SMDJ6.5CA
SMDJ6.5CA
    SUNMATE(森美特)
    SMC(DO-214AB)
    双向TVS 6.5V截止 峰值浪涌电流:267.9A
SMDJ6.5CA 数据手册
SMDJ5.0A(CA) - SMDJ170A(CA) SURFACE MOUNT TRANSIENT VOLTAGE SUPPRESSOR DIODE VOLTAGE RANGE: 5.0 - 17 0V POWER: 3000Wa t t s Features ! Glass Passivated Die Construction ! ! ! Uni- and Bi-Directional Versions Available Excellent Clamping Capability Fast Response Time ! Plastic Case Material has UL Flammability Classification Rating 94V-O SMC/DO-214AB B Mechanical Data ! ! ! ! ! A Case: SMC/DO-214AB, Molded Plastic Terminals: Solder Plated, Solderable per MIL-STD-750, Method 2026 Polarity: Cathode Band or Cathode Notch Marking: Type Number Weight: 0.21 grams (approx.) C D J H Maximum Ratings and Electrical Characteristics G E Dim Min Max A 5.59 6.22 B 6.60 7.11 C 2.75 3.18 D 0.15 0.31 8.13 E 7.75 G 0.10 0.20 H 0.76 1.52 J 2.00 2.62 All Dimensions in mm TA = 25C unless otherwise specified Single phase, half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20%. Symbol Characteristic Value 3000 Unit W Peak Pulse Power Dissipation 10/1000µS Waveform (Note 1, 2) Figure 3 PPPM Peak Pulse Current on 10/1000µS Waveform (Note 1) Figure 4 IPPM See Table 1 A Peak Forward Surge Current 8.3ms Single Half Sine-Wave Superimposed on Rated Load (JEDEC Method) (Note 2, 3) IFSM 100 A Tj, TSTG -55 to +150 °C Operating and Storage Temperature Range Note: 1. Non-repetitive current pulse, per Figure 4 and derated above TA = 25°C per Figure 1. 2. Mounted on 8.0mm2 copper pads to each terminal. 3. Measured on 8.3ms single half sine-wave or equivalent square wave, duty cycle = 4 pulses per minutes maximum. 1 of 5 www.sunmate.tw Type Number (Uni) (Bi) Marking Reverse Stand-Off Voltage Breakdown Voltage Min. @IT Breakdown Voltage Max. @ IT Test Current Maximum Clamping Voltage @IPP Peak Pulse Current Reverse Leakage @VRMW (Uni) (Bi) VRMW(V) VBR MIN(V) VBR MAX(V) IT (mA) VC(V) IPP(A) IR(uA) SMDJ5.0 SMDJ5.0C HDD IDD 5.0 6.40 7.55 10 9.6 312.5 800.0 SMDJ5.0A SMDJ5.0CA HDE IDE 5.0 6.40 7.25 10 9.2 326.1 800.0 SMDJ6.0 SMDJ6.0C HDF IDF 6.0 6.67 8.45 10 11.4 263.2 800.0 SMDJ6.0A SMDJ6.0CA HDG IDG 6.0 6.67 7.67 10 10.3 291.3 800.0 SMDJ6.5 SMDJ6.5C HDH IDH 6.5 7.22 9.14 10 12.3 243.9 500.0 SMDJ6.5A SMDJ6.5CA HDK IDK 6.5 7.22 8.30 10 11.2 267.9 500.0 