5.0SMDJ12A(CA)-5.0SMDJ170A(CA) SMC
Surface Mount Transient Voltage Suppressor Power
5000Watts
Stand-Off Voltage: 12V~170V
Pinning
1.Cathode
2.Anode
FEATURES
Peak power dissipation 5000w @10 x 1000 us Pulse
Low profile package.
Excellent clamping capability.
Typical IR less than 5uA when VBR above 22V.
Glass passivated junction.
Fast response time: typically less than 1.0ps from 0 Volts to
BV min
IEC 61000-4-2 ESD 30KV(Air), 30KV(Contact)
ESD protection of data lines in accordance with IEC 61000-4-2
EFT protection of data lines in accordance with IEC 61000-4-4
Halogen free and ROHS compliant
Lead-free finish
1
2
Unipolar
Bipolar
DO-214AB/SMC
MECHANICAL CHARACTERISTICS
Case: SMC (DO-214AB) Molded Plastic over glass passivated
junction.
Mounting Position: Any
Polarity: by cathode band denotes UNI-directional device, none
cathode band denotes bi-directional device.
Terminal: Solder plated
Maximum Ratings and Characteristics @ 25°C Ambient Temperature (unless otherwise noted)
Parameter
Symbol
Value
Unit
Peak Pulse Power Dissipation on 10/1000 us waveform (Note 1, 2, FIG.1)
PPPM
5000
W
Peak Forward Surge Current, 8.3ms Single Half Sine-Wave (Note 2. 3)
IFSM
300
A
Peak Pulse Current of on 10/1000us Waveform (Note 1, FIG.3)
IPPM
See Next Table
A
Power dissipation on Infinite heat sink at TL=50 °C
PD
6.5
W
TJ,TSTG
-55 to +150
°C
Operating Junction Temperature and Storage Temperature Range
NOTES:
1. Non-repetitive current pulse, per Fig.3 and derated above TA=25°C per Fig.2.
2
2.Mounted on 8.0x8.0mm (0.03mm thick) Copper Pads to each terminal.
3.Measured on 8.3ms single half sine-wave, or equivalent square wave, for Unidirectional device only.
www.yfwdiode.com
1/5
Guangdong YFW Electronics Co, Ltd.
Electrical Specification @ Tamb 25°C
Type Number
(Uni)
(Bi)
Marking
(Uni)
(Bi)
Reverse
StandOff
Voltage
Breakdown
Voltage
Min. @IT
Breakdown
Voltage
Max. @ IT
Test
Current
Maximum
Clamping
Voltage
@IPP
VRMW(V)
VBR MIN(V)
VBR MAX(V)
IT (mA)
VC(V)
IPP(A)
IR(uA)
Peak
Pulse
Current
Reverse
Leakage
@VRMW
5.0SMDJ12A 5.0SMDJ12CA
5.0SMDJ13A 5.0SMDJ13CA
5PEP 5BEP
5PEQ 5BEQ
12.0
13.0
13.30
14.40
14.70
15.90
10
10
19.9
21.5
252.00
233.00
800
500
5.0SMDJ14A 5.0SMDJ14CA
5PER 5BER
14.0
15.60
17.20
10
23.2
216.00
200
5.0SMDJ15A 5.0SMDJ15CA
5PES 5BES
15.0
16.70
18.50
1
24.4
205.00
100
5.0SMDJ16A 5.0SMDJ16CA
5.0SMDJ17A 5.0SMDJ17CA
5PET 5BET
5PEU 5BEU
16.0
17.0
17.80
18.90
20.50
20.90
1
1
26.0
27.6
193.00
181.00
50
5.0SMDJ18A 5.0SMDJ18CA
5PEV 5BEV
18.0
20.00
22.10
1
29.2
172.00
10
5.0SMDJ20A 5.0SMDJ20CA
5PEW 5BEW
20.0
22.20
24.50
1
32.4
155.00
5
5.0SMDJ22A 5.0SMDJ22CA
5.0SMDJ24A 5.0SMDJ24CA
5PEX 5BEX
5PEZ 5BEZ
22.0
24.0
24.40
26.70
26.90
29.50
1
1
35.5
38.9
141.00
129.00
5
5
5.0SMDJ26A 5.0SMDJ26CA
5PFE 5BFE
26.0
28.90
31.90
1
42.1
119.00
5
5.0SMDJ28A 5.0SMDJ28CA
5PFG 5BFG
28.0
31.10
34.40
1
45.4
110.00
5
5.0SMDJ30A 5.0SMDJ30CA
5PFK 5BFK
30.0
33.30
36.80
1
48.4
103.00
5
5.0SMDJ33A 5.0SMDJ33CA
5PFM 5BFM
33.0
36.70
40.60
1
53.3
93.90
5
5.0SMDJ36A 5.0SMDJ36CA
5PFP 5BFP
36.0
40.00
44.20
1
58.1
