SMCJ5.0A
SMCJ5.0A
    MSKSEMI(美森科)
    SMC(DO-214AB)
    ESD(静电放电)、TVS(瞬态电压抑制器)、TSS(半导体放电管)、MOV(压敏电阻)、GDT(气体放电管)、PLED(保护发光二极管)
SMCJ5.0A 数据手册
SMCJ5.0(C)A -SMCJ440(C)A Product specification SMCJ5.0(C)A -SMCJ440(C)A Features MECHANICAL DATA 0  15 0 0 W peak pulse power capability at 10 /  Case: SMC  Terminals: Solderable per MIL- STD-7 5 0 , Method 10 0 0 μ s waveform  For surface mounted applications to optimize board space 20 2 6  Approx. Weight : 0 .22g (0 .0077oz)  Glass passivated chip junction  Halogen free and RoHS compliant Reference News PACKAGE OUTLINE PIN CONFIGURATION SMC(DO-214AB) Unipolar SMC(DO-214AB) Bipolar Peak Pulse Power Dissipation on 10/ 1000 us waveform PPPM 1500 W Peak Forward Surge Current ,8 .3ms Single Half Sine-Wave Superimposed on Rated Load (JEDEC Method) ( UNI) IFSM 200 A Power dissipation on Infinite heat sink at TA =50 ℃ PD 6 .5 W Maximum instantaneous forward voltage at 100 A for unidirectional only VF 3 .5 V Peak Pulse Current on 10/ 1000 us waveform I PPM See Next Table A Typical Thermal Resistance Junction to Ambient(Note 1 ) R θJA R θJL Operating Junction Temperature and Storage Temperature Range Tj , Tstg NOTES: 1. Mounted on 8 mm2 (0 . 13mm Copyright© Msksemi Incorporated 75 15 ℃/W -55 ~ +150 ℃ thick) land areas . www.msksemi.com SMCJ5.0(C)A -SMCJ440(C)A Characteristics at Ta = 25℃ SMCJ5 .0CA GDE BDE 5 6 .4 7 10 9 .2 163 800 SMCJ6 .0A SMCJ6 .0CA GDG BDG 6 6 .67 7 .37 10 10 .3 145 .7 800 SMCJ6 .5A SMCJ6 .5CA GDK BDK 6 .5 7 .22 7 .98 10 11 .2 134 500 SMCJ7 .0A SMCJ7 .0CA GDM BDM 7 7 .78 8 .6 10 12 125 200 SMCJ7 .5A SMCJ7 .5CA GDP BDP 7 .5 8 .33 9 .21 1 12 .9 116 .3 100 SMCJ8 .0A SMCJ8 .0CA GDR BDR 8 8 .89 9 .83 1 13 .6 110 .3 50 SMCJ8 .5A SMCJ8 .5CA GDT BDT 8 .5 9 .44 10 .4 1 14 .4 104 .2 20 SMCJ9 .0A SMCJ9 .0CA GDV BDV 9 10 11 . 1 1 15 .4 97 .4 10 SMCJ1 0 A SMCJ10CA GDX BDX 10 11 . 1 12 .3 1 17 88 .3 5 SMCJ11CA GDZ BDZ 11 12 .2 13 .5 1 18 .2 82 .5 1 SMCJ1 2 A SMCJ12CA GEE BEE 12 13 .3 14 .7 1 19 .9 75 .4 1 SMCJ1 3 A SMCJ13CA GEG BEG 13 14 .4 15 .9 1 21 .5 69 .8 1 SMCJ1 4 A SMCJ14CA GEK BEK 14 15 .6 17 .2 1 23 .2 64 .7 1 SMCJ1 5 A SMCJ15CA GEM BEM 15 16 .7 18 .5 1 24 .4 61 .5 1 SMCJ1 6 A SMCJ16CA GEP BEP 16 17 .8 19 .7 1 26 57 .7 1 SMCJ1 7 A SMCJ17CA GER BER 17 18 .9 20 .9 1 27 .6 54 .4 1 SMCJ1 8 A SMCJ18CA GET BET 18 20 22 . 1 1 29 .2 51 .4 1 SMCJ2 0 A SMCJ20CA GEV BEV 20 22 .2 24 .5 1 32 .4 46 .3 1 SMCJ2 2 A SMCJ22CA GEX BEX 22 24 .4 26 .9 1 35 .5 42 .3 1 SMCJ2 4 A SMCJ24CA GEZ BEZ 24 26 .7 29 .5 1 38 .9 38 .6 1 SMCJ2 6 A SMCJ26CA GFE BFE 26 28 .9 31 .9 1 42 . 1 35 .7 1 SMCJ2 8 A SMCJ28CA GFG BFG 28 31 . 1 34 .4 1 45 .4 33 . 1 1 SMCJ3 0 A SMCJ30CA GFK BFK 30 33 .3 36 .8 1 48 .4 31 1 SMCJ3 3 A SMCJ33CA GFM BFM 33 36 .7 40 .6 1 53 .3 28 .2 1 SMCJ3 6 A SMCJ36CA GFP BFP 36 40 44 .2 1 58 . 1 25 .9 1 SMCJ4 0 A SMCJ40CA GFR BFR 40 44 .4 49 . 1 1 64 .5 23 .3 1 SMCJ4 3 A SMCJ43CA GFT BFT 43 47 .8 52 .8 1 69 .4 21 .7 1 SMCJ4 5 A SMCJ45CA GFV BFV 45 50 55 .3 1 72 .7 20 .6 1 SMCJ4 8 A SMCJ48CA GFX BFX 48 53 .3 58 .9 1 77 .4 19 .4 1 SMCJ5 1 A SMCJ51CA GFZ BFZ 51 56 .7 62 .7 1 82 .4 18 .2 1 SMCJ5 4 A SMCJ54CA GGE BGE 54 60 66 .3 1 87 . 1 17 .3 1 SMCJ5 8 A SMCJ58CA GGG BGG 58 64 .4 71 .2 1 93 .6 16 . 1 1 SMCJ6 0 A SMCJ60CA GGK BGK 60 66 .7 73 .7 1 96 .8 15 .5 1 SMCJ6 4 A SMCJ64CA GGM BGM 64 71 . 1 78 .6 1 103 14 .6 1 SMCJ7 0 A SMCJ70CA GGP BGP 70 77 .8 86 1 113 13 .3 1 SMCJ7 5 A SMCJ75CA GGR BGR 75 83 .3 92 . 