SMDJ7.0 SMDJ7.0C HDL IDL 7.0 7.78 9.86 10 13.3 225.6 200.0 SMDJ7.0A SMDJ7.0CA HDM IDM 7.0 7.78 8.95 10 12.0 250.0 200.0 SMDJ7.5 SMDJ7.5C HDN IDN 7.5 8.33 10.67 1.0 14.3 209.8 100.0 SMDJ7.5A SMDJ7.5CA HDP IDP 7.5 8.33 9.58 1.0 12.9 232.6 100.0 SMDJ8.0 SMDJ8.0C HDQ IDQ 8.0 8.89 11.3 1.0 15.0 200.0 50.0 SMDJ8.0A SMDJ8.0CA HDR IDR 8.0 8.89 10.23 1.0 13.6 220.6 50.0 SMDJ8.5 SMDJ8.5C HDS IDS 8.5 9.44 11.92 1.0 15.9 188.7 20.0 SMDJ8.5A SMDJ8.5CA HDT IDT 8.5 9.44 10.82 1.0 14.4 208.3 20.0 SMDJ9.0 SMDJ9.0C HDU IDU 9.0 10.0 12.6 1.0 16.9 177.5 10.0 SMDJ9.0A SMDJ9.0CA HDV IDV 9.0 10.0 11.5 1.0 15.4 194.8 10.0 SMDJ10 SMDJ10C HDW IDW 10 11.1 14.1 1.0 18.8 159.6 5.0 SMDJ10A SMDJ10CA HDX IDX 10 11.1 12.8 1.0 17.0 176.5 5.0 SMDJ11 SMDJ11C HDY IDY 11 12.2 15.4 1.0 20.1 149.3 5.0 SMDJ11A SMDJ11CA HDZ IDZ 11 12.2 14.0 1.0 18.2 164.8 5.0 SMDJ12 SMDJ12C HED IED 12 13.3 16.9 1.0 22.0 136.4 5.0 SMDJ12A SMDJ12CA HEE IEE 12 13.3 15.3 1.0 19.9 150.8 5.0 SMDJ13 SMDJ13C HEF IEF 13 14.4 18.2 1.0 23.8 126.1 5.0 SMDJ13A SMDJ13CA HEG IEG 13 14.4 16.5 1.0 21.5 139.5 5.0 SMDJ14 SMDJ14C HEH IEH 14 15.6 19.8 1.0 25.8 116.3 5.0 SMDJ14A SMDJ14CA HEK IEK 14 15.6 17.9 1.0 23.2 129.3 5.0 SMDJ15 SMDJ15C HEL IEL 15 16.7 21.1 1.0 26.9 111.5 5.0 SMDJ15A SMDJ15CA HEM IEM 15 16.7 19.2 1.0 24.4 123.0 5.0 SMDJ16 SMDJ16C HEN IEN 16 17.8 22.6 1.0 28.8 104.2 5.0 SMDJ16A SMDJ16CA HEP IEP 16 17.8 20.5 1.0 26.0 115.4 5.0 SMDJ17 SMDJ17C HEQ IEQ 17 18.9 23.9 1.0 30.5 98.4 5.0 SMDJ17A SMDJ17CA HER IER 17 18.9 21.7 1.0 27.6 108.7 5.0 SMDJ18 SMDJ18C HES IES 18 20.0 25.3 1.0 32.2 93.2 5.0 SMDJ18A SMDJ18CA HET IET 18 20.0 23.3 1.0 29.2 102.7 5.0 SMDJ20 SMDJ20C HEU IEU 20 22.2 28.1 1.0 35.8 83.8 5.0 SMDJ20A SMDJ20CA HEV IEV 20 22.2 25.5 1.0 32.4 92.6 5.0 2 of 5 www.sunmate.tw Type Number (Uni) (Bi) Marking Reverse Stand-Off Voltage Breakdown Voltage Min. @IT Breakdown Voltage Max. @ IT Test Current Maximum Clamping Voltage @IPP Peak Pulse Current Reverse Leakage @VRMW (Uni) (Bi) VRMW(V) VBR MIN(V) VBR MAX(V) IT (mA) VC(V) IPP(A) IR(uA) SMDJ22 SMDJ22C HEW IEW 22 24.4 30.9 1.0 39.4 76.1 5.0 SMDJ22A SMDJ22CA HEX IEX 22 24.4 28.0 1.0 35.5 84.5 5.0 SMDJ24 SMDJ24C HEY IEY 24 26.7 33.8 1.0 43.0 69.8 5.0 SMDJ24A SMDJ24CA HEZ IEZ 24 26.7 30.7 1.0 38.9 77.1 5.0 SMDJ26 SMDJ26C HFD IFD 26 28.9 