SMDJ90CA
SMDJ90CA
    LIOWN(里阳)
    SMC(DO-214AB)
    表面贴装TVS二极管,适用于保护敏感电子设备免受电压瞬变影响,无卤且符合ROHS标准
SMDJ90CA 数据手册
TVS Diodes Datasheet SMDJ Series Surface Mount – 3000W Description The SMDJ series is designed specifically to protect sensitive electronic equipment from voltage transients induced by lightning and other transient voltage events. For surface mounted applications in order to optimize board space. SMC Additional Information Features Maximum Ratings and Characteristics (TA=25℃) Rating Peak pulse power dissipation at 10/1000μs waveform(Note1, Note2, Fig.1) Symbol 3000W Peak pulse current of at 10/1000 μs waveform (Note 1, Fig.3) IPPM See Table(A) Steady state power dissipation at TA=50℃ (Fig.5) PM(AV) 6.5W Maximum Instantaneous Forward Voltage at 100A for Unidirectional Only VF 3.5V Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load, (JEDEC Method) (Note3, Fig.6) Operating junction and Storage Temperature Ranges Typical thermal resistance junction to lead Typical thermal resistance junction to ambient Halogen free and RoHS compliant  Low profile package  Built-in strain relief design  Low inductance  Excellent clamping capability  3000W peak pulse power capability at 10/1000μs waveform, repetition rate (duty cycle): 0.01% Value PPPM   Fast response time  Typical IR less than 2μA above 10V devices  Peak 260 ℃ high temperature Reflow Soldering withstanding  Meet MSL level1, per J-STD-020  IEC-61000-4-2 ESD 30kV(Air), 30kV (Contact)  Unit Weight: 0.265g Applications TVS components are ideal for the protection of I/O Interfaces, VCC bus and other vulnerable circuits used in IFSM 300A telecom, computer, Industrial and consumer electronic applications. TJ、TSTG -55℃ to +150℃ RθJL 15℃/W RθJA 75℃/W Functional Diagram Notes: 1. Non-repetitive current pulse, per Fig.3 and derating above TA=25℃ per Fig.2. 2. Each terminal is surface Mounted on the 8.0mm×8.0mm copper pads. 3. 8.3ms single half sine-wave or equivalent square wave, duty cycle=4 pulses per minutes maximum. 1 © 2023 Liown Semiconductor Co., Ltd. Specifications are subject to change without notice. Version: V5 TVS Diodes Datasheet SMDJ Series Surface Mount – 3000W Electrical Characteristics (TA=25℃) Part Number Device Reverse Breakdown Marking Stand-Off Voltage Code Voltage @IT Maximum Test Clamping Current Voltage @IPP Peak Reverse Pulse Leakage Current @VR Uni. Bi. Uni. Bi. VR(V) VB MIn.(V) VB Max.