1 1 121 12 .4 1 SMCJ7 8 A SMCJ78CA GGT BGT 78 86 .7 95 .8 1 126 11 .9 1 SMCJ8 5 A SMCJ85CA GGV BGV 85 94 .4 104 1 137 11 1 BGX SMCJ5 .0A SMCJ1 1 A SMCJ9 0 A SMCJ90CA GGX 90 100 111 1 146 10 .3 1 SMCJ1 0 0 A SMCJ100CA GGZ BGZ 100 111 123 1 162 9 .3 1 SMCJ11 0 A SMCJ110CA GHE BHE 110 122 135 1 177 8 .5 1 SMCJ1 2 0 A SMCJ120CA GHG BHG 120 133 147 1 193 7 .8 1 SMCJ1 3 0 A SMCJ130CA GHK BHK 130 144 159 1 209 7 .2 1 SMCJ1 5 0 A SMCJ150CA GHM BHM 150 167 185 1 243 6 .2 1 SMCJ1 6 0 A SMCJ160CA GHP BHP 160 178 197 1 259 5 .8 1 Copyright© Msksemi Incorporated www.msksemi.com SMCJ5.0(C)A -SMCJ440(C)A SMCJ1 7 0 A SMCJ170CA GHR BHR 170 189 209 1 275 5 .5 1 SMCJ1 8 0 A SMCJ180CA GHT BHT 180 201 222 1 292 5.1 1 SMCJ2 0 0 A SMCJ200CA GHV BHV 200 224 247 1 324 4 .6 1 SMCJ2 2 0 A SMCJ220CA GHX BHX 220 246 272 1 356 4 .2 1 SMCJ2 5 0 A SMCJ250CA GHZ BHZ 250 279 309 1 405 3 .7 1 SMCJ3 0 0 A SMCJ300CA GJE BJE 300 335 371 1 486 3.1 1 SMCJ3 5 0 A SMCJ350CA GJG BJG 350 391 432 1 567 2 .6 1 SMCJ4 0 0 A SMCJ400CA GJK BJK 400 447 494 1 648 2 .3 1 SMCJ4 4 0 A SMCJ440CA GJM BJM 440 492 543 1 713 2.1 1 Copyright© Msksemi Incorporated www.msksemi.com SMCJ5.0(C)A -SMCJ440(C)A Fig.2 Pulse Waveform P PPM,PEAK PULSE FORWARD ,kW Fig.1 Peak Pulse Power Rating Curve 150 100 10 1 0.31x0.31" (8 0 x 80m m) Copper pad A rea T A =25°C t f =10us I ppm ,Peak Pulse Current (%) Non-Repet iv e Pulse.Wavefo m Shown in F ig ure.3 T A=25°C Pulse W idth (td) is Defined as the Poi nt where the Peak. Current Decayst to 50% of Ipp Peak Value 100 80 Half Value-I pp /2 60 10/1000usec Waveform as Defined bye R.E.A. 40 20 td 0 00 0.1 1 10 100 1000 0 10000 3.0 2.0 1.0 t d,PULSE WIDTH ,us 4.0 T,TIME,ms Fig.3 Forward Current Derating Curve Fig.4 Typical Junction Capacitance 100000 Bi-directional V= 0V 100 10000 Cj (pF) PEAK PULSE POWER(P PP)OR CURRENT(I PP) DERATINGIN PERCENTAGE% I ppm 80 60 Uni-directional V=0V 1000 Uni-directional @ V R 100 40 Bi-directional @ V R Tj=25℃ 10 20 f = 1MHz Vsig=mVp-p 1 0 25 50 75 100 125 150 175 T A,AMBIENT TEMPERATURE,°C 1 10 100 1000 V BR - Reverse Breakdown Voltage (V) I FSM,PEAK FORWARD S URGE CURRENT, AMPERES Fig.5 Maximum Non-Repetitive Peak Forward Surge Current 240 200 160 120 80 40 T J=T Jmax 8.3ms Single Half Sinepwave JEDEC Method 0 1 10 100 Number of Cycles at 60Hz Copyright© Msksemi Incorporated www.msksemi.com SMCJ5.0(C)A -SMCJ440(C)A PACKAGE MECHANICAL DATA B Dimensions H F A C Ref. D G E K J L J Millimeters Min. Max. Min. Max. A 5.75 6.25 0.226 0.246 B 6.90 7.40 0.272 0.291 C 2.75 3.25 0.108 0.128 D 0.95 1.52 0.037 0.060 E 7.70 8.20 0.303 0.323 F 0.051 0.203 0.002 0.008 G 0.15 0.31 0.006 0.012 H 2.15 2.62 0.085 0.103 J 2.40 L 0.094 0.165 4.20 K DO-214AB (SMC) Inches 0.130 3.30 REELSPECIFICATION P/N PKG QTY SMCJ5.0(C)A -SMCJ440(C)A SMC 3000 Copyright© Msksemi Incorporated www.msksemi.com SMCJ5.0(C)A -SMCJ440(C)A Attention ■ Any and all MSKSEMI Semiconductor products described or contained herein do not handle applications that require extremely high levels of reliability, such as life-support have specifications that can systems, aircraft's control systems, or other applications whose failure can be reasonably expected to result in serious physical and/or material damage. Consult with your MSKSEMI Semiconductor representative nearest you before using any MSKSEMI Semiconductor products described or contained herein in