SMDJ60A
SMDJ60A
    ZHIDE(志得)
    SMC(DO-214AB)
    单向TVS 60V截止 峰值浪涌电流:31A@10/1000US
SMDJ60A 数据手册
SMDJxx(C)A Series Surface Mount Transient Voltage Suppressor Rectifiers Reverse Voltage 5.0 ~ 440 V 3000 Watt Peak Pulse Power DO214AB/(SMC) Features ● Glass passivated chip ● 3000 W peak pulse power capability with a 10/1000 us waveform, repetitive rate (duty cycle):0.01 % ● Excellent clamping capability ● Low reverse leakage ● Very fast response time ● Lead and body according with RoHS standard Mechanical Data ● Case: DO214AB/(SMC) Molded plastic ● Lead: Solderable per MIL-STD-750, method 2026 ● Epoxy: UL 94V-0 rate flame retardant ● Polarity: Color band denotes cathode end except Bipolar Unit: inch (mm) ● Mounting position: Any Maximum Ratings & Characteristics Ratings at 25℃ ambient temperature unless otherwise specified. Symbols Value Unit Peak power dissipation with a 10/1000 us waveform(1) PPP 3000 W Peak pulse current wih a 10/1000 us waveform(1) IPP See Next Table A Power dissipation on infinite heatsink at TL = 75 °C PD 6.5 W IFSM 300 A VF 3.5/6.5 V TJ,TSTG -55 to +150 ℃ Parameter Peak forward surge current, 8.3 ms single half sinewave unidirectional only(2) Maximum instantaneous forward voltage at 100 A for unidirectional only(3) Operating junction and storage temperature range Note: 1)Non-repetitive current pulse per Fig.5 and derated above TA= 25 °C per Fig.1; 2)Measured on 8.3 ms single half sine-wave or equivalent square wave, duty cycle = 4 pulses per minute maximum; 3)VF
SMDJ60A
- 物料型号:SMDJxx(C)A Series - 器件简介:Surface Mount Transient Voltage Suppressor Rectifiers Reverse Voltage 5.0 ~ 440 V 3000 Watt Peak Pulse Power - 引脚分配:未提供具体引脚分配信息 - 参数特性:包括Peak power dissipation、Peak pulse current、Power dissipation on infinite heatsink at TL = 75°C等 - 功能详解:文档中提供了器件的特性,例如玻璃钝化芯片、3000 W峰值脉冲功率能力、优秀的钳位能力、低反向漏电、非常快的响应时间等 - 应用信息:未提供具体应用信息 - 封装信息:封装类型为DO214AB/(SMC),引脚可焊性符合MIL-STD-750,环氧树脂为UL 94V-0级阻燃
SMDJ60A 价格&库存
很抱歉,暂时无法提供与“SMDJ60A”相匹配的价格&库存,您可以联系我们找货