36.6 1.0 46.6 64.4 5.0 SMDJ26A SMDJ26CA HFE IFE 26 28.9 33.2 1.0 42.1 71.3 5.0 SMDJ28 SMDJ28C HFF IFF 28 31.1 39.4 1.0 50.0 60.0 5.0 SMDJ28A SMDJ28CA HFG IFG 28 31.1 35.8 1.0 45.4 66.1 5.0 SMDJ30 SMDJ30C HFH IFH 30 33.3 42.2 1.0 53.5 56.1 5.0 SMDJ30A SMDJ30CA HFK IFK 30 33.3 38.3 1.0 48.4 62.0 5.0 SMDJ33 SMDJ33C HFL IFL 33 36.7 46.5 1.0 59.0 50.8 5.0 SMDJ33A SMDJ33CA HFM IFM 33 36.7 42.2 1.0 53.3 56.3 5.0 SMDJ36 SMDJ36C HFN IFN 36 40.0 50.7 1.0 64.3 46.7 5.0 SMDJ36A SMDJ36CA HFP IFP 36 40.0 46.0 1.0 58.1 51.6 5.0 SMDJ40 SMDJ40C HFQ IFQ 40 44.4 56.3 1.0 71.4 42.0 5.0 SMDJ40A SMDJ40CA HFR IFR 40 44.4 51.1 1.0 64.5 46.5 5.0 SMDJ43 SMDJ43C HFS IFS 43 47.8 60.5 1.0 76.7 39.1 5.0 SMDJ43A SMDJ43CA HFT IFT 43 47.8 54.9 1.0 69.4 43.2 5.0 SMDJ45 SMDJ45C HFU IFU 45 50.0 63.3 1.0 80.3 37.4 5.0 SMDJ45A SMDJ45CA HFV IFV 45 50.0 57.5 1.0 72.7 41.3 5.0 SMDJ48 SMDJ48C HFW IFW 48 53.3 67.5 1.0 85.5 35.1 5.0 SMDJ48A SMDJ48CA HFX IFX 48 53.3 61.3 1.0 77.4 38.8 5.0 SMDJ51 SMDJ51C HFY IFY 51 56.7 71.8 1.0 91.1 32.9 5.0 SMDJ51A SMDJ51CA HFZ IFZ 51 56.7 65.2 1.0 82.4 36.4 5.0 SMDJ54 SMDJ54C HGD IGD 54 60.0 76.0 1.0 96.3 31.2 5.0 SMDJ54A SMDJ54CA HGE IGE 54 60.0 69.0 1.0 87.1 34.4 5.0 SMDJ58 SMDJ58C HGF IGF 58 64.4 81.6 1.0 103 29.1 5.0 SMDJ58A SMDJ58CA HGG IGG 58 64.4 74.1 1.0 93.6 32.1 5.0 SMDJ60 SMDJ60C HGH IGH 60 66.7 84.5 1.0 107 28.0 5.0 SMDJ60A SMDJ60CA HGK IGK 60 66.7 76.7 1.0 96.8 31.0 5.0 SMDJ64 SMDJ64C HGL IGL 64 71.1 90.1 1.0 114 26.3 5.0 SMDJ64A SMDJ64CA HGM IGM 64 71.1 81.8 1.0 103 29.1 5.0 SMDJ70 SMDJ70C HGN IGN 70 77.8 98.6 1.0 125 24.0 5.0 SMDJ70A SMDJ70CA HGP IGP 70 77.8 89.5 1.0 113 26.5 5.0 SMDJ75 SMDJ75C HGQ IGQ 75 83.0 105.7 1.0 134 22.4 5.0 SMDJ75A SMDJ75CA HGR IGR 75 83.0 95.8 1.0 121 24.8 5.0 3 of 5 www.sunmate.tw Type Number (Uni) (Bi) Marking Reverse Stand-Off Voltage Breakdown Voltage Min. @IT Breakdown Voltage Max. @ IT Test Current Maximum Clamping Voltage @IPP Peak Pulse Current Reverse Leakage @VRMW (Uni) (Bi) VRMW(V) VBR MIN(V) VBR MAX(V) IT (mA) VC(V) IPP(A) IR(uA) SMDJ78 SMDJ78C HGS IGS 78 86.0 109.8 1.0 139 21.6 5.0 SMDJ78A SMDJ78CA HGT IGT 78 86.0 99.7 1.0 126 23.8 5.0 SMDJ85 SMDJ85C HGU IGU 85 94.0 119.2 1.0 151 19.9 5.0 SMDJ85A SMDJ85CA HGV IGV 85 94.0 108.2 1.0 137 21.9 5.0 SMDJ90 SMDJ90C HGW IGW 90 