5.0SMDJ28CA
5.0SMDJ28CA
    YFW(佑风微)
    SMC(DO-214AB)
    双向TVS 28V截止 峰值浪涌电流:110A@10/1000US
5.0SMDJ28CA 数据手册
5.0SMDJ12A(CA)-5.0SMDJ170A(CA) SMC Surface Mount Transient Voltage Suppressor Power 5000Watts Stand-Off Voltage: 12V~170V Pinning 1.Cathode 2.Anode FEATURES  Peak power dissipation 5000w @10 x 1000 us Pulse  Low profile package.  Excellent clamping capability.  Typical IR less than 5uA when VBR above 22V.  Glass passivated junction.  Fast response time: typically less than 1.0ps from 0 Volts to BV min  IEC 61000-4-2 ESD 30KV(Air), 30KV(Contact)  ESD protection of data lines in accordance with IEC 61000-4-2  EFT protection of data lines in accordance with IEC 61000-4-4  Halogen free and ROHS compliant  Lead-free finish 1 2 Unipolar Bipolar DO-214AB/SMC MECHANICAL CHARACTERISTICS  Case: SMC (DO-214AB) Molded Plastic over glass passivated junction.  Mounting Position: Any  Polarity: by cathode band denotes UNI-directional device, none cathode band denotes bi-directional device.  Terminal: Solder plated Maximum Ratings and Characteristics @ 25°C Ambient Temperature (unless otherwise noted) Parameter Symbol Value Unit Peak Pulse Power Dissipation on 10/1000 us waveform (Note 1, 2, FIG.1) PPPM 5000 W Peak Forward Surge Current, 8.3ms Single Half Sine-Wave (Note 2. 3) IFSM 300 A Peak Pulse Current of on 10/1000us Waveform (Note 1, FIG.3) IPPM See Next Table A Power dissipation on Infinite heat sink at TL=50 °C PD 6.5 W TJ,TSTG -55 to +150 °C Operating Junction Temperature and Storage Temperature Range NOTES: 1. Non-repetitive current pulse, per Fig.3 and derated above TA=25°C per Fig.2. 2 2.Mounted on 8.0x8.0mm (0.03mm thick) Copper Pads to each terminal. 3.Measured on 8.3ms single half sine-wave, or equivalent square wave, for Unidirectional device only. www.yfwdiode.com 1/5 Guangdong YFW Electronics Co, Ltd. 5.0SMDJ12A(CA)-5.0SMDJ170A(CA) SMC Electrical Specification @ Tamb 25°C Type Number (Uni) (Bi) Marking (Uni) (Bi) Reverse StandOff Voltage Breakdown Voltage Min. @IT Breakdown Voltage Max. @ IT Test Current Maximum Clamping Voltage @IPP VRMW(V) VBR MIN(V) VBR MAX(V) IT (mA) VC(V) IPP(A) IR(uA) Peak Pulse Current Reverse Leakage @VRMW 5.0SMDJ12A 5.0SMDJ12CA 5.0SMDJ13A 5.0SMDJ13CA 5PEP 5BEP 5PEQ 5BEQ 12.0 13.0 13.30 14.40 14.70 15.90 10 10 19.9 21.5 252.00 233.00 800 500 5.0SMDJ14A 5.0SMDJ14CA 5PER 5BER 14.0 15.60 17.20 10 23.2 216.00 200 5.0SMDJ15A 5.0SMDJ15CA 5PES 5BES 15.0 16.70 18.50 1 24.4 205.00 100 5.0SMDJ16A 5.0SMDJ16CA 5.0SMDJ17A 5.0SMDJ17CA 5PET 5BET 5PEU 5BEU 16.0 17.0 17.80 18.90 20.50 20.90 1 1 26.0 27.6 193.00 181.00 50 20 5.0SMDJ18A 5.0SMDJ18CA 5PEV 5BEV 18.0 20.00 22.10 1 29.2 172.00 10 5.0SMDJ20A 5.0SMDJ20CA 5PEW 5BEW 20.0 22.20 24.50 1 32.4 155.00 5 5.0SMDJ22A 5.0SMDJ22CA 5.0SMDJ24A 5.0SMDJ24CA 5PEX 5BEX 5PEZ 5BEZ 22.0 24.0 24.40 26.70 26.90 29.50 1 1 35.5 38.9 141.00 129.00 5 5 5.0SMDJ26A 5.0SMDJ26CA 5PFE 5BFE 26.0 28.90 31.90 1 42.1 119.00 5 5.0SMDJ28A 5.0SMDJ28CA 5PFG 5BFG 28.0 31.10 34.40 1 45.4 110.00 5 5.0SMDJ30A 5.0SMDJ30CA 5PFK 5BFK 30.0 33.30 36.80 1 48.4 103.00 5 5.0SMDJ33A 5.0SMDJ33CA 5PFM 5BFM 33.0 36.70 40.60 1 53.3 93.90 5 5.0SMDJ36A 5.0SMDJ36CA 