25 °C Pulse Width (td) is defined as the Point where the Peak Current decays to 50 % of IPPM Peak Value IPPM 10 Half Value IPPM/2 10/1000 μs Waveform as defined by R.E.A. 50 td 0 0 1.0 2.0 3.0 4.0 t –时间 Time (ms) FIGURE 3 峰值脉冲功率降额曲线 Peak Pulse Power Derating Curve +86 592-571-5838 www.SETsafe.com www.SETfuse.com FIGURE 4 脉冲波形 Pulse Waveform 厦门赛尔特电子有限公司版权所有 All Rights Reserved by Xiamen SET Electronics Co., Ltd. 2021-2023 V2.1 E-mail : sales@SETfuse.com 10 瞬态抑制二极管 TVS Diodes SMCJ Series Transient Voltage Suppression Diodes Uni-direction at Zero-bias 电容 CJ –(pF) 10000 Bi-direction at Zero-bias 1000 Uni-direction at VR-bias 100 Bi-direction at VR-bias 10 1 TVS 1 10 100 100 10 1 0.1 0.01 0.001 1000 0.01 0.1 VBR – 反向击穿电压 Reverse Breakdown Voltage (V) 10 100 1000 TP – 脉宽 Pulse Duration (s) FIGURE 5 典型结电容 Typical Junction Capacitance FIGURE 6 典型瞬态热阻 Typical Transient Thermal Impedance 200 100.0 Single die 180 IF– 正向峰值电流 Peak Forward Current (A) IFSM - 正向浪涌峰值电流 Peak Forward Surge Current (A) 1 TVS 瞬态热阻 Transient Thermal Impedance (°C /W) 100000 160 140 120 100 80 60 40 20 0 1 10 60 Hz周波数 Number of Cycles at 60 Hz Stacked die 10.0 1.0 0.1 0.0 100 1.0 2.0 3.0 4.0 5.0 6.0 7.0 8.0 VF– 正向峰值电压 Peak Forward Voltage (V) 9.0 FIGURE 7 最大非重复正向浪涌电流(单向型) FIGURE 8 峰值正向电压及电流(典型值) Maximum Non-Repetitive Forward Surge Current Peak Forward Drop vs Peak Forward Current (Typical Values) Uni-Directional only 环境特性 Environmental Specifications 物理特性 Physical Specifications 高温存储 High Temp. Storage JESD22-A103 重量 Weight 0.007 ounce,0.21 grams 高温反偏 HTRB JESD22-A108 封装 Case JESD22DO214AB. Molded plastic body over glass passivated junction 湿度敏感性等级 MSL JESDEC-J-STD-020, Level 1 Color band denotes positive end (cathode) except Bidirectional 高温高湿反偏 H3TRB JESD22-A101 极性 Polarity 耐焊接热 RSH JESD22-A111 端子 Terminal Matte Tin-plated leads, Solderability per JESD22-B102 +86 592-571-5838 www.SETsafe.com www.SETfuse.com 厦门赛尔特电子有限公司版权所有 All Rights Reserved by Xiamen SET Electronics Co., Ltd. 2021-2023 V2.1 E-mail : sales@SETfuse.com 11 瞬态抑制二极管 TVS Diodes SMCJ Series Transient Voltage Suppression Diodes 焊接参数 Soldering Parameters tP Critical Zone TL to TP TP Ramp-up tL TS (max) TS (min) Ramp-down TVS 温度 Temperature (T) TVS TL tS Preheat 25 °C t 25 °C to Peak 时间 Time (t) 回流焊条件 Reflowing Condition 回流焊接参数 Reflow Soldering Parameters 预热 Pre-heat 无铅组装 Lead-Free Assembly 最低温(TS (min)) Temperature Min (TS (min)) 150 °C 最高温(TS (max)) Temperature Max (TS (max)) 200 °C 升温时长(tS) Time (min to max) (tS) 60 ~ 120 Seconds 平均升温速率(液相温度(TL)至峰值温度(TP)) 3 °C / Second max. Average Ramp-up Rate ( Liquidus Temp (TL) to Peak Temp (TP)) TS (max) 到TL升温速率 3 °C / Second max. TS (max) to TL Ramp-up Rate 温度 Temperature (TL) (Liquidus) 回流 Reflow 时长 Time (min to max) (tL) 实际峰值温度 (tP) 5 °C 以内的时间 Time of within 5 °C of actual Peak Temperature (tP) 降温速率 Ramp-down Rate 8 Minutes max. 260 °C 极限温度 Do Not Exceed www.SETfuse.com 20 ~ 40 Seconds 6 °C / Second max. 25 °C 至峰值温度时长 Time from 25 °C to Peak Temperature www.SETsafe.com 60 ~ 150 Seconds 260+0/-5 °C 峰值温度 Peak Temperature (TP) +86 592-571-5838 217 °C 厦门赛尔特电子有限公司版权所有 All Rights