86.10
5
5.0SMDJ40A 5.0SMDJ40CA
5PFR 5BFR
40.0
44.40
49.10
1
64.5
77.60
5
5.0SMDJ43A 5.0SMDJ43CA
5.0SMDJ45A 5.0SMDJ45CA
5PFT 5BFT
5PFV 5BFV
43.0
45.0
47.80
50.00
52.80
55.30
1
1
69.4
72.7
72.10
68.80
5
5
5.0SMDJ48A 5.0SMDJ48CA
5PFX 5BFX
48.0
53.30
58.90
1
77.4
64.70
5
5.0SMDJ51A 5.0SMDJ51CA
5PFZ
5BFZ
51.0
56.70
62.70
1
82.4
60.70
5
5.0SMDJ54A 5.0SMDJ54CA
5PGE 5BGE
54.0
60.00
66.30
1
87.1
57.50
5
5.0SMDJ58A 5.0SMDJ58CA
5PGG 5BGG
58.0
64.40
71.20
1
93.6
53.50
5
5.0SMDJ60A 5.0SMDJ60CA
5PGK 5BGK
60.0
66.70
73.70
1
96.8
51.70
5
5.0SMDJ64A 5.0SMDJ64CA
5PGM 5BGM
64.0
71.10
78.60
1
103.0
48.60
5
5.0SMDJ70A 5.0SMDJ70CA
5PGP 5BGP
70.0
77.80
86.00
1
113.0
44.30
5
5.0SMDJ75A 5.0SMDJ75CA
5PGR 5BGR
75.0
83.00
92.10
1
121.0
41.40
5
5.0SMDJ78A 5.0SMDJ78CA
5PGT 5BGT
78.0
86.00
95.80
1
126.0
39.70
5
5.0SMDJ85A 5.0SMDJ85CA
5PGV 5BGV
85.0
94.00
104.00
1
137.0
36.50
5
5.0SMDJ90A 5.0SMDJ90CA
5PGX 5BGX
90.0
100.00
111.00
1
146.0
34.30
5
5.0SMDJ100A 5.0SMDJ100CA
5PGZ 5BGZ
100.0
111.00
123.00
1
162.0
30.90
5
5.0SMDJ110A 5.0SMDJ110CA
5PHE 5BHE
110.0
122.00
135.00
1
177.0
28.30
5
5.0SMDJ120A 5.0SMDJ120CA
5PHG 5BHG
120.0
133.00
147.00
1
193.0
26.00
5
5.0SMDJ130A 5.0SMDJ130CA
5.0SMDJ150A 5.0SMDJ150CA
5PHK 5BHK
5PHM 5BHM
130.0
150.0
144.00
167.00
159.00
185.00
1
1
209.0
243.0
24.00
20.60
5
5
5.0SMDJ160A 5.0SMDJ160CA
5PHP 5BHP
160.0
178.00
197.00
1
259.0
19.30
5
5.0SMDJ170A 5.0SMDJ170CA
5PHR 5BHR
170.0
189.00
209.00
1
275.0
18.20
5
※ For Bi-directional type having VRWM of 20 Volts and less, the IR limit is double
※ For parts without A, the VBR is ± 10% and VC is 5% higher than with A parts.
www.yfwdiode.com
2/5
I-V Curve Characteristics
Uni-directional
Bi-directional
PPPM
Peak Pulse Power Dissipation - Max power dissipation
VRWM
Reverse Stand-off Voltage - Maximum voltage that can be applied to TVS without operation
VBR
Breakdown Voltage – Maximum voltage that flows though the TVS at a specified current (IT)
VC
Clamping Voltage – Peak voltage measured across the TVS at a specified IPPM (peak impulse current)
IR
Reverse Leakage Current – Current measured at VR
VF
Forward Voltage Drop for Uni-directional
www.yfwdiode.com
3/5
Ratings and Characteristic Curves (TA=25°C unless otherwise noted)
Fig.1 - Peak Pulse Power Rating
Fig.2 - Pulse Derating Cure
Fig.3 – Pulse Waveform
www.yfwdiode.com
Fig.4 - Typical Junction Capacitance
4/5
DO-214AB SMC
Package Outline
Plastic surface mounted package; 2 leads
E
A
A1
A
C
b
D
L
E1
VM
A
A
E
D
E1
A1
C
L
b
max
2.62
7.0
6.2
8.0
0.21
0.31
1.6
3.25
min
2.00
6.5
5.6
7.6
0.05
0.15
0.9
2.75
max
103
276
244
315
8.3
12
63
128
min
79
256
220
299
2.0
5.9
35
108
UNIT
mm
mil
The recommended mounting pad size
3.8
(150)
4.1
(160)
4.3
(170)
4.1
(160)
mm
Unit :
(mil)
Summary of Packing Options
Package
DO-214AB SMC
www.yfwdiode.com
Packing Description
Packing Quantity
Industry Standard
Tape/Reel,13”reel
3000
EIA-481-1
5/5
很抱歉,暂时无法提供与“5.0SMDJ75CA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+4.81680
- 10+4.02840
- 30+3.68280
- 100+3.26160
- 500+3.07800
- 850+2.95920