100 126.5 1.0 160 18.8 5.0 SMDJ90A SMDJ90CA HGX IGX 90 100 115.5 1.0 146 20.5 5.0 SMDJ100 SMDJ100C HGY IGY 100 111 141.0 1.0 179 16.8 5.0 SMDJ100A SMDJ100CA HGZ IGZ 100 111 128.0 1.0 162 18.5 5.0 SMDJ110 SMDJ110C HHD IHD 110 122 154.5 1.0 196 15.3 5.0 SMDJ110A SMDJ110CA HHE IHE 110 122 140.5 1.0 177 16.9 5.0 SMDJ120 SMDJ120C HHF IHF 120 133 169.0 1.0 214 14.0 5.0 SMDJ120A SMDJ120CA HHG IHG 120 133 153.0 1.0 193 15.5 5.0 SMDJ130 SMDJ130C HHH IHH 130 144 182.5 1.0 231 13.0 5.0 SMDJ130A SMDJ130CA HHK IHK 130 144 165.5 1.0 209 14.4 5.0 SMDJ150 SMDJ150C HHL IHL 150 167 211.5 1.0 268 11.2 5.0 SMDJ150A SMDJ150CA HHM IHM 150 167 192.5 1.0 243 12.3 5.0 SMDJ160 SMDJ160C HHN IHN 160 178 226.0 1.0 287 10.5 5.0 SMDJ160A SMDJ160CA HHP IHP 160 178 205.0 1.0 259 11.6 5.0 SMDJ170 SMDJ170C HHQ IHQ 170 189 239.5 1.0 304 9.9 5.0 SMDJ170A SMDJ170CA HHR IHR 170 189 217.5 1.0 275 10.9 5.0 4 of 5 www.sunmate.tw O Ratings and Characteristic Curves (TA=25 C unlessotherwise noted) Peak Pulse Power (PPP) or Current (IPP) Derating in Percentage % PPPM - Peak Pulse Power (kW) 100 10 1 0.1 0.1 1 10 100 td - Pulse Width (μs) 1000 100 80 60 40 20 0 10000 0 Figure 1 -PeakPulsePower Rating Curve 150 175 100000 tr=10µsec Peak Value IPPM TJ=25°C Pulse Width(td) is defined as the point where the peak current decays to 50% of IPPM CJ – Junction Capacitance (pF) IPPM - Peak Pulse Current, % IRSM 50 75 100 125 TA-Ambient temperature(°C) Figure 2 -Pulse DeratingCurve 150 100 Half Value IPPM (IPPM/2) 50 10/1000µsec. Waveform as defined by R.E.A tc 0 0 Bi-directional @zero bins 10000 Uni-directional @zero bins 1000 Uni-directional @VRWM 100 10 Tj=25°C f=1.0MHz Vsig=50mVp-p Bi-directional @VRWM 1 1.0 2.0 t - Time (ms) 3.0 1.0 4.0 Figure 3 -Pulse Waveform 10.0 100.0 VBR-Reverse Breakdown Voltage (V) 1000.0 Figure 4 -TypicalJunction Capacitance 300 6.0 IFSM-Peak Forward Surge Current (A) PM(AV), Steady State Power Dissipation (W) 25 5.0 4.0 3.0 2.0 1.0 TJ=TJ max. 8.3 ms Single Half Sine-Wave 250 200 150 100 0.0 0 25 50 75 100 125 150 TL - Lead Temperature(°C) 175 1 200 10 Number of Cycles at 60Hz 100 Figure 6 -Maximum Non-RepetitiveSurge Current Figure 5-SteadyStatePower Derating Curve 5 of 5 www.sunmate.tw
SMDJ6.5CA 价格&库存
很抱歉,暂时无法提供与“SMDJ6.5CA”相匹配的价格&库存,您可以联系我们找货