(V) IT(mA) VC(V) IPP(A) IR(μA) SMDJ5.0A SMDJ5.0CA RDE DDE 5.0 6.40 7.00 10 9.2 326.1 800 SMDJ6.0A SMDJ6.0CA RDG DDG 6.0 6.67 7.37 10 10.3 291.3 600 SMDJ6.5A SMDJ6.5CA RDK DDK 6.5 7.22 7.98 10 11.2 267.9 300 SMDJ7.0A SMDJ7.0CA PDM DDM 7.0 7.78 8.60 10 12.0 250.0 200 SMDJ7.5A SMDJ7.5CA PDP DDP 7.5 8.33 9.21 1 12.9 232.6 100 SMDJ8.0A SMDJ8.0CA PDR DDR 8.0 8.89 9.83 1 13.6 220.6 50 SMDJ8.5A SMDJ8.5CA PDT DDT 8.5 9.44 10.40 1 14.4 208.3 20 SMDJ9.0A SMDJ9.0CA PDV DDV 9.0 10.00 11.10 1 15.4 194.8 10 SMDJ10A SMDJ10CA PDX DDX 10.0 11.10 12.30 1 17.0 176.5 5 SMDJ11A SMDJ11CA PDZ DDZ 11.0 12.20 13.50 1 18.2 164.8 2 SMDJ12A SMDJ12CA PEE DEE 12.0 13.30 14.70 1 19.9 150.8 2 SMDJ13A SMDJ13CA PEG DEG 13.0 14.40 15.90 1 21.5 139.5 1 SMDJ14A SMDJ14CA PEK DEK 14.0 15.60 17.20 1 23.2 129.3 1 SMDJ15A SMDJ15CA PEM DEM 15.0 16.70 18.50 1 24.4 123.0 1 SMDJ16A SMDJ16CA PEP DEP 16.0 17.80 19.70 1 26.0 115.4 1 SMDJ17A SMDJ17CA PER DER 17.0 18.90 20.90 1 27.6 108.7 1 SMDJ18A SMDJ18CA PET DET 18.0 20.00 22.10 1 29.2 102.7 1 SMDJ20A SMDJ20CA PEV DEV 20.0 22.20 24.50 1 32.4 92.6 1 SMDJ22A SMDJ22CA PEX DEX 22.0 24.40 26.90 1 35.5 84.5 1 SMDJ24A SMDJ24CA PEZ DEZ 24.0 26.70 29.50 1 38.9 77.1 1 SMDJ26A SMDJ26CA PFE DFE 26.0 28.90 31.90 1 42.1 71.3 1 SMDJ28A SMDJ28CA PFG DFG 28.0 31.10 34.40 1 45.4 66.1 1 SMDJ30A SMDJ30CA PFK DFK 30.0 33.30 36.80 1 48.4 62.0 1 SMDJ33A SMDJ33CA PFM DFM 33.0 36.70 40.60 1 53.3 56.3 1 SMDJ36A SMDJ36CA PFP DFP 36.0 40.00 44.20 1 58.1 51.6 1 SMDJ40A SMDJ40CA PFR DFR 40.0 44.40 49.10 1 64.5 46.5 1 SMDJ43A SMDJ43CA PFT DFT 43.0 47.80 52.80 1 69.4 43.2 1 SMDJ45A SMDJ45CA PFV DFV 45.0 50.00 55.30 1 72.7 41.3 1 SMDJ48A SMDJ48CA PFX DFX 48.0 53.30 58.90 1 77.4 38.8 1 2 © 2023 Liown Semiconductor Co., Ltd. Specifications are subject to change without notice. Version: V5 TVS Diodes Datasheet SMDJ Series Surface Mount – 3000W Part Number Device Reverse Breakdown Marking Stand-Off Voltage Code Voltage @IT Maximum Test Clamping Current Voltage @IPP Peak Reverse Pulse Leakage Current @VR Uni. Bi. Uni. Bi. VR(V) VB MIn.(V) VB Max.(V) IT(mA) VC(V) IPP(A) IR(μA) SMDJ51A SMDJ51CA PFZ DFZ 51.0 56.70 62.70 1 82.4 36.4 1 SMDJ54A SMDJ54CA PGE DGE 54.0 60.00 66.30 1 87.1 34.4 1 SMDJ58A SMDJ58CA PGG DGG 58.0 64.40 71.20 1 93.6 32.1 1 SMDJ60A SMDJ60CA PGK DGK 60.0 66.70 73.70 1 96.8 31.0 1 SMDJ64A SMDJ64CA PGM DGM 64.0 71.10 78.60 1 103.0 29.1 1 SMDJ70A SMDJ70CA PGP DGP 70.0 77.80 86.00 1 113.0 26.5 1 SMDJ75A SMDJ75CA PGR DGR 75.0 83.30 92.10 1 121.0 24.8 1 SMDJ78A SMDJ78CA PGT DGT 78.0 86.70 95.80 1 126.0 23.8 1 SMDJ85A SMDJ85CA PGV DGV 85.0 94.40 104.00 1 137.0 21.9 1 SMDJ90A SMDJ90CA PGX DGX 90.0 100.00 111.00 1 146.0 20.5 1 SMDJ100A SMDJ100CA PGZ DGZ 100.0 111.00 123.00 1 162.0 18.5 1 SMDJ110A SMDJ110CA PHE DHE 