such applications. ■ MSKSEMI Semiconductor assumes no responsibility for equipment failures that result from using products at values that exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or other parameters) listed in products specificationsof any andall MSKSEMI Semiconductor products described orcontained herein. ■ Specifications of any and all MSKSEMI Semiconductor products described or contained herein stipulate the performance, characteristics, and functions of the described products in the independent state, and are not guarantees of the performance, characteristics, and functions of the described products as mounted in the customer’s products or equipment. To verify symptoms and states that cannot be evaluated in an independent device, the customer should always evaluate and test devices mounted in the customer’sproducts orequipment. ■ MSKSEMI Semiconductor. strives to supply high-quality high-reliability products. However, any and all semiconductor products fail with someprobability. It is possiblethat these probabilistic failures could give rise to accidents or events that could endanger human lives, that could give rise to smoke or fire, or that could cause damage to other property. When designing equipment, adopt safety measures so that these kinds of accidents or events cannot occur. Such measures include but are not limited to protective circuits anderror prevention circuitsfor safedesign, redundant design, and structural design. ■ In the event that any or all MSKSEMI Semiconductor products(including technical data, services) described or contained herein are controlled under any of applicable local export control laws and regulations, such products must not be exported without obtaining the export license from theauthorities concerned in accordance with the above law. ■ No part of this publication may be reproduced or transmitted in any form or by any means, electronic or mechanical, including photocopying and recording, or any information storage or retrieval system, or otherwise, without the prior written permission of MSKSEMI Semiconductor. ■ Information (including circuit diagrams and circuit parameters) herein is for example only ; it is not guaranteed for volume production. MSKSEMI Semiconductor believes information herein is accurate and reliable, but no guarantees are made or implied regarding its use or any infringementsof intellectual property rights or other rightsof third parties. ■ Any and all information described or contained herein are subject to change without notice due to product/technology improvement, etc. Whendesigning equipment, referto the "Delivery Specification" for the MSKSEMI Semiconductor productthat you intend to use. Copyright© Msksemi Incorporated www.msksemi.com
SMCJ5.0A
物料型号:SMCJ5.0(C)A - SMCJ440(C)A
器件简介: - 这些型号属于半导体放电管(Transient Voltage Suppressor, TVS),用于保护电子设备免受电压突波的损害。
引脚分配: - 根据文档中的PACKAGE OUTLINE PIN CONFIGURATION部分,这些器件采用SMC(DO-214AB)封装,具有两个引脚,一个是阳极(Anode),一个是阴极(Cathode)。
参数特性: - 峰值脉冲功率:1500W(10/1000μs波形) - 峰值正向浪涌电流:200A(8.3ms单半正弦波叠加在额定负载上,JEDEC方法) - 无限热沉上的功率耗散:6.5W(TA=50°C) - 最大瞬态正向电压:3.5V(100A时,仅单向) - 典型热阻:75°C/W(结到环境),15°C/W(结到引脚) - 工作和存储结温范围:-55°C至+150°C
功能详解: - 这些器件设计用于表面贴装应用,以优化板空间,具有玻璃钝化芯片结构,无卤素且符合RoHS标准。
应用信息: - 适用于需要高可靠性的电子设备,如电源保护、信号线路保护等。
封装信息: - 封装类型:SMC(DO-214AB) - 封装尺寸:根据机械数据部分,提供了详细的尺寸信息。
SMCJ5.0A 价格&库存
很抱歉,暂时无法提供与“SMCJ5.0A”相匹配的价格&库存,您可以联系我们找货