Reserved by Xiamen SET Electronics Co., Ltd. 2021-2023 V2.1 E-mail : sales@SETfuse.com 12 瞬态抑制二极管 TVS Diodes SMCJ Series Transient Voltage Suppression Diodes 包装信息 Packaging Information 编带 Tape P2 尺寸 Dimension (mm) W 16.00+0.3/-0.10 P0 4.00±0.10 P1 8.00±0.10 P2 2.00±0.10 D0 1.55±0.05 D1 1.55±0.05 E 1.75±0.10 F 7.50±0.10 A0 6.15±0.10 B0 8.30±0.10 K0 2.48±0.10 T 0.30±0.05 T D0 A0 P1 K0 卷盘尺寸 Reel Size 13寸卷盘 13” Reel A A 330 mm C 13.2 mm W1 16.4 mm C Arbor hole Dia. Direction of Feed W1 型号 Part Number 封装 Package 卷盘数量QTY (Reel) 包装选项 Packaging Option 包装规格 Packaging Specification SMCJ××× DO-214AB 3000 PCS Tape & Reel – 16 mm tape/13” reel EIA STD RS-481 +86 592-571-5838 www.SETsafe.com www.SETfuse.com 厦门赛尔特电子有限公司版权所有 All Rights Reserved by Xiamen SET Electronics Co., Ltd. 2021-2023 V2.1 E-mail : sales@SETfuse.com 13 TVS D1 B0 TVS W F E P0 符号 Symbol 瞬态抑制二极管 TVS Diodes SMCJ Series TVS TVS Transient Voltage Suppression Diodes 注意 ATTENTION 使用方法 Usage 1. 2. 3. 请在规定的温度范围内使用TVS。 TVS must be operated in the specified ambient temp. 请勿使用强极性溶剂清洗TVS以免破坏封装层。 Do not clean the TVS with strong polar solvent such as ketone, esters, benzene and halogenated hydrocarbon, to avoid damaging the encapsulating layer. 请勿对TVS施加剧烈的振动,冲击或压力,以避免元件开裂。 Please do not apply severe vibration, shock or pressure to TVS, to avoid element cracking. 更换 Replacement 1. 2. 若TVS出现可视化损伤,请将其更换。 If TVS is visually damaged, please replace it. TVS为非修理型产品,安全起见,请更换同等规格的TVS。 TVS is a non-repairable product. For safety sake, please use equivalent TVS for replacement. 存储 Storage 1. 存储温度范围。 Storage Temp. Range: (-55 to 150) °C. 2. 请勿将TVS存放于高温高湿或腐蚀性气体环境中,已避免影响引脚的焊接性能,请于收货后一年内进行使用 。 Do not store the TVS at the high temp., high humidity or corrosive gas environment, to avoid influencing the solder-ability of the lead wires. The product shall be used up within 1 year after receiving the goods. +86 592-571-5838 www.SETsafe.com www.SETfuse.com 厦门赛尔特电子有限公司版权所有 All Rights Reserved by Xiamen SET Electronics Co., Ltd. 2021-2023 V2.1 E-mail : sales@SETfuse.com 14 瞬态抑制二极管 TVS Diodes SMCJ Series Transient Voltage Suppression Diodes 环境条件 Environmental Conditions 1. 2. 3. 请勿暴露于室外阳光直射环境。 TVS should not be exposed to the open air, nor direct sunshine. 请避免雨水,水汽等高温高湿环境。 TVS should avoid rain, water vapor or other condition of high temp. and high humidity. 请避免沙尘,盐雾等有害环境。 TVS should avoid sand dust, salt mist, or other harmful gases. TVS最大典型结电容 Max. Typical Capacitance of TVS 高频线路应用中请参照规格书中所给出的典型电容曲线。 The typical capacitance of TVS is listed in the specifications. Designers may refer to it when designing TVS in high frequency circuit. 1. 安装TVS时请避免敲击,防止物理损伤。 TVS TVS 安装机械应力 Installation Mechanical Stress Do not knock TVS when installing, to avoid mechanical damage. 2. 请不要对 TVS 施加剧烈的振动、冲击或压力,以免表面树脂或元件破裂。 Please do not apply severe vibration, shock or pressure to TVS, to avoid surface resin or element cracking. +86 592-571-5838 www.SETsafe.com www.SETfuse.com 厦门赛尔特电子有限公司版权所有 All Rights Reserved by Xiamen SET Electronics Co., Ltd. 2021-2023 V2.1 E-mail : sales@SETfuse.com 15
SMCJ24CA 价格&库存
很抱歉,暂时无法提供与“SMCJ24CA”相匹配的价格&库存,您可以联系我们找货