110.0 122.00 135.00 1 177.0 16.9 1 SMDJ120A SMDJ120CA PHG DHG 120.0 133.00 147.00 1 193.0 15.5 1 SMDJ130A SMDJ130CA PHK DHK 130.0 144.00 159.00 1 209.0 14.4 1 SMDJ150A SMDJ150CA PHM DHM 150.0 167.00 185.00 1 243.0 12.3 2 SMDJ160A SMDJ160CA PHP DHP 160.0 178.00 197.00 1 259.0 11.6 2 SMDJ170A SMDJ170CA PHR DHR 170.0 189.00 209.00 1 275.0 10.9 2 SMDJ180A SMDJ180CA HHT IHT 180.0 201.00 222.00 1 292.0 10.3 2 SMDJ190A SMDJ190CA HHV IHV 190.0 211.00 233.00 1 308.0 9.7 2 SMDJ200A SMDJ200CA HHX IHX 200.0 224.00 247.00 1 324.0 9.3 2 SMDJ210A SMDJ210CA HHZ IHZ 210.0 237.00 263.00 1 340.0 8.8 2 SMDJ220A SMDJ220CA HIE IIE 220.0 246.00 272.00 1 356.0 8.4 2 3 © 2023 Liown Semiconductor Co., Ltd. Specifications are subject to change without notice. Version: V5 TVS Diodes Datasheet SMDJ Series Surface Mount – 3000W Ratings and Characteristic Curves (TA=25℃) Figure 1. Peak Pulse Power Rating Curve Figure 2. Pulse Derating Curve Figure 3. Pulse Waveform Figure 4. Typical Junction Capacitance Figure 5. Steady State Power Dissipation Derating Curve Figure 6. Maximum Non-Repetitive Forward Surge Current Uni-Directional 4 © 2023 Liown Semiconductor Co., Ltd. Specifications are subject to change without notice. Version: V5 TVS Diodes Datasheet SMDJ Series Surface Mount – 3000W Soldering Parameters Reflow Condition Pre Heat -Temperature Min (TS min) 150°C -Temperature Max (TS max) 200°C -Time (min to max) ( tS) 60 – 180 secs Average ramp-up rate (TL to TP) 3°C/second max. TS max to TL-Ramp-up Rate 3°C/second max. Time -Temperature (TL) 217°C -Time (tL) 60-150 seconds maintained above: Peak Temperature (TP) Time within 5°C of actual Peak Temperature (tP) Reflow Soldering Lead–free 260°C 20-40 seconds Ramp-down Rate 6°C/second max. Time 25°C to Peak Temperature 8 minutes max. Dimensions (SMC/DO-214AB) Symbol 5 Millimeters Inches Min. Max. Min. Max. A 2.900 3.200 0.114 0.126 B 6.600 7.110 0.260 0.280 C 5.590 6.220 0.220 0.245 D 2.060 2.620 0.079 0.103 E 0.760 1.520 0.030 0.060 F - 0.203 - 0.008 G 7.750 8.130 0.305 0.320 H 0.152 0.305 0.006 0.012 T 2.200 2.750 0.087 0.108 I 3.300 - 0.129 - J 2.400 - 0.094 - K - 4.200 - 0.165 © 2023 Liown Semiconductor Co., Ltd. Specifications are subject to change without notice. Version: V5 TVS Diodes Datasheet SMDJ Series Surface Mount – 3000W Part Number Code and Marking Code Packaging Specification 13 Inches Reel Tape For Uni-Devices Quantity:3000pcs/reel 6 © 2023 Liown Semiconductor Co., Ltd. Specifications are subject to change without notice. Version: V5
SMDJ90CA 价格&库存
很抱歉,暂时无法提供与“SMDJ90CA”相匹配的价格&库存,您可以联系我们找货