5PFP 5BFP 36.0 40.00 44.20 1 58.1 86.10 5 5.0SMDJ40A 5.0SMDJ40CA 5PFR 5BFR 40.0 44.40 49.10 1 64.5 77.60 5 5.0SMDJ43A 5.0SMDJ43CA 5.0SMDJ45A 5.0SMDJ45CA 5PFT 5BFT 5PFV 5BFV 43.0 45.0 47.80 50.00 52.80 55.30 1 1 69.4 72.7 72.10 68.80 5 5 5.0SMDJ48A 5.0SMDJ48CA 5PFX 5BFX 48.0 53.30 58.90 1 77.4 64.70 5 5.0SMDJ51A 5.0SMDJ51CA 5PFZ 5BFZ 51.0 56.70 62.70 1 82.4 60.70 5 5.0SMDJ54A 5.0SMDJ54CA 5PGE 5BGE 54.0 60.00 66.30 1 87.1 57.50 5 5.0SMDJ58A 5.0SMDJ58CA 5PGG 5BGG 58.0 64.40 71.20 1 93.6 53.50 5 5.0SMDJ60A 5.0SMDJ60CA 5PGK 5BGK 60.0 66.70 73.70 1 96.8 51.70 5 5.0SMDJ64A 5.0SMDJ64CA 5PGM 5BGM 64.0 71.10 78.60 1 103.0 48.60 5 5.0SMDJ70A 5.0SMDJ70CA 5PGP 5BGP 70.0 77.80 86.00 1 113.0 44.30 5 5.0SMDJ75A 5.0SMDJ75CA 5PGR 5BGR 75.0 83.00 92.10 1 121.0 41.40 5 5.0SMDJ78A 5.0SMDJ78CA 5PGT 5BGT 78.0 86.00 95.80 1 126.0 39.70 5 5.0SMDJ85A 5.0SMDJ85CA 5PGV 5BGV 85.0 94.00 104.00 1 137.0 36.50 5 5.0SMDJ90A 5.0SMDJ90CA 5PGX 5BGX 90.0 100.00 111.00 1 146.0 34.30 5 5.0SMDJ100A 5.0SMDJ100CA 5PGZ 5BGZ 100.0 111.00 123.00 1 162.0 30.90 5 5.0SMDJ110A 5.0SMDJ110CA 5PHE 5BHE 110.0 122.00 135.00 1 177.0 28.30 5 5.0SMDJ120A 5.0SMDJ120CA 5PHG 5BHG 120.0 133.00 147.00 1 193.0 26.00 5 5.0SMDJ130A 5.0SMDJ130CA 5.0SMDJ150A 5.0SMDJ150CA 5PHK 5BHK 5PHM 5BHM 130.0 150.0 144.00 167.00 159.00 185.00 1 1 209.0 243.0 24.00 20.60 5 5 5.0SMDJ160A 5.0SMDJ160CA 5PHP 5BHP 160.0 178.00 197.00 1 259.0 19.30 5 5.0SMDJ170A 5.0SMDJ170CA 5PHR 5BHR 170.0 189.00 209.00 1 275.0 18.20 5 ※ For Bi-directional type having VRWM of 20 Volts and less, the IR limit is double ※ For parts without A, the VBR is ± 10% and VC is 5% higher than with A parts. www.yfwdiode.com 2/5 Guangdong YFW Electronics Co, Ltd. 5.0SMDJ12A(CA)-5.0SMDJ170A(CA) SMC I-V Curve Characteristics Uni-directional Bi-directional PPPM Peak Pulse Power Dissipation - Max power dissipation VRWM Reverse Stand-off Voltage - Maximum voltage that can be applied to TVS without operation VBR Breakdown Voltage – Maximum voltage that flows though the TVS at a specified current (IT) VC Clamping Voltage – Peak voltage measured across the TVS at a specified IPPM (peak impulse current) IR Reverse Leakage Current – Current measured at VR VF Forward Voltage Drop for Uni-directional www.yfwdiode.com 3/5 Guangdong YFW Electronics Co, Ltd. 5.0SMDJ12A(CA)-5.0SMDJ170A(CA) SMC Ratings and Characteristic Curves (TA=25°C unless otherwise noted) Fig.1 - Peak Pulse Power Rating Fig.2 - Pulse Derating Cure Fig.3 – Pulse Waveform www.yfwdiode.com Fig.4 - Typical Junction Capacitance 4/5 Guangdong YFW Electronics Co, Ltd. 5.0SMDJ12A(CA)-5.0SMDJ170A(CA) SMC DO-214AB SMC Package Outline Plastic surface mounted package; 2 leads E A A1 A C b D L E1 VM A A E D E1 A1 C L b max 2.62 7.0 6.2 8.0 0.21 0.31 1.6 3.25 min 2.00 6.5 5.6 7.6 0.05 0.15 0.9 2.75 max 103 276 244 315 8.3 12 63 128 min 79 256 220 299 2.0 5.9 35 108 UNIT mm mil The recommended mounting pad size 3.8 (150) 4.1 (160) 4.3 (170) 4.1 (160) mm Unit : (mil) Summary of Packing Options Package DO-214AB SMC www.yfwdiode.com Packing Description Packing Quantity Industry Standard Tape/Reel,13”reel 3000 EIA-481-1 5/5 Guangdong YFW Electronics Co, Ltd.
